Nextcloud AIO wont start, 100% packet loss
Nextcloud AIO v5.1.0
Operating system Kubuntu 22.04
nginx version v2.9.20
The issue you are facing: Can’t start apache & nextcloud containers all of a sudden, so when i restart pc nextcloud/aio-nextcloud:latest says it is unhealty, and after some time it gets healthy somehow and then apache gets unhealthy
The output of nextcloud/aio-nextcloud:latest “/start.sh /usr/bin/…” 14 hours ago Up 2 minutes (unhealthy):
Added mimetype "application/vnd.xmind.workbook" to database
Added mimetype "application/yaml" to database
Added 117 new mimetypes
Updated 0 filecache rows
Waiting for database to start...
              now
 2023-05-12 22:47:32.365053+02
(1 row)
+ '[' -n '' ']'
+ set +x
Configuring Redis as session handler...
Setting php max children...
System config value tempdirectory set to string /mnt/ncdata/tmp/
Applying one-click-instance settings...
System config value one-click-instance set to boolean true
System config value one-click-instance.user-limit set to integer 100
System config value one-click-instance.link set to string https://nextcloud.com/all-in-one/
support already enabled
Adjusting log files...
System config value logfile set to string /var/www/html/data/nextcloud.log
Config value logfile for app admin_audit set to /var/www/html/data/audit.log
System config value updatedirectory set to string /nc-updater
Applying network settings...
System config value trusted_domains => 1 set to string atizd.duckdns.org
System config value overwrite.cli.url set to string https://atizd.duckdns.org/
System config value htaccess.RewriteBase set to string /
.htaccess has been updated
System config value files_external_allow_create_new_local set to boolean false
System config value trusted_proxies => 0 set to string 127.0.0.1
System config value trusted_proxies => 1 set to string ::1
Config value base_endpoint for app notify_push set to https://atizd.duckdns.org/push
Config value wopi_url for app richdocuments set to https://atizd.duckdns.org/
System config value allow_local_remote_servers set to boolean true
No ipv6-address found for atizd.duckdns.org.
Config value wopi_allowlist for app richdocuments set to 78.2.176.148,127.0.0.1/8,192.168.0.0/16,172.16.0.0/12,10.0.0.0/8,fd00::/8,::1,109.60.102.198,109.60.100.66,213.149.61.33
Added atizd.duckdns.org:3478.
There is nothing to delete.
System config value enabledPreviewProviders => 0 set to string OC\Preview\Imaginary
System config value preview_imaginary_url set to string http://nextcloud-aio-imaginary:9000
[12-May-2023 23:04:52] NOTICE: fpm is running, pid 607
[12-May-2023 23:04:52] NOTICE: ready to handle connections
[2023-05-12 23:07:03.751252 +02:00] ERROR [notify_push] src/main.rs:77: Self test failed: Error while communicating with nextcloud instance
              now
 2023-05-13 11:33:59.566152+02
(1 row)
+ '[' -n '' ']'
+ set +x
[13-May-2023 11:50:19] NOTICE: fpm is running, pid 574
[13-May-2023 11:50:19] NOTICE: ready to handle connections
[2023-05-13 11:52:30.354982 +02:00] ERROR [notify_push] src/main.rs:77: Self test failed: Error while communicating with nextcloud instance
The output of apache
Waiting for Nextcloud to start...
{"level":"info","ts":1683925497.413171,"msg":"using provided configuration","config_file":"/Caddyfile","config_adapter":""}
[Fri May 12 23:04:57.435209 2023] [mpm_event:notice] [pid 684:tid 139999022517064] AH00489: Apache/2.4.57 (Unix) configured -- resuming normal operations
[Fri May 12 23:04:57.435528 2023] [core:notice] [pid 684:tid 139999022517064] AH00094: Command line: '/usr/local/apache2/bin/httpd -D FOREGROUND'
[Sat May 13 11:31:38.301903 2023] [mpm_event:notice] [pid 21:tid 139961167887176] AH00489: Apache/2.4.57 (Unix) configured -- resuming normal operations
[Sat May 13 11:31:38.302421 2023] [core:notice] [pid 21:tid 139961167887176] AH00094: Command line: '/usr/local/apache2/bin/httpd -D FOREGROUND'
{"level":"info","ts":1683970298.3228323,"msg":"using provided configuration","config_file":"/Caddyfile","config_adapter":""}
How do i fix this, it have been running perfectly fine, i was syncing my folder from my pc and suddenly it stopped connecting
i am able to connect to localhost:8080/containers where i can see containers that are running but can not connect to localhost:11000 where i upload my files to nextcloud
also when i try to ping my web adress, it says it has 100% packet loss
Hi, it looks like your database is not started? Can you check its logs?
this are database logs from nextcloud aio site localhost:8080 where i can see all containers running
Setting max connections...
PostgreSQL Database directory appears to contain a database; Skipping initialization
2023-05-12 22:36:01.849 CEST [13] LOG:  starting PostgreSQL 15.2 on x86_64-pc-linux-musl, compiled by gcc (Alpine 12.2.1_git20220924-r4) 12.2.1 20220924, 64-bit
2023-05-12 22:36:01.849 CEST [13] LOG:  listening on IPv4 address "0.0.0.0", port 5432
2023-05-12 22:36:01.849 CEST [13] LOG:  listening on IPv6 address "::", port 5432
2023-05-12 22:36:01.854 CEST [13] LOG:  listening on Unix socket "/var/run/postgresql/.s.PGSQL.5432"
2023-05-12 22:36:01.862 CEST [23] LOG:  database system was shut down at 2023-05-12 22:30:06 CEST
2023-05-12 22:36:01.868 CEST [13] LOG:  database system is ready to accept connections
2023-05-12 22:41:01.961 CEST [21] LOG:  checkpoint starting: time
2023-05-12 22:41:09.695 CEST [21] LOG:  checkpoint complete: wrote 80 buffers (0.5%); 0 WAL file(s) added, 0 removed, 0 recycled; write=7.719 s, sync=0.006 s, total=7.735 s; sync files=33, longest=0.003 s, average=0.001 s; distance=276 kB, estimate=276 kB
2023-05-12 22:46:01.795 CEST [21] LOG:  checkpoint starting: time
2023-05-12 22:46:07.726 CEST [21] LOG:  checkpoint complete: wrote 60 buffers (0.4%); 0 WAL file(s) added, 0 removed, 0 recycled; write=5.914 s, sync=0.008 s, total=5.932 s; sync files=39, longest=0.003 s, average=0.001 s; distance=981 kB, estimate=981 kB
2023-05-12 22:47:25.224 CEST [12] LOG:  starting PostgreSQL 15.2 on x86_64-pc-linux-musl, compiled by gcc (Alpine 12.2.1_git20220924-r4) 12.2.1 20220924, 64-bit
2023-05-12 22:47:25.224 CEST [12] LOG:  listening on IPv4 address "0.0.0.0", port 5432
2023-05-12 22:47:25.224 CEST [12] LOG:  listening on IPv6 address "::", port 5432
2023-05-12 22:47:25.255 CEST [12] LOG:  listening on Unix socket "/var/run/postgresql/.s.PGSQL.5432"
2023-05-12 22:47:25.273 CEST [22] LOG:  database system was interrupted; last known up at 2023-05-12 22:46:07 CEST
2023-05-12 22:47:26.039 CEST [22] LOG:  database system was not properly shut down; automatic recovery in progress
2023-05-12 22:47:26.047 CEST [22] LOG:  redo starts at 1/15E5E948
2023-05-12 22:47:26.053 CEST [22] LOG:  invalid record length at 1/15E66B98: wanted 24, got 0
2023-05-12 22:47:26.053 CEST [22] LOG:  redo done at 1/15E66B60 system usage: CPU: user: 0.00 s, system: 0.00 s, elapsed: 0.00 s
2023-05-12 22:47:26.077 CEST [20] LOG:  checkpoint starting: end-of-recovery immediate wait
2023-05-12 22:47:26.142 CEST [20] LOG:  checkpoint complete: wrote 10 buffers (0.1%); 0 WAL file(s) added, 0 removed, 0 recycled; write=0.021 s, sync=0.012 s, total=0.076 s; sync files=9, longest=0.005 s, average=0.002 s; distance=32 kB, estimate=32 kB
2023-05-12 22:47:26.169 CEST [12] LOG:  database system is ready to accept connections
2023-05-12 23:07:26.542 CEST [20] LOG:  checkpoint starting: time
2023-05-12 23:07:34.005 CEST [20] LOG:  checkpoint complete: wrote 75 buffers (0.5%); 0 WAL file(s) added, 0 removed, 0 recycled; write=7.448 s, sync=0.005 s, total=7.464 s; sync files=39, longest=0.002 s, average=0.001 s; distance=325 kB, estimate=325 kB
2023-05-12 23:12:26.105 CEST [20] LOG:  checkpoint starting: time
2023-05-12 23:12:30.961 CEST [20] LOG:  checkpoint complete: wrote 49 buffers (0.3%); 0 WAL file(s) added, 0 removed, 0 recycled; write=4.832 s, sync=0.006 s, total=4.857 s; sync files=23, longest=0.003 s, average=0.001 s; distance=249 kB, estimate=318 kB
2023-05-12 23:17:27.062 CEST [20] LOG:  checkpoint starting: time
2023-05-12 23:17:30.705 CEST [20] LOG:  checkpoint complete: wrote 37 buffers (0.2%); 0 WAL file(s) added, 0 removed, 0 recycled; write=3.612 s, sync=0.014 s, total=3.644 s; sync files=13, longest=0.010 s, average=0.002 s; distance=145 kB, estimate=300 kB
2023-05-12 23:22:27.788 CEST [20] LOG:  checkpoint starting: time
2023-05-12 23:22:31.343 CEST [20] LOG:  checkpoint complete: wrote 37 buffers (0.2%); 0 WAL file(s) added, 0 removed, 0 recycled; write=3.522 s, sync=0.014 s, total=3.555 s; sync files=12, longest=0.010 s, average=0.002 s; distance=149 kB, estimate=285 kB
2023-05-12 23:27:27.443 CEST [20] LOG:  checkpoint starting: time
2023-05-12 23:27:30.886 CEST [20] LOG:  checkpoint complete: wrote 35 buffers (0.2%); 0 WAL file(s) added, 0 removed, 0 recycled; write=3.420 s, sync=0.005 s, total=3.444 s; sync files=11, longest=0.003 s, average=0.001 s; distance=129 kB, estimate=270 kB
2023-05-12 23:32:27.981 CEST [20] LOG:  checkpoint starting: time
2023-05-12 23:32:31.434 CEST [20] LOG:  checkpoint complete: wrote 35 buffers (0.2%); 0 WAL file(s) added, 0 removed, 0 recycled; write=3.420 s, sync=0.014 s, total=3.453 s; sync files=11, longest=0.010 s, average=0.002 s; distance=149 kB, estimate=257 kB
2023-05-12 23:37:27.532 CEST [20] LOG:  checkpoint starting: time
2023-05-12 23:37:30.977 CEST [20] LOG:  checkpoint complete: wrote 35 buffers (0.2%); 0 WAL file(s) added, 0 removed, 0 recycled; write=3.420 s, sync=0.006 s, total=3.445 s; sync files=11, longest=0.003 s, average=0.001 s; distance=142 kB, estimate=246 kB
2023-05-12 23:42:28.075 CEST [20] LOG:  checkpoint starting: time
2023-05-12 23:42:31.520 CEST [20] LOG:  checkpoint complete: wrote 35 buffers (0.2%); 0 WAL file(s) added, 0 removed, 0 recycled; write=3.421 s, sync=0.005 s, total=3.445 s; sync files=11, longest=0.003 s, average=0.001 s; distance=149 kB, estimate=236 kB
2023-05-12 23:47:28.620 CEST [20] LOG:  checkpoint starting: time
2023-05-12 23:47:32.063 CEST [20] LOG:  checkpoint complete: wrote 35 buffers (0.2%); 0 WAL file(s) added, 0 removed, 0 recycled; write=3.420 s, sync=0.014 s, total=3.444 s; sync files=11, longest=0.012 s, average=0.002 s; distance=137 kB, estimate=226 kB
2023-05-12 23:52:28.163 CEST [20] LOG:  checkpoint starting: time
2023-05-12 23:52:31.617 CEST [20] LOG:  checkpoint complete: wrote 35 buffers (0.2%); 0 WAL file(s) added, 0 removed, 1 recycled; write=3.420 s, sync=0.013 s, total=3.454 s; sync files=11, longest=0.011 s, average=0.002 s; distance=158 kB, estimate=219 kB
2023-05-12 23:57:28.716 CEST [20] LOG:  checkpoint starting: time
2023-05-12 23:57:32.171 CEST [20] LOG:  checkpoint complete: wrote 35 buffers (0.2%); 0 WAL file(s) added, 0 removed, 0 recycled; write=3.420 s, sync=0.013 s, total=3.456 s; sync files=11, longest=0.011 s, average=0.002 s; distance=147 kB, estimate=212 kB
2023-05-13 00:02:28.268 CEST [20] LOG:  checkpoint starting: time
2023-05-13 00:02:31.721 CEST [20] LOG:  checkpoint complete: wrote 35 buffers (0.2%); 0 WAL file(s) added, 0 removed, 0 recycled; write=3.421 s, sync=0.013 s, total=3.453 s; sync files=11, longest=0.012 s, average=0.002 s; distance=147 kB, estimate=206 kB
2023-05-13 00:07:28.820 CEST [20] LOG:  checkpoint starting: time
2023-05-13 00:07:32.270 CEST [20] LOG:  checkpoint complete: wrote 35 buffers (0.2%); 0 WAL file(s) added, 0 removed, 0 recycled; write=3.420 s, sync=0.013 s, total=3.451 s; sync files=11, longest=0.012 s, average=0.002 s; distance=132 kB, estimate=198 kB
2023-05-13 00:12:28.368 CEST [20] LOG:  checkpoint starting: time
2023-05-13 00:12:31.921 CEST [20] LOG:  checkpoint complete: wrote 36 buffers (0.2%); 0 WAL file(s) added, 0 removed, 0 recycled; write=3.521 s, sync=0.013 s, total=3.553 s; sync files=12, longest=0.012 s, average=0.002 s; distance=154 kB, estimate=194 kB
2023-05-13 00:17:29.018 CEST [20] LOG:  checkpoint starting: time
2023-05-13 00:17:32.474 CEST [20] LOG:  checkpoint complete: wrote 35 buffers (0.2%); 0 WAL file(s) added, 0 removed, 0 recycled; write=3.420 s, sync=0.013 s, total=3.457 s; sync files=11, longest=0.011 s, average=0.002 s; distance=136 kB, estimate=188 kB
2023-05-13 00:22:29.574 CEST [20] LOG:  checkpoint starting: time
2023-05-13 00:22:33.027 CEST [20] LOG:  checkpoint complete: wrote 35 buffers (0.2%); 0 WAL file(s) added, 0 removed, 0 recycled; write=3.420 s, sync=0.013 s, total=3.453 s; sync files=11, longest=0.012 s, average=0.002 s; distance=146 kB, estimate=184 kB
2023-05-13 00:27:29.126 CEST [20] LOG:  checkpoint starting: time
2023-05-13 00:27:32.670 CEST [20] LOG:  checkpoint complete: wrote 36 buffers (0.2%); 0 WAL file(s) added, 0 removed, 0 recycled; write=3.521 s, sync=0.013 s, total=3.544 s; sync files=12, longest=0.011 s, average=0.002 s; distance=144 kB, estimate=180 kB
2023-05-13 00:32:29.766 CEST [20] LOG:  checkpoint starting: time
2023-05-13 00:32:33.219 CEST [20] LOG:  checkpoint complete: wrote 36 buffers (0.2%); 0 WAL file(s) added, 0 removed, 0 recycled; write=3.422 s, sync=0.013 s, total=3.454 s; sync files=11, longest=0.011 s, average=0.002 s; distance=155 kB, estimate=177 kB
2023-05-13 00:37:29.318 CEST [20] LOG:  checkpoint starting: time
2023-05-13 00:37:32.770 CEST [20] LOG:  checkpoint complete: wrote 35 buffers (0.2%); 0 WAL file(s) added, 0 removed, 0 recycled; write=3.420 s, sync=0.013 s, total=3.452 s; sync files=11, longest=0.011 s, average=0.002 s; distance=142 kB, estimate=174 kB
2023-05-13 00:42:29.869 CEST [20] LOG:  checkpoint starting: time
2023-05-13 00:42:33.320 CEST [20] LOG:  checkpoint complete: wrote 35 buffers (0.2%); 0 WAL file(s) added, 0 removed, 0 recycled; write=3.420 s, sync=0.013 s, total=3.452 s; sync files=11, longest=0.011 s, average=0.002 s; distance=147 kB, estimate=171 kB
2023-05-13 00:47:29.377 CEST [20] LOG:  checkpoint starting: time
2023-05-13 00:47:32.829 CEST [20] LOG:  checkpoint complete: wrote 35 buffers (0.2%); 0 WAL file(s) added, 0 removed, 0 recycled; write=3.420 s, sync=0.013 s, total=3.453 s; sync files=11, longest=0.011 s, average=0.002 s; distance=135 kB, estimate=168 kB
2023-05-13 00:52:29.928 CEST [20] LOG:  checkpoint starting: time
2023-05-13 00:52:33.380 CEST [20] LOG:  checkpoint complete: wrote 35 buffers (0.2%); 0 WAL file(s) added, 0 removed, 0 recycled; write=3.421 s, sync=0.013 s, total=3.452 s; sync files=11, longest=0.011 s, average=0.002 s; distance=154 kB, estimate=166 kB
2023-05-13 00:57:29.478 CEST [20] LOG:  checkpoint starting: time
2023-05-13 00:57:32.921 CEST [20] LOG:  checkpoint complete: wrote 35 buffers (0.2%); 0 WAL file(s) added, 0 removed, 0 recycled; write=3.420 s, sync=0.013 s, total=3.443 s; sync files=11, longest=0.012 s, average=0.002 s; distance=146 kB, estimate=164 kB
2023-05-13 01:02:30.018 CEST [20] LOG:  checkpoint starting: time
2023-05-13 01:02:33.470 CEST [20] LOG:  checkpoint complete: wrote 35 buffers (0.2%); 0 WAL file(s) added, 0 removed, 0 recycled; write=3.421 s, sync=0.012 s, total=3.452 s; sync files=11, longest=0.011 s, average=0.002 s; distance=158 kB, estimate=164 kB
2023-05-13 01:07:30.570 CEST [20] LOG:  checkpoint starting: time
2023-05-13 01:07:34.022 CEST [20] LOG:  checkpoint complete: wrote 35 buffers (0.2%); 0 WAL file(s) added, 0 removed, 0 recycled; write=3.420 s, sync=0.013 s, total=3.452 s; sync files=11, longest=0.011 s, average=0.002 s; distance=142 kB, estimate=161 kB
2023-05-13 01:12:30.119 CEST [20] LOG:  checkpoint starting: time
2023-05-13 01:12:33.665 CEST [20] LOG:  checkpoint complete: wrote 36 buffers (0.2%); 0 WAL file(s) added, 0 removed, 0 recycled; write=3.521 s, sync=0.013 s, total=3.546 s; sync files=12, longest=0.012 s, average=0.002 s; distance=169 kB, estimate=169 kB
2023-05-13 01:17:30.763 CEST [20] LOG:  checkpoint starting: time
2023-05-13 01:17:34.107 CEST [20] LOG:  checkpoint complete: wrote 34 buffers (0.2%); 0 WAL file(s) added, 0 removed, 0 recycled; write=3.320 s, sync=0.005 s, total=3.344 s; sync files=10, longest=0.003 s, average=0.001 s; distance=155 kB, estimate=168 kB
2023-05-13 01:22:30.204 CEST [20] LOG:  checkpoint starting: time
2023-05-13 01:22:33.747 CEST [20] LOG:  checkpoint complete: wrote 36 buffers (0.2%); 0 WAL file(s) added, 0 removed, 0 recycled; write=3.521 s, sync=0.013 s, total=3.544 s; sync files=12, longest=0.011 s, average=0.002 s; distance=151 kB, estimate=166 kB
2023-05-13 01:27:30.835 CEST [20] LOG:  checkpoint starting: time
2023-05-13 01:27:34.286 CEST [20] LOG:  checkpoint complete: wrote 35 buffers (0.2%); 0 WAL file(s) added, 0 removed, 0 recycled; write=3.420 s, sync=0.013 s, total=3.452 s; sync files=11, longest=0.011 s, average=0.002 s; distance=126 kB, estimate=162 kB
2023-05-13 01:32:30.386 CEST [20] LOG:  checkpoint starting: time
2023-05-13 01:32:34.131 CEST [20] LOG:  checkpoint complete: wrote 38 buffers (0.2%); 0 WAL file(s) added, 0 removed, 0 recycled; write=3.721 s, sync=0.014 s, total=3.745 s; sync files=12, longest=0.012 s, average=0.002 s; distance=145 kB, estimate=160 kB
2023-05-13 01:37:30.216 CEST [20] LOG:  checkpoint starting: time
2023-05-13 01:37:33.672 CEST [20] LOG:  checkpoint complete: wrote 37 buffers (0.2%); 0 WAL file(s) added, 0 removed, 0 recycled; write=3.423 s, sync=0.014 s, total=3.457 s; sync files=11, longest=0.011 s, average=0.002 s; distance=140 kB, estimate=158 kB
2023-05-13 01:42:30.747 CEST [20] LOG:  checkpoint starting: time
2023-05-13 01:42:34.199 CEST [20] LOG:  checkpoint complete: wrote 35 buffers (0.2%); 0 WAL file(s) added, 0 removed, 0 recycled; write=3.420 s, sync=0.013 s, total=3.453 s; sync files=11, longest=0.011 s, average=0.002 s; distance=148 kB, estimate=157 kB
2023-05-13 01:47:30.298 CEST [20] LOG:  checkpoint starting: time
2023-05-13 01:47:33.750 CEST [20] LOG:  checkpoint complete: wrote 35 buffers (0.2%); 0 WAL file(s) added, 0 removed, 0 recycled; write=3.421 s, sync=0.012 s, total=3.452 s; sync files=11, longest=0.011 s, average=0.002 s; distance=130 kB, estimate=155 kB
2023-05-13 01:52:30.849 CEST [20] LOG:  checkpoint starting: time
2023-05-13 01:52:34.301 CEST [20] LOG:  checkpoint complete: wrote 35 buffers (0.2%); 0 WAL file(s) added, 0 removed, 0 recycled; write=3.421 s, sync=0.013 s, total=3.452 s; sync files=11, longest=0.011 s, average=0.002 s; distance=146 kB, estimate=154 kB
2023-05-13 01:57:30.401 CEST [20] LOG:  checkpoint starting: time
2023-05-13 01:57:33.825 CEST [20] LOG:  checkpoint complete: wrote 35 buffers (0.2%); 0 WAL file(s) added, 0 removed, 0 recycled; write=3.411 s, sync=0.004 s, total=3.425 s; sync files=11, longest=0.003 s, average=0.001 s; distance=139 kB, estimate=152 kB
2023-05-13 02:02:30.922 CEST [20] LOG:  checkpoint starting: time
2023-05-13 02:02:34.366 CEST [20] LOG:  checkpoint complete: wrote 35 buffers (0.2%); 0 WAL file(s) added, 0 removed, 0 recycled; write=3.420 s, sync=0.013 s, total=3.444 s; sync files=11, longest=0.012 s, average=0.002 s; distance=141 kB, estimate=151 kB
2023-05-13 02:07:30.466 CEST [20] LOG:  checkpoint starting: time
2023-05-13 02:07:33.919 CEST [20] LOG:  checkpoint complete: wrote 35 buffers (0.2%); 0 WAL file(s) added, 0 removed, 0 recycled; write=3.421 s, sync=0.013 s, total=3.453 s; sync files=11, longest=0.011 s, average=0.002 s; distance=132 kB, estimate=149 kB
2023-05-13 02:12:31.014 CEST [20] LOG:  checkpoint starting: time
2023-05-13 02:12:34.457 CEST [20] LOG:  checkpoint complete: wrote 35 buffers (0.2%); 0 WAL file(s) added, 0 removed, 0 recycled; write=3.420 s, sync=0.013 s, total=3.443 s; sync files=11, longest=0.012 s, average=0.002 s; distance=150 kB, estimate=150 kB
2023-05-13 02:17:31.554 CEST [20] LOG:  checkpoint starting: time
2023-05-13 02:17:35.006 CEST [20] LOG:  checkpoint complete: wrote 35 buffers (0.2%); 0 WAL file(s) added, 0 removed, 0 recycled; write=3.420 s, sync=0.013 s, total=3.452 s; sync files=11, longest=0.011 s, average=0.002 s; distance=145 kB, estimate=149 kB
2023-05-13 02:22:31.104 CEST [20] LOG:  checkpoint starting: time
2023-05-13 02:22:34.440 CEST [20] LOG:  checkpoint complete: wrote 34 buffers (0.2%); 0 WAL file(s) added, 0 removed, 0 recycled; write=3.320 s, sync=0.006 s, total=3.336 s; sync files=10, longest=0.003 s, average=0.001 s; distance=151 kB, estimate=151 kB
2023-05-13 02:27:31.539 CEST [20] LOG:  checkpoint starting: time
2023-05-13 02:27:34.990 CEST [20] LOG:  checkpoint complete: wrote 35 buffers (0.2%); 0 WAL file(s) added, 0 removed, 0 recycled; write=3.419 s, sync=0.014 s, total=3.452 s; sync files=11, longest=0.010 s, average=0.002 s; distance=133 kB, estimate=149 kB
2023-05-13 02:32:32.073 CEST [20] LOG:  checkpoint starting: time
2023-05-13 02:32:35.518 CEST [20] LOG:  checkpoint complete: wrote 35 buffers (0.2%); 0 WAL file(s) added, 0 removed, 0 recycled; write=3.420 s, sync=0.015 s, total=3.445 s; sync files=11, longest=0.010 s, average=0.002 s; distance=157 kB, estimate=157 kB
2023-05-13 02:37:32.618 CEST [20] LOG:  checkpoint starting: time
2023-05-13 02:37:36.071 CEST [20] LOG:  checkpoint complete: wrote 35 buffers (0.2%); 0 WAL file(s) added, 0 removed, 0 recycled; write=3.420 s, sync=0.014 s, total=3.453 s; sync files=11, longest=0.010 s, average=0.002 s; distance=142 kB, estimate=156 kB
2023-05-13 02:42:32.162 CEST [20] LOG:  checkpoint starting: time
2023-05-13 02:42:35.615 CEST [20] LOG:  checkpoint complete: wrote 35 buffers (0.2%); 0 WAL file(s) added, 0 removed, 0 recycled; write=3.420 s, sync=0.014 s, total=3.454 s; sync files=11, longest=0.010 s, average=0.002 s; distance=148 kB, estimate=155 kB
2023-05-13 02:47:32.715 CEST [20] LOG:  checkpoint starting: time
2023-05-13 02:47:36.168 CEST [20] LOG:  checkpoint complete: wrote 36 buffers (0.2%); 0 WAL file(s) added, 0 removed, 0 recycled; write=3.421 s, sync=0.014 s, total=3.453 s; sync files=11, longest=0.010 s, average=0.002 s; distance=133 kB, estimate=153 kB
2023-05-13 02:52:32.268 CEST [20] LOG:  checkpoint starting: time
2023-05-13 02:52:35.720 CEST [20] LOG:  checkpoint complete: wrote 35 buffers (0.2%); 0 WAL file(s) added, 0 removed, 0 recycled; write=3.420 s, sync=0.014 s, total=3.453 s; sync files=11, longest=0.010 s, average=0.002 s; distance=153 kB, estimate=153 kB
2023-05-13 02:57:32.819 CEST [20] LOG:  checkpoint starting: time
2023-05-13 02:57:36.272 CEST [20] LOG:  checkpoint complete: wrote 35 buffers (0.2%); 0 WAL file(s) added, 0 removed, 0 recycled; write=3.420 s, sync=0.014 s, total=3.454 s; sync files=11, longest=0.011 s, average=0.002 s; distance=141 kB, estimate=152 kB
2023-05-13 03:02:32.371 CEST [20] LOG:  checkpoint starting: time
2023-05-13 03:02:35.823 CEST [20] LOG:  checkpoint complete: wrote 35 buffers (0.2%); 0 WAL file(s) added, 0 removed, 0 recycled; write=3.420 s, sync=0.013 s, total=3.452 s; sync files=11, longest=0.011 s, average=0.002 s; distance=151 kB, estimate=152 kB
2023-05-13 03:07:32.922 CEST [20] LOG:  checkpoint starting: time
2023-05-13 03:07:36.374 CEST [20] LOG:  checkpoint complete: wrote 35 buffers (0.2%); 0 WAL file(s) added, 0 removed, 0 recycled; write=3.420 s, sync=0.013 s, total=3.452 s; sync files=11, longest=0.012 s, average=0.002 s; distance=135 kB, estimate=150 kB
2023-05-13 03:12:32.474 CEST [20] LOG:  checkpoint starting: time
2023-05-13 03:12:35.925 CEST [20] LOG:  checkpoint complete: wrote 35 buffers (0.2%); 0 WAL file(s) added, 0 removed, 0 recycled; write=3.420 s, sync=0.013 s, total=3.451 s; sync files=11, longest=0.012 s, average=0.002 s; distance=159 kB, estimate=159 kB
2023-05-13 03:17:33.025 CEST [20] LOG:  checkpoint starting: time
2023-05-13 03:17:36.477 CEST [20] LOG:  checkpoint complete: wrote 35 buffers (0.2%); 0 WAL file(s) added, 0 removed, 0 recycled; write=3.420 s, sync=0.013 s, total=3.452 s; sync files=11, longest=0.011 s, average=0.002 s; distance=151 kB, estimate=158 kB
2023-05-13 03:22:33.576 CEST [20] LOG:  checkpoint starting: time
2023-05-13 03:22:37.028 CEST [20] LOG:  checkpoint complete: wrote 35 buffers (0.2%); 0 WAL file(s) added, 0 removed, 0 recycled; write=3.421 s, sync=0.013 s, total=3.453 s; sync files=11, longest=0.011 s, average=0.002 s; distance=150 kB, estimate=158 kB
2023-05-13 03:27:33.126 CEST [20] LOG:  checkpoint starting: time
2023-05-13 03:27:36.468 CEST [20] LOG:  checkpoint complete: wrote 34 buffers (0.2%); 0 WAL file(s) added, 0 removed, 0 recycled; write=3.320 s, sync=0.004 s, total=3.342 s; sync files=10, longest=0.003 s, average=0.001 s; distance=134 kB, estimate=155 kB
2023-05-13 03:32:33.565 CEST [20] LOG:  checkpoint starting: time
2023-05-13 03:32:37.008 CEST [20] LOG:  checkpoint complete: wrote 35 buffers (0.2%); 0 WAL file(s) added, 0 removed, 0 recycled; write=3.420 s, sync=0.004 s, total=3.443 s; sync files=11, longest=0.003 s, average=0.001 s; distance=147 kB, estimate=154 kB
2023-05-13 03:37:33.108 CEST [20] LOG:  checkpoint starting: time
2023-05-13 03:37:36.559 CEST [20] LOG:  checkpoint complete: wrote 35 buffers (0.2%); 0 WAL file(s) added, 0 removed, 0 recycled; write=3.421 s, sync=0.013 s, total=3.452 s; sync files=11, longest=0.011 s, average=0.002 s; distance=142 kB, estimate=153 kB
2023-05-13 03:42:33.640 CEST [20] LOG:  checkpoint starting: time
2023-05-13 03:42:37.092 CEST [20] LOG:  checkpoint complete: wrote 35 buffers (0.2%); 0 WAL file(s) added, 0 removed, 0 recycled; write=3.420 s, sync=0.013 s, total=3.452 s; sync files=11, longest=0.011 s, average=0.002 s; distance=144 kB, estimate=152 kB
2023-05-13 03:47:33.191 CEST [20] LOG:  checkpoint starting: time
2023-05-13 03:47:36.646 CEST [20] LOG:  checkpoint complete: wrote 35 buffers (0.2%); 0 WAL file(s) added, 0 removed, 0 recycled; write=3.420 s, sync=0.017 s, total=3.456 s; sync files=11, longest=0.015 s, average=0.002 s; distance=132 kB, estimate=150 kB
2023-05-13 03:52:33.744 CEST [20] LOG:  checkpoint starting: time
2023-05-13 03:52:37.176 CEST [20] LOG:  checkpoint complete: wrote 35 buffers (0.2%); 0 WAL file(s) added, 0 removed, 0 recycled; write=3.411 s, sync=0.003 s, total=3.433 s; sync files=11, longest=0.002 s, average=0.001 s; distance=149 kB, estimate=150 kB
2023-05-13 03:57:33.254 CEST [20] LOG:  checkpoint starting: time
2023-05-13 03:57:36.709 CEST [20] LOG:  checkpoint complete: wrote 36 buffers (0.2%); 0 WAL file(s) added, 0 removed, 0 recycled; write=3.423 s, sync=0.013 s, total=3.455 s; sync files=11, longest=0.012 s, average=0.002 s; distance=141 kB, estimate=149 kB
2023-05-13 04:02:33.807 CEST [20] LOG:  checkpoint starting: time
2023-05-13 04:02:37.267 CEST [20] LOG:  checkpoint complete: wrote 35 buffers (0.2%); 0 WAL file(s) added, 0 removed, 0 recycled; write=3.420 s, sync=0.013 s, total=3.460 s; sync files=11, longest=0.012 s, average=0.002 s; distance=144 kB, estimate=149 kB
2023-05-13 04:07:33.367 CEST [20] LOG:  checkpoint starting: time
2023-05-13 04:07:36.818 CEST [20] LOG:  checkpoint complete: wrote 35 buffers (0.2%); 0 WAL file(s) added, 0 removed, 0 recycled; write=3.420 s, sync=0.013 s, total=3.451 s; sync files=11, longest=0.011 s, average=0.002 s; distance=129 kB, estimate=147 kB
2023-05-13 04:12:33.916 CEST [20] LOG:  checkpoint starting: time
2023-05-13 04:12:37.367 CEST [20] LOG:  checkpoint complete: wrote 35 buffers (0.2%); 0 WAL file(s) added, 0 removed, 0 recycled; write=3.420 s, sync=0.013 s, total=3.452 s; sync files=11, longest=0.011 s, average=0.002 s; distance=144 kB, estimate=146 kB
2023-05-13 04:17:33.466 CEST [20] LOG:  checkpoint starting: time
2023-05-13 04:17:36.915 CEST [20] LOG:  checkpoint complete: wrote 35 buffers (0.2%); 0 WAL file(s) added, 0 removed, 0 recycled; write=3.419 s, sync=0.013 s, total=3.450 s; sync files=11, longest=0.011 s, average=0.002 s; distance=139 kB, estimate=146 kB
2023-05-13 04:22:34.014 CEST [20] LOG:  checkpoint starting: time
2023-05-13 04:22:37.457 CEST [20] LOG:  checkpoint complete: wrote 35 buffers (0.2%); 0 WAL file(s) added, 0 removed, 0 recycled; write=3.412 s, sync=0.012 s, total=3.443 s; sync files=11, longest=0.011 s, average=0.002 s; distance=147 kB, estimate=147 kB
2023-05-13 04:27:34.557 CEST [20] LOG:  checkpoint starting: time
2023-05-13 04:27:38.010 CEST [20] LOG:  checkpoint complete: wrote 35 buffers (0.2%); 0 WAL file(s) added, 0 removed, 0 recycled; write=3.420 s, sync=0.013 s, total=3.453 s; sync files=11, longest=0.012 s, average=0.002 s; distance=133 kB, estimate=146 kB
2023-05-13 04:32:34.079 CEST [20] LOG:  checkpoint starting: time
2023-05-13 04:32:37.423 CEST [20] LOG:  checkpoint complete: wrote 34 buffers (0.2%); 0 WAL file(s) added, 0 removed, 0 recycled; write=3.320 s, sync=0.005 s, total=3.344 s; sync files=10, longest=0.003 s, average=0.001 s; distance=158 kB, estimate=158 kB
2023-05-13 04:37:34.522 CEST [20] LOG:  checkpoint starting: time
2023-05-13 04:37:37.974 CEST [20] LOG:  checkpoint complete: wrote 35 buffers (0.2%); 0 WAL file(s) added, 0 removed, 0 recycled; write=3.420 s, sync=0.013 s, total=3.452 s; sync files=11, longest=0.011 s, average=0.002 s; distance=147 kB, estimate=156 kB
2023-05-13 04:42:35.072 CEST [20] LOG:  checkpoint starting: time
2023-05-13 04:42:38.523 CEST [20] LOG:  checkpoint complete: wrote 35 buffers (0.2%); 0 WAL file(s) added, 0 removed, 0 recycled; write=3.420 s, sync=0.013 s, total=3.452 s; sync files=11, longest=0.011 s, average=0.002 s; distance=148 kB, estimate=156 kB
2023-05-13 04:47:35.622 CEST [20] LOG:  checkpoint starting: time
2023-05-13 04:47:39.065 CEST [20] LOG:  checkpoint complete: wrote 35 buffers (0.2%); 0 WAL file(s) added, 0 removed, 0 recycled; write=3.420 s, sync=0.004 s, total=3.443 s; sync files=11, longest=0.003 s, average=0.001 s; distance=135 kB, estimate=153 kB
2023-05-13 04:52:35.164 CEST [20] LOG:  checkpoint starting: time
2023-05-13 04:52:38.607 CEST [20] LOG:  checkpoint complete: wrote 35 buffers (0.2%); 0 WAL file(s) added, 0 removed, 0 recycled; write=3.421 s, sync=0.013 s, total=3.443 s; sync files=11, longest=0.011 s, average=0.002 s; distance=157 kB, estimate=157 kB
2023-05-13 04:57:35.706 CEST [20] LOG:  checkpoint starting: time
2023-05-13 04:57:39.158 CEST [20] LOG:  checkpoint complete: wrote 35 buffers (0.2%); 0 WAL file(s) added, 0 removed, 0 recycled; write=3.420 s, sync=0.013 s, total=3.452 s; sync files=11, longest=0.012 s, average=0.002 s; distance=149 kB, estimate=156 kB
2023-05-13 05:02:35.257 CEST [20] LOG:  checkpoint starting: time
2023-05-13 05:02:38.714 CEST [20] LOG:  checkpoint complete: wrote 35 buffers (0.2%); 0 WAL file(s) added, 0 removed, 0 recycled; write=3.422 s, sync=0.014 s, total=3.457 s; sync files=11, longest=0.010 s, average=0.002 s; distance=153 kB, estimate=156 kB
2023-05-13 05:07:35.812 CEST [20] LOG:  checkpoint starting: time
2023-05-13 05:07:39.265 CEST [20] LOG:  checkpoint complete: wrote 35 buffers (0.2%); 0 WAL file(s) added, 0 removed, 0 recycled; write=3.420 s, sync=0.014 s, total=3.453 s; sync files=11, longest=0.010 s, average=0.002 s; distance=131 kB, estimate=153 kB
2023-05-13 05:12:35.363 CEST [20] LOG:  checkpoint starting: time
2023-05-13 05:12:38.814 CEST [20] LOG:  checkpoint complete: wrote 36 buffers (0.2%); 0 WAL file(s) added, 0 removed, 0 recycled; write=3.421 s, sync=0.013 s, total=3.452 s; sync files=11, longest=0.011 s, average=0.002 s; distance=155 kB, estimate=155 kB
2023-05-13 05:17:35.910 CEST [20] LOG:  checkpoint starting: time
2023-05-13 05:17:39.353 CEST [20] LOG:  checkpoint complete: wrote 35 buffers (0.2%); 0 WAL file(s) added, 0 removed, 0 recycled; write=3.421 s, sync=0.013 s, total=3.443 s; sync files=11, longest=0.011 s, average=0.002 s; distance=141 kB, estimate=154 kB
2023-05-13 05:22:35.452 CEST [20] LOG:  checkpoint starting: time
2023-05-13 05:22:38.904 CEST [20] LOG:  checkpoint complete: wrote 35 buffers (0.2%); 0 WAL file(s) added, 0 removed, 0 recycled; write=3.420 s, sync=0.014 s, total=3.453 s; sync files=11, longest=0.010 s, average=0.002 s; distance=142 kB, estimate=153 kB
2023-05-13 05:27:36.003 CEST [20] LOG:  checkpoint starting: time
2023-05-13 05:27:39.457 CEST [20] LOG:  checkpoint complete: wrote 35 buffers (0.2%); 0 WAL file(s) added, 0 removed, 0 recycled; write=3.420 s, sync=0.014 s, total=3.454 s; sync files=11, longest=0.010 s, average=0.002 s; distance=130 kB, estimate=150 kB
2023-05-13 05:32:36.555 CEST [20] LOG:  checkpoint starting: time
2023-05-13 05:32:40.008 CEST [20] LOG:  checkpoint complete: wrote 35 buffers (0.2%); 0 WAL file(s) added, 0 removed, 0 recycled; write=3.420 s, sync=0.014 s, total=3.454 s; sync files=11, longest=0.010 s, average=0.002 s; distance=151 kB, estimate=151 kB
2023-05-13 05:37:36.106 CEST [20] LOG:  checkpoint starting: time
2023-05-13 05:37:39.442 CEST [20] LOG:  checkpoint complete: wrote 34 buffers (0.2%); 0 WAL file(s) added, 0 removed, 0 recycled; write=3.311 s, sync=0.006 s, total=3.336 s; sync files=10, longest=0.003 s, average=0.001 s; distance=142 kB, estimate=150 kB
2023-05-13 05:42:36.541 CEST [20] LOG:  checkpoint starting: time
2023-05-13 05:42:39.983 CEST [20] LOG:  checkpoint complete: wrote 35 buffers (0.2%); 0 WAL file(s) added, 0 removed, 0 recycled; write=3.420 s, sync=0.003 s, total=3.443 s; sync files=11, longest=0.002 s, average=0.001 s; distance=148 kB, estimate=150 kB
2023-05-13 05:47:37.082 CEST [20] LOG:  checkpoint starting: time
2023-05-13 05:47:40.535 CEST [20] LOG:  checkpoint complete: wrote 35 buffers (0.2%); 0 WAL file(s) added, 0 removed, 0 recycled; write=3.420 s, sync=0.014 s, total=3.453 s; sync files=11, longest=0.010 s, average=0.002 s; distance=135 kB, estimate=148 kB
2023-05-13 05:52:37.631 CEST [20] LOG:  checkpoint starting: time
2023-05-13 05:52:41.083 CEST [20] LOG:  checkpoint complete: wrote 35 buffers (0.2%); 0 WAL file(s) added, 0 removed, 0 recycled; write=3.421 s, sync=0.013 s, total=3.452 s; sync files=11, longest=0.011 s, average=0.002 s; distance=152 kB, estimate=152 kB
2023-05-13 05:57:37.173 CEST [20] LOG:  checkpoint starting: time
2023-05-13 05:57:40.626 CEST [20] LOG:  checkpoint complete: wrote 35 buffers (0.2%); 0 WAL file(s) added, 0 removed, 0 recycled; write=3.420 s, sync=0.014 s, total=3.453 s; sync files=11, longest=0.010 s, average=0.002 s; distance=146 kB, estimate=152 kB
2023-05-13 06:02:37.726 CEST [20] LOG:  checkpoint starting: time
2023-05-13 06:02:41.177 CEST [20] LOG:  checkpoint complete: wrote 35 buffers (0.2%); 0 WAL file(s) added, 0 removed, 0 recycled; write=3.421 s, sync=0.013 s, total=3.452 s; sync files=11, longest=0.011 s, average=0.002 s; distance=145 kB, estimate=151 kB
2023-05-13 06:07:37.276 CEST [20] LOG:  checkpoint starting: time
2023-05-13 06:07:40.831 CEST [20] LOG:  checkpoint complete: wrote 36 buffers (0.2%); 0 WAL file(s) added, 0 removed, 0 recycled; write=3.521 s, sync=0.014 s, total=3.555 s; sync files=12, longest=0.010 s, average=0.002 s; distance=143 kB, estimate=150 kB
2023-05-13 06:12:37.930 CEST [20] LOG:  checkpoint starting: time
2023-05-13 06:12:41.382 CEST [20] LOG:  checkpoint complete: wrote 35 buffers (0.2%); 0 WAL file(s) added, 0 removed, 0 recycled; write=3.420 s, sync=0.014 s, total=3.452 s; sync files=11, longest=0.010 s, average=0.002 s; distance=152 kB, estimate=152 kB
2023-05-13 06:17:37.481 CEST [20] LOG:  checkpoint starting: time
2023-05-13 06:17:40.936 CEST [20] LOG:  checkpoint complete: wrote 36 buffers (0.2%); 0 WAL file(s) added, 0 removed, 0 recycled; write=3.422 s, sync=0.014 s, total=3.456 s; sync files=11, longest=0.010 s, average=0.002 s; distance=146 kB, estimate=152 kB
2023-05-13 06:22:38.036 CEST [20] LOG:  checkpoint starting: time
2023-05-13 06:22:41.488 CEST [20] LOG:  checkpoint complete: wrote 35 buffers (0.2%); 0 WAL file(s) added, 0 removed, 0 recycled; write=3.421 s, sync=0.013 s, total=3.453 s; sync files=11, longest=0.011 s, average=0.002 s; distance=148 kB, estimate=151 kB
2023-05-13 06:27:38.587 CEST [20] LOG:  checkpoint starting: time
2023-05-13 06:27:42.039 CEST [20] LOG:  checkpoint complete: wrote 35 buffers (0.2%); 0 WAL file(s) added, 0 removed, 0 recycled; write=3.420 s, sync=0.013 s, total=3.452 s; sync files=11, longest=0.011 s, average=0.002 s; distance=131 kB, estimate=149 kB
2023-05-13 06:32:38.113 CEST [20] LOG:  checkpoint starting: time
2023-05-13 06:32:41.565 CEST [20] LOG:  checkpoint complete: wrote 35 buffers (0.2%); 0 WAL file(s) added, 0 removed, 0 recycled; write=3.420 s, sync=0.013 s, total=3.453 s; sync files=11, longest=0.012 s, average=0.002 s; distance=153 kB, estimate=153 kB
2023-05-13 06:37:38.662 CEST [20] LOG:  checkpoint starting: time
2023-05-13 06:37:42.113 CEST [20] LOG:  checkpoint complete: wrote 35 buffers (0.2%); 0 WAL file(s) added, 0 removed, 0 recycled; write=3.420 s, sync=0.013 s, total=3.451 s; sync files=11, longest=0.011 s, average=0.002 s; distance=140 kB, estimate=152 kB
2023-05-13 06:42:38.211 CEST [20] LOG:  checkpoint starting: time
2023-05-13 06:42:41.555 CEST [20] LOG:  checkpoint complete: wrote 34 buffers (0.2%); 0 WAL file(s) added, 0 removed, 0 recycled; write=3.320 s, sync=0.005 s, total=3.344 s; sync files=10, longest=0.003 s, average=0.001 s; distance=146 kB, estimate=151 kB
2023-05-13 06:47:38.654 CEST [20] LOG:  checkpoint starting: time
2023-05-13 06:47:42.108 CEST [20] LOG:  checkpoint complete: wrote 35 buffers (0.2%); 0 WAL file(s) added, 0 removed, 0 recycled; write=3.420 s, sync=0.014 s, total=3.454 s; sync files=11, longest=0.010 s, average=0.002 s; distance=130 kB, estimate=149 kB
2023-05-13 06:52:38.189 CEST [20] LOG:  checkpoint starting: time
2023-05-13 06:52:41.651 CEST [20] LOG:  checkpoint complete: wrote 35 buffers (0.2%); 0 WAL file(s) added, 0 removed, 0 recycled; write=3.419 s, sync=0.013 s, total=3.462 s; sync files=11, longest=0.011 s, average=0.002 s; distance=154 kB, estimate=154 kB
2023-05-13 06:57:38.750 CEST [20] LOG:  checkpoint starting: time
2023-05-13 06:57:42.203 CEST [20] LOG:  checkpoint complete: wrote 35 buffers (0.2%); 0 WAL file(s) added, 0 removed, 0 recycled; write=3.421 s, sync=0.013 s, total=3.453 s; sync files=11, longest=0.011 s, average=0.002 s; distance=143 kB, estimate=152 kB
2023-05-13 07:02:38.294 CEST [20] LOG:  checkpoint starting: time
2023-05-13 07:02:41.746 CEST [20] LOG:  checkpoint complete: wrote 35 buffers (0.2%); 0 WAL file(s) added, 0 removed, 0 recycled; write=3.420 s, sync=0.013 s, total=3.452 s; sync files=11, longest=0.011 s, average=0.002 s; distance=147 kB, estimate=152 kB
2023-05-13 07:07:38.843 CEST [20] LOG:  checkpoint starting: time
2023-05-13 07:07:42.295 CEST [20] LOG:  checkpoint complete: wrote 35 buffers (0.2%); 0 WAL file(s) added, 0 removed, 0 recycled; write=3.420 s, sync=0.013 s, total=3.452 s; sync files=11, longest=0.011 s, average=0.002 s; distance=132 kB, estimate=150 kB
2023-05-13 07:12:38.394 CEST [20] LOG:  checkpoint starting: time
2023-05-13 07:12:41.845 CEST [20] LOG:  checkpoint complete: wrote 35 buffers (0.2%); 0 WAL file(s) added, 0 removed, 0 recycled; write=3.420 s, sync=0.013 s, total=3.451 s; sync files=11, longest=0.011 s, average=0.002 s; distance=156 kB, estimate=156 kB
2023-05-13 07:17:38.945 CEST [20] LOG:  checkpoint starting: time
2023-05-13 07:17:42.397 CEST [20] LOG:  checkpoint complete: wrote 35 buffers (0.2%); 0 WAL file(s) added, 0 removed, 0 recycled; write=3.420 s, sync=0.013 s, total=3.452 s; sync files=11, longest=0.011 s, average=0.002 s; distance=141 kB, estimate=155 kB
2023-05-13 07:22:38.495 CEST [20] LOG:  checkpoint starting: time
2023-05-13 07:22:41.948 CEST [20] LOG:  checkpoint complete: wrote 35 buffers (0.2%); 0 WAL file(s) added, 0 removed, 0 recycled; write=3.422 s, sync=0.013 s, total=3.453 s; sync files=11, longest=0.011 s, average=0.002 s; distance=148 kB, estimate=154 kB
2023-05-13 07:27:39.047 CEST [20] LOG:  checkpoint starting: time
2023-05-13 07:27:42.500 CEST [20] LOG:  checkpoint complete: wrote 35 buffers (0.2%); 0 WAL file(s) added, 0 removed, 0 recycled; write=3.421 s, sync=0.013 s, total=3.453 s; sync files=11, longest=0.011 s, average=0.002 s; distance=132 kB, estimate=152 kB
2023-05-13 07:32:39.600 CEST [20] LOG:  checkpoint starting: time
2023-05-13 07:32:43.053 CEST [20] LOG:  checkpoint complete: wrote 36 buffers (0.2%); 0 WAL file(s) added, 0 removed, 0 recycled; write=3.422 s, sync=0.013 s, total=3.454 s; sync files=11, longest=0.011 s, average=0.002 s; distance=156 kB, estimate=156 kB
2023-05-13 07:37:39.152 CEST [20] LOG:  checkpoint starting: time
2023-05-13 07:37:42.602 CEST [20] LOG:  checkpoint complete: wrote 35 buffers (0.2%); 0 WAL file(s) added, 0 removed, 0 recycled; write=3.420 s, sync=0.013 s, total=3.451 s; sync files=11, longest=0.011 s, average=0.002 s; distance=137 kB, estimate=154 kB
2023-05-13 07:42:39.702 CEST [20] LOG:  checkpoint starting: time
2023-05-13 07:42:43.155 CEST [20] LOG:  checkpoint complete: wrote 35 buffers (0.2%); 0 WAL file(s) added, 0 removed, 0 recycled; write=3.420 s, sync=0.014 s, total=3.453 s; sync files=11, longest=0.010 s, average=0.002 s; distance=147 kB, estimate=153 kB
2023-05-13 07:47:39.251 CEST [20] LOG:  checkpoint starting: time
2023-05-13 07:47:42.578 CEST [20] LOG:  checkpoint complete: wrote 34 buffers (0.2%); 0 WAL file(s) added, 0 removed, 0 recycled; write=3.311 s, sync=0.007 s, total=3.328 s; sync files=10, longest=0.004 s, average=0.001 s; distance=133 kB, estimate=151 kB
2023-05-13 07:52:39.674 CEST [20] LOG:  checkpoint starting: time
2023-05-13 07:52:43.126 CEST [20] LOG:  checkpoint complete: wrote 35 buffers (0.2%); 0 WAL file(s) added, 0 removed, 0 recycled; write=3.421 s, sync=0.013 s, total=3.452 s; sync files=11, longest=0.011 s, average=0.002 s; distance=155 kB, estimate=155 kB
2023-05-13 07:57:39.224 CEST [20] LOG:  checkpoint starting: time
2023-05-13 07:57:42.667 CEST [20] LOG:  checkpoint complete: wrote 35 buffers (0.2%); 0 WAL file(s) added, 0 removed, 0 recycled; write=3.420 s, sync=0.004 s, total=3.444 s; sync files=11, longest=0.003 s, average=0.001 s; distance=146 kB, estimate=154 kB
2023-05-13 08:02:39.766 CEST [20] LOG:  checkpoint starting: time
2023-05-13 08:02:43.218 CEST [20] LOG:  checkpoint complete: wrote 35 buffers (0.2%); 0 WAL file(s) added, 0 removed, 0 recycled; write=3.421 s, sync=0.013 s, total=3.452 s; sync files=11, longest=0.011 s, average=0.002 s; distance=151 kB, estimate=154 kB
2023-05-13 08:07:39.318 CEST [20] LOG:  checkpoint starting: time
2023-05-13 08:07:42.769 CEST [20] LOG:  checkpoint complete: wrote 35 buffers (0.2%); 0 WAL file(s) added, 0 removed, 0 recycled; write=3.420 s, sync=0.013 s, total=3.452 s; sync files=11, longest=0.011 s, average=0.002 s; distance=140 kB, estimate=152 kB
2023-05-13 08:12:39.868 CEST [20] LOG:  checkpoint starting: time
2023-05-13 08:12:43.320 CEST [20] LOG:  checkpoint complete: wrote 35 buffers (0.2%); 0 WAL file(s) added, 0 removed, 0 recycled; write=3.420 s, sync=0.013 s, total=3.453 s; sync files=11, longest=0.012 s, average=0.002 s; distance=150 kB, estimate=152 kB
2023-05-13 08:17:39.419 CEST [20] LOG:  checkpoint starting: time
2023-05-13 08:17:42.863 CEST [20] LOG:  checkpoint complete: wrote 35 buffers (0.2%); 0 WAL file(s) added, 0 removed, 0 recycled; write=3.412 s, sync=0.013 s, total=3.444 s; sync files=11, longest=0.012 s, average=0.002 s; distance=143 kB, estimate=151 kB
2023-05-13 08:22:39.946 CEST [20] LOG:  checkpoint starting: time
2023-05-13 08:22:43.396 CEST [20] LOG:  checkpoint complete: wrote 35 buffers (0.2%); 0 WAL file(s) added, 0 removed, 0 recycled; write=3.419 s, sync=0.013 s, total=3.451 s; sync files=11, longest=0.011 s, average=0.002 s; distance=147 kB, estimate=151 kB
2023-05-13 08:27:39.494 CEST [20] LOG:  checkpoint starting: time
2023-05-13 08:27:42.945 CEST [20] LOG:  checkpoint complete: wrote 35 buffers (0.2%); 0 WAL file(s) added, 0 removed, 0 recycled; write=3.420 s, sync=0.013 s, total=3.451 s; sync files=11, longest=0.011 s, average=0.002 s; distance=129 kB, estimate=149 kB
2023-05-13 08:32:40.043 CEST [20] LOG:  checkpoint starting: time
2023-05-13 08:32:43.494 CEST [20] LOG:  checkpoint complete: wrote 35 buffers (0.2%); 0 WAL file(s) added, 0 removed, 0 recycled; write=3.420 s, sync=0.013 s, total=3.452 s; sync files=11, longest=0.011 s, average=0.002 s; distance=151 kB, estimate=151 kB
2023-05-13 08:37:40.592 CEST [20] LOG:  checkpoint starting: time
2023-05-13 08:37:44.046 CEST [20] LOG:  checkpoint complete: wrote 36 buffers (0.2%); 0 WAL file(s) added, 0 removed, 0 recycled; write=3.423 s, sync=0.012 s, total=3.454 s; sync files=11, longest=0.011 s, average=0.002 s; distance=144 kB, estimate=150 kB
2023-05-13 08:42:40.111 CEST [20] LOG:  checkpoint starting: time
2023-05-13 08:42:43.554 CEST [20] LOG:  checkpoint complete: wrote 35 buffers (0.2%); 0 WAL file(s) added, 0 removed, 0 recycled; write=3.420 s, sync=0.013 s, total=3.444 s; sync files=11, longest=0.012 s, average=0.002 s; distance=148 kB, estimate=150 kB
2023-05-13 08:47:40.646 CEST [20] LOG:  checkpoint starting: time
2023-05-13 08:47:44.098 CEST [20] LOG:  checkpoint complete: wrote 35 buffers (0.2%); 0 WAL file(s) added, 0 removed, 0 recycled; write=3.420 s, sync=0.013 s, total=3.453 s; sync files=11, longest=0.012 s, average=0.002 s; distance=132 kB, estimate=148 kB
2023-05-13 08:52:40.184 CEST [20] LOG:  checkpoint starting: time
2023-05-13 08:52:43.529 CEST [20] LOG:  checkpoint complete: wrote 34 buffers (0.2%); 0 WAL file(s) added, 0 removed, 0 recycled; write=3.321 s, sync=0.006 s, total=3.346 s; sync files=10, longest=0.003 s, average=0.001 s; distance=149 kB, estimate=149 kB
2023-05-13 08:57:40.626 CEST [20] LOG:  checkpoint starting: time
2023-05-13 08:57:44.079 CEST [20] LOG:  checkpoint complete: wrote 35 buffers (0.2%); 0 WAL file(s) added, 0 removed, 0 recycled; write=3.420 s, sync=0.014 s, total=3.453 s; sync files=11, longest=0.010 s, average=0.002 s; distance=137 kB, estimate=148 kB
2023-05-13 09:02:40.176 CEST [20] LOG:  checkpoint starting: time
2023-05-13 09:02:43.628 CEST [20] LOG:  checkpoint complete: wrote 35 buffers (0.2%); 0 WAL file(s) added, 0 removed, 0 recycled; write=3.419 s, sync=0.014 s, total=3.453 s; sync files=11, longest=0.010 s, average=0.002 s; distance=149 kB, estimate=149 kB
2023-05-13 09:07:40.728 CEST [20] LOG:  checkpoint starting: time
2023-05-13 09:07:44.180 CEST [20] LOG:  checkpoint complete: wrote 35 buffers (0.2%); 0 WAL file(s) added, 0 removed, 0 recycled; write=3.420 s, sync=0.013 s, total=3.452 s; sync files=11, longest=0.012 s, average=0.002 s; distance=133 kB, estimate=148 kB
2023-05-13 09:12:40.278 CEST [20] LOG:  checkpoint starting: time
2023-05-13 09:12:43.729 CEST [20] LOG:  checkpoint complete: wrote 35 buffers (0.2%); 0 WAL file(s) added, 0 removed, 0 recycled; write=3.420 s, sync=0.014 s, total=3.452 s; sync files=11, longest=0.010 s, average=0.002 s; distance=157 kB, estimate=157 kB
2023-05-13 09:17:40.829 CEST [20] LOG:  checkpoint starting: time
2023-05-13 09:17:44.285 CEST [20] LOG:  checkpoint complete: wrote 35 buffers (0.2%); 0 WAL file(s) added, 0 removed, 1 recycled; write=3.420 s, sync=0.015 s, total=3.457 s; sync files=11, longest=0.010 s, average=0.002 s; distance=143 kB, estimate=155 kB
2023-05-13 09:22:40.370 CEST [20] LOG:  checkpoint starting: time
2023-05-13 09:22:43.822 CEST [20] LOG:  checkpoint complete: wrote 35 buffers (0.2%); 0 WAL file(s) added, 0 removed, 0 recycled; write=3.421 s, sync=0.013 s, total=3.452 s; sync files=11, longest=0.011 s, average=0.002 s; distance=145 kB, estimate=154 kB
2023-05-13 09:27:40.922 CEST [20] LOG:  checkpoint starting: time
2023-05-13 09:27:44.374 CEST [20] LOG:  checkpoint complete: wrote 35 buffers (0.2%); 0 WAL file(s) added, 0 removed, 0 recycled; write=3.420 s, sync=0.013 s, total=3.452 s; sync files=11, longest=0.011 s, average=0.002 s; distance=131 kB, estimate=152 kB
2023-05-13 09:32:40.470 CEST [20] LOG:  checkpoint starting: time
2023-05-13 09:32:43.921 CEST [20] LOG:  checkpoint complete: wrote 35 buffers (0.2%); 0 WAL file(s) added, 0 removed, 0 recycled; write=3.420 s, sync=0.013 s, total=3.451 s; sync files=11, longest=0.011 s, average=0.002 s; distance=153 kB, estimate=153 kB
2023-05-13 09:37:41.021 CEST [20] LOG:  checkpoint starting: time
2023-05-13 09:37:44.472 CEST [20] LOG:  checkpoint complete: wrote 35 buffers (0.2%); 0 WAL file(s) added, 0 removed, 0 recycled; write=3.420 s, sync=0.013 s, total=3.452 s; sync files=11, longest=0.011 s, average=0.002 s; distance=143 kB, estimate=152 kB
2023-05-13 09:42:41.555 CEST [20] LOG:  checkpoint starting: time
2023-05-13 09:42:44.997 CEST [20] LOG:  checkpoint complete: wrote 35 buffers (0.2%); 0 WAL file(s) added, 0 removed, 0 recycled; write=3.420 s, sync=0.013 s, total=3.442 s; sync files=11, longest=0.011 s, average=0.002 s; distance=155 kB, estimate=155 kB
2023-05-13 09:47:42.097 CEST [20] LOG:  checkpoint starting: time
2023-05-13 09:47:45.547 CEST [20] LOG:  checkpoint complete: wrote 35 buffers (0.2%); 0 WAL file(s) added, 0 removed, 0 recycled; write=3.419 s, sync=0.013 s, total=3.451 s; sync files=11, longest=0.011 s, average=0.002 s; distance=133 kB, estimate=153 kB
2023-05-13 09:52:42.646 CEST [20] LOG:  checkpoint starting: time
2023-05-13 09:52:46.100 CEST [20] LOG:  checkpoint complete: wrote 36 buffers (0.2%); 0 WAL file(s) added, 0 removed, 0 recycled; write=3.423 s, sync=0.013 s, total=3.454 s; sync files=11, longest=0.011 s, average=0.002 s; distance=154 kB, estimate=154 kB
2023-05-13 09:57:42.198 CEST [20] LOG:  checkpoint starting: time
2023-05-13 09:57:45.541 CEST [20] LOG:  checkpoint complete: wrote 34 buffers (0.2%); 0 WAL file(s) added, 0 removed, 0 recycled; write=3.320 s, sync=0.005 s, total=3.344 s; sync files=10, longest=0.003 s, average=0.001 s; distance=141 kB, estimate=153 kB
2023-05-13 10:02:42.641 CEST [20] LOG:  checkpoint starting: time
2023-05-13 10:02:46.090 CEST [20] LOG:  checkpoint complete: wrote 35 buffers (0.2%); 0 WAL file(s) added, 0 removed, 0 recycled; write=3.419 s, sync=0.013 s, total=3.450 s; sync files=11, longest=0.011 s, average=0.002 s; distance=145 kB, estimate=152 kB
2023-05-13 10:07:42.186 CEST [20] LOG:  checkpoint starting: time
2023-05-13 10:07:45.639 CEST [20] LOG:  checkpoint complete: wrote 35 buffers (0.2%); 0 WAL file(s) added, 0 removed, 0 recycled; write=3.420 s, sync=0.013 s, total=3.454 s; sync files=11, longest=0.012 s, average=0.002 s; distance=128 kB, estimate=150 kB
2023-05-13 10:12:42.738 CEST [20] LOG:  checkpoint starting: time
2023-05-13 10:12:46.191 CEST [20] LOG:  checkpoint complete: wrote 35 buffers (0.2%); 0 WAL file(s) added, 0 removed, 0 recycled; write=3.420 s, sync=0.014 s, total=3.453 s; sync files=11, longest=0.012 s, average=0.002 s; distance=148 kB, estimate=149 kB
2023-05-13 10:17:42.284 CEST [20] LOG:  checkpoint starting: time
2023-05-13 10:17:45.738 CEST [20] LOG:  checkpoint complete: wrote 35 buffers (0.2%); 0 WAL file(s) added, 0 removed, 0 recycled; write=3.421 s, sync=0.014 s, total=3.455 s; sync files=11, longest=0.010 s, average=0.002 s; distance=141 kB, estimate=149 kB
2023-05-13 10:22:42.834 CEST [20] LOG:  checkpoint starting: time
2023-05-13 10:22:46.278 CEST [20] LOG:  checkpoint complete: wrote 35 buffers (0.2%); 0 WAL file(s) added, 0 removed, 0 recycled; write=3.412 s, sync=0.014 s, total=3.444 s; sync files=11, longest=0.010 s, average=0.002 s; distance=151 kB, estimate=151 kB
2023-05-13 10:27:42.365 CEST [20] LOG:  checkpoint starting: time
2023-05-13 10:27:45.817 CEST [20] LOG:  checkpoint complete: wrote 35 buffers (0.2%); 0 WAL file(s) added, 0 removed, 0 recycled; write=3.420 s, sync=0.013 s, total=3.452 s; sync files=11, longest=0.011 s, average=0.002 s; distance=136 kB, estimate=150 kB
2023-05-13 10:32:42.915 CEST [20] LOG:  checkpoint starting: time
2023-05-13 10:32:46.367 CEST [20] LOG:  checkpoint complete: wrote 35 buffers (0.2%); 0 WAL file(s) added, 0 removed, 0 recycled; write=3.420 s, sync=0.013 s, total=3.453 s; sync files=11, longest=0.011 s, average=0.002 s; distance=154 kB, estimate=154 kB
2023-05-13 10:37:42.466 CEST [20] LOG:  checkpoint starting: time
2023-05-13 10:37:45.918 CEST [20] LOG:  checkpoint complete: wrote 35 buffers (0.2%); 0 WAL file(s) added, 0 removed, 0 recycled; write=3.420 s, sync=0.013 s, total=3.452 s; sync files=11, longest=0.011 s, average=0.002 s; distance=146 kB, estimate=153 kB
2023-05-13 10:42:43.014 CEST [20] LOG:  checkpoint starting: time
2023-05-13 10:42:46.466 CEST [20] LOG:  checkpoint complete: wrote 35 buffers (0.2%); 0 WAL file(s) added, 0 removed, 0 recycled; write=3.420 s, sync=0.013 s, total=3.452 s; sync files=11, longest=0.011 s, average=0.002 s; distance=145 kB, estimate=152 kB
2023-05-13 10:47:43.566 CEST [20] LOG:  checkpoint starting: time
2023-05-13 10:47:46.991 CEST [20] LOG:  checkpoint complete: wrote 35 buffers (0.2%); 0 WAL file(s) added, 0 removed, 0 recycled; write=3.412 s, sync=0.004 s, total=3.426 s; sync files=11, longest=0.003 s, average=0.001 s; distance=134 kB, estimate=150 kB
2023-05-13 10:52:44.091 CEST [20] LOG:  checkpoint starting: time
2023-05-13 10:52:47.542 CEST [20] LOG:  checkpoint complete: wrote 35 buffers (0.2%); 0 WAL file(s) added, 0 removed, 0 recycled; write=3.420 s, sync=0.013 s, total=3.452 s; sync files=11, longest=0.012 s, average=0.002 s; distance=154 kB, estimate=154 kB
2023-05-13 10:57:44.642 CEST [20] LOG:  checkpoint starting: time
2023-05-13 10:57:48.094 CEST [20] LOG:  checkpoint complete: wrote 35 buffers (0.2%); 0 WAL file(s) added, 0 removed, 0 recycled; write=3.420 s, sync=0.013 s, total=3.453 s; sync files=11, longest=0.011 s, average=0.002 s; distance=146 kB, estimate=153 kB
2023-05-13 11:02:44.194 CEST [20] LOG:  checkpoint starting: time
2023-05-13 11:02:50.056 CEST [20] LOG:  checkpoint complete: wrote 60 buffers (0.4%); 0 WAL file(s) added, 0 removed, 0 recycled; write=5.837 s, sync=0.006 s, total=5.862 s; sync files=22, longest=0.003 s, average=0.001 s; distance=290 kB, estimate=290 kB
2023-05-13 11:07:44.156 CEST [20] LOG:  checkpoint starting: time
2023-05-13 11:07:47.603 CEST [20] LOG:  checkpoint complete: wrote 35 buffers (0.2%); 0 WAL file(s) added, 0 removed, 0 recycled; write=3.417 s, sync=0.013 s, total=3.448 s; sync files=11, longest=0.012 s, average=0.002 s; distance=135 kB, estimate=275 kB
2023-05-13 11:12:44.702 CEST [20] LOG:  checkpoint starting: time
2023-05-13 11:12:48.150 CEST [20] LOG:  checkpoint complete: wrote 35 buffers (0.2%); 0 WAL file(s) added, 0 removed, 0 recycled; write=3.417 s, sync=0.013 s, total=3.448 s; sync files=11, longest=0.011 s, average=0.002 s; distance=156 kB, estimate=263 kB
2023-05-13 11:17:44.248 CEST [20] LOG:  checkpoint starting: time
2023-05-13 11:17:47.386 CEST [20] LOG:  checkpoint complete: wrote 32 buffers (0.2%); 0 WAL file(s) added, 0 removed, 0 recycled; write=3.117 s, sync=0.004 s, total=3.139 s; sync files=11, longest=0.003 s, average=0.001 s; distance=131 kB, estimate=250 kB
2023-05-13 11:22:44.486 CEST [20] LOG:  checkpoint starting: time
2023-05-13 11:22:47.934 CEST [20] LOG:  checkpoint complete: wrote 35 buffers (0.2%); 0 WAL file(s) added, 0 removed, 0 recycled; write=3.418 s, sync=0.012 s, total=3.449 s; sync files=11, longest=0.011 s, average=0.002 s; distance=138 kB, estimate=239 kB
2023-05-13 11:27:45.034 CEST [20] LOG:  checkpoint starting: time
2023-05-13 11:27:48.481 CEST [20] LOG:  checkpoint complete: wrote 35 buffers (0.2%); 0 WAL file(s) added, 0 removed, 0 recycled; write=3.417 s, sync=0.012 s, total=3.448 s; sync files=11, longest=0.011 s, average=0.002 s; distance=125 kB, estimate=227 kB
2023-05-13 11:32:45.581 CEST [20] LOG:  checkpoint starting: time
2023-05-13 11:32:49.029 CEST [20] LOG:  checkpoint complete: wrote 35 buffers (0.2%); 0 WAL file(s) added, 0 removed, 0 recycled; write=3.418 s, sync=0.013 s, total=3.448 s; sync files=11, longest=0.011 s, average=0.002 s; distance=146 kB, estimate=219 kB
2023-05-13 11:33:52.556 CEST [11] LOG:  starting PostgreSQL 15.2 on x86_64-pc-linux-musl, compiled by gcc (Alpine 12.2.1_git20220924-r4) 12.2.1 20220924, 64-bit
2023-05-13 11:33:52.564 CEST [11] LOG:  listening on IPv4 address "0.0.0.0", port 5432
2023-05-13 11:33:52.570 CEST [11] LOG:  listening on IPv6 address "::", port 5432
2023-05-13 11:33:52.582 CEST [11] LOG:  listening on Unix socket "/var/run/postgresql/.s.PGSQL.5432"
2023-05-13 11:33:52.618 CEST [21] LOG:  database system was interrupted; last known up at 2023-05-13 11:32:49 CEST
2023-05-13 11:33:53.161 CEST [21] LOG:  database system was not properly shut down; automatic recovery in progress
2023-05-13 11:33:53.166 CEST [21] LOG:  redo starts at 1/17401050
2023-05-13 11:33:53.166 CEST [21] LOG:  invalid record length at 1/17401138: wanted 24, got 0
2023-05-13 11:33:53.166 CEST [21] LOG:  redo done at 1/17401100 system usage: CPU: user: 0.00 s, system: 0.00 s, elapsed: 0.00 s
2023-05-13 11:33:53.176 CEST [19] LOG:  checkpoint starting: end-of-recovery immediate wait
2023-05-13 11:33:53.202 CEST [19] LOG:  checkpoint complete: wrote 3 buffers (0.0%); 0 WAL file(s) added, 0 removed, 0 recycled; write=0.009 s, sync=0.003 s, total=0.028 s; sync files=2, longest=0.002 s, average=0.002 s; distance=0 kB, estimate=0 kB
2023-05-13 11:33:53.215 CEST [11] LOG:  database system is ready to accept connections
2023-05-13 11:43:53.402 CEST [19] LOG:  checkpoint starting: time
2023-05-13 11:43:54.537 CEST [19] LOG:  checkpoint complete: wrote 12 buffers (0.1%); 0 WAL file(s) added, 0 removed, 0 recycled; write=1.114 s, sync=0.004 s, total=1.135 s; sync files=12, longest=0.002 s, average=0.001 s; distance=57 kB, estimate=57 kB
2023-05-13 11:53:53.735 CEST [19] LOG:  checkpoint starting: time
2023-05-13 11:53:56.874 CEST [19] LOG:  checkpoint complete: wrote 32 buffers (0.2%); 0 WAL file(s) added, 0 removed, 0 recycled; write=3.117 s, sync=0.005 s, total=3.140 s; sync files=11, longest=0.003 s, average=0.001 s; distance=130 kB, estimate=130 kB
2023-05-13 11:58:53.974 CEST [19] LOG:  checkpoint starting: time
2023-05-13 11:58:57.415 CEST [19] LOG:  checkpoint complete: wrote 35 buffers (0.2%); 0 WAL file(s) added, 0 removed, 0 recycled; write=3.418 s, sync=0.014 s, total=3.441 s; sync files=11, longest=0.010 s, average=0.002 s; distance=141 kB, estimate=141 kB
2023-05-13 12:03:53.515 CEST [19] LOG:  checkpoint starting: time
2023-05-13 12:03:56.944 CEST [19] LOG:  checkpoint complete: wrote 35 buffers (0.2%); 0 WAL file(s) added, 0 removed, 0 recycled; write=3.409 s, sync=0.003 s, total=3.430 s; sync files=11, longest=0.002 s, average=0.001 s; distance=129 kB, estimate=140 kB
2023-05-13 12:08:54.042 CEST [19] LOG:  checkpoint starting: time
2023-05-13 12:08:57.474 CEST [19] LOG:  checkpoint complete: wrote 35 buffers (0.2%); 0 WAL file(s) added, 0 removed, 0 recycled; write=3.409 s, sync=0.014 s, total=3.433 s; sync files=11, longest=0.010 s, average=0.002 s; distance=150 kB, estimate=150 kB
2023-05-13 12:13:54.574 CEST [19] LOG:  checkpoint starting: time
2023-05-13 12:13:58.023 CEST [19] LOG:  checkpoint complete: wrote 35 buffers (0.2%); 0 WAL file(s) added, 0 removed, 0 recycled; write=3.418 s, sync=0.014 s, total=3.449 s; sync files=11, longest=0.010 s, average=0.002 s; distance=144 kB, estimate=149 kB
2023-05-13 12:18:54.122 CEST [19] LOG:  checkpoint starting: time
2023-05-13 12:18:57.670 CEST [19] LOG:  checkpoint complete: wrote 36 buffers (0.2%); 0 WAL file(s) added, 0 removed, 0 recycled; write=3.510 s, sync=0.014 s, total=3.548 s; sync files=12, longest=0.010 s, average=0.002 s; distance=155 kB, estimate=155 kB
2023-05-13 12:23:54.766 CEST [19] LOG:  checkpoint starting: time
2023-05-13 12:23:58.217 CEST [19] LOG:  checkpoint complete: wrote 36 buffers (0.2%); 0 WAL file(s) added, 0 removed, 0 recycled; write=3.420 s, sync=0.014 s, total=3.451 s; sync files=11, longest=0.010 s, average=0.002 s; distance=136 kB, estimate=153 kB
2023-05-13 12:28:54.316 CEST [19] LOG:  checkpoint starting: time
2023-05-13 12:28:57.855 CEST [19] LOG:  checkpoint complete: wrote 36 buffers (0.2%); 0 WAL file(s) added, 0 removed, 0 recycled; write=3.518 s, sync=0.012 s, total=3.539 s; sync files=12, longest=0.011 s, average=0.001 s; distance=170 kB, estimate=170 kB
2023-05-13 12:33:54.954 CEST [19] LOG:  checkpoint starting: time
2023-05-13 12:33:58.406 CEST [19] LOG:  checkpoint complete: wrote 35 buffers (0.2%); 0 WAL file(s) added, 0 removed, 0 recycled; write=3.418 s, sync=0.016 s, total=3.452 s; sync files=11, longest=0.015 s, average=0.002 s; distance=145 kB, estimate=167 kB
2023-05-13 12:38:54.502 CEST [19] LOG:  checkpoint starting: time
2023-05-13 12:38:57.941 CEST [19] LOG:  checkpoint complete: wrote 35 buffers (0.2%); 0 WAL file(s) added, 0 removed, 0 recycled; write=3.418 s, sync=0.013 s, total=3.440 s; sync files=11, longest=0.011 s, average=0.002 s; distance=152 kB, estimate=166 kB
2023-05-13 12:43:55.039 CEST [19] LOG:  checkpoint starting: time
2023-05-13 12:43:58.485 CEST [19] LOG:  checkpoint complete: wrote 35 buffers (0.2%); 0 WAL file(s) added, 0 removed, 0 recycled; write=3.418 s, sync=0.012 s, total=3.447 s; sync files=11, longest=0.011 s, average=0.002 s; distance=139 kB, estimate=163 kB
2023-05-13 12:47:47.245 CEST [12] LOG:  starting PostgreSQL 15.2 on x86_64-pc-linux-musl, compiled by gcc (Alpine 12.2.1_git20220924-r4) 12.2.1 20220924, 64-bit
2023-05-13 12:47:47.246 CEST [12] LOG:  listening on IPv4 address "0.0.0.0", port 5432
2023-05-13 12:47:47.246 CEST [12] LOG:  listening on IPv6 address "::", port 5432
2023-05-13 12:47:47.260 CEST [12] LOG:  listening on Unix socket "/var/run/postgresql/.s.PGSQL.5432"
2023-05-13 12:47:47.276 CEST [22] LOG:  database system was interrupted; last known up at 2023-05-13 12:43:58 CEST
2023-05-13 12:47:47.521 CEST [22] LOG:  database system was not properly shut down; automatic recovery in progress
2023-05-13 12:47:47.526 CEST [22] LOG:  redo starts at 1/1759EBE0
2023-05-13 12:47:47.533 CEST [22] LOG:  invalid record length at 1/175C7288: wanted 24, got 0
2023-05-13 12:47:47.533 CEST [22] LOG:  redo done at 1/175C7250 system usage: CPU: user: 0.00 s, system: 0.00 s, elapsed: 0.00 s
2023-05-13 12:47:47.542 CEST [20] LOG:  checkpoint starting: end-of-recovery immediate wait
2023-05-13 12:47:47.601 CEST [20] LOG:  checkpoint complete: wrote 39 buffers (0.2%); 0 WAL file(s) added, 0 removed, 0 recycled; write=0.016 s, sync=0.023 s, total=0.063 s; sync files=14, longest=0.011 s, average=0.002 s; distance=161 kB, estimate=161 kB
2023-05-13 12:47:47.612 CEST [12] LOG:  database system is ready to accept connections
2023-05-13 12:52:47.705 CEST [20] LOG:  checkpoint starting: time
2023-05-13 12:52:48.135 CEST [20] LOG:  checkpoint complete: wrote 4 buffers (0.0%); 0 WAL file(s) added, 0 removed, 0 recycled; write=0.402 s, sync=0.011 s, total=0.430 s; sync files=2, longest=0.011 s, average=0.006 s; distance=11 kB, estimate=146 kB
2023-05-13 12:57:47.234 CEST [20] LOG:  checkpoint starting: time
2023-05-13 12:57:48.487 CEST [20] LOG:  checkpoint complete: wrote 13 buffers (0.1%); 0 WAL file(s) added, 0 removed, 0 recycled; write=1.214 s, sync=0.004 s, total=1.254 s; sync files=13, longest=0.002 s, average=0.001 s; distance=59 kB, estimate=137 kB
2023-05-13 13:07:47.686 CEST [20] LOG:  checkpoint starting: time
2023-05-13 13:07:50.830 CEST [20] LOG:  checkpoint complete: wrote 32 buffers (0.2%); 0 WAL file(s) added, 0 removed, 0 recycled; write=3.119 s, sync=0.005 s, total=3.144 s; sync files=11, longest=0.003 s, average=0.001 s; distance=140 kB, estimate=140 kB
2023-05-13 13:12:47.930 CEST [20] LOG:  checkpoint starting: time
2023-05-13 13:12:51.373 CEST [20] LOG:  checkpoint complete: wrote 35 buffers (0.2%); 0 WAL file(s) added, 0 removed, 0 recycled; write=3.420 s, sync=0.005 s, total=3.444 s; sync files=11, longest=0.003 s, average=0.001 s; distance=148 kB, estimate=148 kB
2023-05-13 13:17:47.470 CEST [20] LOG:  checkpoint starting: time
2023-05-13 13:17:51.023 CEST [20] LOG:  checkpoint complete: wrote 36 buffers (0.2%); 0 WAL file(s) added, 0 removed, 0 recycled; write=3.520 s, sync=0.014 s, total=3.553 s; sync files=12, longest=0.010 s, average=0.002 s; distance=146 kB, estimate=148 kB
2023-05-13 13:22:47.122 CEST [20] LOG:  checkpoint starting: time
2023-05-13 13:22:50.573 CEST [20] LOG:  checkpoint complete: wrote 35 buffers (0.2%); 0 WAL file(s) added, 0 removed, 0 recycled; write=3.420 s, sync=0.014 s, total=3.451 s; sync files=11, longest=0.010 s, average=0.002 s; distance=152 kB, estimate=152 kB
2023-05-13 13:27:47.671 CEST [20] LOG:  checkpoint starting: time
2023-05-13 13:27:51.225 CEST [20] LOG:  checkpoint complete: wrote 36 buffers (0.2%); 0 WAL file(s) added, 0 removed, 0 recycled; write=3.521 s, sync=0.014 s, total=3.554 s; sync files=12, longest=0.010 s, average=0.002 s; distance=156 kB, estimate=156 kB
2023-05-13 13:32:47.322 CEST [20] LOG:  checkpoint starting: time
2023-05-13 13:32:50.763 CEST [20] LOG:  checkpoint complete: wrote 35 buffers (0.2%); 0 WAL file(s) added, 0 removed, 0 recycled; write=3.411 s, sync=0.013 s, total=3.442 s; sync files=11, longest=0.010 s, average=0.002 s; distance=145 kB, estimate=155 kB
2023-05-13 13:37:47.862 CEST [20] LOG:  checkpoint starting: time
2023-05-13 13:37:51.303 CEST [20] LOG:  checkpoint complete: wrote 35 buffers (0.2%); 0 WAL file(s) added, 0 removed, 0 recycled; write=3.409 s, sync=0.014 s, total=3.441 s; sync files=11, longest=0.010 s, average=0.002 s; distance=130 kB, estimate=152 kB
Then your nextcloud and apache logs are not complete. Can you post them again? Are all containers shown as green == running in thr AIO interface?
in interface all of them were green
apache was red because i had to turn it off because i couldnt acces AIO interface and i have my aio-talk:latest unhealthy but friend told me it doenst matter
i just started it (apache) and this are logs from apache (it was starting over 3 minutes)
~$ sudo docker logs 7e7abc09b6ee
Waiting for Nextcloud to start...
{"level":"info","ts":1683925497.413171,"msg":"using provided configuration","config_file":"/Caddyfile","config_adapter":""}
[Fri May 12 23:04:57.435209 2023] [mpm_event:notice] [pid 684:tid 139999022517064] AH00489: Apache/2.4.57 (Unix) configured -- resuming normal operations
[Fri May 12 23:04:57.435528 2023] [core:notice] [pid 684:tid 139999022517064] AH00094: Command line: '/usr/local/apache2/bin/httpd -D FOREGROUND'
[Sat May 13 11:31:38.301903 2023] [mpm_event:notice] [pid 21:tid 139961167887176] AH00489: Apache/2.4.57 (Unix) configured -- resuming normal operations
[Sat May 13 11:31:38.302421 2023] [core:notice] [pid 21:tid 139961167887176] AH00094: Command line: '/usr/local/apache2/bin/httpd -D FOREGROUND'
{"level":"info","ts":1683970298.3228323,"msg":"using provided configuration","config_file":"/Caddyfile","config_adapter":""}
{"level":"info","ts":1683971423.5220168,"msg":"using provided configuration","config_file":"/Caddyfile","config_adapter":""}
[Sat May 13 11:50:23.541368 2023] [mpm_event:notice] [pid 642:tid 140487675833160] AH00489: Apache/2.4.57 (Unix) configured -- resuming normal operations
[Sat May 13 11:50:23.541430 2023] [core:notice] [pid 642:tid 140487675833160] AH00094: Command line: '/usr/local/apache2/bin/httpd -D FOREGROUND'
{"level":"info","ts":1683978258.2468567,"msg":"using provided configuration","config_file":"/Caddyfile","config_adapter":""}
[Sat May 13 13:44:18.269673 2023] [mpm_event:notice] [pid 23:tid 139789051013960] AH00489: Apache/2.4.57 (Unix) configured -- resuming normal operations
[Sat May 13 13:44:18.270062 2023] [core:notice] [pid 23:tid 139789051013960] AH00094: Command line: '/usr/local/apache2/bin/httpd -D FOREGROUND'
nextcloud/aio-nextcloud:latest logs
sudo docker logs 8b02274d34fe
              now
 2023-05-12 22:37:23.680902+02
(1 row)
+ '[' -n '' ']'
+ set +x
Installing imagemagick via apk...
Enabling Imagick...
Configuring Redis as session handler...
Setting php max children...
Checking connection to appstore
Appstore is reachable
Maintenance mode already disabled
Getting and backing up the status of apps for later, this might take a while...
Disabling apps before the update in order to make the update procedure more safe. This can take a while...
quicknotes 0.8.5 disabled
spreed 15.0.5 disabled
richdocuments 7.1.3 disabled
notify_push 0.6.2 disabled
documentserver_community 0.1.13 disabled
Initializing nextcloud 25.0.6.1 ...
Initializing finished
Upgrading nextcloud from 25.0.4.1 to 25.0.6.1...
Nextcloud or one of the apps require upgrade - only a limited number of commands are available
You may use your browser or the occ upgrade command to do the upgrade
Setting log level to debug
Turned on maintenance mode
Updating database schema
Updated database
Starting code integrity check...
Finished code integrity check
Update successful
Turned off maintenance mode
Resetting log level
Sus could 25.0.6
Posting notifications to users that are admins...
Posting 'Nextcloud update to 25.0.6.1 successful!' to: ati
Done!
Restoring the status of apps. This can take a while...
Enabling notify_push...
Enabling richdocuments...
Enabling spreed...
Enabling quicknotes...
Enabling documentserver_community...
Doing some optimizations...
 - Repair MySQL collation
     - Not a mysql database -> nothing to do
 - Repair mime types
 - Clean tags and favorites
     - 0 tags of deleted users have been removed.
     - 0 tags for delete files have been removed.
     - 0 tag entries for deleted tags have been removed.
     - 0 tags with no entries have been removed.
 - Repair invalid shares
 - Move .step file of updater to backup location
 - Add move avatar background job
     - Repair step already executed
 - Add preview cleanup background jobs
 - Migrate oauth2_clients table to nextcloud schema
     - Update the oauth2_access_tokens table schema.
     - Update the oauth2_clients table schema.
 - Fix potential broken mount points
     - No mounts updated
 - Repair language codes
 - Add log rotate job
 - Clear frontend caches
     - Image cache cleared
     - JS cache cleared
 - Clear every generated avatar on major updates
 - Add preview background cleanup job
 - Queue a one-time job to cleanup old backups of the updater
 - Cleanup invalid photocache files for carddav
 - Add background job to cleanup login flow v2 tokens
 - Remove potentially over exposing share links
     - No need to remove link shares.
 - Clear access cache of projects
 - Reset generated avatar flag
 - Keep legacy encryption enabled
 - Check encryption key format
 - Remove old dashboard app config data
 - Add job to cleanup the bruteforce entries
 - Queue a one-time job to check for user uploaded certificates
 - Repair DAV shares
 - Add background job to set the lookup server share state for users
 - Add token cleanup job
 - Clean up abandoned apps
 - Add possibly missing system config
 - Upgrading Circles App
 - Fix component of birthday calendars
     - 2 birthday calendars updated.
 - Regenerating birthday calendars to use new icons and fix old birthday events without year
 - Fix broken values of calendar objects
    0 [>---------------------------]
 - Registering building of calendar search index as background job
 - Register building of social profile search index as background job
 - Registering background jobs to update cache for webcal calendars
     - Added 0 background jobs to update webcal calendars
 - Registering building of calendar reminder index as background job
 - Clean up orphan event and contact data
     - 0 events without a calendar have been cleaned up
     - 0 properties without an events have been cleaned up
     - 0 changes without a calendar have been cleaned up
     - 0 cached events without a calendar subscription have been cleaned up
     - 0 changes without a calendar subscription have been cleaned up
     - 0 contacts without an addressbook have been cleaned up
     - 0 properties without a contact have been cleaned up
     - 0 changes without an addressbook have been cleaned up
 - Remove activity entries of private events
     - Removed 0 activity entries
 - Clean up old calendar subscriptions from deleted users that were not cleaned-up
    0 [->--------------------------]
     - 0 calendar subscriptions without an user have been cleaned up
 - Remove invalid object properties
     - 0 invalid object properties removed.
 - Rebuild font library
     - WARNING: Error while trying to rebuild fonts, if you had any custom fonts configured you'll need to run `occ documentserver:fonts --rebuild`
 - Fix the share type of guest shares when migrating from ownCloud
 - Copy the share password into the dedicated column
 - Set existing shares as accepted
 - Set binary permissions
 - Update OAuth token expiration times
 - Create help command
 - Invalidate access cache for projects conversation provider
     - Invalidation not required
 - Cache the user display names
 - Switches from default updater server to the customer one if a valid subscription is available
 - Send an admin notification if monthly report is disabled
 - Initialize migration of background images from dashboard to theming app
 - Add background job to check for backup codes
 - Populating added database structures for workflows
Check indices of the share table.
Check indices of the filecache table.
Adding additional parent index to the filecache table, this can take some time...
Filecache table updated successfully.
Check indices of the twofactor_providers table.
Check indices of the login_flow_v2 table.
Check indices of the whats_new table.
Check indices of the cards table.
Check indices of the cards_properties table.
Check indices of the calendarobjects_props table.
Check indices of the schedulingobjects table.
Check indices of the oc_properties table.
Check indices of the oc_jobs table.
Check indices of the oc_direct_edit table.
Check indices of the oc_preferences table.
Check indices of the oc_mounts table.
Check columns of the comments table.
Done.
Check primary keys.
Done.
All tables already up to date!
mimetypelist.js is updated
Added mimetype "application/x-7z-compressed" to database
Added mimetype "application/msaccess" to database
Added mimetype "application/illustrator" to database
Added mimetype "video/x-msvideo" to database
Added mimetype "text/x-shellscript" to database
Added mimetype "application/x-msdos-program" to database
Added mimetype "application/x-bin" to database
Added mimetype "application/x-blender" to database
Added mimetype "image/bpg" to database
Added mimetype "application/x-bzip2" to database
Added mimetype "text/x-c" to database
Added mimetype "text/x-c++src" to database
Added mimetype "application/comicbook+7z" to database
Added mimetype "application/comicbook+ace" to database
Added mimetype "application/comicbook+rar" to database
Added mimetype "application/comicbook+tar" to database
Added mimetype "application/comicbook+truecrypt" to database
Added mimetype "application/comicbook+zip" to database
Added mimetype "application/coreldraw" to database
Added mimetype "application/java" to database
Added mimetype "application/cmd" to database
Added mimetype "text/css" to database
Added mimetype "text/csv" to database
Added mimetype "application/x-cbr" to database
Added mimetype "application/x-deb" to database
Added mimetype "application/vnd.ms-word.document.macroEnabled.12" to database
Added mimetype "application/vnd.openxmlformats-officedocument.wordprocessingml.template" to database
Added mimetype "video/dv" to database
Added mimetype "application/vnd.ms-fontobject" to database
Added mimetype "application/postscript" to database
Added mimetype "application/epub+zip" to database
Added mimetype "application/x-fictionbook+xml" to database
Added mimetype "audio/flac" to database
Added mimetype "video/x-flv" to database
Added mimetype "application/vnd.oasis.opendocument.graphics-flat-xml" to database
Added mimetype "application/vnd.oasis.opendocument.presentation-flat-xml" to database
Added mimetype "application/vnd.oasis.opendocument.spreadsheet-flat-xml" to database
Added mimetype "application/vnd.oasis.opendocument.text-flat-xml" to database
Added mimetype "application/gpx+xml" to database
Added mimetype "text/x-h" to database
Added mimetype "image/heif" to database
Added mimetype "text/calendar" to database
Added mimetype "image/x-icon" to database
Added mimetype "text/impress" to database
Added mimetype "text/x-java-source" to database
Added mimetype "image/jp2" to database
Added mimetype "application/x-kdbx" to database
Added mimetype "application/x-iwork-keynote-sffkey" to database
Added mimetype "application/km" to database
Added mimetype "application/vnd.google-earth.kml+xml" to database
Added mimetype "application/vnd.google-earth.kmz" to database
Added mimetype "application/x-krita" to database
Added mimetype "text/x-ldif" to database
Added mimetype "application/vnd.lotus-wordpro" to database
Added mimetype "video/mp2t" to database
Added mimetype "audio/mpegurl" to database
Added mimetype "audio/m4b" to database
Added mimetype "video/x-matroska" to database
Added mimetype "application/x-freemind" to database
Added mimetype "application/x-mobipocket-ebook" to database
Added mimetype "audio/mpeg" to database
Added mimetype "video/mpeg" to database
Added mimetype "application/x-msi" to database
Added mimetype "video/MP2T" to database
Added mimetype "application/x-iwork-numbers-sffnumbers" to database
Added mimetype "application/vnd.oasis.opendocument.formula" to database
Added mimetype "audio/ogg" to database
Added mimetype "video/ogg" to database
Added mimetype "application/msonenote" to database
Added mimetype "text/org" to database
Added mimetype "application/font-sfnt" to database
Added mimetype "application/x-iwork-pages-sffpages" to database
Added mimetype "application/x-font" to database
Added mimetype "application/x-php" to database
Added mimetype "application/x-perl" to database
Added mimetype "audio/x-scpls" to database
Added mimetype "application/vnd.ms-powerpoint.template.macroEnabled.12" to database
Added mimetype "application/vnd.openxmlformats-officedocument.presentationml.template" to database
Added mimetype "application/vnd.ms-powerpoint.addin.macroEnabled.12" to database
Added mimetype "application/vnd.ms-powerpoint.slideshow.macroEnabled.12" to database
Added mimetype "application/vnd.openxmlformats-officedocument.presentationml.slideshow" to database
Added mimetype "application/vnd.ms-powerpoint.presentation.macroEnabled.12" to database
Added mimetype "text/reveal" to database
Added mimetype "application/rss+xml" to database
Added mimetype "text/rtf" to database
Added mimetype "application/sgf" to database
Added mimetype "image/sgi" to database
Added mimetype "application/x-shockwave-flash" to database
Added mimetype "application/x-compressed" to database
Added mimetype "application/x-tar" to database
Added mimetype "application/vnd.garmin.tcx+xml" to database
Added mimetype "application/x-tex" to database
Added mimetype "image/tga" to database
Added mimetype "image/tiff" to database
Added mimetype "application/internet-shortcut" to database
Added mimetype "text/vcard" to database
Added mimetype "video/dvd" to database
Added mimetype "application/vnd.visio" to database
Added mimetype "application/vnd.ms-visio.drawing.macroEnabled.12" to database
Added mimetype "application/vnd.ms-visio.drawing" to database
Added mimetype "application/vnd.ms-visio.stencil.macroEnabled.12" to database
Added mimetype "application/vnd.ms-visio.stencil" to database
Added mimetype "application/vnd.ms-visio.template.macroEnabled.12" to database
Added mimetype "application/vnd.ms-visio.template" to database
Added mimetype "audio/wav" to database
Added mimetype "video/webm" to database
Added mimetype "image/webp" to database
Added mimetype "application/font-woff" to database
Added mimetype "application/vnd.wordperfect" to database
Added mimetype "application/x-gimp" to database
Added mimetype "application/vnd.ms-excel.addin.macroEnabled.12" to database
Added mimetype "application/vnd.ms-excel.sheet.binary.macroEnabled.12" to database
Added mimetype "application/vnd.ms-excel.sheet.macroEnabled.12" to database
Added mimetype "application/vnd.ms-excel.template.macroEnabled.12" to database
Added mimetype "application/vnd.openxmlformats-officedocument.spreadsheetml.template" to database
Added mimetype "application/vnd.xmind.workbook" to database
Added mimetype "application/yaml" to database
Added 117 new mimetypes
Updated 0 filecache rows
Waiting for database to start...
              now
 2023-05-12 22:47:32.365053+02
(1 row)
+ '[' -n '' ']'
+ set +x
System config value tempdirectory set to string /mnt/ncdata/tmp/
Applying one-click-instance settings...
System config value one-click-instance set to boolean true
System config value one-click-instance.user-limit set to integer 100
System config value one-click-instance.link set to string https://nextcloud.com/all-in-one/
support already enabled
Adjusting log files...
System config value logfile set to string /var/www/html/data/nextcloud.log
Config value logfile for app admin_audit set to /var/www/html/data/audit.log
System config value updatedirectory set to string /nc-updater
Applying network settings...
System config value trusted_domains => 1 set to string atizd.duckdns.org
System config value overwrite.cli.url set to string https://atizd.duckdns.org/
System config value htaccess.RewriteBase set to string /
.htaccess has been updated
System config value files_external_allow_create_new_local set to boolean false
System config value trusted_proxies => 0 set to string 127.0.0.1
System config value trusted_proxies => 1 set to string ::1
Config value base_endpoint for app notify_push set to https://atizd.duckdns.org/push
Config value wopi_url for app richdocuments set to https://atizd.duckdns.org/
System config value allow_local_remote_servers set to boolean true
No ipv6-address found for atizd.duckdns.org.
Config value wopi_allowlist for app richdocuments set to 78.2.176.148,127.0.0.1/8,192.168.0.0/16,172.16.0.0/12,10.0.0.0/8,fd00::/8,::1,109.60.102.198,109.60.100.66,213.149.61.33
Added atizd.duckdns.org:3478.
There is nothing to delete.
System config value enabledPreviewProviders => 0 set to string OC\Preview\Imaginary
System config value preview_imaginary_url set to string http://nextcloud-aio-imaginary:9000
[12-May-2023 23:04:52] NOTICE: fpm is running, pid 607
[12-May-2023 23:04:52] NOTICE: ready to handle connections
[2023-05-12 23:07:03.751252 +02:00] ERROR [notify_push] src/main.rs:77: Self test failed: Error while communicating with nextcloud instance
              now
 2023-05-13 11:33:59.566152+02
(1 row)
+ '[' -n '' ']'
+ set +x
[13-May-2023 11:50:19] NOTICE: fpm is running, pid 574
[13-May-2023 11:50:19] NOTICE: ready to handle connections
[2023-05-13 11:52:30.354982 +02:00] ERROR [notify_push] src/main.rs:77: Self test failed: Error while communicating with nextcloud instance
              now
 2023-05-13 12:47:54.061084+02
(1 row)
+ '[' -n '' ']'
+ set +x
[13-May-2023 13:04:14] NOTICE: fpm is running, pid 578
[13-May-2023 13:04:14] NOTICE: ready to handle connections
[2023-05-13 13:06:25.355268 +02:00] ERROR [notify_push] src/main.rs:77: Self test failed: Error while communicating with nextcloud instance
logs from nextcloud/aio-talk:latest
sudo docker logs 7c0f6a48d671
++ dig nextcloud-aio-talk A +short
+ IPv4_ADDRESS_TALK=172.22.0.4
+ set +x
Janus version: 1103 (1.1.3)
Janus commit: not-a-git-repo
Compiled on:  Sat Mar 11 10:37:39 UTC 2023
Adding 1 external loggers
Logger plugins folder: /usr/lib/janus/loggers
Loading logger plugin 'libjanus_jsonlog.so'...
[WARN] JSON logger disabled
  Starting Meetecho Janus (WebRTC Server) v1.1.3
Checking command line arguments...
Debug/log level is 4
Debug/log timestamps are disabled
Debug/log colors are disabled
Adding 'vmnet' to the ICE ignore list...
Using 172.22.0.4 as local IP...
Token based authentication disabled
Initializing recorder code
Initializing ICE stuff (Full mode, ICE-TCP candidates disabled, half-trickle, IPv6 support disabled)
TURN REST API backend: (disabled)
[WARN] Janus is deployed on a private address (172.22.0.4) but you didn't specify any STUN server! Expect trouble if this is supposed to work over the internet and not just in a LAN...
Crypto: OpenSSL >= 1.1.0
[WARN] The libsrtp installation does not support AES-GCM profiles
No cert/key specified, autogenerating some...
Fingerprint of our certificate: DF:77:00:BC:6B:C1:25:D5:85:A4:6D:50:48:CA:A9:E7:D8:7E:8C:2C:E6:AA:9F:F4:A7:C3:46:33:7E:9E:4D:33
main.go:133: Starting up version de701dbcae52c77f3f98634cb9a61b15f79674ed/go1.20.2 as pid 17
main.go:142: Using a maximum of 2 CPUs
natsclient.go:93: Could not create connection (nats: no servers available for connection), will retry in 1s
Event handlers support disabled
Plugins folder: /usr/lib/janus/plugins
Loading plugin 'libjanus_sip.so'...
[16] 2023/05/12 22:35:44.987250 [INF] Starting nats-server
[16] 2023/05/12 22:35:44.987311 [INF]   Version:  2.9.16
[16] 2023/05/12 22:35:44.987313 [INF]   Git:      [f84ca24]
[16] 2023/05/12 22:35:44.987315 [INF]   Name:     NCAPFRI4XMGVYZADCLSMFN5KX5R44SNW4DXXINB5YNLVI7M2VIBY2JPB
[16] 2023/05/12 22:35:44.987317 [INF]   ID:       NCAPFRI4XMGVYZADCLSMFN5KX5R44SNW4DXXINB5YNLVI7M2VIBY2JPB
[16] 2023/05/12 22:35:44.987322 [INF] Using configuration file: /etc/nats.conf
0: (18): INFO: System cpu num is 2
0: (18): INFO: log file opened: /var/tmp/turn_18_2023-05-12.log
0: (18): INFO: System enable num is 2
0: (18): INFO: 0 bytes per second allowed, combined server capacity
0: (18): INFO: White listing: 172.22.0.4
0: (18): INFO: Black listing: 0.0.0.0-0.255.255.255
0: (18): INFO: Black listing: 10.0.0.0-10.255.255.255
0: (18): INFO: Black listing: 100.64.0.0-100.127.255.255
0: (18): INFO: Black listing: 127.0.0.0-127.255.255.255
0: (18): INFO: Black listing: 169.254.0.0-169.254.255.255
0: (18): INFO: Black listing: 172.16.0.0-172.31.255.255
0: (18): INFO: Black listing: 192.0.0.0-192.0.0.255
0: (18): INFO: Black listing: 192.0.2.0-192.0.2.255
0: (18): INFO: Black listing: 192.88.99.0-192.88.99.255
0: (18): INFO: Black listing: 192.168.0.0-192.168.255.255
0: (18): INFO: Black listing: 198.18.0.0-198.19.255.255
0: (18): INFO: Black listing: 198.51.100.0-198.51.100.255
0: (18): INFO: Black listing: 203.0.113.0-203.0.113.255
0: (18): INFO: Black listing: 240.0.0.0-255.255.255.255
0: (18): INFO: Coturn Version Coturn-4.6.2 'Gorst'
0: (18): INFO: Max number of open files/sockets allowed for this process: 200000
0: (18): INFO: Due to the open files/sockets limitation, max supported number of TURN Sessions possible is: 100000 (approximately)
0: (18): INFO:
==== Show him the instruments, Practical Frost: ====
0: (18): INFO: OpenSSL compile-time version: OpenSSL 3.0.8 7 Feb 2023 (0x30000080)
0: (18): INFO: TLS 1.3 supported
0: (18): INFO: DTLS 1.2 supported
0: (18): INFO: TURN/STUN ALPN supported
0: (18): INFO: Third-party authorization (oAuth) supported
0: (18): INFO: GCM (AEAD) supported
0: (18): INFO: SQLite supported, default database location is /var/lib/coturn/turndb
0: (18): INFO: Redis supported
0: (18): INFO: PostgreSQL supported
0: (18): INFO: MySQL supported
0: (18): INFO: MongoDB supported
0: (18): INFO: Default Net Engine version: 3 (UDP thread per CPU core)
0: (18): INFO: Domain name:
0: (18): INFO: Default realm: atizd.duckdns.org
0: (18): ERROR: CONFIG: Empty cli-password, and so telnet cli interface is disabled! Please set a non empty cli-password!
Joining Janus requests handler thread
0: (18): INFO: Certificate file found: //turn_server_cert.pem
0: (18): INFO: Private key file found: //turn_server_pkey.pem
0: (18): WARNING: NO EXPLICIT LISTENER ADDRESS(ES) ARE CONFIGURED
0: (18): INFO: ===========Discovering listener addresses: =========
0: (18): INFO: Listener address to use: 127.0.0.1
0: (18): INFO: Listener address to use: 172.22.0.4
0: (18): INFO: =====================================================
0: (18): INFO: Total: 1 'real' addresses discovered
0: (18): WARNING: NO EXPLICIT RELAY ADDRESS(ES) ARE CONFIGURED
0: (18): INFO: ===========Discovering relay addresses: =============
0: (18): INFO: Relay address to use: 172.22.0.4
0: (18): INFO: Total: 1 relay addresses discovered
0: (18): INFO: pid file created: /var/tmp/turnserver.pid
0: (18): INFO: IO method: epoll (with changelist)
[16] 2023/05/12 22:35:45.000480 [INF] Listening for client connections on 127.0.0.1:4222
[16] 2023/05/12 22:35:45.001489 [INF] Server is ready
Sessions watchdog started
JANUS SIP plugin initialized!
Loading plugin 'libjanus_videoroom.so'...
JANUS VideoRoom plugin initialized!
Loading plugin 'libjanus_lua.so'...
[echotest.lua] Loading...
[echotest.lua] Loaded
[echotest.lua] Initializing...
[echotest.lua] Initialized
Janus Lua plugin initialized!
Loading plugin 'libjanus_duktape.so'...
[echotest.js]  Loading script...
[echotest.js]  Modules folder: /usr/share/janus/duktape
[echotest.js]  Loading module: janus-sdp
[echotest.js]  Module loaded
[echotest.js]  Script loaded
[echotest.js]  Initializing...
[echotest.js]  Initialized
Janus JavaScript plugin (Duktape) initialized!
Loading plugin 'libjanus_textroom.so'...
JANUS TextRoom plugin initialized!
Loading plugin 'libjanus_echotest.so'...
JANUS EchoTest plugin initialized!
Loading plugin 'libjanus_audiobridge.so'...
JANUS AudioBridge plugin initialized!
Loading plugin 'libjanus_streaming.so'...
JANUS Streaming plugin initialized!
Loading plugin 'libjanus_nosip.so'...
JANUS NoSIP plugin initialized!
Loading plugin 'libjanus_recordplay.so'...
JANUS Record&Play plugin initialized!
Loading plugin 'libjanus_videocall.so'...
JANUS VideoCall plugin initialized!
Transport plugins folder: /usr/lib/janus/transports
Loading transport plugin 'libjanus_websockets.so'...
libwebsockets logging: 0
Websockets server started (port 8188)...
JANUS WebSockets transport plugin initialized!
Loading transport plugin 'libjanus_pfunix.so'...
[WARN] No Unix Sockets server started, giving up...
[WARN] The 'janus.transport.pfunix' plugin could not be initialized
Loading transport plugin 'libjanus_mqtt.so'...
MQTT SSL support disabled
[WARN] MQTT support disabled for both Janus and Admin API, giving up
JANUS MQTT transport plugin destroyed!
[WARN] The 'janus.transport.mqtt' plugin could not be initialized
Loading transport plugin 'libjanus_nanomsg.so'...
JANUS Nanomsg transport plugin initialized!
Loading transport plugin 'libjanus_rabbitmq.so'...
WebSockets thread started
RabbitMQ SSL support disabled
[WARN] RabbitMQ support disabled for both Janus and Admin API, giving up
[WARN] The 'janus.transport.rabbitmq' plugin could not be initialized
Loading transport plugin 'libjanus_http.so'...
HTTP webserver started (port 8088, /janus path listener)...
JANUS REST (HTTP/HTTPS) transport plugin initialized!
Nanomsg thread started
HTTP transport timer started
natsclient.go:108: Connection established to nats://127.0.0.1:4222 (NCAPFRI4XMGVYZADCLSMFN5KX5R44SNW4DXXINB5YNLVI7M2VIBY2JPB)
grpc_common.go:167: WARNING: No GRPC server certificate and/or key configured, running unencrypted
grpc_common.go:169: WARNING: No GRPC CA configured, expecting unencrypted connections
backend_storage_static.go:72: Backend backend-1 added for https://atizd.duckdns.org/
hub.go:200: Using a maximum of 8 concurrent backend connections per host
hub.go:207: Using a timeout of 10s for backend connections
hub.go:303: Not using GeoIP database
Creating new session: 4043043209527552; 0x7f8df6ff45a0
Creating new handle in session 4043043209527552: 4273604225936235; 0x7f8df6ff45a0 0x7f8df7927630
mcu_janus.go:294: Connected to Janus WebRTC Server 1.1.3 by Meetecho s.r.l.
mcu_janus.go:300: Found JANUS VideoRoom plugin 0.0.9 by Meetecho s.r.l.
mcu_janus.go:305: Data channels are supported
mcu_janus.go:307: WARNING: Full-Trickle is NOT enabled in Janus!
mcu_janus.go:311: Maximum bandwidth 1048576 bits/sec per publishing stream
mcu_janus.go:312: Maximum bandwidth 2097152 bits/sec per screensharing stream
mcu_janus.go:318: Created Janus session 4043043209527552
mcu_janus.go:325: Created Janus handle 4273604225936235
main.go:263: Using janus MCU
hub.go:385: Using a timeout of 10s for MCU requests
backend_server.go:105: No IPs configured for the stats endpoint, only allowing access from 127.0.0.1
main.go:339: Listening on 0.0.0.0:8081
+ IPv4_ADDRESS_TALK=172.22.0.6
+ set +x
[15] 2023/05/12 22:47:27.053999 [INF] Starting nats-server
[15] 2023/05/12 22:47:27.054071 [INF]   Version:  2.9.16
[15] 2023/05/12 22:47:27.054074 [INF]   Git:      [f84ca24]
[15] 2023/05/12 22:47:27.054077 [INF]   Name:     NB3MSMFYPIBGEW6WUSY44Q2Q77LVEOLRKI7E4XOMIXBUEG5APNH6D4B7
[15] 2023/05/12 22:47:27.054083 [INF]   ID:       NB3MSMFYPIBGEW6WUSY44Q2Q77LVEOLRKI7E4XOMIXBUEG5APNH6D4B7
[15] 2023/05/12 22:47:27.054091 [INF] Using configuration file: /etc/nats.conf
[15] 2023/05/12 22:47:27.064703 [INF] Listening for client connections on 127.0.0.1:4222
[15] 2023/05/12 22:47:27.064722 [INF] Server is ready
Using 172.22.0.6 as local IP...
[WARN] Janus is deployed on a private address (172.22.0.6) but you didn't specify any STUN server! Expect trouble if this is supposed to work over the internet and not just in a LAN...
0: (17): INFO: System cpu num is 2
0: (17): INFO: log file opened: /var/tmp/turn_17_2023-05-12.log
0: (17): INFO: System enable num is 2
0: (17): INFO: 0 bytes per second allowed, combined server capacity
0: (17): INFO: White listing: 172.22.0.6
0: (17): INFO: Black listing: 0.0.0.0-0.255.255.255
0: (17): INFO: Black listing: 10.0.0.0-10.255.255.255
0: (17): INFO: Black listing: 100.64.0.0-100.127.255.255
0: (17): INFO: Black listing: 127.0.0.0-127.255.255.255
0: (17): INFO: Black listing: 169.254.0.0-169.254.255.255
0: (17): INFO: Black listing: 172.16.0.0-172.31.255.255
0: (17): INFO: Black listing: 192.0.0.0-192.0.0.255
0: (17): INFO: Black listing: 192.0.2.0-192.0.2.255
0: (17): INFO: Black listing: 192.88.99.0-192.88.99.255
0: (17): INFO: Black listing: 192.168.0.0-192.168.255.255
0: (17): INFO: Black listing: 198.18.0.0-198.19.255.255
0: (17): INFO: Black listing: 198.51.100.0-198.51.100.255
0: (17): INFO: Black listing: 203.0.113.0-203.0.113.255
0: (17): INFO: Black listing: 240.0.0.0-255.255.255.255
0: (17): INFO: Coturn Version Coturn-4.6.2 'Gorst'
0: (17): INFO: Max number of open files/sockets allowed for this process: 200000
0: (17): INFO: Due to the open files/sockets limitation, max supported number of TURN Sessions possible is: 100000 (approximately)
0: (17): INFO:
0: (17): INFO: OpenSSL compile-time version: OpenSSL 3.0.8 7 Feb 2023 (0x30000080)
0: (17): INFO: TLS 1.3 supported
0: (17): INFO: DTLS 1.2 supported
0: (17): INFO: TURN/STUN ALPN supported
0: (17): INFO: Third-party authorization (oAuth) supported
0: (17): INFO: GCM (AEAD) supported
0: (17): INFO: SQLite supported, default database location is /var/lib/coturn/turndb
0: (17): INFO: Redis supported
0: (17): INFO: PostgreSQL supported
0: (17): INFO: MySQL supported
0: (17): INFO: MongoDB supported
0: (17): INFO: Default Net Engine version: 3 (UDP thread per CPU core)
0: (17): INFO: Domain name:
0: (17): INFO: Default realm: atizd.duckdns.org
0: (17): ERROR: CONFIG: Empty cli-password, and so telnet cli interface is disabled! Please set a non empty cli-password!
0: (17): INFO: Certificate file found: //turn_server_cert.pem
0: (17): INFO: Private key file found: //turn_server_pkey.pem
0: (17): WARNING: NO EXPLICIT LISTENER ADDRESS(ES) ARE CONFIGURED
0: (17): INFO: ===========Discovering listener addresses: =========
0: (17): INFO: Listener address to use: 127.0.0.1
0: (17): INFO: Listener address to use: 172.22.0.6
0: (17): INFO: =====================================================
0: (17): INFO: Total: 1 'real' addresses discovered
0: (17): WARNING: NO EXPLICIT RELAY ADDRESS(ES) ARE CONFIGURED
0: (17): INFO: ===========Discovering relay addresses: =============
0: (17): INFO: Relay address to use: 172.22.0.6
0: (17): INFO: Total: 1 relay addresses discovered
0: (17): INFO: pid file created: /var/tmp/turnserver.pid
0: (17): INFO: IO method: epoll (with changelist)
Fingerprint of our certificate: C2:93:CC:FB:82:22:41:AA:55:8A:54:15:6F:DF:30:35:B7:2B:02:33:C1:63:8B:66:9F:02:B2:B6:78:6B:51:20
main.go:133: Starting up version de701dbcae52c77f3f98634cb9a61b15f79674ed/go1.20.2 as pid 16
natsclient.go:108: Connection established to nats://127.0.0.1:4222 (NB3MSMFYPIBGEW6WUSY44Q2Q77LVEOLRKI7E4XOMIXBUEG5APNH6D4B7)
main.go:228: Could not initialize janus MCU (dial tcp 127.0.0.1:8188: connect: connection refused) will retry in 1s
Creating new session: 2174089620293442; 0x7f6da661a5a0
mcu_janus.go:318: Created Janus session 2174089620293442
Creating new handle in session 2174089620293442: 8703256691687975; 0x7f6da661a5a0 0x7f6da6f4ce60
mcu_janus.go:325: Created Janus handle 8703256691687975
+ IPv4_ADDRESS_TALK=172.22.0.8
+ set +x
[15] 2023/05/13 11:33:54.856211 [INF] Starting nats-server
[15] 2023/05/13 11:33:54.856278 [INF]   Version:  2.9.16
[15] 2023/05/13 11:33:54.856281 [INF]   Git:      [f84ca24]
[15] 2023/05/13 11:33:54.856283 [INF]   Name:     NDR7REOZZBTJCYKS5PWXIXMDSUPPUOEZZ7VFBKQDFNSRRBZAQZ4MY2VN
[15] 2023/05/13 11:33:54.856288 [INF]   ID:       NDR7REOZZBTJCYKS5PWXIXMDSUPPUOEZZ7VFBKQDFNSRRBZAQZ4MY2VN
[15] 2023/05/13 11:33:54.856306 [INF] Using configuration file: /etc/nats.conf
[15] 2023/05/13 11:33:54.863925 [INF] Listening for client connections on 127.0.0.1:4222
[15] 2023/05/13 11:33:54.863944 [INF] Server is ready
0: (17): INFO: log file opened: /var/tmp/turn_17_2023-05-13.log
0: (17): INFO: White listing: 172.22.0.8
0: (17): INFO:
Using 172.22.0.8 as local IP...
[WARN] Janus is deployed on a private address (172.22.0.8) but you didn't specify any STUN server! Expect trouble if this is supposed to work over the internet and not just in a LAN...
0: (17): INFO: Listener address to use: 172.22.0.8
0: (17): INFO: Relay address to use: 172.22.0.8
Fingerprint of our certificate: E1:D7:3C:62:62:2F:BE:A8:B4:5F:44:8A:D5:59:27:4D:4C:8E:C0:28:DF:37:AF:10:DB:71:58:57:D3:63:34:D0
natsclient.go:108: Connection established to nats://127.0.0.1:4222 (NDR7REOZZBTJCYKS5PWXIXMDSUPPUOEZZ7VFBKQDFNSRRBZAQZ4MY2VN)
Creating new session: 4545864547627168; 0x7f17868ca5a0
Creating new handle in session 4545864547627168: 2400046441248817; 0x7f17868ca5a0 0x7f17871fde60
mcu_janus.go:318: Created Janus session 4545864547627168
mcu_janus.go:325: Created Janus handle 2400046441248817
+ IPv4_ADDRESS_TALK=172.22.0.3
+ set +x
0: (17): INFO: White listing: 172.22.0.3
0: (17): INFO:
[15] 2023/05/13 12:47:50.448130 [INF] Starting nats-server
[15] 2023/05/13 12:47:50.448218 [INF]   Version:  2.9.16
[15] 2023/05/13 12:47:50.448221 [INF]   Git:      [f84ca24]
[15] 2023/05/13 12:47:50.448225 [INF]   Name:     NBMJPGQDKY7WJFUFJ4GTXCA7BLMSVNMQBVWZBDYXF2EWKOLNTDFIW246
[15] 2023/05/13 12:47:50.448228 [INF]   ID:       NBMJPGQDKY7WJFUFJ4GTXCA7BLMSVNMQBVWZBDYXF2EWKOLNTDFIW246
[15] 2023/05/13 12:47:50.448237 [INF] Using configuration file: /etc/nats.conf
[15] 2023/05/13 12:47:50.454273 [INF] Listening for client connections on 127.0.0.1:4222
[15] 2023/05/13 12:47:50.454293 [INF] Server is ready
0: (17): INFO: Listener address to use: 172.22.0.3
0: (17): INFO: Relay address to use: 172.22.0.3
Using 172.22.0.3 as local IP...
[WARN] Janus is deployed on a private address (172.22.0.3) but you didn't specify any STUN server! Expect trouble if this is supposed to work over the internet and not just in a LAN...
Fingerprint of our certificate: AF:B9:68:FB:58:1C:3B:A8:8D:42:0A:19:E2:70:B4:B5:ED:1A:26:1E:B2:B9:F2:EE:CF:BC:C7:6E:38:CA:59:43
natsclient.go:108: Connection established to nats://127.0.0.1:4222 (NBMJPGQDKY7WJFUFJ4GTXCA7BLMSVNMQBVWZBDYXF2EWKOLNTDFIW246)
Creating new session: 4137525687366793; 0x7f2b834575a0
mcu_janus.go:318: Created Janus session 4137525687366793
Creating new handle in session 4137525687366793: 7446612535042422; 0x7f2b834575a0 0x7f2b83d89e60
mcu_janus.go:325: Created Janus handle 7446612535042422
I see. Can you follow How to debug performance issues with Nextcloud? · nextcloud/all-in-one · Discussion #2475 · GitHub then?
i tried this
~$ sudo docker exec --user www-data -it nextcloud-aio-nextcloud php occ config:system:set auth.bruteforce.protection.enabled --type bool --value=true
System config value auth.bruteforce.protection.enabled set to boolean true
~$ sudo docker exec --user www-data -it nextcloud-aio-nextcloud php occ config:system:set ratelimit.protection.enabled --type bool --value=true
and it was not helpfull, apache and netxtcould were yellow (running) for 10 mintes and after 20 minutes they went green, but still 100% packet loss, apache still unhealty
i still get this log for apache
{"level":"info","ts":1684001046.1448395,"msg":"using provided configuration","config_file":"/Caddyfile","config_adapter":""}
[Sat May 13 20:04:06.161515 2023] [mpm_event:notice] [pid 641:tid 139762583874376] AH00489: Apache/2.4.57 (Unix) configured -- resuming normal operations
[Sat May 13 20:04:06.161577 2023] [core:notice] [pid 641:tid 139762583874376] AH00094: Command line: '/usr/local/apache2/bin/httpd -D FOREGROUND'
and this error for aio-nextcloud
[2023-05-13 20:06:14.254997 +02:00] ERROR [notify_push] src/main.rs:77: Self test failed: Error while communicating with nextcloud instance
The errors in the logs are unrelated.
What is the output of sudo docker inspect nextcloud-aio-apache ?
~$ sudo docker inspect nextcloud-aio-apache
[sudo] password for ati:
        "Id": "7e7abc09b6eed835edb8ccceda1f8732cd37c0f62d1a9f6e9a183025b4bd2205",
        "Created": "2023-05-12T20:37:35.625874621Z",
        "Path": "start.sh",
        "Args": [
            "/usr/bin/supervisord",
            "-c",
            "/supervisord.conf"
        "State": {
            "Status": "running",
            "Running": true,
            "Paused": false,
            "Restarting": false,
            "OOMKilled": false,
            "Dead": false,
            "Pid": 2774,
            "ExitCode": 0,
            "Error": "",
            "StartedAt": "2023-05-13T17:47:38.983882381Z",
            "FinishedAt": "2023-05-13T19:47:32.320405502+02:00",
            "Health": {
                "Status": "unhealthy",
                "FailingStreak": 150,
                "Log": [
                        "Start": "2023-05-13T22:29:13.878644013+02:00",
                        "End": "2023-05-13T22:29:43.879661524+02:00",
                        "ExitCode": -1,
                        "Output": "Health check exceeded timeout (30s)"
                        "Start": "2023-05-13T22:30:13.895422889+02:00",
                        "End": "2023-05-13T22:30:43.895790792+02:00",
                        "ExitCode": -1,
                        "Start": "2023-05-13T22:31:13.912018974+02:00",
                        "End": "2023-05-13T22:31:43.912793231+02:00",
                        "ExitCode": -1,
                        "Start": "2023-05-13T22:32:13.929504931+02:00",
                        "End": "2023-05-13T22:32:43.929656384+02:00",
                        "ExitCode": -1,
                        "Start": "2023-05-13T22:33:13.936894289+02:00",
                        "End": "2023-05-13T22:33:43.937928405+02:00",
                        "ExitCode": -1,
        "Image": "sha256:4dc5a89216f42dd08e58012503290bdfd6cbc1039ffba3f8e9bf2f0b233e657b",
        "ResolvConfPath": "/var/snap/docker/common/var-lib-docker/containers/7e7abc09b6eed835edb8ccceda1f8732cd37c0f62d1a9f6e9a183025b4bd2205/resolv.conf",
        "HostnamePath": "/var/snap/docker/common/var-lib-docker/containers/7e7abc09b6eed835edb8ccceda1f8732cd37c0f62d1a9f6e9a183025b4bd2205/hostname",
        "HostsPath": "/var/snap/docker/common/var-lib-docker/containers/7e7abc09b6eed835edb8ccceda1f8732cd37c0f62d1a9f6e9a183025b4bd2205/hosts",
        "LogPath": "/var/snap/docker/common/var-lib-docker/containers/7e7abc09b6eed835edb8ccceda1f8732cd37c0f62d1a9f6e9a183025b4bd2205/7e7abc09b6eed835edb8ccceda1f8732cd37c0f62d1a9f6e9a183025b4bd2205-json.log",
        "Name": "/nextcloud-aio-apache",
        "RestartCount": 0,
        "Driver": "overlay2",
        "Platform": "linux",
        "MountLabel": "",
        "ProcessLabel": "",
        "AppArmorProfile": "docker-default",
        "ExecIDs": [
            "a33a3058876f0c0996b01bd12acba27fba1df283d7f01fe25be4d68f5519a8b2"
        "HostConfig": {
            "Binds": [
                "nextcloud_aio_nextcloud:/var/www/html:ro",
                "nextcloud_aio_apache:/mnt/data:rw"
            "ContainerIDFile": "",
            "LogConfig": {
                "Type": "json-file",
                "Config": {}
            "NetworkMode": "nextcloud-aio",
            "PortBindings": {
                "11000/tcp": [
                        "HostIp": "0.0.0.0",
                        "HostPort": "11000"
            "RestartPolicy": {
                "Name": "unless-stopped",
                "MaximumRetryCount": 0
            "AutoRemove": false,
            "VolumeDriver": "",
            "VolumesFrom": null,
            "CapAdd": null,
            "CapDrop": null,
            "CgroupnsMode": "private",
            "Dns": [],
            "DnsOptions": [],
            "DnsSearch": [],
            "ExtraHosts": null,
            "GroupAdd": null,
            "IpcMode": "private",
            "Cgroup": "",
            "Links": null,
            "OomScoreAdj": 0,
            "PidMode": "",
            "Privileged": false,
            "PublishAllPorts": false,
            "ReadonlyRootfs": false,
            "SecurityOpt": null,
            "UTSMode": "",
            "UsernsMode": "",
            "ShmSize": 67108864,
            "Runtime": "runc",
            "ConsoleSize": [
                0,
                0
            "Isolation": "",
            "CpuShares": 0,
            "Memory": 0,
            "NanoCpus": 0,
            "CgroupParent": "",
            "BlkioWeight": 0,
            "BlkioWeightDevice": null,
            "BlkioDeviceReadBps": null,
            "BlkioDeviceWriteBps": null,
            "BlkioDeviceReadIOps": null,
            "BlkioDeviceWriteIOps": null,
            "CpuPeriod": 0,
            "CpuQuota": 0,
            "CpuRealtimePeriod": 0,
            "CpuRealtimeRuntime": 0,
            "CpusetCpus": "",
            "CpusetMems": "",
            "Devices": null,
            "DeviceCgroupRules": null,
            "DeviceRequests": null,
            "KernelMemory": 0,
            "KernelMemoryTCP": 0,
            "MemoryReservation": 0,
            "MemorySwap": 0,
            "MemorySwappiness": null,
            "OomKillDisable": null,
            "PidsLimit": null,
            "Ulimits": null,
            "CpuCount": 0,
            "CpuPercent": 0,
            "IOMaximumIOps": 0,
            "IOMaximumBandwidth": 0,
            "MaskedPaths": [
                "/proc/asound",
                "/proc/acpi",
                "/proc/kcore",
                "/proc/keys",
                "/proc/latency_stats",
                "/proc/timer_list",
                "/proc/timer_stats",
                "/proc/sched_debug",
                "/proc/scsi",
                "/sys/firmware"
            "ReadonlyPaths": [
                "/proc/bus",
                "/proc/fs",
                "/proc/irq",
                "/proc/sys",
                "/proc/sysrq-trigger"
        "GraphDriver": {
            "Data": {
                "LowerDir": "/var/snap/docker/common/var-lib-docker/overlay2/6f698ae965c0d09e8ac4fef1e8c0c6a724d94686814eb77be9ef875501ffaa30-init/diff:/var/snap/docker/common/var-lib-docker/overlay2/61f59913d76783af6645ff6554bc1d30039855093e010a45817e90287ef88104/diff:/var/snap/docker/common/var-lib-docker/overlay2/b79c0d34c3dfcb167894aca7c6f3f6d64e23a4a02a5edeb11e16c79b2f20f40b/diff:/var/snap/docker/common/var-lib-docker/overlay2/de0841e1e2c0bfe8d48d0af82d761d7705f105535961baeccf0abbc8fcd55e68/diff:/var/snap/docker/common/var-lib-docker/overlay2/146c113eaca901f90908a05794fef1591ce4749cef9595695e4d50dd99e4b302/diff:/var/snap/docker/common/var-lib-docker/overlay2/cd524ac4b069259d58ceea7f80d6e5f06e5d27565c2a2e4dd47a1c560b0fa6ac/diff:/var/snap/docker/common/var-lib-docker/overlay2/85cef07d2088d2586ca6732bfaa43ec48373a24bb2c9d055419e0c402c2eda4e/diff:/var/snap/docker/common/var-lib-docker/overlay2/5de7e30ed62fce77d9f54d84f391ce8a2f3c432e87fa1e99ee81a3f998987a07/diff:/var/snap/docker/common/var-lib-docker/overlay2/9ee1673d4ac72936fef93d36c3633df0269bc389b6b2447e6506019038f7156d/diff:/var/snap/docker/common/var-lib-docker/overlay2/e441fc955b355eadd0b083974f9df61a6169992e99e0dbc9cec4cbb355c713d6/diff:/var/snap/docker/common/var-lib-docker/overlay2/ca55a516ca92b6ccb3bc929ffb8c4be579d6d6904be90536185ffa2c1a469c6c/diff:/var/snap/docker/common/var-lib-docker/overlay2/cc788188ff919fb16b92855dc30e532016cb3e6906fdbf96df127b8b2e74ed3f/diff:/var/snap/docker/common/var-lib-docker/overlay2/8e8129917f05fff8c67457f55aba7b3c6d24921ab7779409a714201ef01e8930/diff:/var/snap/docker/common/var-lib-docker/overlay2/2eddd441caae5862c15806372f47626b863da62d966c4dec34b20bd1616077ef/diff:/var/snap/docker/common/var-lib-docker/overlay2/b0cb0400c1ba18a0878f7324b2ffe4eb9a936264352cc80e93994104e8a4dcda/diff:/var/snap/docker/common/var-lib-docker/overlay2/f1cbef633f4ae52b4b6f556c7f58ffe7542a9eccc159564419863bb46c27f1fe/diff:/var/snap/docker/common/var-lib-docker/overlay2/612fac9b932a37d0476ac049df882f26559c2499c2fcc83b24d36143660b9dc1/diff:/var/snap/docker/common/var-lib-docker/overlay2/084ebd271f2ebeb0a55eb61e0954465d941d70e00e2373d6bd33bf05defded9c/diff:/var/snap/docker/common/var-lib-docker/overlay2/72daaeb3658f6d594e8cecfb5ccb20b678bbf5381fecc9c05a27c8a976373f06/diff:/var/snap/docker/common/var-lib-docker/overlay2/f5476a6fd032096618c75e16f6baf72f79d223e3e635a818f135084ecbc3c67c/diff:/var/snap/docker/common/var-lib-docker/overlay2/316ea99a45e8eff7d6cfb5bc601ae3bd439cb82b2adedcbbd6acc9e6c356646c/diff:/var/snap/docker/common/var-lib-docker/overlay2/a1095b15684a6335abe12ae4661d694528a77db123eb30d88a81d8609c2ac9b7/diff",
                "MergedDir": "/var/snap/docker/common/var-lib-docker/overlay2/6f698ae965c0d09e8ac4fef1e8c0c6a724d94686814eb77be9ef875501ffaa30/merged",
                "UpperDir": "/var/snap/docker/common/var-lib-docker/overlay2/6f698ae965c0d09e8ac4fef1e8c0c6a724d94686814eb77be9ef875501ffaa30/diff",
                "WorkDir": "/var/snap/docker/common/var-lib-docker/overlay2/6f698ae965c0d09e8ac4fef1e8c0c6a724d94686814eb77be9ef875501ffaa30/work"
            "Name": "overlay2"
        "Mounts": [
                "Type": "volume",
                "Name": "nextcloud_aio_apache",
                "Source": "/var/snap/docker/common/var-lib-docker/volumes/nextcloud_aio_apache/_data",
                "Destination": "/mnt/data",
                "Driver": "local",
                "Mode": "rw",
                "RW": true,
                "Propagation": ""
                "Type": "volume",
                "Name": "nextcloud_aio_nextcloud",
                "Source": "/var/snap/docker/common/var-lib-docker/volumes/nextcloud_aio_nextcloud/_data",
                "Destination": "/var/www/html",
                "Driver": "local",
                "Mode": "ro",
                "RW": false,
                "Propagation": ""
        "Config": {
            "Hostname": "7e7abc09b6ee",
            "Domainname": "",
            "User": "www-data",
            "AttachStdin": false,
            "AttachStdout": false,
            "AttachStderr": false,
            "ExposedPorts": {
                "11000/tcp": {},
                "80/tcp": {}
            "Tty": false,
            "OpenStdin": false,
            "StdinOnce": false,
            "Env": [
                "NC_DOMAIN=atizd.duckdns.org",
                "NEXTCLOUD_HOST=nextcloud-aio-nextcloud",
                "COLLABORA_HOST=nextcloud-aio-collabora",
                "TALK_HOST=nextcloud-aio-talk",
                "APACHE_PORT=11000",
                "ONLYOFFICE_HOST=nextcloud-aio-onlyoffice",
                "TZ=Europe/Zagreb",
                "APACHE_MAX_SIZE=10737418240",
                "APACHE_MAX_TIME=3600",
                "PATH=/usr/local/apache2/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin",
                "HTTPD_PREFIX=/usr/local/apache2",
                "HTTPD_VERSION=2.4.57",
                "HTTPD_SHA256=dbccb84aee95e095edfbb81e5eb926ccd24e6ada55dcd83caecb262e5cf94d2a",
                "HTTPD_PATCHES="
            "Cmd": [
                "-c",
                "/supervisord.conf"
            "Healthcheck": {
                "Test": [
                    "CMD-SHELL",
                    "healthcheck.sh"
            "Image": "nextcloud/aio-apache:latest",
            "Volumes": {
                "/mnt/data": {}
            "WorkingDir": "/usr/local/apache2",
            "Entrypoint": [
                "start.sh"
            "OnBuild": null,
            "Labels": {
                "com.centurylinklabs.watchtower.monitor-only": "true"
            "StopSignal": "SIGWINCH"
        "NetworkSettings": {
            "Bridge": "",
            "SandboxID": "d78fc6ba8520d0d12c7b1320dbc46468ea2799756a19e81d7336b2bbe8a5c5bc",
            "HairpinMode": false,
            "LinkLocalIPv6Address": "",
            "LinkLocalIPv6PrefixLen": 0,
            "Ports": {
                "11000/tcp": [
                        "HostPort": "11000"
                "80/tcp": null
            "SandboxKey": "/run/snap.docker/netns/d78fc6ba8520",
            "SecondaryIPAddresses": null,
            "SecondaryIPv6Addresses": null,
            "EndpointID": "",
            "Gateway": "",
            "GlobalIPv6Address": "",
            "GlobalIPv6PrefixLen": 0,
            "IPAddress": "",
            "IPPrefixLen": 0,
            "IPv6Gateway": "",
            "MacAddress": "",
            "Networks": {
                "nextcloud-aio": {
                    "IPAMConfig": null,
                    "Links": null,
                    "Aliases": [
                        "7e7abc09b6ee"
                    "NetworkID": "70aeb124fb9186bcc44cf229bd2438c171ddcee3c43cfc52fec32af6cb4fff31",
                    "EndpointID": "db1833e7fded7ea19324f07146d8ee671d21fb10a33a8c9d9ae1ad422f5deaad",
                    "Gateway": "172.22.0.1",
                    "IPAddress": "172.22.0.3",
                    "IPPrefixLen": 16,
                    "IPv6Gateway": "",
                    "MacAddress": "02:42:ac:16:00:03",
                    "DriverOpts": null
Thanks!
What Reverse proxy are you using and is it running in a container? Can you post the config here?
i am using NGINX proxy manager v2.9.20
containers:
sudo docker ps
CONTAINER ID   IMAGE                                 COMMAND                  CREATED        STATUS                   PORTS        NAMES
7e7abc09b6ee   nextcloud/aio-apache:latest           "start.sh /usr/bin/s…"   27 hours ago   Up 6 hours (unhealthy)   80/tcp, 0.0.0.0:11000->11000/tcp        nextcloud-aio-apache
8b02274d34fe   nextcloud/aio-nextcloud:latest        "/start.sh /usr/bin/…"   27 hours ago   Up 6 hours (healthy)     9000/tcp        nextcloud-aio-nextcloud
ccf4df959f20   nextcloud/aio-imaginary:latest        "imaginary -p 9000 -…"   27 hours ago   Up 6 hours (healthy)        nextcloud-aio-imaginary
9e78fdc48d6e   nextcloud/aio-redis:latest            "start.sh"               27 hours ago   Up 6 hours (healthy)     6379/tcp        nextcloud-aio-redis
810777c78988   nextcloud/aio-postgresql:latest       "start.sh"               27 hours ago   Up 6 hours (healthy)     5432/tcp        nextcloud-aio-database
7c0f6a48d671   nextcloud/aio-talk:latest             "start.sh /usr/bin/s…"   27 hours ago   Up 6 hours (unhealthy)   0.0.0.0:3478->3478/tcp, 0.0.0.0:3478->3478/udp, :::3478->3478/tcp, :::3478->3478/udp, 5349/tcp, 5349/udp   nextcloud-aio-talk
7b6ec144f5be   nextcloud/aio-collabora:latest        "/start-collabora-on…"   27 hours ago   Up 6 hours (healthy)     9980/tcp        nextcloud-aio-collabora
be5c0f9438e9   nextcloud/all-in-one:latest           "start.sh /usr/bin/s…"   27 hours ago   Up 6 hours (healthy)     80/tcp, 8443/tcp, 9000/tcp, 0.0.0.0:8080->8080/tcp, :::8080->8080/tcp                                      nextcloud-aio-mastercontainer
11eb314a1f27   lscr.io/linuxserver/ddclient:latest   "/init"                  8 weeks ago    Up 6 hours        ddclient
632a4875ca64   jc21/nginx-proxy-manager:latest       "/init"                  8 weeks ago    Up 6 hours               0.0.0.0:80-81->80-81/tcp, :::80-81->80-81/tcp, 0.0.0.0:443->443/tcp, :::443->443/tcp                       nginxproxymanager-app-1
f6db88e34217   jc21/mariadb-aria:latest              "/scripts/run.sh"        8 weeks ago    Up 6 hours               3306/tcp        nginxproxymanager-db-1
NGINX config:
NGINX docker config file is basic one from their site i belive
What does running curl -vvv -L http://localhost:11000/login.php on the host that runs the docker daemon return?
~$ curl -vvv -L http://localhost:11000/login.php
*   Trying 127.0.0.1:11000...
* Connected to localhost (127.0.0.1) port 11000 (#0)
> GET /login.php HTTP/1.1
> Host: localhost:11000
> User-Agent: curl/7.81.0
> Accept: */*
* Mark bundle as not supporting multiuse
< HTTP/1.1 302 Found
< Cache-Control: no-store, no-cache, must-revalidate
< Content-Length: 0
< Content-Security-Policy: default-src 'self'; script-src 'self' 'nonce-SlhWWU1xVkFxck91Y1JTRDJocStCaFRvTG90MEl5RG5VcWtFL1RsNE91QT06Wmk5Z0JmY0Q3WnlZUEZteXJGUHZmMjJ4WS93ZVpoYTFLczR6eEZSTWQ0cz0='; style-src 'self' 'unsafe-inline'; frame-src *; img-src * data: blob:; font-src 'self' data:; media-src *; connect-src *; object-src 'none'; base-uri 'self';
< Content-Type: text/html; charset=UTF-8
< Date: Sun, 14 May 2023 10:59:37 GMT
< Expires: Thu, 19 Nov 1981 08:52:00 GMT
< Location: https://atizd.duckdns.org/login
< Pragma: no-cache
< Referrer-Policy: no-referrer
< Server: Caddy
< Server: Apache/2.4.57 (Unix)
< Set-Cookie: oc_sessionPassphrase=pIvT7BDFZnV63uNDbwLCYODSuXeiUxECVDHKrW1hnPmE0GRZ0aDatrGvRyQ%2FJaW%2FifbHr%2Fuo0DtaRkiUwlyLGPIIDrGK6b3Bua2EIR9FT9diDFD0ZKzJaQ5A5dyDDrxG; path=/; secure; HttpOnly; SameSite=Lax
< Set-Cookie: __Host-nc_sameSiteCookielax=true; path=/; httponly;secure; expires=Fri, 31-Dec-2100 23:59:59 GMT; SameSite=lax
< Set-Cookie: __Host-nc_sameSiteCookiestrict=true; path=/; httponly;secure; expires=Fri, 31-Dec-2100 23:59:59 GMT; SameSite=strict
< Set-Cookie: ocqhsx4ol9jw=51396ee004ada115bf0464e29273269d; path=/; secure; HttpOnly; SameSite=Lax
< Strict-Transport-Security: max-age=31536000;
< X-Content-Type-Options: nosniff
< X-Frame-Options: SAMEORIGIN
< X-Permitted-Cross-Domain-Policies: none
< X-Powered-By: PHP/8.0.28
< X-Robots-Tag: noindex, nofollow
< X-Xss-Protection: 1; mode=block
* Connection #0 to host localhost left intact
* Clear auth, redirects to port from 11000 to 443
* Issue another request to this URL: 'https://atizd.duckdns.org/login'
*   Trying 213.149.61.33:443...
* connect to 213.149.61.33 port 443 failed: Connection timed out
* Failed to connect to atizd.duckdns.org port 443 after 129238 ms: Connection timed out
* Closing connection 1
curl: (28) Failed to connect to atizd.duckdns.org port 443 after 129238 ms: Connection timed out
Thanks! And what is the output of curl -vvv -L http://192.168.0.218:11000/login.php
~$ curl -vvv -L http://192.168.0.218:11000/login.php
*   Trying 192.168.0.218:11000...
* Connected to 192.168.0.218 (192.168.0.218) port 11000 (#0)
> Host: 192.168.0.218:11000
> Accept: */*
< Content-Length: 0
< Content-Security-Policy: default-src 'self'; script-src 'self' 'nonce-d0I4bEdCUTRFRWtqRWtxZTc2d2kxMlcyTTdqVU1PZHNhdWNhWW1neDYvcz06a0g1VFlDTnVlMlpUSWlpcmd1Wnh1VlBiQ3RtdGNvb0tYSzR4VkIxQ3BwQT0='; style-src 'self' 'unsafe-inline'; frame-src *; img-src * data: blob:; font-src 'self' data:; media-src *; connect-src *; object-src 'none'; base-uri 'self';
< Date: Sun, 14 May 2023 11:56:37 GMT
< Pragma: no-cache
< Server: Caddy
< Set-Cookie: oc_sessionPassphrase=3AuOlqmYXyHRkA2RdbTUFksObnBZRh2v2SoL834XgdM8%2BZFnGtpgE81P6%2FbXITJelG4GzE2dKt97Nbq5wcAlCx7g1ymyb%2Bm%2FXXujAUIhACwFsxq4ETJZYZI%2FO1shW1CX; path=/; secure; HttpOnly; SameSite=Lax
< Set-Cookie: ocqhsx4ol9jw=8dbffa1495ba5ee122a8e5c1cab1dec7; path=/; secure; HttpOnly; SameSite=Lax
* Connection #0 to host 192.168.0.218 left intact
* Failed to connect to atizd.duckdns.org port 443 after 129370 ms: Connection timed out
curl: (28) Failed to connect to atizd.duckdns.org port 443 after 129370 ms: Connection timed out
Can you try curl -vvv http://localhost:11000/login.php again? (Without the -L)
~$ curl -vvv http://localhost:11000/login.php
> Accept: */*
< Content-Length: 0
< Content-Security-Policy: default-src 'self'; script-src 'self' 'nonce-VHhXY1drQThBUDBCQ3FrV2FPeEcyZHRBUFBJVGlnbDVMNGplTmREUXFwZz06S243ekczRjdONnRGVTlwYUxaa2VsWXcxZDU5bThHQUpIY09ZWFlxZDJMTT0='; style-src 'self' 'unsafe-inline'; frame-src *; img-src * data: blob:; font-src 'self' data:; media-src *; connect-src *; object-src 'none'; base-uri 'self';
< Date: Sun, 14 May 2023 16:27:43 GMT
< Pragma: no-cache
< Server: Caddy
< Set-Cookie: oc_sessionPassphrase=9i1D26UXYy6hXtq06%2FeYGxrLRom5FFYsqxRvmPeGiAfHGtSJZP9SHdTExI07JtXfv700pb9KjaKcGR5G8u5rz2b9n8SOZ4SXH6HvrJ7UkkvfJeJTe5hbDbHg0d4zbFRR; path=/; secure; HttpOnly; SameSite=Lax
< Set-Cookie: ocqhsx4ol9jw=10638bfc04a42550c4efe3bbbae48f63; path=/; secure; HttpOnly; SameSite=Lax
One last test for now: curl -vvv http://localhost:11000/login (apparently the .php at the end is wrong)
> GET /login HTTP/1.1
> Accept: */*
< HTTP/1.1 200 OK
< Cache-Control: no-cache, no-store, must-revalidate
< Content-Security-Policy: default-src 'none';base-uri 'none';manifest-src 'self';script-src 'self' blob:;style-src 'self' 'unsafe-inline';img-src 'self' data: blob: https://atizd.duckdns.org https://*.tile.openstreetmap.org;font-src 'self' data:;connect-src 'self' blob: atizd.duckdns.org:3478 wss://atizd.duckdns.org;media-src 'self' blob:;frame-src 'self' nc: https://atizd.duckdns.org;child-src blob: 'self';frame-ancestors 'self' https://atizd.duckdns.org;worker-src blob: 'self';form-action 'self' https://atizd.duckdns.org
< Date: Sun, 14 May 2023 18:43:26 GMT
< Feature-Policy: autoplay 'self';camera 'self';fullscreen 'self';geolocation 'none';microphone 'self';payment 'none'
< Pragma: no-cache
< Server: Caddy
< Set-Cookie: oc_sessionPassphrase=NyC%2BvgtuHJvwhWB%2B6miCKlkAcwbNCgolNo50BwtXFKx%2BQEx1PIOdDxn6P91Lx7gFB9jiSdi1g3VH%2FWVEKE4MDlk4tPBm3eA9MaWlBYGTstdSrn7tfaWiK%2BJjsvDfiUBu; path=/; secure; HttpOnly; SameSite=Lax
< Set-Cookie: ocqhsx4ol9jw=5cd260cf73014de311f1f56bdcd2ef58; path=/; secure; HttpOnly; SameSite=Lax
< X-Request-Id: BpflgDALVMFFNCNjgWNx
< Transfer-Encoding: chunked
<!DOCTYPE html>
<html class="ng-csp" data-placeholder-focus="false" lang="en" data-locale="en" >
        <head
 data-requesttoken="hmxiPx1K5BplVr92hc/OX5w2nHz3j989AOtiyJv0uk8=:qTUEUXgLqFIhGNMhroqpFcZT0TG91qh2SaAvhNXE1Ds=">
                <meta charset="utf-8">
                <title>
                        Login – Sus could               </title>
                <meta name="viewport" content="width=device-width, initial-scale=1.0, minimum-scale=1.0">
                                <meta name="apple-itunes-app" content="app-id=1125420102">
                                <meta name="theme-color" content="#0082c9">
                <link rel="icon" href="/apps/theming/favicon?v=c1dfd96e">
                <link rel="apple-touch-icon" href="/apps/theming/icon?v=c1dfd96e">
                <link rel="mask-icon" sizes="any" href="/core/img/favicon-mask.svg" color="#0082c9">
                <link rel="manifest" href="/apps/theming/manifest?v=c1dfd96e">
                <link rel="stylesheet" href="/core/css/server.css?v=896f9334-6">
<link rel="stylesheet" href="/apps/files_rightclick/css/app.css?v=1bf6e69c-6">
<link rel="stylesheet" href="/apps/theming/css/default.css?v=47354877-6">
<link rel="stylesheet" href="/core/css/guest.css?v=896f9334-6">
                <script nonce="aG14aVB4MUs1QnBsVnI5MmhjL09YNXcybkh6M2o5ODlBT3RpeUp2MHVrOD06cVRVRVVYZ0xxRkloR05NaHJvcXBGY1pUMFRHOTFxaDJTYUF2aE5YRTFEcz0=" defer src="/core/js/oc.js?v=896f9334"></script>
<script nonce="aG14aVB4MUs1QnBsVnI5MmhjL09YNXcybkh6M2o5ODlBT3RpeUp2MHVrOD06cVRVRVVYZ0xxRkloR05NaHJvcXBGY1pUMFRHOTFxaDJTYUF2aE5YRTFEcz0=" defer src="/dist/core-common.js?v=896f9334-6"></script>
<script nonce="aG14aVB4MUs1QnBsVnI5MmhjL09YNXcybkh6M2o5ODlBT3RpeUp2MHVrOD06cVRVRVVYZ0xxRkloR05NaHJvcXBGY1pUMFRHOTFxaDJTYUF2aE5YRTFEcz0=" defer src="/dist/core-main.js?v=896f9334-6"></script>
<script nonce="aG14aVB4MUs1QnBsVnI5MmhjL09YNXcybkh6M2o5ODlBT3RpeUp2MHVrOD06cVRVRVVYZ0xxRkloR05NaHJvcXBGY1pUMFRHOTFxaDJTYUF2aE5YRTFEcz0=" defer src="/dist/core-files_fileinfo.js?v=896f9334-6"></script>
<script nonce="aG14aVB4MUs1QnBsVnI5MmhjL09YNXcybkh6M2o5ODlBT3RpeUp2MHVrOD06cVRVRVVYZ0xxRkloR05NaHJvcXBGY1pUMFRHOTFxaDJTYUF2aE5YRTFEcz0=" defer src="/dist/core-files_client.js?v=896f9334-6"></script>
<script nonce="aG14aVB4MUs1QnBsVnI5MmhjL09YNXcybkh6M2o5ODlBT3RpeUp2MHVrOD06cVRVRVVYZ0xxRkloR05NaHJvcXBGY1pUMFRHOTFxaDJTYUF2aE5YRTFEcz0=" defer src="/js/core/merged-template-prepend.js?v=896f9334-6"></script>
<script nonce="aG14aVB4MUs1QnBsVnI5MmhjL09YNXcybkh6M2o5ODlBT3RpeUp2MHVrOD06cVRVRVVYZ0xxRkloR05NaHJvcXBGY1pUMFRHOTFxaDJTYUF2aE5YRTFEcz0=" defer src="/dist/core-login.js?v=896f9334-6"></script>
<script nonce="aG14aVB4MUs1QnBsVnI5MmhjL09YNXcybkh6M2o5ODlBT3RpeUp2MHVrOD06cVRVRVVYZ0xxRkloR05NaHJvcXBGY1pUMFRHOTFxaDJTYUF2aE5YRTFEcz0=" defer src="/dist/files_sharing-main.js?v=896f9334-6"></script>
<script nonce="aG14aVB4MUs1QnBsVnI5MmhjL09YNXcybkh6M2o5ODlBT3RpeUp2MHVrOD06cVRVRVVYZ0xxRkloR05NaHJvcXBGY1pUMFRHOTFxaDJTYUF2aE5YRTFEcz0=" defer src="/apps/files_rightclick/js/script.js?v=896f9334-6"></script>
<script nonce="aG14aVB4MUs1QnBsVnI5MmhjL09YNXcybkh6M2o5ODlBT3RpeUp2MHVrOD06cVRVRVVYZ0xxRkloR05NaHJvcXBGY1pUMFRHOTFxaDJTYUF2aE5YRTFEcz0=" defer src="/apps/files_rightclick/js/files.js?v=896f9334-6"></script>
<script nonce="aG14aVB4MUs1QnBsVnI5MmhjL09YNXcybkh6M2o5ODlBT3RpeUp2MHVrOD06cVRVRVVYZ0xxRkloR05NaHJvcXBGY1pUMFRHOTFxaDJTYUF2aE5YRTFEcz0=" defer src="/apps/theming/js/theming.js?v=896f9334-6"></script>
                <meta property="og:title" content="Sus could"/><meta property="og:description" content="a safe home for all your data"/><meta property="og:site_name" content="Sus could"/><meta property="og:url" content="https://atizd.duckdns.org/"/><meta property="og:type" content="website"/><meta property="og:image" content="https://atizd.duckdns.org/apps/theming/icon?v=c1dfd96e"/><link rel="stylesheet" media="" href="/apps/theming/theme/default.css?plain=1&amp;v=c1dfd96e" class="theme"/><link rel="stylesheet" media="(prefers-color-scheme: light)" href="/apps/theming/theme/light.css?plain=1&amp;v=c1dfd96e" class="theme"/><link rel="stylesheet" media="(prefers-color-scheme: dark)" href="/apps/theming/theme/dark.css?plain=1&amp;v=c1dfd96e" class="theme"/><link rel="stylesheet" media="(prefers-contrast: more)" href="/apps/theming/theme/light-highcontrast.css?plain=1&amp;v=c1dfd96e" class="theme"/><link rel="stylesheet" media="(prefers-color-scheme: dark) and (prefers-contrast: more)" href="/apps/theming/theme/dark-highcontrast.css?plain=1&amp;v=c1dfd96e" class="theme"/><link rel="stylesheet" media="" href="/apps/theming/theme/light.css?plain=0&amp;v=c1dfd96e" class="theme"/><link rel="stylesheet" media="" href="/apps/theming/theme/dark.css?plain=0&amp;v=c1dfd96e" class="theme"/><link rel="stylesheet" media="" href="/apps/theming/theme/light-highcontrast.css?plain=0&amp;v=c1dfd96e" class="theme"/><link rel="stylesheet" media="" href="/apps/theming/theme/dark-highcontrast.css?plain=0&amp;v=c1dfd96e" class="theme"/><link rel="stylesheet" media="" href="/apps/theming/theme/opendyslexic.css?plain=0&amp;v=c1dfd96e" class="theme"/><meta name="robots" content="noindex, nofollow"/>     </head>
        <body id="body-login">
                <noscript>
        <div id="nojavascript">
                <div>
                        This application requires JavaScript for correct operation. Please <a href="https://www.enable-javascript.com/" target="_blank" rel="noreferrer noopener">enable JavaScript</a> and reload the page.                </div>
        </div>
</noscript>
                                        <input type="hidden" id="initial-state-core-loginUsername" value="IiI=">
                                        <input type="hidden" id="initial-state-core-loginAutocomplete" value="dHJ1ZQ==">
                                        <input type="hidden" id="initial-state-core-loginThrottleDelay" value="MA==">
                                        <input type="hidden" id="initial-state-core-loginResetPasswordLink" value="IiI=">
                                        <input type="hidden" id="initial-state-core-loginCanResetPassword" value="dHJ1ZQ==">
                                        <input type="hidden" id="initial-state-core-webauthn-available" value="dHJ1ZQ==">
                                        <input type="hidden" id="initial-state-core-hideLoginForm" value="ZmFsc2U=">
                                        <input type="hidden" id="initial-state-core-countAlternativeLogins" value="MA==">
                                        <input type="hidden" id="initial-state-core-alternativeLogins" value="W10=">
                                        <input type="hidden" id="initial-state-core-projects_enabled" value="ZmFsc2U=">
                                        <input type="hidden" id="initial-state-core-config" value="eyJzZXNzaW9uX2xpZmV0aW1lIjoxNDQwLCJzZXNzaW9uX2tlZXBhbGl2ZSI6dHJ1ZSwiYXV0b19sb2dvdXQiOmZhbHNlLCJ2ZXJzaW9uIjoiMjUuMC42LjEiLCJ2ZXJzaW9uc3RyaW5nIjoiMjUuMC42IiwiZW5hYmxlX2F2YXRhcnMiOnRydWUsImxvc3RfcGFzc3dvcmRfbGluayI6bnVsbCwibW9kUmV3cml0ZVdvcmtpbmciOnRydWUsInNoYXJpbmcubWF4QXV0b2NvbXBsZXRlUmVzdWx0cyI6MjUsInNoYXJpbmcubWluU2VhcmNoU3RyaW5nTGVuZ3RoIjowLCJibGFja2xpc3RfZmlsZXNfcmVnZXgiOiJcXC4ocGFydHxmaWxlcGFydCkkIiwibG9nbGV2ZWwiOiIyIn0=">
                                        <input type="hidden" id="initial-state-core-capabilities" value="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">
                                        <input type="hidden" id="initial-state-core-versionHash" value="Ijg5NmY5MzM0Ig==">
                                        <input type="hidden" id="initial-state-theming-data" value="eyJuYW1lIjoiU3VzIGNvdWxkIiwidXJsIjoiaHR0cHM6XC9cL25leHRjbG91ZC5jb20iLCJzbG9nYW4iOiJhIHNhZmUgaG9tZSBmb3IgYWxsIHlvdXIgZGF0YSIsImNvbG9yIjoiIzAwODJjOSIsImRlZmF1bHRDb2xvciI6IiMwMDgyYzkiLCJpbXByaW50VXJsIjoiIiwicHJpdmFjeVVybCI6IiIsImludmVydGVkIjpmYWxzZSwiY2FjaGVCdXN0ZXIiOiJjMWRmZDk2ZSIsImVuYWJsZWRUaGVtZXMiOltdfQ==">
                                        <input type="hidden" id="initial-state-comments-maxAutoCompleteResults" value="MTA=">
                                <div class="wrapper">
                        <div class="v-align">
        <header role="banner">
                                                <div id="header">
                                                        <div class="logo"></div>
                                                </div>
                                        </header>
        <main>
                                        <h1 class="hidden-visually">
                                                Sus could                                       </h1>
<div>
        <div id="login"></div>
</div>
                                </main>
                        </div>
                </div>
                <footer role="contentinfo">
                        <p class="info">
                                <a href="https://nextcloud.com" target="_blank" rel="noreferrer noopener" class="entity-name">Sus could</a> – a safe home for all your data                 </p>
                </footer>
        </body>
</html>
what do you think, what is going on?
I am not sure honestly but based on https://portchecker.co is port 443 closed for your domain. So your reverse proxy does not seem to work correctly or the dns config is wrong or the port is not opened/forwarded which you need to fix.
AIO on the other hand seems to work correctly which you proofed with the commands.
