Nextcloud AIO Using Docker With ZFS Share
Hey all, I have a NextCloud AIO instance I have set up and got running without issues internally with NextCloud. I am having issues attaching a share in NextCloud to my ZFS share which is an NFS share within my NAS. Any assistance to this would be appreciated. I am trying to expand it to my large share on my network while using NextCloud. I can both use and connect to NextCloud, and connect to and send files to my NAS. I cannot see or access the NAS directory in NextCloud despite it being hosted on the same system via Docker.
Nextcloud version (eg, 20.0.5): 6.0.0 AIO
Operating system and version (eg, Ubuntu 20.04): Fedora Server 37
Apache or nginx version (eg, Apache 2.4.25): AIO Version
PHP version (eg, 7.4): AIO Version
Mounting the ZFS share in NextCloud files.
Yes
  1. Install AIO VIA Docker
  2. Have a NAS with a ZFS Pool
  3. Issue is immediately there. Cannot connect to or transfer files into the ZFS Pool.
I want to make sure I understand your situation:
  • AIO is being hosted on your NAS
  • You have a folder on your NAS which you currently use as a ZFS Share (in NFS mode) outside of Nextcloud
  • You’d like to make the contents of that folder (the one used as a ZFS Share) available within Nextcloud?
Assuming you don’t want to replace your existing Nextcloud data directory, the easiest would probably be to:
The most reliable and highest performing approach would probably be bind mounting (in Docker) the NAS folder into your Nextcloud instance then either:
