Hi. I’m currently installing NextCloud on Docker in purpose to share documents for my company later. Right now I’m having diffilcuties how to submit domain (AIO instance), is there any possiblity that I can use my IP public? Thank you.
Hi, what exactly is the error message?
I’m having a little bit diffilcuties where I need to submit domain to create AIO instance. I’m using duckdns but getting an error “Domain does not point to this server or the reverse proxy is not configured correctly. See the mastercontainer logs for more details. (‘sudo docker logs -f nextcloud-aio-mastercontainer’) If you should be using Cloudflare, make sure to disable the Cloudflare Proxy feature as it might block the domain validation. Same for any other firewall or service that blocks unencrypted access on port 443”.
