Nextcloud and HiDrive as external storage
I’m trying to use Strato HiDrive as an external webdave storage.
I tried it with these paths but it’s not working.
Any ideas or is this a general problem with NC?
Greetz
It seems like webdav is part of an additional protocol package that need to be seperatly bought. Do you have ordered that additional package for hidrive?
Can you access the hidrive from your local computer via webdav?
Is there anything in log you can provide?
I’m sorry, you are right. They changed this.
Problem solved… :sob:
Do you have a link for it? In the Hidrive FAQs I still find that webdav also SSL enabled is still available.
When I follow the instructions I get the green circle but the sync is kind of broken.
