Nextcloud version 27.1.11
Docker version: nextcloud:27-apache
Redis:latest (7.2)
We have over 1000 users in AD catalog.
And NC have troubles syncing “Domain users” group.
Randomly some users drop out from that group in NC on every sync.
Is it some limit of Community version or it can be fixed?
Normally, there should be no limitation in the community version. First step to debug normally is to check the logs, if you can find some obvious errors.
There is no such thing as a community edition in terms of the code base. It’s all the same.
Can you me more specific? What have you already tried and/or looked at? For example:
What appears in your Nextcloud log during these events?
Have you temporarily adjusted your loglevel from 2 to 1 or 0 to get more details? There should be some clues from the LDAP integration; users aren’t just dropped silently generally
Did this start happening at a certain point you can pinpoint (e.g. after a particular upgrade)? Or has it always been this way?
Maybe post your ldap config occ ldap:show-config
Do these users appear anywhere via the occ commands like occ ldap:show-remnants?[1]
