Nextcloud AIO Auto Logout
I previously asked the following for snap https://help.nextcloud.com/t/nextcloud-snap-office-single-user-multi-login/226596
However, i have tried adding the ‘session_lifetime’ and ‘auto_logout’ into AIO’s config.php and it stops the website from running, on deletion it works again.
Is there another way to add them?
Thanks,
Dave
Stops from running… how? Can you be more specific? What do your browser console and server logs say? You may want to use the support template as guidance to figure out what information to include and where to find it.
