Nextcloud version: 25.0.2
Operating system and version: Ubuntu 22.04 LTS
Apache or nginx version: 2.4.54
PHP version: 8.1.3
I have a Nextcloud instance with the Built In CODE server installed. It used to work, but I didn’t use it for a while, and now when I click a document to edit, it downloads instead of edits. If I select a file and click the “…” to look for options, there is no edit option or anything to indicate opening in CODE. It’s like Nextcloud doesn’t see the built in CODE server and functions normally as if it doesn’t exist.
If I go to Administration and find the “Nextcloud Office” pane, I can see the radio button for “Use the built-in CODE - Collabora Online Development Edition” is checked, and above that I have a green check for “Collabora Online server is reachable”.
There is nothing in the logs, neither a warning nor error. I’ve also checked the apache error and access logs, nothing there either. I’m not sure where else to look.
Is this the first time you’ve seen this error? : Yes
- Go to Files, find a document
- Click it.
- A download dialog from the browser pops up
Absolutely no log entries at any severity including Debug show up for this action. There are previous warnings in the logs not related to this issue.
'instanceid' => '------------------',
'passwordsalt' => '--------------',
'secret' => '-------------------',
0 => 'subdomain.domain.com',
1 => 'domain.com',
2 => 'nextcloud.domain.com',
'defaultapp' => 'files',
'version' => '25.0.2.3',
'overwritehost' => 'nextcloud.domain.com',
'overwritewebroot' => '',
'overwrite.cli.url' => 'https://nextcloud.domain.com',
'dbname' => 'hda_nextcloud',
'dbhost' => 'localhost:3306',
'dbuser' => 'usr_servername_nextcloud',
'dbpassword' => '--------',
'theme' => '',
'log_type' => 'file',
'loglevel' => 2,
'mail_smtpmode' => 'smtp',
'mail_domain' => 'subdomain.domain.com',
'mail_smtphost' => '127.0.0.1',
'mail_smtpport' => '25',
'default_phone_region' => 'US',
'app_install_overwrite' =>
0 => 'files_3d',
1 => 'files_texteditor',
2 => 'printer',
3 => 'epubreader',
'trashbin_retention_obligation' => 'auto,15',
'allow_local_remote_servers' => true,
There is basically nothing, this is the output of multitail -f --mergeall /var/log/apache2/error.nextcloud.log /var/log/apache2/access.nextcloud.log
during a click of a document
*.93.213.50 - - [16/Dec/2022:12:52:29 -0800] "PUT /ocs/v2.php/apps/user_status/api/v1/heartbeat?format=json HTTP/1.1" 200 1645 "-" "Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:107.0) Gecko/20100101 Fire
fox/107.0"
174.34.209.194 - username [16/Dec/2022:12:52:34 -0800] "PROPFIND /remote.php/dav/files/0c904fda-590e-103b-8ab3-8f73b30b6c02/Mike HTTP/1.1" 207 5466 "-" "Mozilla/5.0 (Windows) mirall/3.4.0stable-Win64 (b
uild 20211129) (Nextcloud, windows-10.0.22621 ClientArchitecture: x86_64 OsArchitecture: x86_64)"
*.93.213.50 - - [16/Dec/2022:12:52:35 -0800] "PUT /ocs/v2.php/apps/user_status/api/v1/heartbeat?format=json HTTP/1.1" 200 1645 "-" "Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:107.0) Gecko/20100101 Fire
fox/107.0"
*.93.213.50 - - [16/Dec/2022:12:52:35 -0800] "PUT /ocs/v2.php/apps/user_status/api/v1/heartbeat?format=json HTTP/1.1" 200 1039 "-" "Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:107.0) Gecko/20100101 Fire
fox/107.0"
*.93.213.50 - - [16/Dec/2022:12:52:36 -0800] "GET /remote.php/webdav/Home/Documents/Philosophy.doc HTTP/1.1" 200 26212 "-" "Mozilla/5.0 (Windows NT
10.0; Win64; x64; rv:107.0) Gecko/20100101 Firefox/107.0"
*.93.213.50 - - [16/Dec/2022:12:52:18 -0800] "GET /apps/logreader/poll?lastReqId=5OEiTeYJMUgAQcMsN6xY HTTP/1.1" 200 918 "-" "Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:107.0) Gecko/20100101 Firefox/107
.0"
No errors in nextcloud.log
