Nextcloud version (eg, 12.0.2): 18.01, been happening in 18.0 as well
Operating system and version (eg, Ubuntu 17.04): 18.04.2 LTS
Apache or nginx version (eg, Apache 2.4.25): Apache 2.4.29
PHP version (eg, 7.1): 7.2.24
A few issues that I suspect are interrelated
In the user UI, I cannot edit the group membership of my own user as the little pencil icon is missing, even though I am an admin user:
When selecting group membership for a user, the dropdown is glitched and it’s not possible to select using mouse input. As you can see, there is a UI glitch in that it’s double displaying the group names, in weird position, and it cannot be selected using mouse only by keyboard input:
I am having this same issue, I need to edit my admin account but cannot. My understanding had been that it was supposed to be fixed in 18.0.1, however the issue still persists in 18.0.2… I found an issue on GitHub outlining this but I have not been able to find it again because it seems to have gotten buried in the 2,000+ issues… It had been in the 18.0.1 Milestone, then was in the 18.0.2 milestone but it does not seem to have been fixed.
I am working on downgrading to 17.0.3, I do not considder 18.x to be stable yet.
Hi, I use Version 18.04 and I can not edit any user as admin, so also not re-new the users. Is there any hint how to fix it without getting a new NC Version?
UPDATE
Ok, I realized now all is working in Windows Edge as expected. But using Safari on Ipad Air has problems for scaling the sreen for user management only.
I can not scale down to see all elements! As a result of this, I have to play around by touches with the user entries, so they let move to left to make the edit elements visible.
I’m having a similar problem: the tabs for users are too wide, so with a normal scale of the website I can not see the column of Quota and can’t even adjust it, because that item is not on screen. The space-eater ist the column “group admin for”, where I can write letters, for it is this wide.
The workaround:
I adjust the scale in Firefox to 80%, but I have difficulties to read or
scale the Firefox-Window on two screens.
Is it possible to change CSS-entrys for those columns?
