Nextcloud AIO failes to bring up nextcloud container after restore of my data
Nextcloud AIO issue. AIO failes to bringup nextcloud server after restore of my data.
  • Nextcloud AIO version v12.1.4
  • Operating system and version: Debian Bookworm on VPS
  • Behind NPM (Nginx Proxy Manager)
  • Is this the first time you’ve seen this error? Yes
  • When did this problem seem to first start? Maybee just a few days ago…
  • Installation method AIO on VPS
  • Are you using Cloudflare, mod_security, or similar? No
The Nextcloud Docker will not go green (log below) once I have completed a restore of my data. However, if I do a fresh install with no data it will come up. I need to figure out how to get it to come up with my data!
  1. Launch nextcloud AIO using this command:
docker run \
--init \
--sig-proxy=false \
--name nextcloud-aio-mastercontainer \
--restart always \
--publish 10.9.0.1:8080:8080 \
--env APACHE_PORT=11000 \
--env APACHE_IP_BINDING=10.9.0.1 \
--env APACHE_ADDITIONAL_NETWORK=“” \
--env SKIP_DOMAIN_VALIDATION=false \
--env NEXTCLOUD_DATADIR=“/mnt/data/nextcloud” \
--env TALK_PORT=3477 \
--env TALK_IP_BINDING=10.9.0.1 \
--env AIO_COMMUNITY_CONTAINERS=" " \
--volume nextcloud_aio_mastercontainer:/mnt/docker-aio-config \
--volume /var/run/docker.sock:/var/run/docker.sock:ro \
ghcr.io/nextcloud-releases/all-in-one:latest
2. Restore the borg backup of my data using AIO mastercontainer web gui
3. Start Containers
2025-12-09T15:21:46.295899800Z -------------------------------
2025-12-09T15:21:46.295928783Z  2025-12-09 08:21:46.294313-07
2025-12-09T15:21:46.295964897Z (1 row)
2025-12-09T15:21:46.295971238Z
2025-12-09T15:21:46.313446968Z + '[' -f /dev-dri-group-was-added ']'
2025-12-09T15:21:46.314525638Z ++ find /dev -maxdepth 1 -mindepth 1 -name dri
2025-12-09T15:21:46.317195898Z + '[' -n '' ']'
2025-12-09T15:21:46.318173802Z + set +x
2025-12-09T15:21:46.359985800Z Connection to nextcloud-aio-redis (172.19.0.8) 6379 port [tcp/redis] succeeded!
2025-12-09T15:21:46.765896713Z The initial Nextcloud installation failed.
2025-12-09T15:21:46.765948802Z For more information about what went wrong, check the logs above.
2025-12-09T15:21:46.765953708Z Please reset AIO properly and try again.
2025-12-09T15:21:46.765999167Z See:
2025-12-09T15:21:46.766007371Z   https://github.com/nextcloud/all-in-one#how-to-properly-reset-the-instance
2025-12-09T15:21:53.479431535Z Connection to nextcloud-aio-database (172.19.0.7) 5432 port [tcp/postgresql] succeeded!
2025-12-09T15:21:55.540608852Z               now
2025-12-09T15:21:55.540670357Z -------------------------------
PASTE
PASTE HERE
/var/lib/docker/volumes/nextcloud_aio_nextcloud/_data/config# cat config.php
'one-click-instance' => true,
'one-click-instance.user-limit' => 100,
'apps_paths' =>
0 =>
'url' => '/apps',
'writable' => false,
1 =>
'url' => '/custom_apps',
'writable' => true,
'check_data_directory_permissions' => false,
'redis' =>
'host' => 'nextcloud-aio-redis',
'password' => '8459b9b693e707b9ea48804f9a64904789a3b775e0b7840e',
'port' => 6379,
'overwritehost' => 'nc.alliumacres.ca',
'passwordsalt' => 'DfBnFq7vBJl3ghAMzCa6GhlB/xDg+p',
'secret' => 'nU6lH2WnMxAHAWlFtWvTCUHPFIgKykXrnEf6Yr8TjqtSG7ZV',
0 => 'localhost',
1 => 'nc.alliumacres.ca',
'datadirectory' => '/mnt/ncdata',
'dbtype' => 'pgsql',
'version' => '32.0.2.2',
'overwrite.cli.url' => 'https://nc.alliumacres.ca/',
'dbname' => 'nextcloud_database',
'dbhost' => 'nextcloud-aio-database:5432',
'dbuser' => 'oc_nextcloud',
'dbpassword' => 'e6544b0489394db11751bb051e6d557bf8596615c051ca9c',
'instanceid' => 'ocwteeia90xs',
'updatechecker' => false,
'loglevel' => 2,
'log_type' => 'file',
'logfile' => '/var/www/html/data/nextcloud.log',
'log_rotate_size' => 10485760,
'log.condition' =>
'apps' =>
0 => 'admin_audit',
'preview_max_x' => 2048,
'preview_max_y' => 2048,
'jpeg_quality' => 60,
'enabledPreviewProviders' =>
1 => 'OC\\Preview\\Image',
2 => 'OC\\Preview\\MarkDown',
3 => 'OC\\Preview\\MP3',
4 => 'OC\\Preview\\TXT',
5 => 'OC\\Preview\\OpenDocument',
6 => 'OC\\Preview\\Movie',
7 => 'OC\\Preview\\Krita',
0 => 'OC\\Preview\\Imaginary',
23 => 'OC\\Preview\\ImaginaryPDF',
'enable_previews' => true,
'mail_smtpmode' => 'smtp',
'versions_retention_obligation' => 'auto, 30',
'activity_expire_days' => 30,
'share_folder' => '/Shared',
'one-click-instance.link' => 'https://nextcloud.com/all-in-one/',
'upgrade.cli-upgrade-link' => 'https://github.com/nextcloud/all-in-one/discussions/2726',
'updatedirectory' => '/nc-updater',
'maintenance_window_start' => 100,
'allow_local_remote_servers' => true,
'davstorage.request_timeout' => 3600,
'documentation_url.server_logs' => 'https://github.com/nextcloud/all-in-one/discussions/5425',
'dbpersistent' => false,
'auth.bruteforce.protection.enabled' => true,
'ratelimit.protection.enabled' => true,
'files_external_allow_create_new_local' => false,
'trusted_proxies' =>
0 => '127.0.0.1',
1 => '::1',
10 => '172.19.0.0/16',
'preview_imaginary_url' => 'http://nextcloud-aio-imaginary:9000',
'preview_imaginary_key' => '423d79fe496a72652cb7adc290c5c732e9fa2a95d9b8df54',
Hi, have you followed the steps like e.g. mentioned starting from point 11 here?
See https://github.com/nextcloud/all-in-one?tab=readme-ov-file#how-to-migrate-from-aio-to-aio
Yes, I did this, and get the same result…
Hm… You could delete the install.failed file in the configured datadir and check if that helps
I also did try that. No go…
Can you point out how exactly you restored the data? So step by step what you did?
So I do have a snapshot of the DATADIR from when it last worked. But, I also ran a borg backup after reloading the AIO-Mastercontainer and then ran restore with a fresh AIO-mastercontainer after performing a clean fresh install as per - https://github.com/nextcloud/all-in-one?tab=readme-ov-file#how-to-migrate-from-aio-to-aio
Also, upon digging further i originally had this condition - https://github.com/nextcloud/all-in-one/issues/7223 however that no longer happens as I did re-install latest docker version on my bookworm VPS.
docker --version
Docker version 29.1.2, build 890dcca
Am I better of using the datadir snapshot perhaps? rather than the borg backup?
Thanks for your Help! I really hope I can get this back up!
Update!
I was able to restore with an older borg backup I had from Sept 8th. Then nextcloud sync actually moved all files missing since spet. 8th back on after that.
My biggest mistake was not having current backups, but looks like id did not loose much as I had the Sync setup with my desktop that restored the gap.
Question: I had a few share links I had setup since Sept 8th. Is there any way to restore those using the snapshot I took of my datadir a couple days ago before rebuilding?
PS: Another mistake, when my nextcloud broke with this condition: https://github.com/nextcloud/all-in-one/issues/7223 (They mention in here it happened to debian bookworm as well as synology). I should have taken a snapshot of the VPS before I started messing around, as I could have gone back to snapshot and fixed using resolution in this issue 7223.
Thanks!
