- Official documentation (searchable and regularly updated)
- How to topics and FAQs
- Forum search
Some or all of the below information will be requested if it isn’t supplied; for fastest response please provide as much as you can. ![]()
latest
Ubuntu server 24.04
replace me
replace me
- PHP version (e.g, 8.3):
replace me
replace me
instalation/setup
docker
replace me
[…] so I’ve been trying to set up the nextcloud AIO for about 3 days now I’ve had the same issue that i specify the ports 11000:80 and 8443:8443. inside my network the hosting server ip is 10.0.0.4 and i ssh into it from my WIN11 machine when setup the container and i look at the logs and it tells me
docker logs nextcloud-aio-mastercontainer
Trying to fix docker.sock permissions internally…
Creating docker group internally with id 988
Initial startup of Nextcloud All-in-One complete!
You should be able to open the Nextcloud AIO Interface now on port 8080 of this server!
E.g. https://internal.ip.of.this.server:8080
Important: do always use an ip-address if you access this port and not a domain as HSTS might block access to it later!
If your server has port 80 and 8443 open and you point a domain to your server, you can get a valid certificate automatically by opening the Nextcloud AIO Interface via:
https://your-domain-that-points-to-this-server.tld:8443
/usr/lib/python3.12/site-packages/supervisor/options.py:13: UserWarning: pkg_resources is deprecated as an API. See Package Discovery and Resource Access using pkg_resources - setuptools 80.10.2 documentation . The pkg_resources package is slated for removal as early as 2025-11-30. Refrain from using this package or pin to Setuptools<81.
import pkg_resources
[Mon Nov 17 08:38:11.085523 2025] [mpm_event:notice] [pid 150:tid 150] AH00489: Apache/2.4.65 (Unix) OpenSSL/3.5.4 configured – resuming normal operations
[Mon Nov 17 08:38:11.085567 2025] [core:notice] [pid 150:tid 150] AH00094: Command line: ‘httpd -D FOREGROUND’
[17-Nov-2025 08:38:11] NOTICE: fpm is running, pid 159
[17-Nov-2025 08:38:11] NOTICE: ready to handle connections
{“level”:“info”,“ts”:1763368691.1099007,“msg”:“maxprocs: Leaving GOMAXPROCS=4: CPU quota undefined”}
{“level”:“info”,“ts”:1763368691.1100607,“msg”:“GOMEMLIMIT is updated”,“package”:“github.com/KimMachineGun/automemlimit/memlimit",“GOMEMLIMIT”:11284228915,"previous”:9223372036854775807}
{“level”:“info”,“ts”:1763368691.1101043,“msg”:“using config from file”,“file”:“/Caddyfile”}
{“level”:“info”,“ts”:1763368691.1109595,“msg”:“adapted config to JSON”,“adapter”:“caddyfile”}
{“level”:“info”,“ts”:1763368691.112357,“msg”:“serving initial configuration”}
when i go to http or https://10.0.0.4:11000 or :8080 or 8443 i get a timed out screen
this is my yaml file for it
version: “3.9”
services:
image: ghcr.io/nextcloud-releases/all-in-one:latest
init: true
restart: unless-stopped
volumes:
- /mnt/data/nextcloud‑data:/mnt/nextcloud‑data
environment: - APACHE_PORT=11000
- APACHE_IP_BINDING=0.0.0.0
- NEXTCLOUD_DATADIR=/mnt/nextcloud-data
- #SKIP_DOMAIN_VALIDATION=true
- NEXTCLOUD_MEMORY_LIMIT=1024M
- NEXTCLOUD_MAX_TIME=7200
ports: - “11000:80”
- “8443:8443”
volumes:
im also new to the self-hosting world so if i said something wrong or if i dont make sense i am sorry please bare with me im open to learn and seeing if anyone has any insights. also let me know any addition info needed to solve this problem ![]()
PASTE HERE
PASTE
PASTE HERE
PASTE HERE
- Use the
preformatted textformatting option in the editor for all log entries and configuration output. - If screenshots are useful, feel free to include them.
- If possible, also include key error output in text form so it can be searched for.
- Try to edit log output only minimally (if at all) so that it can be ran through analyzers / formatters by those trying to help you.
