example
longer
example
here
Nextcloud version (eg, 12.0.2): 15.0.2
Operating system and version (eg, Ubuntu 17.04): FreeNAS-11.2-RELEASE-U1
Apache or nginx version (eg, Apache 2.4.25): nginx/1.14.2
PHP version (eg, 7.1): 7.1.26
The issue you are facing: I cannot connect to my AD with NextCloud. It says:
Connection to LDAP server could not be established
The Base DN appears to be wrong
- Try to connect to AD
- That’s it
Configuration Error (prefix s01): login filter does not contain %uid place holder.
Configuration Error (prefix s01): No LDAP Login Filter given!
'ldapIgnoreNamingRules' => false,
no significant information
