[/details]
Nextcloud version (eg, 20.0.5): 26.0.1
Operating system and version (eg, Ubuntu 20.04): lscr.io/linuxserver/nextcloud:26.0.0 (alpine)
Apache or nginx version (eg, Apache 2.4.25): nginx 1.22.1
PHP version (eg, 7.4): 8.1.17
I recently switched from using ingress-nginx in kubernetes to Istio, and after switching, nextcloud complains that the webserver is not setup to resolve the following:
Your web server is not properly set up to resolve "/.well-known/webfinger". Further information can be found in the documentation ↗.
Your web server is not properly set up to resolve "/.well-known/nodeinfo". Further information can be found in the documentation ↗.
Your web server is not properly set up to resolve "/.well-known/caldav". Further information can be found in the documentation ↗.
Your web server is not properly set up to resolve "/.well-known/carddav". Further information can be found in the documentation ↗.
I tried opening one of the urls in my browser (server.url/.well-known/caldav), and it seems to work:
This is the WebDAV interface. It can only be accessed by WebDAV clients such as the Nextcloud desktop sync client.
My istio virtual service:
apiVersion: networking.istio.io/v1alpha3
kind: VirtualService
metadata:
spec:
hosts:
- "cloud.url.com"
gateways:
- nextcloud-gateway
http:
- match:
- uri:
prefix: /
route:
- destination:
port:
number: 80
host: nextcloud.default.svc.cluster.local
The relevant nginx conf (basically the default conf):
location ^~ /.well-known {
# The rules in this block are an adaptation of the rules
# in `.htaccess` that concern `/.well-known`.
location = /.well-known/carddav { return 301 /remote.php/dav/; }
location = /.well-known/caldav { return 301 /remote.php/dav/; }
location /.well-known/acme-challenge { try_files $uri $uri/ =404; }
location /.well-known/pki-validation { try_files $uri $uri/ =404; }
# Let Nextcloud's API for `/.well-known` URIs handle all other
# requests by passing them to the front-end controller.
return 301 /index.php$request_uri;
Access and Error logs for nginx don’t show anything during this. Nextcloud works fine besides these warnings.
