My Nextcloud server did a daily backup and now it won’t reboot. If I login to the :8448 screen I get the message “Daily backup currently running” but it’s been like this for a hour. Below is the logs
Trying to fix docker.sock permissions internally…
Adding internal www-data to group ping
e[0;92mInitial startup of Nextcloud All-in-One complete!
You should be able to open the Nextcloud AIO Interface now on port 8080 of this server!
E.g. https://internal.ip.of.this.server:8080
If your server has port 80 and 8443 open and you point a domain to your server, you can get a valid certificate automatically by opening the Nextcloud AIO Interface via:
https://your-domain-that-points-to-this-server.tld:8443e[0m
++ head -1 /mnt/docker-aio-config/data/daily_backup_time
- BACKUP_TIME=18:00
- export BACKUP_TIME
- export DAILY_BACKUP=1
- DAILY_BACKUP=1
++ sed -n 2p /mnt/docker-aio-config/data/daily_backup_time - ‘[’ ‘’ ‘!=’ automaticUpdatesAreNotEnabled ‘]’
- export AUTOMATIC_UPDATES=1
- AUTOMATIC_UPDATES=1
++ sed -n 3p /mnt/docker-aio-config/data/daily_backup_time - ‘[’ ‘’ ‘!=’ successNotificationsAreNotEnabled ‘]’
- export SEND_SUCCESS_NOTIFICATIONS=1
- SEND_SUCCESS_NOTIFICATIONS=1
- set +x
Daily backup script has started
[30-Oct-2023 18:00:47] NOTICE: fpm is running, pid 115
[30-Oct-2023 18:00:47] NOTICE: ready to handle connections
[Mon Oct 30 18:00:47.069184 2023] [mpm_event:notice] [pid 110:tid 139764874582856] AH00489: Apache/2.4.58 (Unix) OpenSSL/3.1.3 configured – resuming normal operations
[Mon Oct 30 18:00:47.069264 2023] [core:notice] [pid 110:tid 139764874582856] AH00094: Command line: ‘httpd -D FOREGROUND’
{“level”:“info”,“ts”:1698688847.0861416,“msg”:“using provided configuration”,“config_file”:“/Caddyfile”,“config_adapter”:“”}
grep: write error: Broken pipe
Starting mastercontainer update…
(The script might get exited due to that. In order to update all the other containers correctly, you need to run this script with the same settings a second time.)
Waiting for watchtower to stop
Creating daily backup…
Waiting for backup container to stop
Starting and updating containers…
Waiting for the Nextcloud container to start
Sending backup notification…
Daily backup script has finished
Deleted Images:
untagged: nextcloud/aio-talk@sha256:a1b489310a4365e6b6ab32a4eec32c1da21f41ea18b4874fc9d8d3ed2e2b5c3c
deleted: sha256:8ee07ed40881434412d5166d4395c7f9d163d06d26c910cf4979b1cb77404593
deleted: sha256:9d193f6fd25a0c0481f54bfe6b45f8caa2ad0cc02296aec0b4a29b2629ee3819
deleted: sha256:7e1a4af2eb774971808206ae6584af41881d5fc704b6cc2e312a267b90148f79
deleted: sha256:1187064e4c0dd23fae809071886ca444b5ffd6ec3f64d31546823d9c39ab8033
deleted: sha256:8da80fa232e9aa1643e43f0b6082c79bbac0c0ab258430729915c926171d36a0
deleted: sha256:35b587c79ff0e05e08c7726741afa9a3f5205023568a326d046d1f658261e586
deleted: sha256:186bddb6c2f636160a01de209f3e39ec4af01f42b590f3a442bf637e27d0de3b
deleted: sha256:442fd6d2d074ff61e256f19694153e6c620c5c41ab5ba7f1cf4fe6d2814e8965
deleted: sha256:9c329311b62ff033c815f065f316eca6d53c88d1167a4aa6af1f914e133a26b9
untagged: nextcloud/aio-redis@sha256:b347a2aeac193c1ce0bc326d5235910c2ed4c500bddba3bc2940eb19854344a1
deleted: sha256:6fb036bc7cf49ef4e660ed1badda5617c98806d351fe440bde31837b00e16d3e
deleted: sha256:ce1e94cbf0752063ac22022dca472fe9314be5a984a4967d0f03b249c650c9ac
deleted: sha256:0c817bff4cdf48ee88148b3ff397e253e0e8372d01b327674d15388052dbf4a2
untagged: nextcloud/aio-nextcloud@sha256:6efa04e7290115463f0eba9fed3158310ec4782308c21da3cdbb5594a0d15bce
deleted: sha256:dfb5d6836e58233e6e6610b4844589d6c743e8b7c6e6d30e56ade18c8cd30512
deleted: sha256:398d145e9d37a9eac9a90e8efea9b39204e1935cdb4e1f64073e8127153c3fa7
deleted: sha256:b6ad4f13cd514f23b13d88c8c1151efe81fd6ada86973b4d3ac2620dd55cea65
deleted: sha256:e92e0a60f2130a8bbeaa2431108cc86c077005a288f9be8958a0c58a9685cf6c
deleted: sha256:862b5941816537f2762b0780d9a7fbf12506c7a7c05c51c9af356f87abdf108d
deleted: sha256:ab05e4eb014936c2ca5921d3be64a4c04ad6fb7577dfdf1d745a21dba1cf2175
deleted: sha256:e203d09535f8566bc1a1b6045089082bbd49662ed26310a1b1f419a49c2eb51f
deleted: sha256:decc1fbc0b1f9d825e25d952b06b60fc60df08033d8d8a8959bbd172a7a0afd7
deleted: sha256:ad1ba4c766b8509e9133b0861938bea49056ed7b6d7fa3c10321627e73b9fbd5
deleted: sha256:54037646023f40c7cf7d2c4cc9eadcdbab90ffff5844076367f21f434381a282
deleted: sha256:4223dafb1e3e896bdcd21fa9ca80a3b5840f37b05dc7d3b1eb57cebdc02d6029
deleted: sha256:a613a1de38ddcd632cf32581dcae44aac208d34d51e1e33f179e6464d69b714d
deleted: sha256:f7416b0a7d00e1a3d739859de6ed6df4025eafdf7b77f7f53e1da240dc4ba0ad
deleted: sha256:3d002bccc2c222285b1e37434064e82b5be69effa0dec7f5c059ed17e77a02e5
deleted: sha256:0b7c2b2ba13357a1b81b8a643eab9f89753bb3d58912b75514b9ee0bb3eca1a2
untagged: nextcloud/aio-watchtower@sha256:bf88b4caf5752aee84638a0f3bde3b7eeca6166c9d7c9276ef742e86add155c6
deleted: sha256:4c88fb463ab343abca323e17a3ec4a4de0ada65e3340d2358bb5c0cbd596d359
deleted: sha256:8a93867481e4f035cb4042de91986177b103fc396236e0e4fca96081d5c8e83d
deleted: sha256:f2eed51659f293bf8912558b48d5c0b334d39f07e394e3f8e500154f4aa9c770
deleted: sha256:c46de0b5ff0879467ceee70221beeb0ba1aa0c0c070fcbf509e6384156af1b58
untagged: nextcloud/aio-borgbackup@sha256:467110e3c7e1ad34269bcc5fe0724f6bdaf4d562870b311f7b7f0721699c2726
deleted: sha256:da4a443c29366c1391df1ebea9bb8a26b3e081d8a624c3d0a481210b57d0cf3f
deleted: sha256:57112803a2e4230dc9010675b32bd027dfc3de47bd59b985a877e7a1e10d5ad2
deleted: sha256:189dfa68fa17c23e5e1a27ead9c8c8c9d7f89af35834fa08ff1fbbc765d99c8a
untagged: nextcloud/aio-postgresql@sha256:e6a792b38b0ecd6352b0461d8412879b0dc5102027d368a34e201be9b955db3a
deleted: sha256:324bc6ed197d7081b2508c41f993779313e8c4cab84d22a7d9f89abaffdf8b70
deleted: sha256:8d77909d3f84072f3e90ec98c94842c82235e59dc0314d874343eb7eb1755065
deleted: sha256:8c01259d0b4ab7b3ee0b8e97dee09be76e55326abb36aff03826a5ca4ee1b304
deleted: sha256:fa159dbad5e4e7c53cdf89f945d271e4a127b7c86acff00523411d83919e9352
deleted: sha256:e76f89a75514d823eaa6456c071dafa761555b2a6dc9a6126a031729430ae65c
untagged: nextcloud/aio-collabora@sha256:a26d657e96b30cfec96ff48922284d36848239081844e9fbb5a007543b923430
deleted: sha256:739c9ccdb5340f1d27b68e63d06d6ac1b8f6548c8fa1994206ffb87a35e05de0
deleted: sha256:f405ff5cf119d98728a3344b9e043aba7e58571dfe83edf640de53f44fa64179
untagged: nextcloud/aio-notify-push@sha256:d307494aff232c0ed08e5ae5fa850a013032db7d3cbaaad5d03f2cf74bea663c
deleted: sha256:92bacb6929cd6c30b984ef6c760e98dcc9a772de63eddeb21406b5d8044767bb
deleted: sha256:15a51c68fbb8ebf20d77789cef6beb8b1ed9a881da9c512430923494b33e09a2
deleted: sha256:e633d3d69f3542bc338d32e5c0bb6fe255a44c807a2a4948236ab7471e95429d
deleted: sha256:783eccf4551e9a51b1fa4c53a95ffe1e764370bb185c17f9e0747d6c95647035
untagged: nextcloud/aio-imaginary@sha256:1654a1c4e2df04db7df9ad48d20fd275032c1c908719b4de8a192963d3bcfedc
deleted: sha256:a527e7b7a37c56046b23c3152c9f3c4a88fad9ebc30ca152b907c9054a8c7f9b
deleted: sha256:baafa3010a55f759c77ffe61798eea2a0852c5fd3120705492201818e23cc223
deleted: sha256:cbc6dc900f5bb97ce80ebef51158acf6532510caf1cca5b94d0c2743805ad496
untagged: nextcloud/aio-apache@sha256:c62aed9748f9cbec1be22e0e9724ad7832ae01bd18ffb9f1b6337f082c354187
deleted: sha256:d114adca9616f9a67b0554385f3fed6a7998caa32d197e9b69b420e996b93c13
deleted: sha256:6e01231429088b49accb708a229a01da269d78e42a8417a7e5cf9430f3f8ed04
deleted: sha256:646299f851a0a7e3775166ee87b34b3b49204a12199ec8df6902393fb21a0c2d
deleted: sha256:604a442e898502e61956effe6997719ceaffa80c3c37f5ba7b4fe07be504f02a
deleted: sha256:9478af229d44970e94ace1297ec76ded077bc5c41b0a7d40548fe5181f37ecff
deleted: sha256:4da992ccb1b9c95d64b9d9f58b7dc3e0fd8d6c82e721c6dc5630ec23d52b7791
deleted: sha256:5ac3c91eda3f7fde9b7cbbf130be572e47acd6a0d1966fe2be09bd4c97390913
deleted: sha256:cafd742004046fda270aa1e4187a19b53b983e25a691c75388ab9a610161e261
Total reclaimed space: 1.427GB
- BACKUP_TIME=18:00
- DAILY_BACKUP=1
- set +x
Deleting duplicate sessions
NOTICE: PHP message: 404 Not Found
Type: Slim\Exception\HttpNotFoundException
4
Message: Not found.
File: /var/www/docker-aio/php/vendor/slim/slim/Slim/Middleware/RoutingMiddleware.php
Line: 76
Trace: #0 /var/www/docker-aio/php/vendor/slim/slim/Slim/Routing/RouteRunner.php(56): Slim\Middleware\RoutingMiddleware->performRouting(Object(GuzzleHttp\Psr7\ServerRequest))
#1 /var/www/docker-aio/php/vendor/slim/csrf/src/Guard.php(476): Slim\Routing\RouteRunner->handle(Object(GuzzleHttp\Psr7\ServerRequest))
#2 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(168): Slim\Csrf\Guard->process(Object(GuzzleHttp\Psr7\ServerRequest), Object(Slim\Routing\RouteRunner))
#3 /var/www/docker-aio/php/vendor/slim/twig-view/src/TwigMiddleware.php(115): Psr\Http\Server\RequestHandlerInterface@anonymous->handle(Object(GuzzleHttp\Psr7\ServerRequest))
#4 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(121): Slim\Views\TwigMiddleware->process(Object(GuzzleHttp\Psr7\ServerRequest), Object(Psr\Http\Server\RequestHandlerInterface@anonymous))
#5 /var/www/docker-aio/php/src/Middleware/AuthMiddleware.php(38): Psr\Http\Server\RequestHandlerInterface@anonymous->handle(Object(GuzzleHttp\Psr7\ServerRequest))
#6 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(269): AIO\Middleware\AuthMiddleware->__invoke(Object(GuzzleHttp\Psr7\ServerRequest), Object(Psr\Http\Server\RequestHandlerInterface@anonymous))
#7 /var/www/docker-aio/php/vendor/slim/slim/Slim/Middleware/ErrorMiddleware.php(76): Psr\Http\Server\RequestHandlerInterface@anonymous->handle(Object(GuzzleHttp\Psr7\ServerRequest))
#8 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(121): Slim\Middleware\ErrorMiddleware->process(Object(GuzzleHttp\Psr7\ServerRequest), Object(Psr\Http\Server\RequestHandlerInterface@anonymous))
#9 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(65): Psr\Http\Server\RequestHandlerInterface@anonymous->handle(Object(GuzzleHttp\Psr7\ServerRequest))
#10 /var/www/docker-aio/php/vendor/slim/slim/Slim/App.php(199): Slim\MiddlewareDispatcher->handle(Object(GuzzleHttp\Psr7\ServerRequest))
#11 /var/www/docker-aio/php/vendor/slim/slim/Slim/App.php(183): Slim\App->handle(Object(GuzzleHttp\Psr7\ServerRequest))
#12 /var/www/docker-aio/php/public/index.php(182): Slim\App->run()
#13 {main}
Tips: To display error details in HTTP response set “displayErrorDetails” to true in the ErrorHandler constructor.
{“level”:“error”,“ts”:1698754600.4759703,“logger”:“http.acme_client”,“msg”:“challenge failed”,“identifier”:“speed.cloudflare.com”,“challenge_type”:“http-01”,“problem”:{“type”:“urn:ietf:params:acme:error:unauthorized”,“title”:“”,“detail”:“2606:4700::6810:4426: Invalid response from http://speed.cloudflare.com/.well-known/acme-challenge/j0o4GPCyQSLaAtcr3cNSlGaz_fBnDsAxkp26QW_2MDI: 404”,“instance”:“”,“subproblems”:[]}}
{“level”:“error”,“ts”:1698754600.476053,“logger”:“http.acme_client”,“msg”:“validating authorization”,“identifier”:“speed.cloudflare.com”,“problem”:{“type”:“urn:ietf:params:acme:error:unauthorized”,“title”:“”,“detail”:“2606:4700::6810:4426: Invalid response from http://speed.cloudflare.com/.well-known/acme-challenge/j0o4GPCyQSLaAtcr3cNSlGaz_fBnDsAxkp26QW_2MDI: 404”,“instance”:“”,“subproblems”:[]},“order”:“https://acme-v02.api.letsencrypt.org/acme/order/1178049587/218912549816",“attempt”:1,"max_attempts”:3}
{“level”:“error”,“ts”:1698754600.4760942,“logger”:“tls.obtain”,“msg”:“could not get certificate from issuer”,“identifier”:“speed.cloudflare.com”,“issuer”:“acme-v02.api.letsencrypt.org-directory”,“error”:“HTTP 403 urn:ietf:params:acme:error:unauthorized - 2606:4700::6810:4426: Invalid response from http://speed.cloudflare.com/.well-known/acme-challenge/j0o4GPCyQSLaAtcr3cNSlGaz_fBnDsAxkp26QW_2MDI: 404”}
{“level”:“error”,“ts”:1698754600.476131,“logger”:“tls.obtain”,“msg”:“will retry”,“error”:“[speed.cloudflare.com] Obtain: [speed.cloudflare.com] solving challenge: speed.cloudflare.com: [speed.cloudflare.com] authorization failed: HTTP 403 urn:ietf:params:acme:error:unauthorized - 2606:4700::6810:4426: Invalid response from http://speed.cloudflare.com/.well-known/acme-challenge/j0o4GPCyQSLaAtcr3cNSlGaz_fBnDsAxkp26QW_2MDI: 404 (ca=https://acme-v02.api.letsencrypt.org/directory)”,“attempt”:1,“retrying_in”:60,“elapsed”:2.272194957,“max_duration”:2592000}
{“level”:“error”,“ts”:1698754672.6298807,“logger”:“http.acme_client”,“msg”:“challenge failed”,“identifier”:“speed.cloudflare.com”,“challenge_type”:“http-01”,“problem”:{“type”:“urn:ietf:params:acme:error:unauthorized”,“title”:“”,“detail”:“104.16.67.38: Invalid response from http://speed.cloudflare.com/.well-known/acme-challenge/xxX8O7GPyCM9wXpCOcqiEVFNEKX6Bj4VmJ_9BxbK_0k: 404”,“instance”:“”,“subproblems”:[]}}
{“level”:“error”,“ts”:1698754672.6300235,“logger”:“http.acme_client”,“msg”:“validating authorization”,“identifier”:“speed.cloudflare.com”,“problem”:{“type”:“urn:ietf:params:acme:error:unauthorized”,“title”:“”,“detail”:“104.16.67.38: Invalid response from http://speed.cloudflare.com/.well-known/acme-challenge/xxX8O7GPyCM9wXpCOcqiEVFNEKX6Bj4VmJ_9BxbK_0k: 404”,“instance”:“”,“subproblems”:[]},“order”:“https://acme-staging-v02.api.letsencrypt.org/acme/order/108729934/11939961214",“attempt”:1,"max_attempts”:3}
{“level”:“error”,“ts”:1698754672.6300678,“logger”:“tls.obtain”,“msg”:“could not get certificate from issuer”,“identifier”:“speed.cloudflare.com”,“issuer”:“acme-v02.api.letsencrypt.org-directory”,“error”:“HTTP 403 urn:ietf:params:acme:error:unauthorized - 104.16.67.38: Invalid response from http://speed.cloudflare.com/.well-known/acme-challenge/xxX8O7GPyCM9wXpCOcqiEVFNEKX6Bj4VmJ_9BxbK_0k: 404”}
{“level”:“error”,“ts”:1698754672.6301064,“logger”:“tls.obtain”,“msg”:“will retry”,“error”:“[speed.cloudflare.com] Obtain: [speed.cloudflare.com] solving challenge: speed.cloudflare.com: [speed.cloudflare.com] authorization failed: HTTP 403 urn:ietf:params:acme:error:unauthorized - 104.16.67.38: Invalid response from http://speed.cloudflare.com/.well-known/acme-challenge/xxX8O7GPyCM9wXpCOcqiEVFNEKX6Bj4VmJ_9BxbK_0k: 404 (ca=https://acme-staging-v02.api.letsencrypt.org/directory)”,“attempt”:2,“retrying_in”:120,“elapsed”:74.42617046,“max_duration”:2592000}
{“level”:“error”,“ts”:1698755608.3777645,“logger”:“http.acme_client”,“msg”:“challenge failed”,“identifier”:“speed.cloudflare.com”,“challenge_type”:“http-01”,“problem”:{“type”:“urn:ietf:params:acme:error:unauthorized”,“title”:“”,“detail”:“2606:4700::6810:4426: Invalid response from http://speed.cloudflare.com/.well-known/acme-challenge/Ldd0Xk20cYTUBHLMFUS-af7jrI1YKsTqGX-Eon3THYc: 404”,“instance”:“”,“subproblems”:[]}}
{“level”:“error”,“ts”:1698755608.378412,“logger”:“http.acme_client”,“msg”:“validating authorization”,“identifier”:“speed.cloudflare.com”,“problem”:{“type”:“urn:ietf:params:acme:error:unauthorized”,“title”:“”,“detail”:“2606:4700::6810:4426: Invalid response from http://speed.cloudflare.com/.well-known/acme-challenge/Ldd0Xk20cYTUBHLMFUS-af7jrI1YKsTqGX-Eon3THYc: 404”,“instance”:“”,“subproblems”:[]},“order”:“https://acme-v02.api.letsencrypt.org/acme/order/1178049587/218915118736",“attempt”:1,"max_attempts”:3}
{“level”:“error”,“ts”:1698755608.3788054,“logger”:“tls.obtain”,“msg”:“could not get certificate from issuer”,“identifier”:“speed.cloudflare.com”,“issuer”:“acme-v02.api.letsencrypt.org-directory”,“error”:“HTTP 403 urn:ietf:params:acme:error:unauthorized - 2606:4700::6810:4426: Invalid response from http://speed.cloudflare.com/.well-known/acme-challenge/Ldd0Xk20cYTUBHLMFUS-af7jrI1YKsTqGX-Eon3THYc: 404”}
{“level”:“error”,“ts”:1698755608.3791742,“logger”:“tls.obtain”,“msg”:“will retry”,“error”:“[speed.cloudflare.com] Obtain: [speed.cloudflare.com] solving challenge: speed.cloudflare.com: [speed.cloudflare.com] authorization failed: HTTP 403 urn:ietf:params:acme:error:unauthorized - 2606:4700::6810:4426: Invalid response from http://speed.cloudflare.com/.well-known/acme-challenge/Ldd0Xk20cYTUBHLMFUS-af7jrI1YKsTqGX-Eon3THYc: 404 (ca=https://acme-v02.api.letsencrypt.org/directory)”,“attempt”:1,“retrying_in”:60,“elapsed”:2.017895412,“max_duration”:2592000}
{“level”:“error”,“ts”:1698755680.2767751,“logger”:“http.acme_client”,“msg”:“challenge failed”,“identifier”:“speed.cloudflare.com”,“challenge_type”:“http-01”,“problem”:{“type”:“urn:ietf:params:acme:error:unauthorized”,“title”:“”,“detail”:“104.16.68.38: Invalid response from http://speed.cloudflare.com/.well-known/acme-challenge/ZlFLLCv0dvVGa0DLFdpA86jMXWh7OY3mo6ytNSAIOQI: 404”,“instance”:“”,“subproblems”:[]}}
{“level”:“error”,“ts”:1698755680.2768276,“logger”:“http.acme_client”,“msg”:“validating authorization”,“identifier”:“speed.cloudflare.com”,“problem”:{“type”:“urn:ietf:params:acme:error:unauthorized”,“title”:“”,“detail”:“104.16.68.38: Invalid response from http://speed.cloudflare.com/.well-known/acme-challenge/ZlFLLCv0dvVGa0DLFdpA86jMXWh7OY3mo6ytNSAIOQI: 404”,“instance”:“”,“subproblems”:[]},“order”:“https://acme-staging-v02.api.letsencrypt.org/acme/order/108729934/11940310284",“attempt”:1,"max_attempts”:3}
{“level”:“error”,“ts”:1698755680.2768598,“logger”:“tls.obtain”,“msg”:“could not get certificate from issuer”,“identifier”:“speed.cloudflare.com”,“issuer”:“acme-v02.api.letsencrypt.org-directory”,“error”:“HTTP 403 urn:ietf:params:acme:error:unauthorized - 104.16.68.38: Invalid response from http://speed.cloudflare.com/.well-known/acme-challenge/ZlFLLCv0dvVGa0DLFdpA86jMXWh7OY3mo6ytNSAIOQI: 404”}
{“level”:“error”,“ts”:1698755680.2769005,“logger”:“tls.obtain”,“msg”:“will retry”,“error”:“[speed.cloudflare.com] Obtain: [speed.cloudflare.com] solving challenge: speed.cloudflare.com: [speed.cloudflare.com] authorization failed: HTTP 403 urn:ietf:params:acme:error:unauthorized - 104.16.68.38: Invalid response from http://speed.cloudflare.com/.well-known/acme-challenge/ZlFLLCv0dvVGa0DLFdpA86jMXWh7OY3mo6ytNSAIOQI: 404 (ca=https://acme-staging-v02.api.letsencrypt.org/directory)”,“attempt”:2,“retrying_in”:120,“elapsed”:73.915622655,“max_duration”:2592000}
Total reclaimed space: 0B
- BACKUP_TIME=18:00
- DAILY_BACKUP=1
- set +x
[31-Oct-2023 19:26:48] WARNING: [pool www] child 272496 exited on signal 9 (SIGKILL) after 11.778574 seconds from start
[31-Oct-2023 19:26:48] NOTICE: [pool www] child 272525 started
{“level”:“error”,“ts”:1698841003.7316742,“logger”:“tls”,“msg”:“tls-alpn challenge”,“remote_addr”:“172.105.184.153:36116”,“server_name”:“”,“error”:"no information found to solve challenge for identifier: "}
[01-Nov-2023 20:03:28] WARNING: [pool www] child 526532 exited on signal 9 (SIGKILL) after 11.917838 seconds from start
[01-Nov-2023 20:03:28] NOTICE: [pool www] child 526559 started
[01-Nov-2023 20:04:26] WARNING: [pool www] child 526672 exited on signal 9 (SIGKILL) after 15.734192 seconds from start
[01-Nov-2023 20:04:26] NOTICE: [pool www] child 526699 started
[01-Nov-2023 20:59:35] WARNING: [pool www] child 535120 exited on signal 9 (SIGKILL) after 13.086290 seconds from start
[01-Nov-2023 20:59:35] NOTICE: [pool www] child 535149 started
++ head -1 /mnt/docker-aio-config/data/daily_backup_time - BACKUP_TIME=18:00
- DAILY_BACKUP=1
- set +x
[01-Nov-2023 22:18:00] WARNING: [pool www] child 547393 exited on signal 9 (SIGKILL) after 12.041813 seconds from start
[01-Nov-2023 22:18:00] NOTICE: [pool www] child 547422 started
[02-Nov-2023 02:30:33] WARNING: [pool www] child 587020 exited on signal 9 (SIGKILL) after 12.719225 seconds from start
[02-Nov-2023 02:30:33] NOTICE: [pool www] child 587040 started
[02-Nov-2023 02:36:56] WARNING: [pool www] child 588015 exited on signal 9 (SIGKILL) after 14.371679 seconds from start
[02-Nov-2023 02:36:56] NOTICE: [pool www] child 588051 started
[02-Nov-2023 02:53:07] WARNING: [pool www] child 590514 exited on signal 9 (SIGKILL) after 22.356974 seconds from start
[02-Nov-2023 02:53:07] NOTICE: [pool www] child 590533 started
[02-Nov-2023 03:27:36] WARNING: [pool www] child 595864 exited on signal 9 (SIGKILL) after 13.024417 seconds from start
[02-Nov-2023 03:27:36] NOTICE: [pool www] child 595898 started
[02-Nov-2023 03:27:49] WARNING: [pool www] child 595898 exited on signal 9 (SIGKILL) after 13.124664 seconds from start
[02-Nov-2023 03:27:49] NOTICE: [pool www] child 595926 started
[02-Nov-2023 04:07:15] WARNING: [pool www] child 601997 exited on signal 9 (SIGKILL) after 12.402803 seconds from start
[02-Nov-2023 04:07:15] NOTICE: [pool www] child 602029 started
[02-Nov-2023 04:15:02] WARNING: [pool www] child 603229 exited on signal 9 (SIGKILL) after 12.826237 seconds from start
[02-Nov-2023 04:15:02] NOTICE: [pool www] child 603253 started
[02-Nov-2023 04:21:02] WARNING: [pool www] child 604183 exited on signal 9 (SIGKILL) after 12.586580 seconds from start
[02-Nov-2023 04:21:02] NOTICE: [pool www] child 604211 started
[02-Nov-2023 05:32:06] WARNING: [pool www] child 615055 exited on signal 9 (SIGKILL) after 12.062469 seconds from start
[02-Nov-2023 05:32:06] NOTICE: [pool www] child 615088 started
[02-Nov-2023 06:23:25] WARNING: [pool www] child 623099 exited on signal 9 (SIGKILL) after 12.347416 seconds from start
[02-Nov-2023 06:23:25] NOTICE: [pool www] child 623123 started
[02-Nov-2023 07:04:56] WARNING: [pool www] child 629495 exited on signal 9 (SIGKILL) after 13.098995 seconds from start
[02-Nov-2023 07:04:56] NOTICE: [pool www] child 629519 started
[02-Nov-2023 07:10:18] WARNING: [pool www] child 630361 exited on signal 9 (SIGKILL) after 14.929274 seconds from start
[02-Nov-2023 07:10:18] NOTICE: [pool www] child 630401 started
[02-Nov-2023 07:10:32] WARNING: [pool www] child 630401 exited on signal 9 (SIGKILL) after 13.952304 seconds from start
[02-Nov-2023 07:10:32] NOTICE: [pool www] child 630427 started
[02-Nov-2023 07:31:17] WARNING: [pool www] child 633651 exited on signal 9 (SIGKILL) after 31.458634 seconds from start
[02-Nov-2023 07:31:17] NOTICE: [pool www] child 633663 started
[02-Nov-2023 08:28:33] WARNING: [pool www] child 642722 exited on signal 9 (SIGKILL) after 12.358193 seconds from start
[02-Nov-2023 08:28:33] NOTICE: [pool www] child 642747 started
[02-Nov-2023 09:58:20] WARNING: [pool www] child 656677 exited on signal 9 (SIGKILL) after 27.983705 seconds from start
[02-Nov-2023 09:58:20] NOTICE: [pool www] child 656760 started
[02-Nov-2023 10:24:14] WARNING: [pool www] child 660731 exited on signal 9 (SIGKILL) after 12.525265 seconds from start
[02-Nov-2023 10:24:14] NOTICE: [pool www] child 660767 started
[02-Nov-2023 10:42:52] WARNING: [pool www] child 663643 exited on signal 9 (SIGKILL) after 21.108423 seconds from start
[02-Nov-2023 10:42:52] NOTICE: [pool www] child 663706 started
[02-Nov-2023 10:44:51] WARNING: [pool www] child 663976 exited on signal 9 (SIGKILL) after 12.838635 seconds from start
[02-Nov-2023 10:44:51] NOTICE: [pool www] child 664008 started
[02-Nov-2023 10:51:54] WARNING: [pool www] child 665149 exited on signal 9 (SIGKILL) after 12.649461 seconds from start
[02-Nov-2023 10:51:54] NOTICE: [pool www] child 665179 started
[02-Nov-2023 10:58:05] WARNING: [pool www] child 666159 exited on signal 9 (SIGKILL) after 12.561669 seconds from start
[02-Nov-2023 10:58:05] NOTICE: [pool www] child 666181 started
[02-Nov-2023 10:58:53] WARNING: [pool www] child 666272 exited on signal 9 (SIGKILL) after 17.053615 seconds from start
[02-Nov-2023 10:58:53] NOTICE: [pool www] child 666327 started
[02-Nov-2023 11:54:37] WARNING: [pool www] child 675037 exited on signal 9 (SIGKILL) after 13.696015 seconds from start
[02-Nov-2023 11:54:37] NOTICE: [pool www] child 675065 started
[02-Nov-2023 12:30:15] WARNING: [pool www] child 680488 exited on signal 9 (SIGKILL) after 12.300264 seconds from start
[02-Nov-2023 12:30:15] NOTICE: [pool www] child 680517 started
[02-Nov-2023 12:30:29] WARNING: [pool www] child 680517 exited on signal 9 (SIGKILL) after 13.878199 seconds from start
[02-Nov-2023 12:30:29] NOTICE: [pool www] child 680542 started
[02-Nov-2023 12:30:46] WARNING: [pool www] child 680542 exited on signal 9 (SIGKILL) after 16.578005 seconds from start
[02-Nov-2023 12:30:46] NOTICE: [pool www] child 680597 started
[02-Nov-2023 12:56:33] WARNING: [pool www] child 681493 exited on signal 9 (SIGKILL) after 28.482092 seconds from start
[02-Nov-2023 12:58:01] NOTICE: [pool www] child 681502 started
[02-Nov-2023 12:58:13] WARNING: [pool www] child 681502 exited on signal 9 (SIGKILL) after 12.248818 seconds from start
[02-Nov-2023 12:58:13] NOTICE: [pool www] child 681515 started
[02-Nov-2023 12:58:34] WARNING: [pool www] child 681515 exited on signal 9 (SIGKILL) after 20.705617 seconds from start
[02-Nov-2023 12:58:34] NOTICE: [pool www] child 681539 started
[02-Nov-2023 12:58:59] WARNING: [pool www] child 681539 exited on signal 9 (SIGKILL) after 24.438800 seconds from start
[02-Nov-2023 12:58:59] NOTICE: [pool www] child 681566 started
[02-Nov-2023 12:59:11] WARNING: [pool www] child 681566 exited on signal 9 (SIGKILL) after 12.000643 seconds from start
[02-Nov-2023 12:59:11] NOTICE: [pool www] child 681569 started
[02-Nov-2023 12:59:24] WARNING: [pool www] child 681569 exited on signal 9 (SIGKILL) after 12.980315 seconds from start
[02-Nov-2023 12:59:24] NOTICE: [pool www] child 681570 started
[02-Nov-2023 13:00:56] WARNING: [pool www] child 681570 exited on signal 9 (SIGKILL) after 92.011714 seconds from start
[02-Nov-2023 13:00:56] NOTICE: [pool www] child 681599 started
[02-Nov-2023 13:01:13] WARNING: [pool www] child 681599 exited on signal 9 (SIGKILL) after 16.892550 seconds from start
[02-Nov-2023 13:01:13] NOTICE: [pool www] child 681616 started
[02-Nov-2023 13:20:46] WARNING: [pool www] child 681883 exited on signal 9 (SIGKILL) after 25.779936 seconds from start
[02-Nov-2023 13:20:46] NOTICE: [pool www] child 681955 started
[02-Nov-2023 13:21:02] WARNING: [pool www] child 681895 exited on signal 9 (SIGKILL) after 40.571462 seconds from start
[02-Nov-2023 13:21:02] NOTICE: [pool www] child 681959 started
[02-Nov-2023 13:21:15] WARNING: [pool www] child 681955 exited on signal 9 (SIGKILL) after 29.117025 seconds from start
[02-Nov-2023 13:21:15] NOTICE: [pool www] child 681998 started
[02-Nov-2023 13:22:01] WARNING: [pool www] child 681959 exited on signal 9 (SIGKILL) after 58.158992 seconds from start
[02-Nov-2023 13:22:01] NOTICE: [pool www] child 682047 started
[02-Nov-2023 13:22:09] WARNING: [pool www] child 681998 exited on signal 9 (SIGKILL) after 53.655259 seconds from start
[02-Nov-2023 13:22:09] NOTICE: [pool www] child 682048 started
[02-Nov-2023 13:23:06] WARNING: [pool www] child 682047 exited on signal 9 (SIGKILL) after 64.961464 seconds from start
[02-Nov-2023 13:23:06] NOTICE: [pool www] child 682082 started
[02-Nov-2023 13:23:20] WARNING: [pool www] child 682048 exited on signal 9 (SIGKILL) after 70.932322 seconds from start
[02-Nov-2023 13:23:20] NOTICE: [pool www] child 682095 started
[02-Nov-2023 13:25:16] WARNING: [pool www] child 682082 exited on signal 9 (SIGKILL) after 130.180171 seconds from start
[02-Nov-2023 13:25:16] NOTICE: [pool www] child 682105 started
[02-Nov-2023 13:25:39] WARNING: [pool www] child 682095 exited on signal 9 (SIGKILL) after 139.286011 seconds from start
[02-Nov-2023 13:26:21] NOTICE: [pool www] child 682146 started
[02-Nov-2023 13:26:24] WARNING: [pool www] child 682105 exited on signal 9 (SIGKILL) after 68.519660 seconds from start
[02-Nov-2023 13:26:24] NOTICE: [pool www] child 682150 started
[02-Nov-2023 13:27:02] WARNING: [pool www] child 682146 exited on signal 9 (SIGKILL) after 40.429539 seconds from start
[02-Nov-2023 13:27:02] NOTICE: [pool www] child 682167 started
[02-Nov-2023 13:27:29] WARNING: [pool www] child 682167 exited on signal 9 (SIGKILL) after 27.097755 seconds from start
[02-Nov-2023 13:27:29] NOTICE: [pool www] child 682238 started
[02-Nov-2023 13:55:14] WARNING: [pool www] child 686335 exited on signal 9 (SIGKILL) after 48.864327 seconds from start
[02-Nov-2023 13:55:14] NOTICE: [pool www] child 686350 started
[02-Nov-2023 13:57:09] WARNING: [pool www] child 686548 exited on signal 9 (SIGKILL) after 25.509051 seconds from start
[02-Nov-2023 13:57:09] NOTICE: [pool www] child 686587 started
[02-Nov-2023 13:59:07] WARNING: [pool www] child 686831 exited on signal 9 (SIGKILL) after 14.469512 seconds from start
[02-Nov-2023 13:59:07] NOTICE: [pool www] child 686865 started
[02-Nov-2023 14:07:39] WARNING: [pool www] child 687515 exited on signal 9 (SIGKILL) after 71.601811 seconds from start
[02-Nov-2023 14:07:39] NOTICE: [pool www] child 687591 started
[02-Nov-2023 14:07:52] WARNING: [pool www] child 687591 exited on signal 9 (SIGKILL) after 12.954240 seconds from start
[02-Nov-2023 14:07:52] NOTICE: [pool www] child 687601 started
[02-Nov-2023 14:08:15] WARNING: [pool www] child 687601 exited on signal 9 (SIGKILL) after 22.448731 seconds from start
[02-Nov-2023 14:08:15] NOTICE: [pool www] child 687606 started
[02-Nov-2023 14:08:29] WARNING: [pool www] child 687606 exited on signal 9 (SIGKILL) after 14.066245 seconds from start
[02-Nov-2023 14:08:29] NOTICE: [pool www] child 687617 started
[02-Nov-2023 14:08:50] WARNING: [pool www] child 687617 exited on signal 9 (SIGKILL) after 20.818851 seconds from start
[02-Nov-2023 14:08:50] NOTICE: [pool www] child 687620 started
[02-Nov-2023 14:09:12] WARNING: [pool www] child 687620 exited on signal 9 (SIGKILL) after 22.527123 seconds from start
[02-Nov-2023 14:09:12] NOTICE: [pool www] child 687638 started
[02-Nov-2023 14:09:42] WARNING: [pool www] child 687638 exited on signal 9 (SIGKILL) after 30.379691 seconds from start
[02-Nov-2023 14:09:42] NOTICE: [pool www] child 687652 started
[02-Nov-2023 14:10:17] WARNING: [pool www] child 687652 exited on signal 9 (SIGKILL) after 34.634599 seconds from start
[02-Nov-2023 14:10:17] NOTICE: [pool www] child 687675 started
[02-Nov-2023 14:11:06] WARNING: [pool www] child 687675 exited on signal 9 (SIGKILL) after 48.989863 seconds from start
[02-Nov-2023 14:11:06] NOTICE: [pool www] child 687723 started
[02-Nov-2023 14:12:21] WARNING: [pool www] child 687723 exited on signal 9 (SIGKILL) after 74.922444 seconds from start
[02-Nov-2023 14:12:21] NOTICE: [pool www] child 687761 started
[02-Nov-2023 14:12:56] WARNING: [pool www] child 687761 exited on signal 9 (SIGKILL) after 34.843860 seconds from start
[02-Nov-2023 14:13:03] NOTICE: [pool www] child 687781 started
[02-Nov-2023 14:13:38] WARNING: [pool www] child 687781 exited on signal 9 (SIGKILL) after 35.152416 seconds from start
[02-Nov-2023 14:13:38] NOTICE: [pool www] child 687803 started
[02-Nov-2023 14:13:50] WARNING: [pool www] child 687803 exited on signal 9 (SIGKILL) after 11.629925 seconds from start
[02-Nov-2023 14:13:50] NOTICE: [pool www] child 687822 started
[02-Nov-2023 14:17:28] WARNING: [pool www] child 688014 exited on signal 9 (SIGKILL) after 38.515538 seconds from start
[02-Nov-2023 14:17:30] NOTICE: [pool www] child 688061 started
[02-Nov-2023 14:17:34] WARNING: [pool www] child 688027 exited on signal 9 (SIGKILL) after 26.814013 seconds from start
[02-Nov-2023 14:17:34] NOTICE: [pool www] child 688068 started
[02-Nov-2023 14:17:50] WARNING: [pool www] child 688061 exited on signal 9 (SIGKILL) after 20.357951 seconds from start
[02-Nov-2023 14:17:50] NOTICE: [pool www] child 688080 started
[02-Nov-2023 14:18:02] WARNING: [pool www] child 688080 exited on signal 9 (SIGKILL) after 12.621814 seconds from start
[02-Nov-2023 14:18:03] NOTICE: [pool www] child 688110 started
[02-Nov-2023 14:30:28] WARNING: [pool www] child 688583 exited on signal 9 (SIGKILL) after 12.549636 seconds from start
[02-Nov-2023 14:30:28] NOTICE: [pool www] child 688620 started
[02-Nov-2023 14:30:41] WARNING: [pool www] child 688620 exited on signal 9 (SIGKILL) after 12.299202 seconds from start
[02-Nov-2023 14:30:41] NOTICE: [pool www] child 688653 started
[02-Nov-2023 14:31:05] WARNING: [pool www] child 688653 exited on signal 9 (SIGKILL) after 24.796717 seconds from start
[02-Nov-2023 14:31:05] NOTICE: [pool www] child 688672 started
[02-Nov-2023 14:32:54] WARNING: [pool www] child 688672 exited on signal 9 (SIGKILL) after 108.622941 seconds from start
[02-Nov-2023 14:32:54] NOTICE: [pool www] child 688687 started
[02-Nov-2023 14:33:39] WARNING: [pool www] child 688687 exited on signal 9 (SIGKILL) after 44.949081 seconds from start
[02-Nov-2023 14:33:39] NOTICE: [pool www] child 688727 started
[02-Nov-2023 14:33:57] WARNING: [pool www] child 688727 exited on signal 9 (SIGKILL) after 17.864790 seconds from start
[02-Nov-2023 14:33:57] NOTICE: [pool www] child 688739 started
[02-Nov-2023 14:34:51] WARNING: [pool www] child 688739 exited on signal 9 (SIGKILL) after 54.338811 seconds from start
[02-Nov-2023 14:35:46] NOTICE: [pool www] child 688780 started
[02-Nov-2023 14:36:02] WARNING: [pool www] child 688780 exited on signal 9 (SIGKILL) after 15.207457 seconds from start
[02-Nov-2023 14:36:02] NOTICE: [pool www] child 688807 started
[02-Nov-2023 14:36:17] WARNING: [pool www] child 688807 exited on signal 9 (SIGKILL) after 14.856444 seconds from start
[02-Nov-2023 14:36:17] NOTICE: [pool www] child 688825 started
[02-Nov-2023 14:37:07] WARNING: [pool www] child 688825 exited on signal 9 (SIGKILL) after 50.887093 seconds from start
[02-Nov-2023 14:38:38] NOTICE: [pool www] child 688912 started
[02-Nov-2023 14:40:57] WARNING: [pool www] child 688912 exited on signal 9 (SIGKILL) after 138.944501 seconds from start
[02-Nov-2023 14:41:52] NOTICE: [pool www] child 688939 started
[02-Nov-2023 14:42:10] WARNING: [pool www] child 688927 exited on signal 9 (SIGKILL) after 118.573050 seconds from start
[02-Nov-2023 14:42:26] NOTICE: [pool www] child 688954 started
[02-Nov-2023 14:42:45] WARNING: [pool www] child 688939 exited on signal 9 (SIGKILL) after 52.966174 seconds from start
[02-Nov-2023 14:42:45] NOTICE: [pool www] child 688972 started
[02-Nov-2023 14:42:56] WARNING: [pool www] child 688954 exited on signal 9 (SIGKILL) after 30.276484 seconds from start
[02-Nov-2023 14:42:56] NOTICE: [pool www] child 688978 started
[02-Nov-2023 14:43:24] WARNING: [pool www] child 688972 exited on signal 9 (SIGKILL) after 38.410893 seconds from start
[02-Nov-2023 14:43:24] NOTICE: [pool www] child 688992 started
[02-Nov-2023 14:43:27] WARNING: [pool www] child 688978 exited on signal 9 (SIGKILL) after 30.322696 seconds from start
[02-Nov-2023 14:43:27] NOTICE: [pool www] child 688999 started
[02-Nov-2023 15:05:58] WARNING: [pool www] child 692296 exited on signal 9 (SIGKILL) after 11.892276 seconds from start
[02-Nov-2023 15:05:58] NOTICE: [pool www] child 692322 started
[02-Nov-2023 15:20:51] WARNING: [pool www] child 694562 exited on signal 9 (SIGKILL) after 11.631392 seconds from start
[02-Nov-2023 15:20:51] NOTICE: [pool www] child 694595 started
[02-Nov-2023 15:21:56] WARNING: [pool www] child 694744 exited on signal 9 (SIGKILL) after 11.837552 seconds from start
[02-Nov-2023 15:21:56] NOTICE: [pool www] child 694782 started
[02-Nov-2023 15:30:30] WARNING: [pool www] child 696082 exited on signal 9 (SIGKILL) after 21.174371 seconds from start
[02-Nov-2023 15:30:30] NOTICE: [pool www] child 696135 started
[02-Nov-2023 15:42:39] WARNING: [pool www] child 697951 exited on signal 9 (SIGKILL) after 11.996855 seconds from start
[02-Nov-2023 15:42:39] NOTICE: [pool www] child 697979 started
[02-Nov-2023 15:50:59] WARNING: [pool www] child 699282 exited on signal 9 (SIGKILL) after 12.323038 seconds from start
[02-Nov-2023 15:50:59] NOTICE: [pool www] child 699313 started
[02-Nov-2023 16:25:19] WARNING: [pool www] child 704604 exited on signal 9 (SIGKILL) after 13.281538 seconds from start
[02-Nov-2023 16:25:19] NOTICE: [pool www] child 704636 started
[02-Nov-2023 16:43:13] WARNING: [pool www] child 707520 exited on signal 9 (SIGKILL) after 13.305208 seconds from start
[02-Nov-2023 16:43:13] NOTICE: [pool www] child 707548 started
[02-Nov-2023 16:47:48] WARNING: [pool www] child 708218 exited on signal 9 (SIGKILL) after 12.197207 seconds from start
[02-Nov-2023 16:47:48] NOTICE: [pool www] child 708248 started
[02-Nov-2023 17:15:24] WARNING: [pool www] child 712511 exited on signal 9 (SIGKILL) after 13.346021 seconds from start
[02-Nov-2023 17:15:24] NOTICE: [pool www] child 712536 started
[02-Nov-2023 18:29:51] WARNING: [pool www] child 724062 exited on signal 9 (SIGKILL) after 33.178509 seconds from start
[02-Nov-2023 18:29:51] NOTICE: [pool www] child 724101 started
[02-Nov-2023 19:29:31] WARNING: [pool www] child 733033 exited on signal 9 (SIGKILL) after 11.836158 seconds from start
[02-Nov-2023 19:29:31] NOTICE: [pool www] child 733062 started
[02-Nov-2023 19:32:38] WARNING: [pool www] child 733542 exited on signal 9 (SIGKILL) after 11.539702 seconds from start
[02-Nov-2023 19:32:38] NOTICE: [pool www] child 733561 started
[02-Nov-2023 19:39:33] WARNING: [pool www] child 734560 exited on signal 9 (SIGKILL) after 17.233081 seconds from start
[02-Nov-2023 19:39:33] NOTICE: [pool www] child 734590 started
[02-Nov-2023 20:03:15] WARNING: [pool www] child 738262 exited on signal 9 (SIGKILL) after 12.585190 seconds from start
[02-Nov-2023 20:03:15] NOTICE: [pool www] child 738291 started
[02-Nov-2023 20:05:02] WARNING: [pool www] child 738571 exited on signal 9 (SIGKILL) after 11.622185 seconds from start
[02-Nov-2023 20:05:02] NOTICE: [pool www] child 738605 started
[02-Nov-2023 23:15:12] WARNING: [pool www] child 766630 exited on signal 9 (SIGKILL) after 15.599990 seconds from start
[02-Nov-2023 23:15:12] NOTICE: [pool www] child 766681 started
[02-Nov-2023 23:41:54] WARNING: [pool www] child 770553 exited on signal 9 (SIGKILL) after 13.968427 seconds from start
[02-Nov-2023 23:41:54] NOTICE: [pool www] child 770591 started
[03-Nov-2023 00:00:06] WARNING: [pool www] child 773334 exited on signal 9 (SIGKILL) after 30.101120 seconds from start
[03-Nov-2023 00:00:06] NOTICE: [pool www] child 773417 started
- BACKUP_TIME=18:00
- DAILY_BACKUP=1
- set +x
[Fri Nov 03 01:34:26.730486 2023] [mpm_event:notice] [pid 102:tid 140216751348552] AH00489: Apache/2.4.58 (Unix) OpenSSL/3.1.3 configured – resuming normal operations
[Fri Nov 03 01:34:26.730605 2023] [core:notice] [pid 102:tid 140216751348552] AH00094: Command line: ‘httpd -D FOREGROUND’
{“level”:“info”,“ts”:1698975266.7442045,“msg”:“using provided configuration”,“config_file”:“/Caddyfile”,“config_adapter”:“”}
[03-Nov-2023 01:34:26] NOTICE: fpm is running, pid 107
[03-Nov-2023 01:34:26] NOTICE: ready to handle connections
Waiting for apache to become available
- BACKUP_TIME=18:00
- DAILY_BACKUP=1
- set +x
{“level”:“info”,“ts”:1698975657.5013034,“msg”:“using provided configuration”,“config_file”:“/Caddyfile”,“config_adapter”:“”}
[Fri Nov 03 01:40:57.710952 2023] [mpm_event:notice] [pid 102:tid 139722645908296] AH00489: Apache/2.4.58 (Unix) OpenSSL/3.1.3 configured – resuming normal operations
[Fri Nov 03 01:40:57.714728 2023] [core:notice] [pid 102:tid 139722645908296] AH00094: Command line: ‘httpd -D FOREGROUND’
[03-Nov-2023 01:40:57] NOTICE: fpm is running, pid 117
[03-Nov-2023 01:40:57] NOTICE: ready to handle connections
4
Message: Not found.
Line: 76
#13 {main}
- BACKUP_TIME=18:00
- DAILY_BACKUP=1
- set +x
{“level”:“info”,“ts”:1698976325.1491835,“msg”:“using provided configuration”,“config_file”:“/Caddyfile”,“config_adapter”:“”}
[Fri Nov 03 01:52:05.171946 2023] [mpm_event:notice] [pid 100:tid 140453383588680] AH00489: Apache/2.4.58 (Unix) OpenSSL/3.1.3 configured – resuming normal operations
[Fri Nov 03 01:52:05.172294 2023] [core:notice] [pid 100:tid 140453383588680] AH00094: Command line: ‘httpd -D FOREGROUND’
[03-Nov-2023 01:52:05] NOTICE: fpm is running, pid 108
[03-Nov-2023 01:52:05] NOTICE: ready to handle connections
- BACKUP_TIME=18:00
- DAILY_BACKUP=1
- set +x
[Fri Nov 03 01:53:38.351754 2023] [mpm_event:notice] [pid 102:tid 140262537759560] AH00489: Apache/2.4.58 (Unix) OpenSSL/3.1.3 configured – resuming normal operations
[Fri Nov 03 01:53:38.351848 2023] [core:notice] [pid 102:tid 140262537759560] AH00094: Command line: ‘httpd -D FOREGROUND’
[03-Nov-2023 01:53:38] NOTICE: fpm is running, pid 107
[03-Nov-2023 01:53:38] NOTICE: ready to handle connections
{“level”:“info”,“ts”:1698976418.3759437,“msg”:“using provided configuration”,“config_file”:“/Caddyfile”,“config_adapter”:“”}
4
Message: Not found.
Line: 76
#13 {main}
This is what I get when running this, sudo docker inspect nextcloud-aio && sudo docker inspect nextcloud-aio-mastercontainer?
“Name”: “nextcloud-aio”,
“Id”: “4c9d6cdf0f6ca24490a0d9997b3de7c5e37c64d5c1b91f27dccada3678dbb83d”,
“Created”: “2023-06-27T10:48:22.385453872Z”,
“Scope”: “local”,
“Driver”: “bridge”,
“EnableIPv6”: false,
“IPAM”: {
“Driver”: “default”,
“Options”: null,
“Config”: [
“Subnet”: “172.18.0.0/16”,
“Gateway”: “172.18.0.1”
“Internal”: false,
“Attachable”: false,
“Ingress”: false,
“ConfigFrom”: {
“Network”: “”
“ConfigOnly”: false,
“Containers”: {
“0957fcc541df624041586fe86e3e56272212bd22b554a8e0c385e67213ff7306”: {
“Name”: “nextcloud-aio-notify-push”,
“EndpointID”: “c906884a6f5f4646c5efc00d8c53d58cc582a18c75382646576c8b73aee6f9f5”,
“MacAddress”: “02:42:ac:12:00:03”,
“IPv4Address”: “172.18.0.3/16”,
“IPv6Address”: “”
“5c7685ac7d367d8001bc45b76ae00a7359e0bcf7f7d4dfffe3368af4553783e9”: {
“Name”: “nextcloud-aio-imaginary”,
“EndpointID”: “ff4dd774b0abdf9c2028af310ce01260539409fa84d6f83a97108a72f3396156”,
“MacAddress”: “02:42:ac:12:00:02”,
“IPv4Address”: “172.18.0.2/16”,
“IPv6Address”: “”
“8161b0983d0e0f93c1eeeb4ee263a9c0cb7b705527b9d0853574b4fd23f9ccb8”: {
“Name”: “nextcloud-aio-nextcloud”,
“EndpointID”: “e1ff0067f45777c6da055aa81cd77677ca9b00bfe580d3ec1809d45d97ea4131”,
“MacAddress”: “02:42:ac:12:00:04”,
“IPv4Address”: “172.18.0.4/16”,
“IPv6Address”: “”
“cb7a55b5be27b56708feae1e247506211929a40f23fdac78c9bf1caa768da86b”: {
“Name”: “nextcloud-aio-mastercontainer”,
“EndpointID”: “bb1642a2d3cfd18a27e50548b29f28d30a881e1c36e8ef03346f587cf541a519”,
“MacAddress”: “02:42:ac:12:00:05”,
“IPv4Address”: “172.18.0.5/16”,
“IPv6Address”: “”
“fbe532ff64325245c56231ce645db07057a6aa82a04c9e139336bcda2579adf9”: {
“Name”: “nextcloud-aio-apache”,
“EndpointID”: “86aa9eab8f24e6c7269b1cabf0c4f9fbcb92c6d702b0cbef64495389c72f3b90”,
“MacAddress”: “02:42:ac:12:00:06”,
“IPv4Address”: “172.18.0.6/16”,
“IPv6Address”: “”
“Options”: {},
“Labels”: {}
Error: No such object: nextcloud-aio-mastercontainer?
