Problem is that I am not able to edit settings for Collabora Online server that is as default.
So It is impossible for me to change it.
Thanks a lot!!!
I am having this exact same issue with 20.0.2snap2 and I also was preparing for the worst, but disable Collabora Online āfixesā it. I can keep the built-in CODE server enabled, it would seem.
I hope it gets fixed soon, because Iām also using Collabora.
Edit:
If I leave both enabled (and everything is slow asā¦), when I go to Settings > Colloabora Online, it also shows an error there: āKon niet verbinden met de Collabora Online server.ā or in English: āCannot connect to the Collabora Online serverā.
Even though I have a local CODE server installed and selected in the options. So, it seems Collabora is trying to connect to some online server somewhere, or perhaps tries to connect to my own locally installed server but fails?
No, what you mean is that, on the Settings > CODE Server, there is a message saying the settings are not really there, but the settings are at Settings > Collabora Online.
To help you get there, it includes a link to the correct settings page.
However, that link is no longer correct. That is annoying of course and should be fixed, but itās just that: a link to another page with settings to make it more convenient for you. That wrong link cannot be related to the issues weāre experiencing, in my opinion.
Just wanted to thank everyone for bringing this up - I just recovered from an unrelated issue that took me down 100% for a few days and then ran into this and was running out of hopeā¦
For the record, disabling the Collabora app (CODE is still enabled for me) immediately resolved the slow response times. Running the snap package on a Debian VM in Proxmox. Canāt wait to hear more as this gets figured out!
Certainly not, but weāve determined that this has nothing to do with the snap itself (it effects other types of installs as well). Something needs to be fixed in richdocuments/richdocumentscode. Please follow this issue, itās all the rest of us are doing as well.
same here - disabling Collabora & CODE server helps.
(btw.: Iām running debian 10 ābusterā (Linux 4.19.0-13-amd64 x86_64) and ONLYOFFICE 6.2.0 within nextcloud snap version 20.0.2
ONLYOFFICE works!)
I also had this issue and understood that this was an issue that had been fixed in a prior release and had come back and that would be fixed in the next release. I basically did a:
sudo snap refresh nextcloud --channel=latest/edge
followed by a:
sudo snap switch nextcloud --channel=stable
That gave me the latest edge release but will synchronies with the next stable release when available. Fixed it for me.
I am currently (therefore) running master-2020-11-28
If you donāt switch back to the stable channel, then you will get daily updates.
This is of course some risk in doing this as these are beta releases.
Thanks all for this thread.
I wasnāt even able to log in since two-factor would time out before the server could respond. Fixed for me per the github issue page.
I donāt think that will work out the way you hope. The edge channel reflects the current state of master, which is far ahead of the current v20 release in stable. The next release that goes to stable will also be a v20 release, and master will probably still be far ahead (thus making the refresh to stable technically a downgrade, which Nextcloud doesnāt support).
If you want to try this type of thing, I suggest using 20/edge
instead which is a daily build of stable20, which does represent whatās coming in a v20 update. Itās still possible to end up stuck there, but itās better. Note that I generally donāt recommend running any edge channels in production.
And another one confirming disabling the Collabora Online - Built-in CODE Server and Collabora Online App and the brings back a speedy nextcloud instance, which is a shame because I love the office integration in nextcloud, itās a nice feature but until now with regular failures.
Yup i had the same issue and i solve it by disabling and removing collabora online
Also in my setup with NC 20.0.2 an collabora online built-it 6.4.14 the web interface was unresponsive. disabling Collabora online the interface return fast again.
Just thought I would add in, can confirm on 20.0.4 still an issue
Still experiencing this on 20.0.5 with CODE plugin. This is quite disappointing. Anyone have any idea whatās going on or when a fix might be available?
It seems that the problem is solved since the last update to 20.0.7.1
At least for me itās working fine even after a reboot of my server.
Yup can confirm works for me 20.0.7
I can confirm the same.
Ubuntu server 20.04.2 + NC 20.0.7 Snap 1
Collabora enabled + reboot Ubuntu server.
Everything works fine now.
Finally !!!
Howād you get it to work? Iām having the issue with my docker install of 20.0.7
Still an issue for me running 2.0.7 on docker. As soon as both components are enabled - massive slow down.
