Nextcloud 30 - Ring of White Pixels Around Menu Avatar
example
longer
example
here
Nextcloud version (eg, 29.0.5): 30.0.1
Operating system and version (eg, Ubuntu 24.04): Archlinux 6.11.4-arch2-1
Apache or nginx version (eg, Apache 2.4.25): Apache 2.4.62
PHP version (eg, 8.3): 8.2.24
In the new Nextcloud 30 UI, when you mouseover (hover) over the menu icon to open the menu (top-right), a white-ring of pixels appears around the avatar. This is in the dark theme (it looks like they either were not themed for the dark theme, or this was just missed)
nextcloud-30-whitepx-crop
  1. Login to Nextcloud
  2. Mouseover (hover) over the Avatar (menu icon) at top-right
  3. Watch the white ring of pixels appear around the Avatar
NOTE: the ability to view individual messages by clicking the ellipse ... at the right side of each error is broken in Nextcloud 30.
None Relevant - see only repeating error in nextcloud.log below
None Relevant
None
Only error is:
{"reqId":"ehczgp8570NrV3CajHsh","level":3,"time":"2024-10-22T20:58:05+00:00","remoteAddr":"192.168.6.104","user":"david","app":"PHP","method":"GET","url":"/nextcloud/apps/theming/icon/settings?v=ffcbc457","message":"Module \"bcmath\" is already loaded at Unknown#0","userAgent":"Mozilla/5.0 (X11; Linux x86_64; rv:131.0) Gecko/20100101 Firefox/131.0","version":"30.0.1.2","data":{"app":"PHP"}}
