Nextcloud version (eg, 18.0.3):
Operating system and version (Ubuntu 18.04.03):
Apache or nginx version (Apache 2.4.):
PHP version (7.3):
I have been using Nextcloud for a while but never actually got the OCC commands running. If I click on the “overview” I get some warnings about several issues but some are indicating that they can fix using the OCC command. For example this one: “occ db:add-missing-indices”. The hosting I am on is supporting a shell but while I am trying to run the commands I am always ending in error.
When I log into the shell using a “custom” generate login I got this: Welcome to Ubuntu 18.04.3 LTS (GNU/Linux 4.4.0-176-generic x86_64)
. I have then tried to navigate to the root folder of Nextcloud and run for example this: sudo -u www-data php occ db:convert-filecache-bigint.
The output is that “sudo” is not recognized and of course I can’t install it. If I run the command without the sudo -u www-data
, I will get the message below:
Your data directory is invalid
Ensure there is a file called ".ocdata" in the root of the data directory.
Cannot create "data" directory
This can usually be fixed by giving the webserver write access to the root directory. See https://docs.nextcloud.com/server/18/go.php?to=admin-dir_permissions
Exception: Environment not properly prepared. in /home/3d-sphere.com/sub/unicorn/lib/private/Console/Application.php:167
Stack trace:
#0 /home/3d-sphere.com/sub/unicorn/console.php(98): OC\Console\Application->loadCommands()
#1 /home/3d-sphere.com/sub/unicorn/occ(11): require_once('/home/3d-sphere...')
#2 {main}uid27767@shellserver:~/3d-sphere.com/sub/unicorn$
I have found some workarounds for the “sudo” issue using “su” but when I point to the www-data user, it asks for password and I certainly have no idea about it: su - www-data -c php occ db:convert-filecache-bigint
I am absolutely lost and have no idea what I am doing wrong or how to run the OCC commands without the error above ect… Any thoughts?
thx, Tomas
Error PHP shell_exec(): Unable to execute 'cat /etc/systemd/timesyncd.conf 2>/dev/null |grep '^NTP=' | cut -f 2 -d " "' at /nfsmnt/hosting1_2/1/b/1b762867-630f-4dca-b3dc-caca865f417b/3d-sphere.com/sub/unicorn/apps/serverinfo/lib/OperatingSystems/DefaultOs.php#96 2020-04-10T23:02:11+0200
Error PHP shell_exec(): Unable to execute 'cat /etc/ntp.conf 2>/dev/null |grep '^pool' | cut -f 2 -d " "' at /nfsmnt/hosting1_2/1/b/1b762867-630f-4dca-b3dc-caca865f417b/3d-sphere.com/sub/unicorn/apps/serverinfo/lib/OperatingSystems/DefaultOs.php#95 2020-04-10T23:02:11+0200
Error PHP shell_exec(): Unable to execute 'cat /etc/systemd/timesyncd.conf 2>/dev/null |grep '^NTP=' | cut -f 2 -d " "' at /nfsmnt/hosting1_2/1/b/1b762867-630f-4dca-b3dc-caca865f417b/3d-sphere.com/sub/unicorn/apps/serverinfo/lib/OperatingSystems/DefaultOs.php#96 2020-04-10T23:02:10+0200
Error PHP shell_exec(): Unable to execute 'cat /etc/ntp.conf 2>/dev/null |grep '^pool' | cut -f 2 -d " "' at /nfsmnt/hosting1_2/1/b/1b762867-630f-4dca-b3dc-caca865f417b/3d-sphere.com/sub/unicorn/apps/serverinfo/lib/OperatingSystems/DefaultOs.php#95 2020-04-10T23:02:10+0200
Error PHP shell_exec(): Unable to execute 'cat /etc/systemd/timesyncd.conf 2>/dev/null |grep '^NTP=' | cut -f 2 -d " "' at /nfsmnt/hosting1_2/1/b/1b762867-630f-4dca-b3dc-caca865f417b/3d-sphere.com/sub/unicorn/apps/serverinfo/lib/OperatingSystems/DefaultOs.php#96 2020-04-10T23:02:09+0200
Error PHP shell_exec(): Unable to execute 'cat /etc/ntp.conf 2>/dev/null |grep '^pool' | cut -f 2 -d " "' at /nfsmnt/hosting1_2/1/b/1b762867-630f-4dca-b3dc-caca865f417b/3d-sphere.com/sub/unicorn/apps/serverinfo/lib/OperatingSystems/DefaultOs.php#95 2020-04-10T23:02:09+0200
Error PHP shell_exec(): Unable to execute 'cat /etc/systemd/timesyncd.conf 2>/dev/null |grep '^NTP=' | cut -f 2 -d " "' at /nfsmnt/hosting1_2/1/b/1b762867-630f-4dca-b3dc-caca865f417b/3d-sphere.com/sub/unicorn/apps/serverinfo/lib/OperatingSystems/DefaultOs.php#96 2020-04-10T23:02:07+0200
Error PHP shell_exec(): Unable to execute 'cat /etc/ntp.conf 2>/dev/null |grep '^pool' | cut -f 2 -d " "' at /nfsmnt/hosting1_2/1/b/1b762867-630f-4dca-b3dc-caca865f417b/3d-sphere.com/sub/unicorn/apps/serverinfo/lib/OperatingSystems/DefaultOs.php#95 2020-04-10T23:02:07+0200
Error PHP shell_exec(): Unable to execute 'cat /etc/systemd/timesyncd.conf 2>/dev/null |grep '^NTP=' | cut -f 2 -d " "' at /nfsmnt/hosting1_2/1/b/1b762867-630f-4dca-b3dc-caca865f417b/3d-sphere.com/sub/unicorn/apps/serverinfo/lib/OperatingSystems/DefaultOs.php#96 2020-04-10T23:02:06+0200
Error PHP shell_exec(): Unable to execute 'cat /etc/ntp.conf 2>/dev/null |grep '^pool' | cut -f 2 -d " "' at /nfsmnt/hosting1_2/1/b/1b762867-630f-4dca-b3dc-caca865f417b/3d-sphere.com/sub/unicorn/apps/serverinfo/lib/OperatingSystems/DefaultOs.php#95 2020-04-10T23:02:06+0200
Error PHP shell_exec(): Unable to execute 'cat /etc/systemd/timesyncd.conf 2>/dev/null |grep '^NTP=' | cut -f 2 -d " "' at /nfsmnt/hosting1_2/1/b/1b762867-630f-4dca-b3dc-caca865f417b/3d-sphere.com/sub/unicorn/apps/serverinfo/lib/OperatingSystems/DefaultOs.php#96 2020-04-10T23:02:05+0200
Error PHP shell_exec(): Unable to execute 'cat /etc/ntp.conf 2>/dev/null |grep '^pool' | cut -f 2 -d " "' at /nfsmnt/hosting1_2/1/b/1b762867-630f-4dca-b3dc-caca865f417b/3d-sphere.com/sub/unicorn/apps/serverinfo/lib/OperatingSystems/DefaultOs.php#95 2020-04-10T23:02:05+0200
Error PHP shell_exec(): Unable to execute 'cat /etc/systemd/timesyncd.conf 2>/dev/null |grep '^NTP=' | cut -f 2 -d " "' at /nfsmnt/hosting1_2/1/b/1b762867-630f-4dca-b3dc-caca865f417b/3d-sphere.com/sub/unicorn/apps/serverinfo/lib/OperatingSystems/DefaultOs.php#96 2020-04-10T23:02:04+0200
Error PHP shell_exec(): Unable to execute 'cat /etc/ntp.conf 2>/dev/null |grep '^pool' | cut -f 2 -d " "' at /nfsmnt/hosting1_2/1/b/1b762867-630f-4dca-b3dc-caca865f417b/3d-sphere.com/sub/unicorn/apps/serverinfo/lib/OperatingSystems/DefaultOs.php#95 2020-04-10T23:02:04+0200
Error PHP shell_exec(): Unable to execute 'cat /etc/systemd/timesyncd.conf 2>/dev/null |grep '^NTP=' | cut -f 2 -d " "' at /nfsmnt/hosting1_2/1/b/1b762867-630f-4dca-b3dc-caca865f417b/3d-sphere.com/sub/unicorn/apps/serverinfo/lib/OperatingSystems/DefaultOs.php#96 2020-04-10T23:02:02+0200
Error PHP shell_exec(): Unable to execute 'cat /etc/ntp.conf 2>/dev/null |grep '^pool' | cut -f 2 -d " "' at /nfsmnt/hosting1_2/1/b/1b762867-630f-4dca-b3dc-caca865f417b/3d-sphere.com/sub/unicorn/apps/serverinfo/lib/OperatingSystems/DefaultOs.php#95 2020-04-10T23:02:02+0200
Error PHP shell_exec(): Unable to execute 'cat /etc/systemd/timesyncd.conf 2>/dev/null |grep '^NTP=' | cut -f 2 -d " "' at /nfsmnt/hosting1_2/1/b/1b762867-630f-4dca-b3dc-caca865f417b/3d-sphere.com/sub/unicorn/apps/serverinfo/lib/OperatingSystems/DefaultOs.php#96 2020-04-10T23:02:01+0200
Error PHP shell_exec(): Unable to execute 'cat /etc/ntp.conf 2>/dev/null |grep '^pool' | cut -f 2 -d " "' at /nfsmnt/hosting1_2/1/b/1b762867-630f-4dca-b3dc-caca865f417b/3d-sphere.com/sub/unicorn/apps/serverinfo/lib/OperatingSystems/DefaultOs.php#95 2020-04-10T23:02:01+0200
Error PHP shell_exec(): Unable to execute 'ip -o -6 addr show lo | sed -e 's/^.*inet6 \([^ ]\+\).*/\1/'' at /nfsmnt/hosting1_2/1/b/1b762867-630f-4dca-b3dc-caca865f417b/3d-sphere.com/sub/unicorn/apps/serverinfo/lib/OperatingSystems/DefaultOs.php#125 2020-04-10T23:01:59+0200
Error PHP shell_exec(): Unable to execute 'ip addr show dev lo | grep "inet " | cut -d ' ' -f 6 | cut -f 1 -d '/'' at /nfsmnt/hosting1_2/1/b/1b762867-630f-4dca-b3dc-caca865f417b/3d-sphere.com/sub/unicorn/apps/serverinfo/lib/OperatingSystems/DefaultOs.php#124 2020-04-10T23:01:59+0200
Error PHP shell_exec(): Unable to execute 'ip addr show dev lo | grep "link/ether " | cut -d ' ' -f 6 | cut -f 1 -d '/'' at /nfsmnt/hosting1_2/1/b/1b762867-630f-4dca-b3dc-caca865f417b/3d-sphere.com/sub/unicorn/apps/serverinfo/lib/OperatingSystems/DefaultOs.php#123 2020-04-10T23:01:59+0200
Error PHP shell_exec(): Unable to execute 'ip -o -6 addr show eth0 | sed -e 's/^.*inet6 \([^ ]\+\).*/\1/'' at /nfsmnt/hosting1_2/1/b/1b762867-630f-4dca-b3dc-caca865f417b/3d-sphere.com/sub/unicorn/apps/serverinfo/lib/OperatingSystems/DefaultOs.php#125 2020-04-10T23:01:59+0200
Error PHP shell_exec(): Unable to execute 'ip addr show dev eth0 | grep "inet " | cut -d ' ' -f 6 | cut -f 1 -d '/'' at /nfsmnt/hosting1_2/1/b/1b762867-630f-4dca-b3dc-caca865f417b/3d-sphere.com/sub/unicorn/apps/serverinfo/lib/OperatingSystems/DefaultOs.php#124 2020-04-10T23:01:59+0200
Error PHP shell_exec(): Unable to execute 'ip addr show dev eth0 | grep "link/ether " | cut -d ' ' -f 6 | cut -f 1 -d '/'' at /nfsmnt/hosting1_2/1/b/1b762867-630f-4dca-b3dc-caca865f417b/3d-sphere.com/sub/unicorn/apps/serverinfo/lib/OperatingSystems/DefaultOs.php#123 2020-04-10T23:01:59+0200
Error PHP shell_exec(): Unable to execute 'ip -o -6 addr show bonding_masters | sed -e 's/^.*inet6 \([^ ]\+\).*/\1/'' at /nfsmnt/hosting1_2/1/b/1b762867-630f-4dca-b3dc-caca865f417b/3d-sphere.com/sub/unicorn/apps/serverinfo/lib/OperatingSystems/DefaultOs.php#125 2020-04-10T23:01:59+0200
Error PHP shell_exec(): Unable to execute 'ip addr show dev bonding_masters | grep "inet " | cut -d ' ' -f 6 | cut -f 1 -d '/'' at /nfsmnt/hosting1_2/1/b/1b762867-630f-4dca-b3dc-caca865f417b/3d-sphere.com/sub/unicorn/apps/serverinfo/lib/OperatingSystems/DefaultOs.php#124 2020-04-10T23:01:59+0200
Error PHP shell_exec(): Unable to execute 'ip addr show dev bonding_masters | grep "link/ether " | cut -d ' ' -f 6 | cut -f 1 -d '/'' at /nfsmnt/hosting1_2/1/b/1b762867-630f-4dca-b3dc-caca865f417b/3d-sphere.com/sub/unicorn/apps/serverinfo/lib/OperatingSystems/DefaultOs.php#123 2020-04-10T23:01:59+0200
Error PHP shell_exec(): Unable to execute 'cat /etc/resolv.conf |grep -i '^nameserver'|head -n1|cut -d ' ' -f2' at /nfsmnt/hosting1_2/1/b/1b762867-630f-4dca-b3dc-caca865f417b/3d-sphere.com/sub/unicorn/apps/serverinfo/lib/OperatingSystems/DefaultOs.php#106 2020-04-10T23:01:59+0200
Warning core Login failed: 'admin' (Remote IP: '94.228.89.180') 2020-04-10T22:57:32+0200
Warning appstoreFetcher Could not connect to appstore: cURL error 28: Operation timed out after 9992 milliseconds with 2768896 out of 4644885 bytes received (see http://curl.haxx.se/libcurl/c/libcurl-errors.html) 2020-04-09T12:30:17+0200
Warning appstoreFetcher Could not connect to appstore: cURL error 28: Operation timed out after 10000 milliseconds with 0 bytes received (see http://curl.haxx.se/libcurl/c/libcurl-errors.html) 2020-04-06T12:00:17+0200
Warning appstoreFetcher Could not connect to appstore: cURL error 28: Connection timed out after 10001 milliseconds (see http://curl.haxx.se/libcurl/c/libcurl-errors.html) 2020-04-05T12:00:19+0200
Info updater \OC\Updater::resetLogLevel: Reset log level to Warning(2) 2020-04-05T11:23:26+0200
Info updater \OC\Updater::maintenanceDisabled: Turned off maintenance mode 2020-04-05T11:23:26+0200
Info updater \OC\Updater::updateEnd: Update successful 2020-04-05T11:23:26+0200
Info updater \OC\Updater::finishedCheckCodeIntegrity: Finished code integrity check 2020-04-05T11:23:26+0200
Info updater \OC\Updater::startCheckCodeIntegrity: Starting code integrity check... 2020-04-05T11:23:23+0200
Info updater \OC\Repair::step: Repair step: Reset generated avatar flag 2020-04-05T11:23:23+0200
Debug no app in context Deprecated event type for \OC\Repair::step: Symfony\Component\EventDispatcher\GenericEvent 2020-04-05T11:23:23+0200
Info updater \OC\Repair::info: Repair info: Repair step already executed 2020-04-05T11:23:23+0200
Debug no app in context Deprecated event type for \OC\Repair::info: Symfony\Component\EventDispatcher\GenericEvent 2020-04-05T11:23:23+0200
Info updater \OC\Repair::step: Repair step: Sets the enterprise logo 2020-04-05T11:23:23+0200
Info updater \OC\Repair::step: Repair step: Switches from deprecated "production" to "stable" update channel 2020-04-05T11:23:23+0200
Info updater \OC\Repair::step: Repair step: Clear access cache of projects 2020-04-05T11:23:23+0200
Info updater \OC\Repair::info: Repair info: No need to remove link shares. 2020-04-05T11:23:23+0200
Info updater \OC\Repair::step: Repair step: Remove potentially over exposing share links 2020-04-05T11:23:23+0200
Info updater \OC\Repair::step: Repair step: Add background job to cleanup login flow v2 tokens 2020-04-05T11:23:23+0200
Info updater \OC\Repair::step: Repair step: Cleanup invalid photocache files for carddav 2020-04-05T11:23:23+0200
Info updater \OC\Repair::step: Repair step: Queue a one-time job to cleanup old backups of the updater 2020-04-05T11:23:23+0200
Info updater \OC\Repair::step: Repair step: Add preview background cleanup job 2020-04-05T11:23:23+0200
Info updater \OC\Repair::step: Repair step: Clear every generated avatar on major updates 2020-04-05T11:23:23+0200
Info updater \OC\Repair::info: Repair info: JS cache cleared 2020-04-05T11:23:23+0200
Debug no app in context Deprecated event type for \OCP\Files::postDelete: Symfony\Component\EventDispatcher\GenericEvent 2020-04-05T11:23:23+0200
Debug no app in context Deprecated event type for \OCP\Files::preDelete: Symfony\Component\EventDispatcher\GenericEvent 2020-04-05T11:23:23+0200
Info updater \OC\Repair::info: Repair info: SCSS cache cleared 2020-04-05T11:23:23+0200
Debug no app in context SCSSCacher: css cache cleared! 2020-04-05T11:23:23+0200
