Hi there…
I am struggling to install Nextcloud AIO. I have installed it before and ran into issues. Now that I am trying to install it again after resetting my instance, I am getting the following error in the Master container’s logs:
It seems like you did not give the mastercontainer volume the correct name?Using a different name is not supported
This is my Docker-Compose file:
version: "3.8"
volumes:
services:
nextcloud:
image: nextcloud/all-in-one:latest-arm64
restart: unless-stopped
volumes:
- nextcloud-aio-mastercontainer:/mnt/docker-aio-config
ports:
- 8680:8080
environment:
- APACHE_PORT=11000
- APACHE_DISABLE_REWRITE_IP=1
- NEXTCLOUD_TRUSTED_DOMAINS=< DOMAIN NAME > < IP ADDRESS > < PROXY IP ADDRESS >
- TRUSTED_PROXIES=< PROXY IP ADDRESS >
The error is on line 13, apparently:
Please help me.
Thanks
Darius
