Nextcloud 34 on K8s MKCOL 405 and files larger than 10Mbyte fail
    • 34.0.1.2
    • Docker Apache container
    • 2.4.67
    • nginx ingress controller - latest official kubernetes - deprecated
    • 8.5.8
    • yes I just noticed it
    • 2 weeks ago
    • Helm chart community
Everytime I try to upload a file bigger than 10Mbytes through my phone (Using nextcloud App or Foldersync Pro and nextcloud connector)
I get the following errors:
storage-nextcloud-69bb9d679d-k9j56 nextcloud 10.10.1.234 - varet [17/Jul/2026:04:55:58 +0000] "MKCOL /remote.php/dav/uploads/user/d319628235dc77e89f2ced3b24e4ef5d HTTP/1.1" 405 768 "-" "Mozilla/5.0 (Android) Nextcloud-android/34.0.0"
storage-nextcloud-69bb9d679d-k9j56 nextcloud 10.10.1.234 - varet [17/Jul/2026:04:55:58 +0000] "PROPFIND /remote.php/dav/uploads/user/d319628235dc77e89f2ced3b24e4ef5d HTTP/1.1" 207 1525 "-" "Mozilla/5.0 (Android) Nextcloud-android/34.0.0"
  1. upload a file through Android App
  2. Failure comes with Conflict on file! but then I canno do nothing more
uploading from my chrome works!
No Lines
PASTE
storage-nextcloud-69bb9d679d-k9j56 nextcloud 10.10.1.234 - user [17/Jul/2026:04:55:58 +0000] "MKCOL /remote.php/dav/uploads/user/d319628235dc77e89f2ced3b24e4ef5d HTTP/1.1" 405 768 "-" "Mozilla/5.0 (Android) Nextcloud-android/34.0.0"
storage-nextcloud-69bb9d679d-k9j56 nextcloud 10.10.1.234 - user[17/Jul/2026:04:55:58 +0000] "PROPFIND /remote.php/dav/uploads/user/d319628235dc77e89f2ced3b24e4ef5d HTTP/1.1" 207 1525 "-" "Mozilla/5.0 (Android) Nextcloud-android/34.0.0"
        "upload_tmp_dir": "\/var\/www\/html\/data\/tmp",
        "tempdirectory": "\/var\/www\/html\/data\/tmp",
        "davstorage.request_timeout": 1800,
        "openmetrics_allowed_clients": [
            "10.10.0.0\/22",
            "172.25.0.0\/16",
            "127.0.0.1"
        "objectstore_clean_room": true,
        "dav.enable.chunked_upload_v2": false,
        "bulkupload.enabled": false,
        "htaccess.RewriteBase": "\/",
        "filelocking.enabled": true,
        "logfile": "data\/nextcloud.log",
        "enable_previews": false,
        "apps_paths": [
                "url": "\/apps",
                "writable": false
                "url": "\/custom_apps",
                "writable": true
        "redis": {
            "port": 6379
        "objectstore_multibucket": {
            "class": "\\OC\\Files\\ObjectStore\\S3",
            "arguments": {
                "num_buckets": 4,
                "bucket": "nextcloud-",
                "autocreate": false,
                "key": "***REMOVED SENSITIVE VALUE***",
                "hostname": "minio.ar80.eu",
                "region": "",
                "port": 443,
                "use_ssl": true,
                "use_path_style": true
        "overwriteprotocol": "https",
        "overwritehost": "nextcloud.domain",
        "default_phone_region": "DE",
        "forwarded_for_headers": [
            "HTTP_X_FORWARDED_FOR"
            "localhost",
            "nextcloud.domain",
            "172.25.*"
        "dbtype": "pgsql",
        "version": "34.0.1.2",
        "overwrite.cli.url": "https:\/\/nextcloud.domain",
        "dbport": "",
        "mail_smtpmode": "smtp",
        "mail_sendmailmode": "smtp",
        "mail_smtpport": "25",
        "loglevel": 2,
        "theme": "",
        "memories.exiftool": "\/var\/www\/html\/custom_apps\/memories\/exiftool-bin\/exiftool-amd64-glibc",
        "upgrade.disable-web": true,
        "app_install_overwrite": [],
        "data-fingerprint": "2ce1e29eb22d0--"
    "apps": {
        "activity": {
            "types": "filesystem",
            "enabled": "yes",
            "installed_version": "7.0.0"
        "admin_audit": {
            "types": "logging",
            "enabled": "yes",
            "installed_version": "1.24.0"
        "app_api": {
            "types": "",
            "installed_version": "34.0.0",
            "enabled": "yes"
        "appstore": {
            "installed_version": "1.0.0",
            "enabled": "yes",
            "types": ""
        "backgroundjob": {
            "lastjob": "71308"
        "bruteforcesettings": {
            "types": "",
            "enabled": "yes",
        "calendar": {
            "types": "",
            "enabled": "yes",
            "installed_version": "6.5.1"
        "circles": {
            "installed_version": "25.0.0",
            "types": "filesystem,dav",
            "loopback_tmp_scheme": "http",
            "enabled": "no",
            "maintenance_run": "0",
            "maintenance_update": "{\"3\":1670216013,\"2\":1670216013,\"1\":1670216013}"
        "cloud_federation_api": {
            "enabled": "yes",
            "installed_version": "1.18.0"
        "comments": {
            "types": "logging",
            "enabled": "yes",
        "contactsinteraction": {
            "types": "dav",
            "enabled": "yes",
            "installed_version": "1.15.0"
        "core": {
            "installedat": "1670096280.6527",
            "vendor": "nextcloud",
            "public_webdav": "dav\/appinfo\/v1\/publicwebdav.php",
            "public_files": "files_sharing\/public.php",
            "metadataGenerationDone": true,
            "backgroundjobs_mode": "cron",
            "emailTestSuccessful": "1",
            "shareapi_default_internal_expire_date": "yes",
            "shareapi_default_permission_canupdate": "no",
            "shareapi_default_permission_candelete": "no",
            "shareapi_default_permissions": "5",
            "shareapi_default_permission_canshare": "no",
            "moveavatarsdone": "yes",
            "previewsCleanedUp": "1",
            "files_metadata_installed": "1",
            "lastupdatedat": 1784263759,
            "lastupdateResult": "[]",
            "lastcron": 1784263804,
            "files_metadata": {
                "blurhash": {
                    "value": null,
                    "type": "string",
                    "etag": "68545b4467864",
                    "indexed": false,
                    "editPermission": 0
                "photos-original_date_time": {
                    "value": null,
                    "type": "int",
                    "etag": "",
                    "indexed": true,
                    "editPermission": 0
            "oc.integritycheck.checker": []
        "dashboard": {
            "types": "",
            "enabled": "yes",
            "installed_version": "7.14.0"
        "dav": {
            "enabled": "yes",
            "checked_for_classified_activity": true,
            "installed_version": "1.39.0",
            "regeneratedBirthdayCalendarsForYearFix": "yes",
            "buildCalendarSearchIndex": "yes",
            "buildCalendarReminderIndex": "yes",
            "chunks_migrated": "1",
            "builtSocialSearchIndex": "yes"
        "deck": {
            "types": "dav",
            "installed_version": "1.18.2",
            "enabled": "yes"
        "federatedfilesharing": {
            "types": "",
            "enabled": "yes",
        "federation": {
            "types": "authentication",
            "enabled": "yes",
        "files": {
            "enabled": "yes",
            "installed_version": "2.6.0",
            "mimetype_version": "32.0.0.13",
            "max_chunk_size": "0"
        "files_downloadlimit": {
            "types": "",
            "enabled": "yes",
            "installed_version": "5.2.0-dev.0"
        "files_external": {
            "enabled": "yes",
            "installed_version": "1.26.0",
            "user_mounting_backends": "ftp,dav,owncloud,sftp,amazons3,swift,\\OC\\Files\\Storage\\SFTP_Key"
        "files_lock": {
            "enabled": "yes",
        "files_pdfviewer": {
            "types": "",
            "enabled": "yes",
            "installed_version": "7.0.0-dev.0"
        "files_reminders": {
            "types": "",
            "enabled": "yes",
            "installed_version": "1.7.0"
        "files_rightclick": {
            "enabled": "no",
            "types": "",
            "installed_version": "1.6.0"
        "files_sharing": {
            "enabled": "yes",
            "incoming_server2server_share_enabled": "no",
            "outgoing_server2server_share_enabled": "yes",
            "outgoing_server2server_group_share_enabled": "no",
            "incoming_server2server_group_share_enabled": "no",
        "files_trashbin": {
            "enabled": "yes",
        "files_versions": {
            "enabled": "yes",
            "installed_version": "1.27.0"
        "firstrunwizard": {
            "enabled": "yes",
            "types": "",
        "geoblocker": {
            "installed_version": "0.5.16",
            "types": "",
            "choosenCountries": "CN, ",
            "chosenService": "1",
            "enabled": "no"
        "integration_onedrive": {
            "installed_version": "1.1.4",
            "types": "",
            "use_popup": "1",
            "client_id": "***REMOVED SENSITIVE VALUE***",
            "client_secret": "***REMOVED SENSITIVE VALUE***",
            "enabled": "no"
        "logreader": {
            "enabled": "yes",
            "installed_version": "7.0.0",
            "types": "logging"
        "lookup_server_connector": {
            "enabled": "yes",
            "installed_version": "1.22.0"
        "maps": {
            "enabled": "no",
            "installed_version": "1.7.1"
        "memories": {
            "installed_version": "4.11.0",
            "enabled": "no",
            "types": ""
        "nextcloud_announcements": {
            "types": "logging",
            "enabled": "yes",
            "pub_date": "Thu, 24 Oct 2019 00:00:00 +0200",
            "installed_version": "6.0.0"
        "notifications": {
            "types": "logging",
            "enabled": "yes",
            "webpush_vapid_pubkey": "BAGL-lE2uIl7O9FcjqqwQ-OmE5So2-vTTHxmrOWG7RffJmzatgM",
            "installed_version": "7.0.0-dev.1",
            "webpush_vapid_privkey": "***REMOVED SENSITIVE VALUE***"
        "oauth2": {
            "enabled": "yes",
        "office": {
            "enabled": "yes",
            "types": ""
        "password_policy": {
            "enabled": "yes",
            "enforceUpperLowerCase": "1",
            "enforceNumericCharacters": "1",
            "enforceSpecialCharacters": "1",
            "installed_version": "6.0.0-dev.0"
        "photos": {
            "types": "dav,authentication",
            "installed_version": "4.0.0-dev.1",
            "enabled": "no",
            "lastPlaceMappedUser": "varet-ereader",
            "lastPlaceMappingDone": "true"
        "privacy": {
            "types": "",
            "enabled": "yes",
            "installed_version": "6.0.0-dev.1"
        "profile": {
            "installed_version": "1.3.0",
            "types": "",
            "enabled": "yes"
        "provisioning_api": {
            "types": "prevent_group_restriction",
            "enabled": "yes",
        "quota_warning": {
            "installed_version": "1.24.0",
            "enabled": "yes"
        "recognize": {
            "installed_version": "12.0.0",
            "enabled": "no",
            "tensorflow.gpu": "false",
            "faces.enabled": "true",
            "landmarks.enabled": "true",
            "musicnn.enabled": "false",
            "movinet.enabled": "false",
            "tensorflow.cores": "4",
            "imagenet.enabled": "true",
            "tensorflow.purejs": "true",
            "node_binary": "\/var\/www\/html\/custom_apps\/recognize\/bin\/node",
            "nice_binary": "\/usr\/bin\/nice",
            "nice_value": "0",
            "ffmpeg_binary": "\/var\/www\/html\/custom_apps\/recognize\/lib\/Migration\/..\/..\/node_modules\/ffmpeg-static\/ffmpeg",
            "faces.status": "true",
            "imagenet.status": "true",
            "landmarks.status": "true",
            "faces.lastFile": "1751473463",
            "imagenet.lastFile": "1751473214",
            "landmarks.lastFile": "1751473373",
            "clusterFaces.lastRun": "0",
            "faces.batchSize": "150",
            "imagenet.batchSize": "100",
            "landmarks.batchSize": "100",
            "movinet.batchSize": "20",
            "musicnn.batchSize": "100",
            "concurrency.enabled": "false"
        "recommendations": {
            "types": "",
            "enabled": "yes",
        "related_resources": {
            "types": "",
            "enabled": "yes",
            "installed_version": "5.0.0-dev.0"
        "richdocuments": {
            "external_apps": "",
            "wopi_allowlist": "10.0.0.0\/8,172.25.0.0\/12",
            "types": "filesystem,prevent_group_restriction",
            "installed_version": "11.0.1",
            "public_wopi_url": "https:\/\/nextcloud.domain",
            "disable_certificate_verification": "yes",
            "edit_groups": "",
            "wopi_url": "https:\/\/nextcloud.domain\/custom_apps\/richdocumentscode\/proxy.php?req=",
            "enabled": "yes"
        "richdocumentscode": {
            "types": "",
            "enabled": "yes",
            "installed_version": "26.4.104"
        "serverinfo": {
            "types": "",
            "enabled": "yes",
            "cached_count_storages": "17",
            "token": "***REMOVED SENSITIVE VALUE***",
            "cached_count_appdata_files": 358895,
            "cached_count_filecache": 770025,
            "installed_version": "6.0.0",
            "size_appdata_storage": 17663074840
        "settings": {
            "types": "",
            "enabled": "yes",
            "installed_version": "1.17.0"
        "sharebymail": {
            "enabled": "yes",
        "sociallogin": {
            "custom_providers": "null",
            "types": "",
            "enabled": "yes",
            "disable_registration": "1",
            "create_disabled_users": "",
            "allow_login_connect": "1",
            "prevent_create_email_exists": "",
            "update_profile_on_login": "",
            "no_prune_user_groups": "",
            "auto_create_groups": "",
            "restrict_users_wo_mapped_groups": "",
            "restrict_users_wo_assigned_groups": "",
            "disable_notify_admins": "",
            "hide_default_login": "",
            "button_text_wo_prefix": "",
            "oauth_providers": "{\"google\":{\"appid\":\"\",\"secret\":\"\",\"auth_params\":{\"hd\":\"\"}},\"amazon\":{\"appid\":\"\",\"secret\":\"\"},\"facebook\":{\"appid\":\"\",\"secret\":\"\"},\"twitter\":{\"appid\":\"\",\"secret\":\"\"},\"GitHub\":{\"appid\":\"\",\"secret\":\"\",\"orgs\":\"\"},\"discord\":{\"appid\":\"\",\"secret\":\"\",\"guilds\":\"\"},\"QQ\":{\"appid\":\"\",\"secret\":\"\"},\"slack\":{\"appid\":\"\",\"secret\":\"\"},\"telegram\":{\"appid\":\"\",\"secret\":\"\"},\"mailru\":{\"appid\":\"\",\"secret\":\"\",\"auth_params\":{\"hd\":\"\"}},\"yandex\":{\"appid\":\"\",\"secret\":\"\",\"auth_params\":{\"hd\":\"\"}},\"BitBucket\":{\"appid\":\"\",\"secret\":\"\",\"workspace\":\"\"},\"PlexTv\":{\"appid\":\"\"}}",
            "installed_version": "6.5.2"
        "support": {
            "types": "session",
            "enabled": "yes",
            "SwitchUpdaterServerHasRun": "yes"
        "survey_client": {
            "installed_version": "1.13.0",
            "types": "",
            "enabled": "no"
        "systemtags": {
            "types": "logging",
            "enabled": "yes",
        "tasks": {
            "types": "",
            "enabled": "no",
            "installed_version": "0.18.1"
        "text": {
            "types": "dav",
            "enabled": "yes",
            "installed_version": "8.0.0"
        "theming": {
            "types": "logging",
            "enabled": "yes",
            "disable-user-theming": "yes",
            "cachebuster": "1",
            "installed_version": "2.9.0"
        "twofactor_backupcodes": {
            "types": "",
            "enabled": "yes",
            "installed_version": "1.23.0"
        "twofactor_totp": {
            "types": "",
            "enabled": "yes",
            "installed_version": "16.0.0"
        "updatenotification": {
            "types": "",
            "enabled": "yes",
            "related_resources": "1.0.4",
            "tasks": "0.15.0",
            "recognize": "3.6.1",
            "deck": "1.12.2",
            "sociallogin": "6.1.0",
            "richdocuments": "10.1.3",
            "richdocumentscode": "24.4.902",
            "update_check_errors": 0,
            "calendar": "5.5.0",
            "core": "33.0.6.2"
        "user_status": {
            "types": "",
            "enabled": "yes",
            "installed_version": "1.14.0"
        "user_usage_report": {
            "installed_version": "5.0.0",
            "enabled": "no"
        "viewer": {
            "types": "",
            "enabled": "yes",
        "weather_status": {
            "types": "",
            "enabled": "yes",
        "webhook_listeners": {
            "enabled": "yes",
        "workflowengine": {
            "enabled": "yes",
            "installed_version": "2.16.0"
The output of occ app:list
  - activity: 7.0.0
  - admin_audit: 1.24.0
  - app_api: 34.0.0
  - appstore: 1.0.0
  - bruteforcesettings: 7.0.0
  - calendar: 6.5.1
  - cloud_federation_api: 1.18.0
  - comments: 1.24.0
  - contactsinteraction: 1.15.0
  - dashboard: 7.14.0
  - dav: 1.39.0
  - deck: 1.18.2
  - federatedfilesharing: 1.24.0
  - federation: 1.24.0
  - files: 2.6.0
  - files_downloadlimit: 5.2.0-dev.0
  - files_external: 1.26.0
  - files_lock: 34.0.0
  - files_pdfviewer: 7.0.0-dev.0
  - files_reminders: 1.7.0
  - files_sharing: 1.26.0
  - files_trashbin: 1.24.0
  - files_versions: 1.27.0
  - firstrunwizard: 7.0.0-dev.0
  - logreader: 7.0.0
  - lookup_server_connector: 1.22.0
  - nextcloud_announcements: 6.0.0
  - notifications: 7.0.0-dev.1
  - oauth2: 1.22.0
  - office: 1.0.0
  - password_policy: 6.0.0-dev.0
  - privacy: 6.0.0-dev.1
  - profile: 1.3.0
  - provisioning_api: 1.24.0
  - quota_warning: 1.24.0
  - recommendations: 7.0.0
  - related_resources: 5.0.0-dev.0
  - richdocuments: 11.0.1
  - richdocumentscode: 26.4.104
  - serverinfo: 6.0.0
  - settings: 1.17.0
  - sharebymail: 1.24.0
  - sociallogin: 6.5.2
  - support: 6.0.0
  - systemtags: 1.24.0
  - text: 8.0.0
  - theming: 2.9.0
  - twofactor_backupcodes: 1.23.0
  - twofactor_totp: 16.0.0
  - updatenotification: 1.24.0
  - user_status: 1.14.0
  - viewer: 7.0.0-dev.0
  - weather_status: 1.14.0
  - webhook_listeners: 1.6.0
  - workflowengine: 2.16.0
  - circles: 34.0.0 (installed 25.0.0)
  - encryption: 2.22.0
  - files_rightclick: 0.15.1 (installed 1.6.0)
  - maps: 1.7.1 (installed 1.7.1)
  - photos: 7.0.0 (installed 4.0.0-dev.1)
  - recognize: 12.0.0 (installed 12.0.0)
  - survey_client: 6.0.0-dev.0 (installed 1.13.0)
  - suspicious_login: 12.0.0-dev.0
  - tasks: 0.18.1 (installed 0.18.1)
  - twofactor_nextcloud_notification: 8.0.0
  - user_ldap: 1.25.0
  - user_usage_report: 5.0.0 (installed 5.0.0)
Nginx Ingress annotations:
      nginx.ingress.kubernetes.io/client-header-buffer-size: 16k
      nginx.ingress.kubernetes.io/cors-allow-headers: DNT,Keep-Alive,User-Agent,X-Requested-With,If-Modified-Since,Cache-Control,Content-Type,Range,Authorization,X-Frontend-For,X-Product,X-Developer-Id
      nginx.ingress.kubernetes.io/cors-allow-methods: GET, HEAD, POST, OPTIONS, PUT,
        PATCH, DELETE, PROPFIND, MKCOL, REPORT, COPY, MOVE
      nginx.ingress.kubernetes.io/enable-cors: "true"
      nginx.ingress.kubernetes.io/enable-modsecurity: "false"
      nginx.ingress.kubernetes.io/large-client-header-buffers: 4 16k
      nginx.ingress.kubernetes.io/proxy-body-size: "0"
      nginx.ingress.kubernetes.io/proxy-buffer-size: 512m
      nginx.ingress.kubernetes.io/proxy-buffering: "off"
      nginx.ingress.kubernetes.io/proxy-busy-buffers-size: 512m
      nginx.ingress.kubernetes.io/proxy-connect-timeout: "60"
      nginx.ingress.kubernetes.io/proxy-http-version: "1.1"
      nginx.ingress.kubernetes.io/proxy-read-timeout: "1800"
      nginx.ingress.kubernetes.io/proxy-request-buffering: "off"
      nginx.ingress.kubernetes.io/proxy-send-timeout: "1800"
      nginx.ingress.kubernetes.io/server-snippet: |-
        set $fixed_destination $http_destination;
        if ($http_destination ~* ^https(.*)$) {
            set $fixed_destination http$1;
        proxy_set_header X-Chunks-Supported true;
        proxy_set_header Destination $fixed_destination;
        proxy_set_header Overwrite $http_overwrite;
        server_tokens off;
        proxy_hide_header X-Powered-By;
        rewrite ^/.well-known/webfinger /index.php/.well-known/webfinger last;
        rewrite ^/.well-known/nodeinfo /index.php/.well-known/nodeinfo last;
        rewrite ^/.well-known/host-meta /public.php?service=host-meta last;
        rewrite ^/.well-known/host-meta.json /public.php?service=host-meta-json;
        location = /.well-known/carddav { return 301 $scheme://$host/remote.php/dav; }
        location = /.well-known/caldav { return 301 $scheme://$host/remote.php/dav; }
