example
longer
example
here
Nextcloud version (eg, 12.0.2): 14.0.3
Operating system and version (eg, Ubuntu 17.04): debian/sid/amd64
Apache or nginx version (eg, Apache 2.4.25): nginx 1.14.0-1
PHP version (eg, 7.1): php-fpm 7.3.0~rc3-1
I noticed my home server only work on chromium, when I use firefox/IE to login via web interface,
I can not see the files (https://imgur.com/a/0JPd9Jd)
When I use chromium/chrome, everything work fine (https://imgur.com/a/q0ny2nl)
NOTHING in nextcloud.log
'instanceid' => 'oc7g5XXXX',
'passwordsalt' => 'XXX-----------------XXX',
'secret' => 'XXX-----------XXX',
0 => 'cloud.domain.com',
'datadirectory' => '/www/cloud/data',
'overwrite.cli.url' => 'https://cloud.domain.com',
'version' => '14.0.3.0',
'dbname' => 'nextcloud',
'dbhost' => 'localhost',
'dbuser' => 'nextcloud',
'dbpassword' => 'XXX----------------XXX',
'logtimezone' => 'UTC',
'auth.bruteforce.protection.enabled' => true,
'apps_paths' =>
0 =>
'path' => '/var/www/cloud.domain.com/www/apps',
'url' => '/apps',
'writable' => true,
'theme' => '',
'loglevel' => 3,
'user_backends' =>
0 =>
'class' => 'OC_User_IMAP',
'arguments' =>
0 => '{domain.com:993/imap/ssl/readonly}INBOX',
'lost_password_link' => 'disable',
'log_type' => 'file',
'logfile' => '/tmp/nextcloud.log',
'redis' =>
'host' => '/var/run/redis/redis.sock',
'port' => 0,
'timeout' => 0.0,
'dbindex' => 2,
'mail_smtpmode' => 'smtp',
'mail_smtpauth' => 1,
'data-fingerprint' => '8c256607260b38fc791356a80905b500',
NOTHING error/warning in nginx.log
