I just converted my Nextcloud AIO 11.4.0 from direct to reverse proxy mode by doing a backup, resetting all the containers/networks/volumes, then restoring the backup.
The reverse proxy is Caddy, with port forwarding of tcp/udp 80/443 from my public IP. It’s working fine for other services on other servers. No ip6.
Nextcloud works in browser and for files, but some random other items don’t work anymore.
- Administration > Overview > Security & setup warnings
Spins, spins, spins, fails. All the failures say something like “could not resolve self”. For example:
Could not check that the data directory is protected. Please check manually that your server does not allow access to the data directory. To allow this check to run you have to make sure that your Web server can connect to itself. Therefore it must be able to resolve and connect to at least one of its
trusted_domainsor theoverwrite.cli.url. This failure may be the result of a server-side DNS mismatch or outbound firewall rule.
- Collabora can’t load
The logs show a bunch of errors like this.
cURL error 28: Connection timed out after 5002 milliseconds (see https://curl.haxx.se/libcurl/c/libcurl-errors.html) for https://{my-public-domain}/hosting/discovery
Some relevant info for troubleshooting…
The Nextcloud Security Scan works (beside the known bug Nextcloud Security Scan broken since weeks · Issue #54013 · nextcloud/server · GitHub) and gives an A+. This should rule out any public DNS and firewall issues.
overwriteprotocol => 'https' -
overwritehost => '{my-public-domain}' -
overwrite.cli.url => 'https://{my-public-domain}/' -
'trusted_domains'are'localhost'and'{my-public-domain}' -
'trusted_proxies'are autogenerated'127.0.0.1','::1','172.18.0.0/16'. I’ve also added the IP of my Caddy reverse proxy:'192.168.50.40' -
I used
docker execto confirmnslookup {my-public-domain}is correct from inside the Nextcloud bridge network. It returns my public IP address. -
I have NAT Reflection enabled (hairpinning) on both my port forward rules.
Any ideas how to troubleshoot further? Seems like DNS is fine, firewalls are fine, and yet Collabora and Nextcloud security checks are broken.
