Hello everyone, I configure nextcloud and collabora via docker.
I use nginx reverse proxy to let nextcloud access via HTTPS. So, I want to know, is I configuring https for Nextcloud now? When I set up the collcbora connection, he will appear "Saved with error: Collabora Online should use the same protocol as the server installation.
I have enabled an HTTPS connection to collabora and can log in to the console.
Do you have a reverse proxy in front of nextcloud and collabora? Using a reverse proxy is the preferred way to configure nextcloud docker for https (a guide is available on the docker project page of nextcloud). Without a reverse proxy, as far as I know, you have to change the configuration of the inbuild ngnix server of nextcloud. I have never done this.
