Nextcloud AIO container takes over 30 minutes to start
Hm, interesting.
Maybe one of your installed Nextcloud apps is causing this then.
You could disable one for one and check if that makes it work (or you disable all non-default apps and restart the containers to test this faster. Afterwards enable one for one again)…
Thank you very much @szaimen
I just tried this: I stopped and disabled all the containers optional and then started Nextcloud again. Instead of 30+ minutes, it took 15 minutes.
It’s a big improvement but when I was testing with a a new OS reinstall and a clean Nextcloud AIO instance (before restoring my borg backup) it took less than 5 minutes to start all the containers (including the optional ones).
Is this normal?
2024-09-04T15:25:48.539238546Z Enabling Imagick...
2024-09-04T15:25:50.105556443Z WARNING: opening from cache https://dl-cdn.alpinelinux.org/alpine/v3.20/main: No such file or directory
2024-09-04T15:25:50.105790053Z WARNING: opening from cache https://dl-cdn.alpinelinux.org/alpine/v3.20/community: No such file or directory
2024-09-04T15:25:50.147087190Z Connection to nextcloud-aio-redis (172.18.0.5) 6379 port [tcp/redis] succeeded!
Yes
Got it.
Thank you.
In case this might be useful, here are the logs that can be found at https://Local-IP:8080/api/docker/logs?id=nextcloud-aio-nextcloud
This is what was shown when I disabled all the optional containers and it took ~15 minutes to start.
2024-09-04T14:20:16.765800513Z Connection to nextcloud-aio-database (172.18.0.2) 5432 port [tcp/postgresql] succeeded!
2024-09-04T14:20:18.802343993Z               now
2024-09-04T14:20:18.802366238Z -------------------------------
2024-09-04T14:20:18.802371560Z  2024-09-04 10:20:18.801546-04
2024-09-04T14:20:18.802375853Z (1 row)
2024-09-04T14:20:18.802380034Z
2024-09-04T14:20:18.809449458Z + '[' -f /dev-dri-group-was-added ']'
2024-09-04T14:20:18.810013617Z ++ find /dev -maxdepth 1 -mindepth 1 -name dri
2024-09-04T14:20:18.810653087Z + '[' -n '' ']'
2024-09-04T14:20:18.810666794Z + set +x
2024-09-04T14:20:18.822567914Z Enabling Imagick...
2024-09-04T14:20:20.001270975Z WARNING: opening from cache https://dl-cdn.alpinelinux.org/alpine/v3.20/main: No such file or directory
2024-09-04T14:20:20.001294279Z WARNING: opening from cache https://dl-cdn.alpinelinux.org/alpine/v3.20/community: No such file or directory
2024-09-04T14:20:20.025352076Z Connection to nextcloud-aio-redis (172.18.0.3) 6379 port [tcp/redis] succeeded!
2024-09-04T14:21:21.203235781Z Applying one-click-instance settings...
2024-09-04T14:21:51.637322417Z System config value one-click-instance set to boolean true
2024-09-04T14:22:22.066859009Z System config value one-click-instance.user-limit set to integer 100
2024-09-04T14:22:52.494031712Z System config value one-click-instance.link set to string https://nextcloud.com/all-in-one/
2024-09-04T14:23:22.921088433Z support already enabled
2024-09-04T14:23:22.935583656Z Adjusting log files...
2024-09-04T14:23:53.343650063Z System config value upgrade.cli-upgrade-link set to string https://github.com/nextcloud/all-in-one/discussions/2726
2024-09-04T14:24:23.769512422Z System config value logfile set to string /var/www/html/data/nextcloud.log
2024-09-04T14:24:54.195325538Z Config value were not updated
2024-09-04T14:25:24.634546874Z System config value updatedirectory set to string /nc-updater
2024-09-04T14:25:55.072875670Z System config value maintenance_window_start set to integer 100
2024-09-04T14:25:55.087168124Z Applying network settings...
2024-09-04T14:26:25.521975372Z System config value allow_local_remote_servers set to boolean true
2024-09-04T14:26:55.969710181Z System config value davstorage.request_timeout set to integer 3600
2024-09-04T14:27:26.415935631Z System config value trusted_domains => 1 set to string secret.supersecurenc.org
2024-09-04T14:27:56.865110878Z System config value overwrite.cli.url set to string https://secret.supersecurenc.org/
2024-09-04T14:28:27.314353720Z System config value htaccess.RewriteBase set to string /
2024-09-04T14:28:57.760169624Z .htaccess has been updated
2024-09-04T14:29:28.207668112Z System config value dbpersistent set to boolean false
2024-09-04T14:29:58.658580743Z System config value auth.bruteforce.protection.enabled set to boolean true
2024-09-04T14:30:29.106472652Z System config value ratelimit.protection.enabled set to boolean true
2024-09-04T14:30:59.552247305Z System config value files_external_allow_create_new_local set to boolean false
2024-09-04T14:32:30.926394011Z notify_push is up-to-date or no updates could be found
2024-09-04T14:33:01.372228561Z System config value trusted_proxies => 0 set to string 127.0.0.1
2024-09-04T14:33:31.820075931Z System config value trusted_proxies => 1 set to string ::1
2024-09-04T14:34:02.293169031Z System config value trusted_proxies => 10 set to string 172.18.0.0/16
2024-09-04T14:34:32.740960256Z Config value were not updated
2024-09-04T14:35:03.194232017Z spreed disabled
2024-09-04T14:35:03.270940188Z spreed 19.0.8 removed
2024-09-04T14:35:03.690852813Z files_antivirus disabled
2024-09-04T14:35:03.705141728Z files_antivirus 5.5.7 removed
2024-09-04T14:35:04.531646168Z app_api disabled
2024-09-04T14:35:04.554126992Z app_api 3.1.0 removed
2024-09-04T14:35:04.590038774Z + '[' true = true ']'
2024-09-04T14:35:04.590066802Z + '[' 443 = 443 ']'
2024-09-04T14:35:04.590722351Z ++ dig nextcloud-aio-apache A +short +search
2024-09-04T14:35:04.591487268Z ++ grep '^[0-9.]\+$'
2024-09-04T14:35:04.591501229Z ++ sort
2024-09-04T14:35:04.591506599Z ++ head -n1
2024-09-04T14:35:04.611964152Z + IPv4_ADDRESS_APACHE=172.18.0.6
2024-09-04T14:35:04.612542037Z ++ dig nextcloud-aio-apache AAAA +short +search
2024-09-04T14:35:04.613557093Z ++ grep '^[0-9a-f:]\+$'
2024-09-04T14:35:04.613573851Z ++ sort
2024-09-04T14:35:04.613579164Z ++ head -n1
2024-09-04T14:35:04.633659699Z + IPv6_ADDRESS_APACHE=
2024-09-04T14:35:04.634239743Z ++ dig nextcloud-aio-mastercontainer A +short +search
2024-09-04T14:35:04.634253873Z ++ grep '^[0-9.]\+$'
2024-09-04T14:35:04.634388757Z ++ sort
2024-09-04T14:35:04.634559419Z ++ head -n1
2024-09-04T14:35:04.654825109Z + IPv4_ADDRESS_MASTERCONTAINER=172.18.0.14
2024-09-04T14:35:04.655388850Z ++ dig nextcloud-aio-mastercontainer AAAA +short +search
2024-09-04T14:35:04.655402361Z ++ grep '^[0-9a-f:]\+$'
2024-09-04T14:35:04.655535782Z ++ sort
2024-09-04T14:35:04.655640240Z ++ head -n1
2024-09-04T14:35:04.676997840Z + IPv6_ADDRESS_MASTERCONTAINER=
2024-09-04T14:35:04.677024398Z + sed -i 's|^;listen.allowed_clients|listen.allowed_clients|' /usr/local/etc/php-fpm.d/www.conf
2024-09-04T14:35:04.678817406Z + sed -i 's|listen.allowed_clients.*|listen.allowed_clients = 127.0.0.1,::1,172.18.0.6,,172.18.0.14,|' /usr/local/etc/php-fpm.d/www.conf
2024-09-04T14:35:04.680864980Z + sed -i '/^listen.allowed_clients/s/,,/,/g' /usr/local/etc/php-fpm.d/www.conf
2024-09-04T14:35:04.683401835Z + sed -i '/^listen.allowed_clients/s/,$//' /usr/local/etc/php-fpm.d/www.conf
2024-09-04T14:35:04.685008053Z + grep listen.allowed_clients /usr/local/etc/php-fpm.d/www.conf
2024-09-04T14:35:04.685959643Z listen.allowed_clients = 127.0.0.1,::1,172.18.0.6,172.18.0.14
2024-09-04T14:35:04.686118626Z + set +x
2024-09-04T14:35:06.026459339Z [04-Sep-2024 10:35:06] NOTICE: fpm is running, pid 680
2024-09-04T14:35:06.026488978Z [04-Sep-2024 10:35:06] NOTICE: ready to handle connections
About these logs, is there any way to get more detailed logs? Like putting this in debug mode or something like that to see all the steps? Because I think something in here is causing the issue because when I stop and then start all the containers and I check the logs for each one, all the containers are either waiting for the Nextcloud container to start or are already started.
each of the 4 steps “System config value” steps runs for 30 sec… the 5th step takes 1:30 (likely 3x30sec) not talking about the fact it usually takes on fragment of a second - 30 sec sounds for me like some timeout… is there some networking layer in between or some strange storage config which takes longer to confirm the write?
likely the problem remains once the system is up and running and you can reproduce the issue running some occ command… this gives you a chance to dig deeper into the problem once the system runs…
@szaimen - “System config value” performs just a simple config manipulation or is there more logic like networking operations included?
Hello there @wwe
Thank you for commenting on my post.
Yeah, I noticed that every single line in the log takes around 30 seconds each to complete. The networking has not change at all. I’ve been self hosting Nextcloud for a long time and just recently it started doing this.
Any occ command you want me to run to try to test if it take 30 seconds?
I would change some meaningless value… one of the mentioned is fine as well e.g. switch bruteforce protection off an on again… maybe the problem occurs already when you read the config… try to isolate the smallest possible operation where the delay is visible - later we can try to break down…
I tested an occ command and it worked right away. It didn’t take 30 seconds.
this a real mystery… I have no explanation why your interactive command runs fast while the one from AiO is slow… there seems to be nothing else - exactly the same command is executed in the entrypoint.sh:
do you have any resource limiting on your installation? which could exceed during massive operations and relax later during normal operations?
further look at you log shows not all operation are delayed in similar way…
until here it runs fast… the problem seems to start here:
do you see anything strange like high resource usage on redis container during this time? try running docker ps, docker compose stats or maybe redis-cli (e.g. docker compose exec -ti redis redis-cli MONITOR) to analyze if there is some excessive activity…
if not try to setup another AiO instance with another FQDN, fresh storage and minimum of functionality to verify the problem occurs there as well.
As I mentioned earlier, no. This is a standard AIO installation. I followed the instructions that can be found here.
Nothing is limiting Nextcloud since Nextcloud is the only thing installed in this VM.
If you read my previous comments you’ll see that I’ve already tried testing with a clean installation and even a clean OS install and everything works fine as it should. But when I restore the borg backup, everything slows down again.
In this case the problem is in the backup… there is not many things which could cause this problem - most likely the config. It should be not hard to work through the config setting by setting and find the difference.
@wwe Here is my configuration file.
  'one-click-instance' => true,
  'one-click-instance.user-limit' => 100,
  'apps_paths' =>
    0 =>
      'url' => '/apps',
      'writable' => false,
    1 =>
      'url' => '/custom_apps',
      'writable' => true,
  'appsallowlist' => false,
  'check_data_directory_permissions' => false,
  'redis' =>
    'host' => 'nextcloud-aio-redis',
    'password' => 'ThisPasswordIsVerySecure',
    'port' => 6379,
  'overwritehost' => 'secret.supersecurenc.org',
  'passwordsalt' => 'SomeSaltHash',
  'secret' => 'IWillTellYouThisSecret',
    0 => 'localhost',
    1 => 'secret.supersecurenc.org',
  'datadirectory' => '/mnt/ncdata',
  'dbtype' => 'pgsql',
  'version' => '29.0.4.1',
  'overwrite.cli.url' => 'https://secret.supersecurenc.org/',
  'dbname' => 'nextcloud_database',
  'dbhost' => 'nextcloud-aio-database',
  'dbuser' => 'oc_nextcloud',
  'dbpassword' => 'WellThisIsTheSuperSecureDBPassword',
  'instanceid' => 'AllThemIdsEverywhere',
  'loglevel' => 2,
  'log_type' => 'file',
  'logfile' => '/var/www/html/data/nextcloud.log',
  'log_rotate_size' => '10485760',
  'log.condition' =>
    'apps' =>
      0 => 'admin_audit',
  'preview_max_x' => 2048,
  'preview_max_y' => 2048,
  'jpeg_quality' => 60,
  'enabledPreviewProviders' =>
    1 => 'OC\\Preview\\Image',
    2 => 'OC\\Preview\\MarkDown',
    3 => 'OC\\Preview\\MP3',
    4 => 'OC\\Preview\\TXT',
    5 => 'OC\\Preview\\OpenDocument',
    6 => 'OC\\Preview\\Movie',
    7 => 'OC\\Preview\\Krita',
    0 => 'OC\\Preview\\Imaginary',
  'enable_previews' => true,
  'mail_smtpmode' => 'smtp',
  'versions_retention_obligation' => 'auto, 30',
  'activity_expire_days' => '30',
  'share_folder' => '/Shared',
  'one-click-instance.link' => 'https://nextcloud.com/all-in-one/',
  'upgrade.cli-upgrade-link' => 'https://github.com/nextcloud/all-in-one/discussions/2726',
  'updatedirectory' => '/nc-updater',
  'maintenance_window_start' => 100,
  'allow_local_remote_servers' => true,
  'davstorage.request_timeout' => 3600,
  'dbpersistent' => false,
  'files_external_allow_create_new_local' => false,
  'trusted_proxies' =>
    0 => '127.0.0.1',
    1 => '::1',
    10 => '172.18.0.0/16',
  'preview_imaginary_key' => 'HashForImaginaryKey',
  'default_phone_region' => 'US',
  'mail_smtpsecure' => 'ssl',
  'mail_from_address' => 'mailer',
  'mail_smtphost' => 'RandomSmtpHost.com',
  'mail_domain' => 'super-securenc.org',
  'mail_smtpport' => '123',
  'mail_smtpauth' => 1,
  'mail_smtpname' => 'mailtome@supersecurenc.org',
  'mail_smtppassword' => '12345qwertyNotMyRealPasswordTho',
  'memories.db.triggers.fcu' => true,
  'memories.exiftool' => '/var/www/html/custom_apps/memories/bin-ext/exiftool-amd64-musl',
  'memories.vod.path' => '/var/www/html/custom_apps/memories/bin-ext/go-vod-amd64',
  'auth.bruteforce.protection.enabled' => true,
  'ratelimit.protection.enabled' => true,
  'data-fingerprint' => 'FingerprintHash',
  'preview_imaginary_url' => 'http://nextcloud-aio-imaginary:9000',
Did you find anything in my configuration file that could be causing the delays?
Here are the system resources while Nextcloud is starting:
Hello everyone!
Today my Nextcloud got updated to version 29.0.6 and I noticed that even though the update process was slow, after it finished updating, the apps and containers started really fast.
So to test it, I stopped all the containers/apps and restarted the VM.
After the restart, I clicked Start containers and they started as fast as they used to before. So that means that the update to 29.0.6 fixed the issue. But how?
I don’t know how long this will stay like this but I’m glad.
Here is the log shown at https://internal.ip:8080/api/docker/logs?id=nextcloud-aio-nextcloud during the update:
2024-09-14T23:15:42.994679457Z Connection to nextcloud-aio-database (172.18.0.5) 5432 port [tcp/postgresql] succeeded!
2024-09-14T23:15:45.020983744Z               now
2024-09-14T23:15:45.021009317Z -------------------------------
2024-09-14T23:15:45.021015630Z  2024-09-14 19:15:45.019942-04
2024-09-14T23:15:45.021034632Z (1 row)
2024-09-14T23:15:45.021039774Z
2024-09-14T23:15:45.029057437Z + '[' -f /dev-dri-group-was-added ']'
2024-09-14T23:15:45.029473034Z ++ find /dev -maxdepth 1 -mindepth 1 -name dri
2024-09-14T23:15:45.030214881Z + '[' -n '' ']'
2024-09-14T23:15:45.030228770Z + set +x
2024-09-14T23:15:45.045416369Z Enabling Imagick...
2024-09-14T23:15:46.568741678Z WARNING: opening from cache https://dl-cdn.alpinelinux.org/alpine/v3.20/main: No such file or directory
2024-09-14T23:15:46.568765709Z WARNING: opening from cache https://dl-cdn.alpinelinux.org/alpine/v3.20/community: No such file or directory
2024-09-14T23:15:46.595061189Z Connection to nextcloud-aio-redis (172.18.0.6) 6379 port [tcp/redis] succeeded!
2024-09-14T23:15:46.904164224Z Checking connection to appstore
2024-09-14T23:15:47.499613969Z Appstore is reachable
2024-09-14T23:17:19.941921810Z Maintenance mode already disabled
2024-09-14T23:17:19.964822754Z Getting and backing up the status of apps for later, this might take a while...
2024-09-14T23:17:19.966989406Z Disabling apps before the update in order to make the update procedure more safe. This can take a while...
2024-09-14T23:18:21.157128718Z contacts 6.0.0 disabled
2024-09-14T23:19:22.227131018Z files_fulltextsearch 29.0.1 disabled
2024-09-14T23:20:23.257832809Z memories 7.3.1 disabled
2024-09-14T23:21:24.264501855Z notify_push 0.7.0 disabled
2024-09-14T23:22:25.272149217Z notes 4.10.1 disabled
2024-09-14T23:23:26.261181940Z tasks 0.16.1 disabled
2024-09-14T23:24:27.232569708Z No such app enabled: occweb
2024-09-14T23:25:28.208690040Z calendar 4.7.16 disabled
2024-09-14T23:26:29.178284005Z fulltextsearch 29.0.1 disabled
2024-09-14T23:27:30.124372012Z fulltextsearch_elasticsearch 29.0.1 disabled
2024-09-14T23:28:31.119731225Z app_api 3.2.0 disabled
2024-09-14T23:29:32.015312839Z files_antivirus 5.5.7 disabled
2024-09-14T23:30:32.900086039Z spreed 19.0.9 disabled
2024-09-14T23:30:33.739869125Z richdocuments 8.4.6 disabled
2024-09-14T23:30:34.548491923Z deck 1.13.1 disabled
2024-09-14T23:30:37.308844092Z All apps are up-to-date or no updates could be found
2024-09-14T23:30:38.475180389Z Initializing nextcloud 29.0.6.1 ...
2024-09-14T23:30:44.415332392Z Initializing finished
2024-09-14T23:30:44.417065668Z Upgrading nextcloud from 29.0.4.1 to 29.0.6.1...
2024-09-14T23:30:44.696003930Z Nextcloud or one of the apps require upgrade - only a limited number of commands are available
2024-09-14T23:30:44.696156810Z You may use your browser or the occ upgrade command to do the upgrade
2024-09-14T23:30:44.706838996Z System config value integrity.check.disabled deleted
2024-09-14T23:30:44.981775120Z Nextcloud or one of the apps require upgrade - only a limited number of commands are available
2024-09-14T23:30:44.981797295Z You may use your browser or the occ upgrade command to do the upgrade
2024-09-14T23:30:44.994414574Z Setting log level to debug
2024-09-14T23:30:44.996842013Z Turned on maintenance mode
2024-09-14T23:30:45.328042642Z Updating database schema
2024-09-14T23:30:45.335826907Z Updated database
2024-09-14T23:30:45.573421638Z Updating <files> ...
2024-09-14T23:30:45.603861988Z Updated <files> to 2.1.1
2024-09-14T23:30:49.280568853Z Starting code integrity check...
2024-09-14T23:30:58.391238961Z Finished code integrity check
2024-09-14T23:30:58.391754409Z Update successful
2024-09-14T23:30:58.391982094Z Turned off maintenance mode
2024-09-14T23:30:58.392107556Z Resetting log level
2024-09-14T23:30:58.820766765Z Nextcloud 29.0.6
2024-09-14T23:30:59.324334021Z Posting notifications to users that are admins...
2024-09-14T23:31:00.626184001Z Posting 'Nextcloud update to 29.0.6.1 successful!' to: admin
2024-09-14T23:31:01.998785637Z Done!
2024-09-14T23:31:02.424490875Z All apps are up-to-date or no updates could be found
2024-09-14T23:31:03.215500795Z Restoring the status of apps. This can take a while...
2024-09-14T23:31:03.215681782Z Enabling deck...
2024-09-14T23:31:03.657987198Z Enabling memories...
2024-09-14T23:31:04.879606668Z Enabling notes...
2024-09-14T23:31:05.349079407Z Enabling calendar...
2024-09-14T23:31:05.794663332Z Enabling notify_push...
2024-09-14T23:31:06.234000778Z Enabling richdocuments...
2024-09-14T23:31:06.687792631Z Enabling tasks...
2024-09-14T23:31:07.147815753Z Enabling spreed...
2024-09-14T23:31:07.668168397Z Enabling contacts...
2024-09-14T23:31:08.143512561Z Enabling files_antivirus...
2024-09-14T23:31:08.628442630Z Enabling app_api...
2024-09-14T23:31:09.144519693Z Enabling files_fulltextsearch...
2024-09-14T23:31:09.667638966Z Enabling fulltextsearch_elasticsearch...
2024-09-14T23:31:10.166327282Z Enabling fulltextsearch...
2024-09-14T23:31:11.197929807Z All apps are up-to-date or no updates could be found
2024-09-14T23:31:12.161092094Z Doing some optimizations...
2024-09-14T23:31:12.637140627Z  - Repair MySQL collation
2024-09-14T23:31:12.637172837Z      - Not a mysql database -> nothing to do
2024-09-14T23:31:12.637179221Z  - Clean tags and favorites
2024-09-14T23:31:12.640620239Z      - 0 tags of deleted users have been removed.
2024-09-14T23:31:12.647340675Z      - 0 tags for delete files have been removed.
2024-09-14T23:31:12.648005627Z      - 0 tag entries for deleted tags have been removed.
2024-09-14T23:31:12.648593807Z      - 0 tags with no entries have been removed.
2024-09-14T23:31:12.648605392Z  - Repair invalid shares
2024-09-14T23:31:12.651989190Z  - Move .step file of updater to backup location
2024-09-14T23:31:12.652009405Z  - Add move avatar background job
2024-09-14T23:31:12.652014700Z      - Repair step already executed
2024-09-14T23:31:12.652019239Z  - Add preview cleanup background jobs
2024-09-14T23:31:12.652023949Z  - Migrate oauth2_clients table to nextcloud schema
2024-09-14T23:31:12.919275304Z      - Update the oauth2_access_tokens table schema.
2024-09-14T23:31:13.139273067Z      - Update the oauth2_clients table schema.
2024-09-14T23:31:13.608392860Z      - Delete clients (and their related access tokens) with the redirect_uri starting with oc:// or ending with *
2024-09-14T23:31:13.611956154Z  - Fix potential broken mount points
2024-09-14T23:31:13.614092433Z      - No mounts updated
2024-09-14T23:31:13.614105839Z  - Repair language codes
2024-09-14T23:31:13.614111144Z  - Add log rotate job
2024-09-14T23:31:13.619061534Z  - Clear frontend caches
2024-09-14T23:31:13.619266422Z      - Image cache cleared
2024-09-14T23:31:13.639332038Z      - JS cache cleared
2024-09-14T23:31:13.639351498Z  - Clear every generated avatar
2024-09-14T23:31:13.639356800Z  - Add preview background cleanup job
2024-09-14T23:31:13.644061076Z  - Queue a one-time job to cleanup old backups of the updater
2024-09-14T23:31:13.648323633Z  - Cleanup invalid photocache files for carddav
2024-09-14T23:31:13.648344990Z  - Add background job to cleanup login flow v2 tokens
2024-09-14T23:31:13.652831012Z  - Remove potentially over exposing share links
2024-09-14T23:31:13.652850878Z      - No need to remove link shares.
2024-09-14T23:31:13.652856157Z  - Clear access cache of projects
2024-09-14T23:31:13.652860631Z  - Reset generated avatar flag
2024-09-14T23:31:13.652865049Z  - Keep legacy encryption enabled
2024-09-14T23:31:13.652869252Z  - Check encryption key format
2024-09-14T23:31:13.652873386Z  - Remove old dashboard app config data
2024-09-14T23:31:13.652877553Z  - Add job to cleanup the bruteforce entries
2024-09-14T23:31:13.656843288Z  - Queue a one-time job to check for user uploaded certificates
2024-09-14T23:31:13.656863186Z  - Repair DAV shares
2024-09-14T23:31:13.656882881Z  - Add background job to set the lookup server share state for users
2024-09-14T23:31:13.660759973Z  - Add token cleanup job
2024-09-14T23:31:13.664684029Z  - Clean up abandoned apps
2024-09-14T23:31:13.665917358Z  - Add possibly missing system config
2024-09-14T23:31:13.665933831Z  - Add AI tasks cleanup job
2024-09-14T23:31:13.673690631Z  - Queue a job to generate metadata
2024-09-14T23:31:13.677389033Z  - migrate lazy config values
2024-09-14T23:31:13.678704922Z  - Cache logo dimension to fix size in emails on Outlook
2024-09-14T23:31:13.678722755Z      - Theming is not used to provide a logo
2024-09-14T23:31:13.678898832Z  - Remove shares of old group memberships
2024-09-14T23:31:13.679893966Z  - Repair mime types
2024-09-14T23:31:13.741988438Z  - Validate the phone number and store it in a known format for search
2024-09-14T23:31:13.750479518Z  - Handle outdated scheduling events
2024-09-14T23:31:13.750499422Z      - Cleaning up old scheduling events
2024-09-14T23:31:13.753530814Z      - Adding background job to delete old scheduling objects
2024-09-14T23:31:13.757726714Z  - AppAPI Daemons configuration GPU params update
2024-09-14T23:31:13.759168077Z      - Daemons configuration GPU params updated: 0
2024-09-14T23:31:13.759188242Z  - Upgrading Circles App
2024-09-14T23:31:13.788189625Z  - Fix component of birthday calendars
2024-09-14T23:31:13.795867074Z      - 2 birthday calendars updated.
2024-09-14T23:31:13.795886876Z  - Regenerating birthday calendars to use new icons and fix old birthday events without year
2024-09-14T23:31:13.795892408Z      - Repair step already executed
2024-09-14T23:31:13.795897027Z  - Fix broken values of calendar objects
2024-09-14T23:31:13.801648545Z     0 [>---------------------------]
2024-09-14T23:31:13.801697165Z  - Registering building of calendar search index as background job
2024-09-14T23:31:13.801704398Z      - Repair step already executed
2024-09-14T23:31:13.801709101Z  - Register building of social profile search index as background job
2024-09-14T23:31:13.801713434Z      - Repair step already executed
2024-09-14T23:31:13.801720312Z  - Registering background jobs to update cache for webcal calendars
2024-09-14T23:31:13.803835243Z      - Added 0 background jobs to update webcal calendars
2024-09-14T23:31:13.803848775Z  - Registering building of calendar reminder index as background job
2024-09-14T23:31:13.803854133Z      - Repair step already executed
2024-09-14T23:31:13.803858593Z  - Clean up orphan event and contact data
2024-09-14T23:31:13.804690356Z      - 0 events without a calendar have been cleaned up
2024-09-14T23:31:13.808870074Z      - 0 properties without an events have been cleaned up
2024-09-14T23:31:13.810905384Z      - 0 changes without a calendar have been cleaned up
2024-09-14T23:31:13.811528413Z      - 0 cached events without a calendar subscription have been cleaned up
2024-09-14T23:31:13.812198228Z      - 0 changes without a calendar subscription have been cleaned up
2024-09-14T23:31:13.815484166Z      - 0 contacts without an addressbook have been cleaned up
2024-09-14T23:31:13.818328495Z      - 0 properties without a contact have been cleaned up
2024-09-14T23:31:13.820679615Z      - 0 changes without an addressbook have been cleaned up
2024-09-14T23:31:13.820696418Z  - Remove activity entries of private events
2024-09-14T23:31:13.838010813Z      - Removed 0 activity entries
2024-09-14T23:31:13.838032589Z  - Clean up old calendar subscriptions from deleted users that were not cleaned-up
2024-09-14T23:31:13.838566045Z     0 [->--------------------------]
2024-09-14T23:31:13.838579253Z      - 0 calendar subscriptions without an user have been cleaned up
2024-09-14T23:31:13.838584482Z  - Remove invalid object properties
2024-09-14T23:31:13.840719059Z      - 0 invalid object properties removed.
2024-09-14T23:31:13.840734602Z  - Fix the share type of guest shares when migrating from ownCloud
2024-09-14T23:31:13.840740191Z  - Copy the share password into the dedicated column
2024-09-14T23:31:13.840744905Z  - Set existing shares as accepted
2024-09-14T23:31:13.840749213Z  - Repair steps for Memories
2024-09-14T23:31:14.058523690Z      - External table schema seem up to date
2024-09-14T23:31:14.067151639Z      - Recreated filecache trigger with: Doctrine\DBAL\Platforms\PostgreSQL100Platform
2024-09-14T23:31:14.079103304Z      - exiftool binary is configured: /var/www/html/custom_apps/memories/bin-ext/exiftool-amd64-musl
2024-09-14T23:31:14.079121753Z      - go-vod binary is configured: /var/www/html/custom_apps/memories/bin-ext/go-vod-amd64
2024-09-14T23:31:14.079127003Z      - ffmpeg binary is configured: /usr/bin/ffmpeg
2024-09-14T23:31:14.079131800Z  - Clean up meta table
2024-09-14T23:31:14.080486370Z  - Show a hint about the new editor to existing users
2024-09-14T23:31:14.080500914Z  - Set binary permissions
2024-09-14T23:31:14.080506175Z  - Update OAuth token expiration times
2024-09-14T23:31:14.081060424Z  - init metadata
2024-09-14T23:31:14.081643138Z  - Create help command
2024-09-14T23:31:14.083234935Z  - Invalidate access cache for projects conversation provider
2024-09-14T23:31:14.083249646Z      - Invalidation not required
2024-09-14T23:31:14.083254956Z  - Cache the user display names
2024-09-14T23:31:14.085017847Z  - Switches from default updater server to the customer one if a valid subscription is available
2024-09-14T23:31:14.085045610Z      - Repair step already executed
2024-09-14T23:31:14.085051088Z  - Send an admin notification if monthly report is disabled
2024-09-14T23:31:14.091658871Z  - Force-reset all Text document sessions
2024-09-14T23:31:14.091682020Z  - Initialize migration of background images from dashboard to theming app
2024-09-14T23:31:14.096086838Z  - Add background job to check for backup codes
2024-09-14T23:31:14.100369819Z  - Populating added database structures for workflows
2024-09-14T23:31:14.847766094Z Adding additional systag_by_objectid index to the oc_systemtag_object_mapping table, this can take some time...
2024-09-14T23:31:15.119141332Z oc_systemtag_object_mapping table updated successfully.
2024-09-14T23:31:15.592402289Z Done.
2024-09-14T23:31:16.344346444Z Done.
2024-09-14T23:31:17.094783231Z All tables already up to date!
2024-09-14T23:31:18.547350734Z Applying one-click-instance settings...
2024-09-14T23:31:19.005080674Z System config value one-click-instance set to boolean true
2024-09-14T23:31:19.482877420Z System config value one-click-instance.user-limit set to integer 100
2024-09-14T23:31:19.958517549Z System config value one-click-instance.link set to string https://nextcloud.com/all-in-one/
2024-09-14T23:31:20.435265958Z support already enabled
2024-09-14T23:31:20.452925632Z Adjusting log files...
2024-09-14T23:31:20.941547232Z System config value upgrade.cli-upgrade-link set to string https://github.com/nextcloud/all-in-one/discussions/2726
2024-09-14T23:31:21.418493743Z System config value logfile set to string /var/www/html/data/nextcloud.log
2024-09-14T23:31:21.893405367Z Config value were not updated
2024-09-14T23:31:22.372173473Z System config value updatedirectory set to string /nc-updater
2024-09-14T23:31:22.849674288Z System config value maintenance_window_start set to integer 100
2024-09-14T23:31:22.870355658Z Applying network settings...
2024-09-14T23:31:23.359982971Z System config value allow_local_remote_servers set to boolean true
2024-09-14T23:31:23.835980319Z System config value davstorage.request_timeout set to integer 3600
2024-09-14T23:31:24.310024848Z System config value trusted_domains => 1 set to string secret.supersecurenc.org
2024-09-14T23:31:24.790900307Z System config value overwrite.cli.url set to string https://secret.supersecurenc.org/
2024-09-14T23:31:25.270050833Z System config value htaccess.RewriteBase set to string /
2024-09-14T23:31:25.771123881Z .htaccess has been updated
2024-09-14T23:31:26.247113975Z System config value dbpersistent set to boolean false
2024-09-14T23:31:26.726690786Z System config value auth.bruteforce.protection.enabled set to boolean true
2024-09-14T23:31:27.200328214Z System config value ratelimit.protection.enabled set to boolean true
2024-09-14T23:31:27.672910649Z System config value files_external_allow_create_new_local set to boolean false
2024-09-14T23:31:29.181689213Z notify_push is up-to-date or no updates could be found
2024-09-14T23:31:29.654371453Z System config value trusted_proxies => 0 set to string 127.0.0.1
2024-09-14T23:31:30.128821925Z System config value trusted_proxies => 1 set to string ::1
2024-09-14T23:31:30.653385986Z System config value trusted_proxies => 10 set to string 172.18.0.0/16
2024-09-14T23:31:31.140375014Z Config value were not updated
2024-09-14T23:31:31.156455904Z + echo nextcloud-aio-collabora
2024-09-14T23:31:31.156481838Z + grep -q 'nextcloud-.*-collabora'
2024-09-14T23:31:31.157589408Z + COLLABORA_HOST=secret.supersecurenc.org
2024-09-14T23:31:31.157601274Z + set +x
2024-09-14T23:31:32.170428204Z richdocuments is up-to-date or no updates could be found
2024-09-14T23:31:32.647930172Z Config value were not updated
2024-09-14T23:31:33.293382561Z No ipv6-address found for secret.supersecurenc.org.
2024-09-14T23:31:33.776936965Z Config value were not updated
2024-09-14T23:31:33.793834848Z + '[' -z '' ']'
2024-09-14T23:31:33.793857099Z + TALK_HOST=secret.supersecurenc.org
2024-09-14T23:31:33.793867169Z + HPB_PATH=/standalone-signaling/
2024-09-14T23:31:33.793872112Z + '[' -z '' ']'
2024-09-14T23:31:33.793876594Z + TURN_DOMAIN=secret.supersecurenc.org
2024-09-14T23:31:33.793881018Z + set +x
2024-09-14T23:31:34.797230289Z spreed is up-to-date or no updates could be found
2024-09-14T23:31:36.239512589Z Connection to nextcloud-aio-talk-recording (172.18.0.9) 1234 port [tcp/*] succeeded!
2024-09-14T23:31:36.700206840Z Config value were not updated
2024-09-14T23:31:36.718267859Z Connection to nextcloud-aio-clamav (172.18.0.7) 3310 port [tcp/*] succeeded!
2024-09-14T23:31:37.729816156Z files_antivirus is up-to-date or no updates could be found
2024-09-14T23:31:38.205228831Z Config value were not updated
2024-09-14T23:31:38.684221030Z Config value were not updated
2024-09-14T23:31:39.166779032Z Config value were not updated
2024-09-14T23:31:39.671146783Z Config value were not updated
2024-09-14T23:31:40.155126840Z Config value were not updated
2024-09-14T23:31:40.636375413Z Config value were not updated
2024-09-14T23:31:41.113954465Z System config value enabledPreviewProviders => 0 set to string OC\Preview\Imaginary
2024-09-14T23:31:41.603267850Z System config value preview_imaginary_url set to string http://nextcloud-aio-imaginary:9000
2024-09-14T23:31:42.104342085Z System config value preview_imaginary_key set to string ThisWasRemovedForPrivacy
2024-09-14T23:31:42.121969348Z Connection to nextcloud-aio-fulltextsearch (172.18.0.8) 9200 port [tcp/*] succeeded!
2024-09-14T23:31:43.106309846Z fulltextsearch is up-to-date or no updates could be found
2024-09-14T23:31:44.108269856Z fulltextsearch_elasticsearch is up-to-date or no updates could be found
2024-09-14T23:31:45.114199055Z files_fulltextsearch is up-to-date or no updates could be found
2024-09-14T23:31:45.589230146Z {
2024-09-14T23:31:45.589256013Z     "search_platform": "OCA\\FullTextSearch_Elasticsearch\\Platform\\ElasticSearchPlatform",
2024-09-14T23:31:45.589262109Z     "app_navigation": "0",
2024-09-14T23:31:45.589266741Z     "provider_indexed": "",
2024-09-14T23:31:45.589271297Z     "cron_err_reset": "1726298496",
2024-09-14T23:31:45.589279764Z     "tick_ttl": "1800",
2024-09-14T23:31:45.589285026Z     "collection_indexing_list": "50",
2024-09-14T23:31:45.589289527Z     "migration_24": "1",
2024-09-14T23:31:45.589293867Z     "collection_internal": "local"
2024-09-14T23:31:45.589298367Z }
2024-09-14T23:31:46.062848332Z {
2024-09-14T23:31:46.062869604Z     "elastic_host": "http:\/\/elastic:ThisWasRemovedForPrivacy@nextcloud-aio-fulltextsearch:9200",
2024-09-14T23:31:46.062875462Z     "elastic_index": "nextcloud-aio",
2024-09-14T23:31:46.062880794Z     "fields_limit": "10000",
2024-09-14T23:31:46.062885190Z     "es_ver_below66": "0",
2024-09-14T23:31:46.062890083Z     "elastic_logger_enabled": "true",
2024-09-14T23:31:46.062894507Z     "analyzer_tokenizer": "standard",
2024-09-14T23:31:46.062898866Z     "allow_self_signed_cert": "false"
2024-09-14T23:31:46.062903157Z }
2024-09-14T23:31:46.568605026Z {
2024-09-14T23:31:46.568628660Z     "files_local": "1",
2024-09-14T23:31:46.568634269Z     "files_external": "0",
2024-09-14T23:31:46.568638844Z     "files_group_folders": "0",
2024-09-14T23:31:46.568643152Z     "files_encrypted": "0",
2024-09-14T23:31:46.568647482Z     "files_federated": "0",
2024-09-14T23:31:46.568651671Z     "files_size": "20",
2024-09-14T23:31:46.568655978Z     "files_pdf": "1",
2024-09-14T23:31:46.568660231Z     "files_office": "1",
2024-09-14T23:31:46.568664557Z     "files_image": "0",
2024-09-14T23:31:46.568668809Z     "files_audio": "0",
2024-09-14T23:31:46.568673035Z     "files_chunk_size": "2"
2024-09-14T23:31:46.568677290Z }
2024-09-14T23:31:47.587493046Z app_api is up-to-date or no updates could be found
2024-09-14T23:31:47.627455694Z + '[' true = true ']'
2024-09-14T23:31:47.627493745Z + '[' 443 = 443 ']'
2024-09-14T23:31:47.629852455Z ++ dig nextcloud-aio-apache A +short +search
2024-09-14T23:31:47.629910569Z ++ grep '^[0-9.]\+$'
2024-09-14T23:31:47.630238240Z ++ head -n1
2024-09-14T23:31:47.630744638Z ++ sort
2024-09-14T23:31:47.651643071Z + IPv4_ADDRESS_APACHE=172.18.0.14
2024-09-14T23:31:47.652239688Z ++ dig nextcloud-aio-apache AAAA +short +search
2024-09-14T23:31:47.652295361Z ++ grep '^[0-9a-f:]\+$'
2024-09-14T23:31:47.652462731Z ++ sort
2024-09-14T23:31:47.652535928Z ++ head -n1
2024-09-14T23:31:47.673563101Z + IPv6_ADDRESS_APACHE=
2024-09-14T23:31:47.674329676Z ++ dig nextcloud-aio-mastercontainer A +short +search
2024-09-14T23:31:47.674345352Z ++ grep '^[0-9.]\+$'
2024-09-14T23:31:47.674545473Z ++ sort
2024-09-14T23:31:47.674666221Z ++ head -n1
2024-09-14T23:31:47.695644849Z + IPv4_ADDRESS_MASTERCONTAINER=172.18.0.2
2024-09-14T23:31:47.696302393Z ++ dig nextcloud-aio-mastercontainer AAAA +short +search
2024-09-14T23:31:47.697060687Z ++ grep '^[0-9a-f:]\+$'
2024-09-14T23:31:47.697076682Z ++ sort
2024-09-14T23:31:47.697082180Z ++ head -n1
2024-09-14T23:31:47.718169367Z + IPv6_ADDRESS_MASTERCONTAINER=
2024-09-14T23:31:47.718192461Z + sed -i 's|^;listen.allowed_clients|listen.allowed_clients|' /usr/local/etc/php-fpm.d/www.conf
2024-09-14T23:31:47.720437210Z + sed -i 's|listen.allowed_clients.*|listen.allowed_clients = 127.0.0.1,::1,172.18.0.14,,172.18.0.2,|' /usr/local/etc/php-fpm.d/www.conf
2024-09-14T23:31:47.723246711Z + sed -i '/^listen.allowed_clients/s/,,/,/g' /usr/local/etc/php-fpm.d/www.conf
2024-09-14T23:31:47.726122028Z + sed -i '/^listen.allowed_clients/s/,$//' /usr/local/etc/php-fpm.d/www.conf
2024-09-14T23:31:47.727819415Z + grep listen.allowed_clients /usr/local/etc/php-fpm.d/www.conf
2024-09-14T23:31:47.728855514Z listen.allowed_clients = 127.0.0.1,::1,172.18.0.14,172.18.0.2
2024-09-14T23:31:47.728965628Z + set +x
2024-09-14T23:31:49.108881965Z [14-Sep-2024 19:31:49] NOTICE: fpm is running, pid 1528
2024-09-14T23:31:49.108907613Z [14-Sep-2024 19:31:49] NOTICE: ready to handle connections
2024-09-14T23:32:03.963154712Z Activating Collabora config...
2024-09-14T23:32:04.447090379Z ✓ Reset callback url autodetect
2024-09-14T23:32:04.447118652Z Checking configuration
2024-09-14T23:32:04.447124217Z 🛈 Configured WOPI URL: https://secret.supersecurenc.org
2024-09-14T23:32:04.447128930Z 🛈 Configured public WOPI URL: https://secret.supersecurenc.org
2024-09-14T23:32:04.447133447Z 🛈 Configured callback URL:
2024-09-14T23:32:04.447138182Z
2024-09-14T23:32:04.601239150Z ✓ Fetched /hosting/discovery endpoint
2024-09-14T23:32:04.603313350Z ✓ Valid mimetype response
2024-09-14T23:32:04.605314131Z ✓ Valid capabilities entry
2024-09-14T23:32:04.703805002Z ✓ Fetched /hosting/capabilities endpoint
2024-09-14T23:32:04.703835929Z ✓ Detected WOPI server: Collabora Online Development Edition 24.04.7.1
2024-09-14T23:32:04.705930491Z
2024-09-14T23:32:04.705952028Z Collabora URL (used for Nextcloud to contact the Collabora server):
2024-09-14T23:32:04.705957807Z   https://secret.supersecurenc.org
2024-09-14T23:32:04.705962550Z Collabora public URL (used in the browser to open Collabora):
2024-09-14T23:32:04.705966888Z   https://secret.supersecurenc.org
2024-09-14T23:32:04.705971320Z Callback URL (used by Collabora to connect back to Nextcloud):
2024-09-14T23:32:04.705975679Z   autodetected (will use the same URL as your user for browsing Nextcloud)
And here’s the log shown at https://internal.ip:8080/api/docker/logs?id=nextcloud-aio-nextcloud after the test restart:
2024-09-14T23:56:56.593300668Z Connection to nextcloud-aio-database (172.18.0.5) 5432 port [tcp/postgresql] succeeded!
2024-09-14T23:56:58.738643528Z               now
2024-09-14T23:56:58.738676557Z -------------------------------
2024-09-14T23:56:58.738682374Z  2024-09-14 19:56:58.723937-04
2024-09-14T23:56:58.738686995Z (1 row)
2024-09-14T23:56:58.738696993Z
2024-09-14T23:56:58.764654687Z + '[' -f /dev-dri-group-was-added ']'
2024-09-14T23:56:58.768331763Z ++ find /dev -maxdepth 1 -mindepth 1 -name dri
2024-09-14T23:56:58.779241271Z + '[' -n '' ']'
2024-09-14T23:56:58.779276999Z + set +x
2024-09-14T23:56:58.838034519Z Enabling Imagick...
2024-09-14T23:57:00.921813763Z WARNING: opening from cache https://dl-cdn.alpinelinux.org/alpine/v3.20/main: No such file or directory
2024-09-14T23:57:00.921857710Z WARNING: opening from cache https://dl-cdn.alpinelinux.org/alpine/v3.20/community: No such file or directory
2024-09-14T23:57:00.965404873Z Connection to nextcloud-aio-redis (172.18.0.6) 6379 port [tcp/redis] succeeded!
2024-09-14T23:57:03.897334054Z Applying one-click-instance settings...
2024-09-14T23:57:04.493150810Z System config value one-click-instance set to boolean true
2024-09-14T23:57:05.099977875Z System config value one-click-instance.user-limit set to integer 100
2024-09-14T23:57:05.680010425Z System config value one-click-instance.link set to string https://nextcloud.com/all-in-one/
2024-09-14T23:57:06.582052630Z support already enabled
2024-09-14T23:57:06.606342822Z Adjusting log files...
2024-09-14T23:57:07.281553165Z System config value upgrade.cli-upgrade-link set to string https://github.com/nextcloud/all-in-one/discussions/2726
2024-09-14T23:57:07.886100943Z System config value logfile set to string /var/www/html/data/nextcloud.log
2024-09-14T23:57:08.448863820Z Config value were not updated
2024-09-14T23:57:09.052432801Z System config value updatedirectory set to string /nc-updater
2024-09-14T23:57:09.798832222Z System config value maintenance_window_start set to integer 100
2024-09-14T23:57:09.830381181Z Applying network settings...
2024-09-14T23:57:10.635137587Z System config value allow_local_remote_servers set to boolean true
2024-09-14T23:57:11.203646392Z System config value davstorage.request_timeout set to integer 3600
2024-09-14T23:57:11.998633896Z System config value trusted_domains => 1 set to string secret.supersecurenc.org
2024-09-14T23:57:12.652136794Z System config value overwrite.cli.url set to string https://secret.supersecurenc.org/
2024-09-14T23:57:13.403251879Z System config value htaccess.RewriteBase set to string /
2024-09-14T23:57:14.023175831Z .htaccess has been updated
2024-09-14T23:57:14.694250047Z System config value dbpersistent set to boolean false
2024-09-14T23:57:15.362168619Z System config value auth.bruteforce.protection.enabled set to boolean true
2024-09-14T23:57:16.082316382Z System config value ratelimit.protection.enabled set to boolean true
2024-09-14T23:57:16.762223806Z System config value files_external_allow_create_new_local set to boolean false
2024-09-14T23:57:19.007352846Z notify_push is up-to-date or no updates could be found
2024-09-14T23:57:19.606479078Z System config value trusted_proxies => 0 set to string 127.0.0.1
2024-09-14T23:57:20.277999872Z System config value trusted_proxies => 1 set to string ::1
2024-09-14T23:57:21.079273876Z System config value trusted_proxies => 10 set to string 172.18.0.0/16
2024-09-14T23:57:21.747084630Z Config value were not updated
2024-09-14T23:57:21.765347936Z + + grep echo -q nextcloud-aio-collabora
2024-09-14T23:57:21.765384875Z 'nextcloud-.*-collabora'
2024-09-14T23:57:21.766796281Z + COLLABORA_HOST=secret.supersecurenc.org
2024-09-14T23:57:21.766817027Z + set +x
2024-09-14T23:57:22.898211973Z richdocuments is up-to-date or no updates could be found
2024-09-14T23:57:23.436354569Z Config value were not updated
2024-09-14T23:57:28.089140786Z No ipv6-address found for secret.supersecurenc.org.
2024-09-14T23:57:28.567213545Z Config value were not updated
2024-09-14T23:57:28.586100945Z + '[' -z '' ']'
2024-09-14T23:57:28.586126737Z + TALK_HOST=secret.supersecurenc.org
2024-09-14T23:57:28.586132776Z + HPB_PATH=/standalone-signaling/
2024-09-14T23:57:28.586137381Z + '[' -z '' ']'
2024-09-14T23:57:28.586142100Z + TURN_DOMAIN=secret.supersecurenc.org
2024-09-14T23:57:28.586146583Z + set +x
2024-09-14T23:57:29.623836003Z spreed is up-to-date or no updates could be found
2024-09-14T23:57:31.124249077Z Connection to nextcloud-aio-talk-recording (172.18.0.9) 1234 port [tcp/*] succeeded!
2024-09-14T23:57:31.604554630Z Config value were not updated
2024-09-14T23:57:31.623227942Z Connection to nextcloud-aio-clamav (172.18.0.7) 3310 port [tcp/*] succeeded!
2024-09-14T23:57:32.684801625Z files_antivirus is up-to-date or no updates could be found
2024-09-14T23:57:33.184605620Z Config value were not updated
2024-09-14T23:57:33.685056891Z Config value were not updated
2024-09-14T23:57:34.181619964Z Config value were not updated
2024-09-14T23:57:34.682037331Z Config value were not updated
2024-09-14T23:57:35.180902057Z Config value were not updated
2024-09-14T23:57:35.669212816Z Config value were not updated
2024-09-14T23:57:36.172998241Z System config value enabledPreviewProviders => 0 set to string OC\Preview\Imaginary
2024-09-14T23:57:36.700555436Z System config value preview_imaginary_url set to string http://nextcloud-aio-imaginary:9000
2024-09-14T23:57:37.194759166Z System config value preview_imaginary_key set to string ThisWasRemovedForPrivacy
2024-09-14T23:57:37.211377234Z Connection to nextcloud-aio-fulltextsearch (172.18.0.8) 9200 port [tcp/*] succeeded!
2024-09-14T23:57:38.235396379Z fulltextsearch is up-to-date or no updates could be found
2024-09-14T23:57:39.289469081Z fulltextsearch_elasticsearch is up-to-date or no updates could be found
2024-09-14T23:57:40.332008621Z files_fulltextsearch is up-to-date or no updates could be found
2024-09-14T23:57:40.841222157Z {
2024-09-14T23:57:40.841247269Z     "search_platform": "OCA\\FullTextSearch_Elasticsearch\\Platform\\ElasticSearchPlatform",
2024-09-14T23:57:40.841253238Z     "app_navigation": "0",
2024-09-14T23:57:40.841257705Z     "provider_indexed": "",
2024-09-14T23:57:40.841261961Z     "cron_err_reset": "1726298496",
2024-09-14T23:57:40.841266124Z     "tick_ttl": "1800",
2024-09-14T23:57:40.841270381Z     "collection_indexing_list": "50",
2024-09-14T23:57:40.841274590Z     "migration_24": "1",
2024-09-14T23:57:40.841278949Z     "collection_internal": "local"
2024-09-14T23:57:40.841283166Z }
2024-09-14T23:57:41.337552110Z {
2024-09-14T23:57:41.337583785Z     "elastic_host": "http:\/\/elastic:ThisWasRemovedForPrivacy@nextcloud-aio-fulltextsearch:9200",
2024-09-14T23:57:41.337590631Z     "elastic_index": "nextcloud-aio",
2024-09-14T23:57:41.337595510Z     "fields_limit": "10000",
2024-09-14T23:57:41.337599742Z     "es_ver_below66": "0",
2024-09-14T23:57:41.337604351Z     "elastic_logger_enabled": "true",
2024-09-14T23:57:41.337609335Z     "analyzer_tokenizer": "standard",
2024-09-14T23:57:41.337613832Z     "allow_self_signed_cert": "false"
2024-09-14T23:57:41.337618042Z }
2024-09-14T23:57:41.834400136Z {
2024-09-14T23:57:41.834518894Z     "files_local": "1",
2024-09-14T23:57:41.834527172Z     "files_external": "0",
2024-09-14T23:57:41.834531963Z     "files_group_folders": "0",
2024-09-14T23:57:41.834536722Z     "files_encrypted": "0",
2024-09-14T23:57:41.834540997Z     "files_federated": "0",
2024-09-14T23:57:41.834545499Z     "files_size": "20",
2024-09-14T23:57:41.834549708Z     "files_pdf": "1",
2024-09-14T23:57:41.834553869Z     "files_office": "1",
2024-09-14T23:57:41.834558157Z     "files_image": "0",
2024-09-14T23:57:41.834562382Z     "files_audio": "0",
2024-09-14T23:57:41.834566633Z     "files_chunk_size": "2"
2024-09-14T23:57:41.834571217Z }
2024-09-14T23:57:42.854309541Z app_api is up-to-date or no updates could be found
2024-09-14T23:57:42.900267071Z + '[' true = true ']'
2024-09-14T23:57:42.900304011Z + '[' 443 = 443 ']'
2024-09-14T23:57:42.901410348Z ++ dig nextcloud-aio-apache A +short +search
2024-09-14T23:57:42.901429215Z ++ grep '^[0-9.]\+$'
2024-09-14T23:57:42.901434821Z ++ sort
2024-09-14T23:57:42.901439144Z ++ head -n1
2024-09-14T23:57:42.921948794Z + IPv4_ADDRESS_APACHE=172.18.0.14
2024-09-14T23:57:42.922556758Z ++ dig nextcloud-aio-apache AAAA +short +search
2024-09-14T23:57:42.922966533Z ++ grep '^[0-9a-f:]\+$'
2024-09-14T23:57:42.922979648Z ++ sort
2024-09-14T23:57:42.922984999Z ++ head -n1
2024-09-14T23:57:42.945697985Z + IPv6_ADDRESS_APACHE=
2024-09-14T23:57:42.946339770Z ++ dig nextcloud-aio-mastercontainer A +short +search
2024-09-14T23:57:42.946597131Z ++ grep '^[0-9.]\+$'
2024-09-14T23:57:42.946841728Z ++ ++ head sort-n1
2024-09-14T23:57:42.946851552Z
2024-09-14T23:57:42.967892003Z + IPv4_ADDRESS_MASTERCONTAINER=172.18.0.2
2024-09-14T23:57:42.969092427Z ++ dig nextcloud-aio-mastercontainer AAAA +short +search
2024-09-14T23:57:42.969113165Z ++ grep '^[0-9a-f:]\+$'
2024-09-14T23:57:42.969225903Z ++ sort
2024-09-14T23:57:42.969505931Z ++ head -n1
2024-09-14T23:57:42.991964080Z + IPv6_ADDRESS_MASTERCONTAINER=
2024-09-14T23:57:42.991991328Z + sed -i 's|^;listen.allowed_clients|listen.allowed_clients|' /usr/local/etc/php-fpm.d/www.conf
2024-09-14T23:57:42.994466719Z + sed -i 's|listen.allowed_clients.*|listen.allowed_clients = 127.0.0.1,::1,172.18.0.14,,172.18.0.2,|' /usr/local/etc/php-fpm.d/www.conf
2024-09-14T23:57:42.996955076Z + sed -i '/^listen.allowed_clients/s/,,/,/g' /usr/local/etc/php-fpm.d/www.conf
2024-09-14T23:57:42.999925859Z + sed -i '/^listen.allowed_clients/s/,$//' /usr/local/etc/php-fpm.d/www.conf
2024-09-14T23:57:43.002036177Z + grep listen.allowed_clients /usr/local/etc/php-fpm.d/www.conf
2024-09-14T23:57:43.002959492Z listen.allowed_clients = 127.0.0.1,::1,172.18.0.14,172.18.0.2
2024-09-14T23:57:43.003281319Z + set +x
2024-09-14T23:57:44.492987098Z [14-Sep-2024 19:57:44] NOTICE: fpm is running, pid 650
2024-09-14T23:57:44.493014627Z [14-Sep-2024 19:57:44] NOTICE: ready to handle connections
I tried to check line per line what changed but I couldn’t find anything.
Can any of you notice anything I didn’t? What could’ve fixed this?
Thanks in advance!
I came back to this thread - before knowing the above - to post that while I’m mystified why you’re experiencing the stated problem, I was keeping an eye on the thread because I really really wanted to get to the bottom of the mystery!
I’m glad it’s behaving more normally for you now. Though I’m still just as mystified as to why. :wink:
