we run NextCloud
using docker.
Nextcloud version: 22.2.3
Operating system and version: Debian GNU/Linux 9.13 (stretch)
Apache version (from within the docker container): Apache/2.4.51 (Debian)
PHP version (from within the docker container): PHP 8.0.13 (cli) (built: Nov 19 2021 21:36:32) ( NTS )
We recently updated from NextCloud 22.2.1
to NextCloud 22.2.3
via docker-compose pull
. Now our users reported issues concerning the search. Hence we do have tons of subfolders it is really hard to manually finding a folder, especially with the lazy loading.
- Use the Search Icon on the top right to search for a folder within “Files”
- After quite a while (it used to be faster) the search shows the results
- If you click on a folder within the search results the expected behaviour is to have this location opened up in the “Files” app
- The folder opens for a brief moment, then you get redirected to its parent folder
Example File structure (Note: our structure contains chars like äöüß and whitespaces, due to the url encoding I kept the example simple for better readability):
ParentFolder
1001Subfolder1
Testfolder01
Testfolder02
1002Subfolder2
TestfolderA
TestfolderB
If I search for “1002” the search results display the “1002Subfolder2”. If I click on the folder, I expect it to be opened up.
Instead the correct contents of 1002Subfolder2
are briefly shown and then I am being redirected to its parent folder ParentFolder
. Clicking any folder that is now displayed within ParentFolder
has no effect at all. JavaScript appears to be broken.
The output of Admin > Logging (the only error that I could find, occured multiple times):
Level: Error
App: Index
TypeError: OCA\Files\Service\TagService::__construct(): Argument #3 ($tagger) must be of type OCP\ITags, null given, called in /var/www/html/apps/files/lib/AppInfo/Application.php on line 106
/var/www/html/apps/files/lib/AppInfo/Application.php - line 106:
OCA\Files\Service\TagService->__construct(OC\User\Session {}, OC\Activity\Manager {}, null, null, OC\EventDisp ... {})
/var/www/html/lib/private/AppFramework/Utility/SimpleContainer.php - line 160:
OCA\Files\AppInfo\Application->OCA\Files\AppInfo\{closure}("*** sensiti ... *")
/var/www/html/3rdparty/pimple/pimple/src/Pimple/Container.php - line 118:
OC\AppFramework\Utility\SimpleContainer->OC\AppFramework\Utility\{closure}("*** sensiti ... *")
/var/www/html/lib/private/AppFramework/Utility/SimpleContainer.php - line 127:
Pimple\Container->offsetGet("OCA\\Files\ ... e")
/var/www/html/lib/private/AppFramework/DependencyInjection/DIContainer.php - line 454:
OC\AppFramework\Utility\SimpleContainer->query("OCA\\Files\ ... e")
/var/www/html/lib/private/AppFramework/DependencyInjection/DIContainer.php - line 432:
OC\AppFramework\DependencyInjection\DIContainer->queryNoFallback("OCA\\Files\ ... e")
/var/www/html/lib/private/AppFramework/Utility/SimpleContainer.php - line 56:
OC\AppFramework\DependencyInjection\DIContainer->query("OCA\\Files\ ... e")
/var/www/html/apps/files/lib/AppInfo/Application.php - line 86:
OC\AppFramework\Utility\SimpleContainer->get("OCA\\Files\ ... e")
Pimple\Container->offsetGet("APIController")
OC\AppFramework\Utility\SimpleContainer->query("APIController")
OC\AppFramework\DependencyInjection\DIContainer->queryNoFallback("APIController")
/var/www/html/lib/private/AppFramework/App.php - line 129:
OC\AppFramework\DependencyInjection\DIContainer->query("APIController")
/var/www/html/lib/private/Route/Router.php - line 302:
OC\AppFramework\App::main("APIController", "getGridView", "*** sensiti ... *", { _route: "f ... "})
/var/www/html/lib/base.php - line 1006:
OC\Route\Router->match("/apps/files ... w")
/var/www/html/index.php - line 36:
OC::handleRequest()
The output of config.php:
'apps_paths' =>
0 =>
'url' => '/apps',
'writable' => false,
1 =>
'url' => '/custom_apps',
'writable' => true,
'instanceid' => 'x',
'passwordsalt' => 'x',
'secret' => 'x',
0 => 'cloud.x.com',
'version' => '22.2.3.0',
'overwrite.cli.url' => 'https://cloud.x.com',
'overwritehost' => 'cloud.x.com',
'dbname' => 'nextcloud',
'dbhost' => 'db',
'dbuser' => 'x',
'dbpassword' => 'x',
'mail_from_address' => 'noreply',
'mail_smtpmode' => 'smtp',
'mail_domain' => 'mail.x.com',
'mail_smtphost' => 'smtp.x.com',
'mail_smtpport' => '465',
'mail_smtpauth' => 1,
'mail_smtpname' => 'noreply@x.com',
'mail_smtppassword' => 'x',
'mail_smtpsecure' => 'ssl',
'loglevel' => 2,
'theme' => '',
The system log output for the vhost:
When the search is fired by typing into the input field:
[02/Dec/2021:16:05:29 +0100] "GET /ocs/v2.php/search/providers/comments/search?term=1002&from=%2Fapps%2Ffiles%2F%3Fdir%3D%2FParentFolder%26fileid%3D2401 HTTP/1.1" 200 128 "-" "Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:94.0) Gecko/20100101 Firefox/94.0"
[02/Dec/2021:16:05:29 +0100] "GET /ocs/v2.php/search/providers/files/search?term=1002&from=%2Fapps%2Ffiles%2F%3Fdir%3D%2FParentFolder%26fileid%3D2401 HTTP/1.1" 200 622 "-" "Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:94.0) Gecko/20100101 Firefox/94.0"
[02/Dec/2021:16:05:29 +0100] "GET /ocs/v2.php/search/providers/settings_apps/search?term=1002&from=%2Fapps%2Ffiles%2F%3Fdir%3D%2FParentFolder%26fileid%3D2401 HTTP/1.1" 200 126 "-" "Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:94.0) Gecko/20100101 Firefox/94.0"
[02/Dec/2021:16:05:29 +0100] "GET /ocs/v2.php/search/providers/talk-message/search?term=1002&from=%2Fapps%2Ffiles%2F%3Fdir%3D%2FParentFolder%26fileid%3D2401 HTTP/1.1" 200 128 "-" "Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:94.0) Gecko/20100101 Firefox/94.0"
[02/Dec/2021:16:05:29 +0100] "GET /ocs/v2.php/search/providers/contacts/search?term=1002&from=%2Fapps%2Ffiles%2F%3Fdir%3D%2FParentFolder%26fileid%3D2401 HTTP/1.1" 200 128 "-" "Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:94.0) Gecko/20100101 Firefox/94.0"
[02/Dec/2021:16:05:29 +0100] "GET /ocs/v2.php/search/providers/talk-conversations/search?term=1002&from=%2Fapps%2Ffiles%2F%3Fdir%3D%2FParentFolder%26fileid%3D2401 HTTP/1.1" 200 133 "-" "Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:94.0) Gecko/20100101 Firefox/94.0"
[02/Dec/2021:16:05:29 +0100] "GET /ocs/v2.php/search/providers/calendar/search?term=1002&from=%2Fapps%2Ffiles%2F%3Fdir%3D%2FParentFolder%26fileid%3D2401 HTTP/1.1" 200 126 "-" "Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:94.0) Gecko/20100101 Firefox/94.0"
[02/Dec/2021:16:05:29 +0100] "GET /ocs/v2.php/search/providers/tasks/search?term=1002&from=%2Fapps%2Ffiles%2F%3Fdir%3D%2FParentFolder%26fileid%3D2401 HTTP/1.1" 200 129 "-" "Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:94.0) Gecko/20100101 Firefox/94.0"
[02/Dec/2021:16:05:29 +0100] "GET /ocs/v2.php/search/providers/settings/search?term=1002&from=%2Fapps%2Ffiles%2F%3Fdir%3D%2FParentFolder%26fileid%3D2401 HTTP/1.1" 200 131 "-" "Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:94.0) Gecko/20100101 Firefox/94.0"
[02/Dec/2021:16:05:29 +0100] "GET /ocs/v2.php/search/providers/talk-message-current/search?term=1002&from=%2Fapps%2Ffiles%2F%3Fdir%3D%2FParentFolder%26fileid%3D2401 HTTP/1.1" 200 131 "-" "Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:94.0) Gecko/20100101 Firefox/94.0"
[02/Dec/2021:16:05:29 +0100] "GET /core/preview?x=32&y=32&fileId=102724 HTTP/1.1" 404 2 "-" "Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:94.0) Gecko/20100101 Firefox/94.0"
[02/Dec/2021:16:05:29 +0100] "GET /core/preview?x=32&y=32&fileId=102723 HTTP/1.1" 404 2 "-" "Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:94.0) Gecko/20100101 Firefox/94.0"
[02/Dec/2021:16:05:29 +0100] "GET /core/preview?x=32&y=32&fileId=111466 HTTP/1.1" 404 2 "-" "Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:94.0) Gecko/20100101 Firefox/94.0"
[02/Dec/2021:16:05:29 +0100] "GET /core/preview?x=32&y=32&fileId=102747 HTTP/1.1" 404 2 "-" "Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:94.0) Gecko/20100101 Firefox/94.0"
[02/Dec/2021:16:05:29 +0100] "GET /core/preview?x=32&y=32&fileId=102727 HTTP/1.1" 404 2 "-" "Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:94.0) Gecko/20100101 Firefox/94.0"
[02/Dec/2021:16:05:29 +0100] "POST /apps/text/session/sync HTTP/1.1" 200 247 "-" "Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:94.0) Gecko/20100101 Firefox/94.0"
When I click on the found "1002Subfolder2" within the search result box:
[02/Dec/2021:16:08:44 +0100] "GET /apps/files/?dir=/ParentFolder&openfile=102723&scrollto=1002Subfolder2 HTTP/1.1" 200 11297 "-" "Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:94.0) Gecko/20100101 Firefox/94.0"
[02/Dec/2021:16:08:44 +0100] "GET /apps/recommendations/l10n/de.js?v=6f68876c-12 HTTP/1.1" 200 343 "-" "Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:94.0) Gecko/20100101 Firefox/94.0"
[02/Dec/2021:16:08:45 +0100] "GET /apps/theming/js/theming.js?v=6f68876c-12 HTTP/1.1" 200 60 "-" "Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:94.0) Gecko/20100101 Firefox/94.0"
[02/Dec/2021:16:08:45 +0100] "GET /apps/files/js/dist/main.js.map HTTP/1.1" 200 555876 "-" "Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:94.0) Gecko/20100101 Firefox/94.0"
[02/Dec/2021:16:08:45 +0100] "GET /apps/files/js/dist/sidebar.js.map HTTP/1.1" 200 811400 "-" "Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:94.0) Gecko/20100101 Firefox/94.0"
[02/Dec/2021:16:08:45 +0100] "GET /core/js/dist/main.js.map HTTP/1.1" 200 1448921 "-" "Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:94.0) Gecko/20100101 Firefox/94.0"
[02/Dec/2021:16:08:45 +0100] "GET /apps/comments/js/comments-app.js.map HTTP/1.1" 200 1139036 "-" "Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:94.0) Gecko/20100101 Firefox/94.0"
[02/Dec/2021:16:08:45 +0100] "GET /ocs/v2.php/apps/notifications/api/v2/notifications HTTP/1.1" 200 81 "-" "Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:94.0) Gecko/20100101 Firefox/94.0"
[02/Dec/2021:16:08:45 +0100] "PUT /apps/user_status/heartbeat HTTP/1.1" 200 116 "-" "Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:94.0) Gecko/20100101 Firefox/94.0"
[02/Dec/2021:16:08:46 +0100] "GET /ocs/v2.php/search/providers?from=%2Fapps%2Ffiles%2F%3Fdir%3D%2FParentFolder%26openfile%3D102723%26scrollto%3D1002Subfolder2 HTTP/1.1" 200 266 "-" "Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:94.0) Gecko/20100101 Firefox/94.0"
[02/Dec/2021:16:08:46 +0100] "GET /apps/theming/icon/files?v=12 HTTP/1.1" 499 0 "-" "Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:94.0) Gecko/20100101 Firefox/94.0"
[02/Dec/2021:16:08:46 +0100] "GET /apps/theming/favicon/files?v=12 HTTP/1.1" 499 0 "-" "Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:94.0) Gecko/20100101 Firefox/94.0"
[02/Dec/2021:16:08:46 +0100] "GET /cron.php HTTP/1.1" 200 20 "-" "Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:94.0) Gecko/20100101 Firefox/94.0"
[02/Dec/2021:16:08:46 +0100] "GET /apps/files_sharing/js/dist/files_sharing_tab.js.map HTTP/1.1" 200 968798 "-" "Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:94.0) Gecko/20100101 Firefox/94.0"
[02/Dec/2021:16:08:46 +0100] "PROPFIND /remote.php/dav/files/My.User/ParentFolder/1002Subfolder2 HTTP/1.1" 207 713 "-" "Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:94.0) Gecko/20100101 Firefox/94.0"
[02/Dec/2021:16:08:46 +0100] "PROPFIND /remote.php/dav/files/My.User/ParentFolder/1002Subfolder2 HTTP/1.1" 207 683 "-" "Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:94.0) Gecko/20100101 Firefox/94.0"
[02/Dec/2021:16:08:46 +0100] "GET /apps/systemtags/lastused HTTP/1.1" 200 22 "-" "Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:94.0) Gecko/20100101 Firefox/94.0"
[02/Dec/2021:16:08:46 +0100] "GET /ocs/v2.php/apps/text/workspace?path=%2ParentFolder%2F1002Subfolder2 HTTP/1.1" 404 141 "-" "Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:94.0) Gecko/20100101 Firefox/94.0"
[02/Dec/2021:16:08:46 +0100] "PROPFIND /remote.php/dav/systemtags-relations/files/102723 HTTP/1.1" 207 266 "-" "Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:94.0) Gecko/20100101 Firefox/94.0"
[02/Dec/2021:16:08:46 +0100] "GET /apps/recommendations/api/recommendations HTTP/1.1" 200 749 "-" "Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:94.0) Gecko/20100101 Firefox/94.0"
[02/Dec/2021:16:08:46 +0100] "REPORT /remote.php/dav/comments/files/102723 HTTP/1.1" 207 156 "-" "Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:94.0) Gecko/20100101 Firefox/94.0"
[02/Dec/2021:16:08:46 +0100] "GET /ocs/v2.php/apps/files_sharing/api/v1/shares?format=json&path=%2ParentFolder%2F1002Subfolder2&reshares=true HTTP/1.1" 200 81 "-" "Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:94.0) Gecko/20100101 Firefox/94.0"
[02/Dec/2021:16:08:46 +0100] "GET /ocs/v2.php/apps/activity/api/v2/activity/filter?format=json&object_type=files&object_id=102723 HTTP/1.1" 304 0 "-" "Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:94.0) Gecko/20100101 Firefox/94.0"
[02/Dec/2021:16:08:46 +0100] "GET /ocs/v2.php/apps/files_sharing/api/v1/shares?format=json&path=%2ParentFolder%2F1002Subfolder2&shared_with_me=true HTTP/1.1" 200 81 "-" "Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:94.0) Gecko/20100101 Firefox/94.0"
[02/Dec/2021:16:08:46 +0100] "GET /ocs/v2.php/apps/user_status/api/v1/statuses/My.User HTTP/1.1" 200 123 "-" "Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:94.0) Gecko/20100101 Firefox/94.0"
[02/Dec/2021:16:08:46 +0100] "GET /ocs/v2.php/collaboration/resources/file/102723?format=json HTTP/1.1" 200 81 "-" "Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:94.0) Gecko/20100101 Firefox/94.0"
[02/Dec/2021:16:08:46 +0100] "GET /apps/text/js/files.js.map HTTP/1.1" 200 285975 "-" "Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:94.0) Gecko/20100101 Firefox/94.0"
[02/Dec/2021:16:08:46 +0100] "GET /index.php/apps/files/ajax/getstoragestats.php?dir=%2FParentFolder%2F1002Subfolder2 HTTP/1.1" 200 247 "-" "Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:94.0) Gecko/20100101 Firefox/94.0"
[02/Dec/2021:16:08:46 +0100] "GET /ocs/v2.php/apps/files_sharing/api/v1/sharees_recommended?format=json&itemType=dir HTTP/1.1" 200 124 "-" "Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:94.0) Gecko/20100101 Firefox/94.0"
[02/Dec/2021:16:08:46 +0100] "GET /core/js/dist/files_client.js.map HTTP/1.1" 200 181899 "-" "Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:94.0) Gecko/20100101 Firefox/94.0"
[02/Dec/2021:16:08:46 +0100] "GET /apps/notifications/js/notifications-main.js.map?v=75bc1e5b45602dbc89f7 HTTP/1.1" 200 956689 "-" "Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:94.0) Gecko/20100101 Firefox/94.0"
[02/Dec/2021:16:08:46 +0100] "GET /core/js/dist/unified-search.js.map HTTP/1.1" 200 528429 "-" "Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:94.0) Gecko/20100101 Firefox/94.0"
[02/Dec/2021:16:08:46 +0100] "GET /apps/viewer/js/viewer-main.js.map?v=e90c2feca473d3bb80b3 HTTP/1.1" 200 984974 "-" "Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:94.0) Gecko/20100101 Firefox/94.0"
[02/Dec/2021:16:08:46 +0100] "GET /custom_apps/groupfolders/js/groupfolders-files.js.map?v=d74f7ef4066d57e71115 HTTP/1.1" 200 959793 "-" "Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:94.0) Gecko/20100101 Firefox/94.0"
[02/Dec/2021:16:08:47 +0100] "GET /apps/theming/styles?v=12 HTTP/1.1" 499 0 "-" "Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:94.0) Gecko/20100101 Firefox/94.0"
[02/Dec/2021:16:08:47 +0100] "GET /css/icons/icons-vars.css?v=1638452756 HTTP/1.1" 499 0 "-" "Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:94.0) Gecko/20100101 Firefox/94.0"
[02/Dec/2021:16:08:47 +0100] "GET /apps/theming/styles?v=12 HTTP/1.1" 200 1234 "-" "Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:94.0) Gecko/20100101 Firefox/94.0"
[02/Dec/2021:16:08:47 +0100] "GET /css/core/88a4-c61a-css-variables.css?v=f9bf374ef30d7adb04e95bd226f7f07a-6f68876c-12 HTTP/1.1" 499 0 "-" "Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:94.0) Gecko/20100101 Firefox/94.0"
[02/Dec/2021:16:08:47 +0100] "PROPFIND /remote.php/dav/files/My.User/ParentFolder HTTP/1.1" 207 47488 "-" "Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:94.0) Gecko/20100101 Firefox/94.0"
[02/Dec/2021:16:08:47 +0100] "GET /index.php/apps/files/ajax/getstoragestats.php?dir=%2FParentFolder%2F1002Subfolder2 HTTP/1.1" 200 247 "-" "Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:94.0) Gecko/20100101 Firefox/94.0"
The networking tab shows the following console output:
XHR GET https://cloud.x.com/ocs/v2.php/apps/text/workspace?path=/ParentFolder/1002Subfolder2
[HTTP/1.1 404 Not Found 81ms]
Uncaught TypeError: model is null
_updateDetailsView merged-index.js:4663
showDetailsView merged-index.js:4633
scrollTo merged-index.js:7294
Underscore 5
scrollTo merged-index.js:7293
initialize merged-index.js:4382
jQuery 8
setFiles merged-index.js:5522
reloadCallback merged-index.js:6258
jQuery 9
getFolderContents client.js:534
promise callback*getFolderContents client.js:527
reload merged-index.js:6185
changeDirectory merged-index.js:6041
actionHandler merged-index.js:3549
action merged-index.js:2983
initialize merged-index.js:4393
Underscore 5
initialize merged-index.js:4388
FileList merged-index.js:4001
initialize merged-index.js:87
<anonymous> merged-index.js:403
Underscore 5
<anonymous> merged-index.js:402
EventListener.handleEvent* merged-index.js:399
Manually navigating to 1002Subfolder2 has no issues, the folder is there and its contents are being displayed when I navigate into it.
- Did we somehow manage to break the search index? If so, how can we clear/refresh it?
- Is this a common issue with
NextCloud 22.2.3
or is it our instance only?
Thanks in advance,
Regards,
balaFPR
