Would it be a good idea to run NC in Docker and MariaDB in Docker on 2 separate hosts? I mean, it would add CPU power but obviously there will be network traffic overhead.
Any views?
imo not for personal use unless your using limited hardware.
unless the two are gigabit connected you will lose speed
I think any benefits would probably be washed out with overhead/complexity for a small instance.
