example
longer
example
here
Nextcloud version :16.0.1
Operating system and version: Ubuntu server 18.04
Apache or nginx version: 2.4.29
PHP version: 7.2
I have two identical virtual systems. One with nextcloud installed and the other one is an apache reverse proxy. On the nextcloud system under Settings->Overview->Security & setup warnings there are no problems. But when I access it through the apache reverse proxy then it tells me:
“Your web server is not properly set up to resolve “/.well-known/caldav”. Further information can be found in the [documentation]
Your web server is not properly set up to resolve “/.well-known/carddav”. Further information can be found in the [documentation]”
Reverse proxy config:
# Redirect 301 /.well-known/carddav http://192.168.178.13/cloud/remote.php/dav
# Redirect 301 /.well-known/caldav http://192.168.178.13/cloud/remote.php/dav
# <Location /.well-known/carddav>
# ProxyPass http://192.168.178.13/cloud/remote.php/dav
# ProxyPassReverse http://192.168.178.13/cloud/remote.php/dav
# </Location>
<Location /cloud>
# RewriteEngine On
# RewriteRule ^/\.well-known/carddav https://%{192.168.178.13}/remote.php/dav/ [R=301,L]
# RewriteRule ^/\.well-known/caldav https://%{192.168.178.13}/remote.php/dav/ [R=301,L]
Redirect 301 /.well-known/carddav /remote.php/dav
Redirect 301 /.well-known/caldav /remote.php/dav
# ProxyPassReverseCookiePath /cloud /cloud
</Location>
Everything except the webdav part works. I tried redirecting it inside the location. I tried it outside the location. I tried it with own locations. Nothing worked
I am relativly new to apache and a bit lost…
I did not find anything about running nextcloud behind a proxy in the documentation and google didn’t help me either.
- Install Nextcloud on one system
- Install a reverse proxy on a second system
- Access the nextcloud instance through the proxy
No entries for the last 3 days. Problem occured after last entry.
'instanceid' => '',
'passwordsalt' => '',
'secret' => '',
0 => '192.168.178.13',
1 => '192.168.178.14',
'trusted_proxies' => ['192.168.178.14'],
'datadirectory' => '/var/www/html/cloud/data',
'dbtype' => 'pgsql',
'version' => '16.0.1.1',
'overwrite.cli.url' => 'http://192.168.178.13/cloud',
'dbname' => 'nextcloud',
'dbhost' => 'localhost',
'dbuser' => 'nextclouduser',
'dbpassword' => 'nextcloud',
'memcache.local' => '\OC\Memcache\APCu',
'overwritehost' => '192.168.178.13',
I am thankful for any help.
