32.06
Almalinux 10.1
No idea how to figgure out
nginx 1.26.3
- PHP version (e.g, 8.3):
No idea how to figgure out :/
Yes
Today
AIO
No
So today I restarted my raspberry pi, where my nextcloud AIO is running. I have a “special“ scenario here, because I use podman (rootless) to host nextcloud AIO instead of docker.
Now after the reboot I get `502 Bad Gateway` from my nginx. I am not sure but I think its because there is no mastercontainer there:
[nextcloud@cpi /]$ podman ps -a
CONTAINER ID IMAGE COMMAND CREATED STATUS PORTS NAMES
57b33b00645e ghcr.io/nextcloud-releases/aio-watchtower:latest 2 weeks ago Exited (0) 54 minutes ago nextcloud-aio-watchtower
750cd7e75b87 ghcr.io/nextcloud-releases/aio-borgbackup:latest 2 weeks ago Exited (0) 51 minutes ago nextcloud-aio-borgbackup
5eec6676d3d1 ghcr.io/nextcloud-releases/aio-notify-push:latest 2 weeks ago Exited (143) 50 minutes ago nextcloud-aio-notify-push
8063e7a88fbf ghcr.io/nextcloud-releases/aio-postgresql:latest 2 weeks ago Exited (1) 50 minutes ago 5432/tcp nextcloud-aio-database
84cb11077f22 ghcr.io/nextcloud-releases/aio-redis:latest 2 weeks ago Exited (0) 50 minutes ago 6379/tcp nextcloud-aio-redis
13ecb0a00f3a ghcr.io/nextcloud-releases/aio-nextcloud:latest /usr/bin/supervis... 2 weeks ago Exited (0) 50 minutes ago 9000/tcp nextcloud-aio-nextcloud
3815cfd766f0 ghcr.io/nextcloud-releases/aio-apache:latest /usr/bin/supervis... 2 weeks ago Up 4 minutes (healthy) 127.0.0.1:11000->11000/tcp, 80/tcp nextcloud-aio-apache
I am not quite sure if there should be a mastercontainer to see??
My mastercontainer should start automatically through this .container file:
[nextcloud@cpi /]$ cat ~/.config/containers/systemd/nextcloud-aio-mastercontainer.container
[Unit]
Description=Nextcloud AIO Master Container
Documentation=https://github.com/nextcloud/all-in-one/blob/main/docker-rootless.md
After=local-fs.target
Requires=podman.socket
[Container]
ContainerName=nextcloud-aio-mastercontainer
Image=docker.io/nextcloud/all-in-one:latest
AutoUpdate=registry
PublishPort=127.0.0.1:11001:8080
Volume=nextcloud_aio_mastercontainer:/mnt/docker-aio-config
Volume=/run/user/1002/podman/podman.sock:/var/run/docker.sock:ro,z
Network=bridge
SecurityLabelDisable=true
Environment=NEXTCLOUD_DATADIR="/media/raid1/nextcloud/"
Environment=APACHE_PORT=11000
Environment=APACHE_IP_BINDING=127.0.0.1
Environment=WATCHTOWER_DOCKER_SOCKET_PATH=/run/user/1002/podman/podman.sock
Environment=SKIP_DOMAIN_VALIDATION=true
[Install]
WantedBy=multi-user.target default.target
But it stays on fail, also when I restart it manually.
[nextcloud@cpi /]$ systemctl restart --user nextcloud-aio-mastercontainer.service
[nextcloud@cpi /]$ systemctl status --user nextcloud-aio-mastercontainer.service
× nextcloud-aio-mastercontainer.service - Nextcloud AIO Master Container
Loaded: loaded (/home/nextcloud/.config/containers/systemd/nextcloud-aio-mastercontainer.container; generated)
Active: failed (Result: exit-code) since Mon 2026-04-27 15:57:14 UTC; 7s ago
Duration: 736ms
Invocation: 9667508c633c4396b186c339e8e48153
Docs: https://github.com/nextcloud/all-in-one/blob/main/docker-rootless.md
Process: 11302 ExecStart=/usr/bin/podman run --name nextcloud-aio-mastercontainer --replace --rm --cgroups=split --network bridge --sdnotify=conmon -d --security-opt label=disable -v ne>
Process: 11425 ExecStopPost=/usr/bin/podman rm -v -f -i nextcloud-aio-mastercontainer (code=exited, status=0/SUCCESS)
Main PID: 11302 (code=exited, status=1/FAILURE)
CPU: 568ms
This is what the journal says when I execute the restart command above.
[root@cpi ~]# journalctl -f
Apr 27 15:59:19 cpi.jp.home systemd[926]: Starting nextcloud-aio-mastercontainer.service - Nextcloud AIO Master Container...
Apr 27 15:59:19 cpi.jp.home kernel: podman0: port 1(veth1) entered blocking state
Apr 27 15:59:19 cpi.jp.home kernel: podman0: port 1(veth1) entered disabled state
Apr 27 15:59:19 cpi.jp.home kernel: veth1: entered allmulticast mode
Apr 27 15:59:19 cpi.jp.home kernel: veth1: entered promiscuous mode
Apr 27 15:59:19 cpi.jp.home kernel: podman0: port 1(veth1) entered forwarding state
Apr 27 15:59:19 cpi.jp.home conmon[11807]: conmon 17e15b2a95107e1ec622 <nwarn>: Failed to add inotify watch for /sys/fs/cgroup/user.slice/user-1002.slice/user@1002.service/app.slice/nextcloud-aio-mastercontainer.service/libpod-payload-17e15b2a95107e1ec622f8729ded23ce4b802290141586087062e598b954c582/memory.events
Apr 27 15:59:19 cpi.jp.home systemd[926]: Started 17e15b2a95107e1ec622f8729ded23ce4b802290141586087062e598b954c582-4ee6bece61fe2eca.timer - [systemd-run] /usr/bin/podman healthcheck run 17e15b2a95107e1ec622f8729ded23ce4b802290141586087062e598b954c582.
Apr 27 15:59:19 cpi.jp.home systemd[926]: Started nextcloud-aio-mastercontainer.service - Nextcloud AIO Master Container.
Apr 27 15:59:19 cpi.jp.home nextcloud-aio-mastercontainer[11769]: 17e15b2a95107e1ec622f8729ded23ce4b802290141586087062e598b954c582
Apr 27 15:59:19 cpi.jp.home systemd[926]: Starting podman.service - Podman API Service...
Apr 27 15:59:19 cpi.jp.home systemd[926]: Started podman.service - Podman API Service.
Apr 27 15:59:19 cpi.jp.home conmon[11854]: conmon 17e15b2a95107e1ec622 <nwarn>: Failed to add inotify watch for /sys/fs/cgroup/user.slice/user-1002.slice/user@1002.service/app.slice/nextcloud-aio-mastercontainer.service/libpod-payload-17e15b2a95107e1ec622f8729ded23ce4b802290141586087062e598b954c582/memory.events
Apr 27 15:59:19 cpi.jp.home conmon[11854]: conmon 17e15b2a95107e1ec622 <nwarn>: Failed to open cgroups file: /sys/fs/cgroup/user.slice/user-1002.slice/user@1002.service/app.slice/nextcloud-aio-mastercontainer.service/libpod-payload-17e15b2a95107e1ec622f8729ded23ce4b802290141586087062e598b954c582/memory.events
Apr 27 15:59:19 cpi.jp.home podman[11850]: time="2026-04-27T15:59:19Z" level=info msg="/usr/bin/podman filtering at log level info"
Apr 27 15:59:19 cpi.jp.home podman[11850]: time="2026-04-27T15:59:19Z" level=info msg="Setting parallel job count to 13"
Apr 27 15:59:19 cpi.jp.home podman[11850]: time="2026-04-27T15:59:19Z" level=info msg="Using sqlite as database backend"
Apr 27 15:59:19 cpi.jp.home podman[11850]: time="2026-04-27T15:59:19Z" level=info msg="Using systemd socket activation to determine API endpoint"
Apr 27 15:59:19 cpi.jp.home podman[11850]: time="2026-04-27T15:59:19Z" level=info msg="API service listening on \"/run/user/1002/podman/podman.sock\". URI: \"unix:///run/user/1002/podman/podman.sock\""
Apr 27 15:59:19 cpi.jp.home podman[11816]: unhealthy
Apr 27 15:59:19 cpi.jp.home podman[11850]: @ - - [27/Apr/2026:15:59:19 +0000] "HEAD /_ping HTTP/1.1" 200 0 "" "Docker-Client/29.3.1 (linux)"
Apr 27 15:59:19 cpi.jp.home systemd[926]: 17e15b2a95107e1ec622f8729ded23ce4b802290141586087062e598b954c582-4ee6bece61fe2eca.service: Main process exited, code=exited, status=1/FAILURE
Apr 27 15:59:19 cpi.jp.home systemd[926]: 17e15b2a95107e1ec622f8729ded23ce4b802290141586087062e598b954c582-4ee6bece61fe2eca.service: Failed with result 'exit-code'.
Apr 27 15:59:19 cpi.jp.home podman[11850]: @ - - [27/Apr/2026:15:59:19 +0000] "GET /v1.41/info HTTP/1.1" 200 2487 "" "Docker-Client/29.3.1 (linux)"
Apr 27 15:59:19 cpi.jp.home podman[11850]: @ - - [27/Apr/2026:15:59:19 +0000] "GET /v1.41/version HTTP/1.1" 200 1029 "" "Docker-Client/29.3.1 (linux)"
Apr 27 15:59:19 cpi.jp.home conmon[11807]: conmon 17e15b2a95107e1ec622 <nwarn>: Failed to open cgroups file: /sys/fs/cgroup/user.slice/user-1002.slice/user@1002.service/app.slice/nextcloud-aio-mastercontainer.service/libpod-payload-17e15b2a95107e1ec622f8729ded23ce4b802290141586087062e598b954c582/memory.events
Apr 27 15:59:20 cpi.jp.home systemd[926]: Stopped 17e15b2a95107e1ec622f8729ded23ce4b802290141586087062e598b954c582-4ee6bece61fe2eca.timer - [systemd-run] /usr/bin/podman healthcheck run 17e15b2a95107e1ec622f8729ded23ce4b802290141586087062e598b954c582.
Apr 27 15:59:20 cpi.jp.home kernel: podman0: port 1(veth1) entered disabled state
Apr 27 15:59:20 cpi.jp.home kernel: veth1 (unregistering): left allmulticast mode
Apr 27 15:59:20 cpi.jp.home kernel: veth1 (unregistering): left promiscuous mode
Apr 27 15:59:20 cpi.jp.home systemd[926]: nextcloud-aio-mastercontainer.service: Main process exited, code=exited, status=1/FAILURE
Apr 27 15:59:20 cpi.jp.home systemd[926]: nextcloud-aio-mastercontainer.service: Failed with result 'exit-code'.
Apr 27 15:59:24 cpi.jp.home podman[11850]: time="2026-04-27T15:59:24Z" level=info msg="Received shutdown.Stop(), terminating!" PID=11850
Apr 27 15:59:35 cpi.jp.home conmon[11958]: conmon 3815cfd766f08e089f26 <nwarn>: Failed to add inotify watch for /sys/fs/cgroup/user.slice/user-1002.slice/user@1002.service/user.slice/libpod-3815cfd766f08e089f26a028f1428d90ac6d6b2626eb21335cba20a8e4b03dbe.scope/container/memory.events
Apr 27 15:59:35 cpi.jp.home conmon[11958]: conmon 3815cfd766f08e089f26 <nwarn>: Failed to open cgroups file: /sys/fs/cgroup/user.slice/user-1002.slice/user@1002.service/user.slice/libpod-3815cfd766f08e089f26a028f1428d90ac6d6b2626eb21335cba20a8e4b03dbe.scope/container/memory.events
Apr 27 15:59:37 cpi.jp.home conmon[11976]: conmon 1e8977e8f1eaa222895f <nwarn>: Failed to add inotify watch for /sys/fs/cgroup/user.slice/user-1003.slice/user@1003.service/app.slice/immich-redis.service/libpod-payload-1e8977e8f1eaa222895fc0489dbd6a81561313ac3da3820a7d42de4922155ee9/memory.events
Apr 27 15:59:37 cpi.jp.home conmon[11976]: conmon 1e8977e8f1eaa222895f <nwarn>: Failed to open cgroups file: /sys/fs/cgroup/user.slice/user-1003.slice/user@1003.service/app.slice/immich-redis.service/libpod-payload-1e8977e8f1eaa222895fc0489dbd6a81561313ac3da3820a7d42de4922155ee9/memory.events
Apr 27 15:59:38 cpi.jp.home systemd[1]: systemd-hostnamed.service: Deactivated successfully.
I know, its not much.
I am confused that the mastercontainer (maybe) tries to start-up , fails, and then immediatly disappears so neatly that I can’t tell if it ever existed at all.
Every help would be much appreciated!!!
