example
longer
example
here
Nextcloud version (eg, 12.0.2): 16.0.1
Operating system and version (eg, Ubuntu 17.04): Centos 7.6
Apache or nginx version (eg, Apache 2.4.25): Apache 2.4.25
PHP version (eg, 7.1): rh php 7.1
When I try to access administration settings in nextcloud I get this error below. If I click anything else what is not under administration it works I can access it. On version 15 I am soure that works. And I didn’t change anything on server.
Service Unavailable
The server is temporarily unable to service your request due to maintenance downtime or capacity problems. Please try again later.
PASTE HERE
PASTE HERE
no errors
