Nextcloud version _ 13.0.5
Operating system and version _ Ubuntu Server 18.04
Apache or nginx version _ nginx 1.15.2
PHP version _ 7.2
I followed the install guide at :https://www.c-rieger.de/nextcloud-13-nginx-installation-guide-for-ubuntu-18-04-lts/ I had another install using Apache and it did the same thing but was less responsive overall. I guess nginx and tuning it made a difference.
When I try to access the server using a LAN connection it takes about 20 seconds to log in from the computer. Access from the apps (Nextcloud, Talk, and Notes) all take forever and sometimes time out trying to connect. When I access it from a WAN connection or through a VPN it works flawlessly. Could it be a problem with my router settings? I have a nice Ubiquity setup but maybe I am missing something.
Not seeing anything but a bunch of errors for antivirus app installed but no ClamAV. Disabled app but no
difference. Will update once log builds.
'instanceid' => '********',
'passwordsalt' => '********',
'secret' => '********',
0 => 'putnam.********.com',
1 => 'putnam.********.com',
'datadirectory' => '/mnt/nc-data/ncdata',
'overwrite.cli.url' => 'putnam.*******.com',
'version' => '13.0.5.2',
'dbname' => 'nextcloud',
'dbhost' => 'localhost',
'dbuser' => 'nc_user',
'dbpassword' => '*******',
'activity_expire_days' => 14,
'auth.bruteforce.protection.enabled' => true,
'blacklisted_files' =>
0 => '.htaccess',
1 => 'Thumbs.db',
2 => 'thumbs.db',
'cron_log' => true,
'enable_previews' => true,
'enabledPreviewProviders' =>
0 => 'OC\\Preview\\PNG',
1 => 'OC\\Preview\\JPEG',
2 => 'OC\\Preview\\GIF',
3 => 'OC\\Preview\\BMP',
4 => 'OC\\Preview\\XBitmap',
5 => 'OC\\Preview\\Movie',
6 => 'OC\\Preview\\PDF',
7 => 'OC\\Preview\\MP3',
8 => 'OC\\Preview\\TXT',
9 => 'OC\\Preview\\MarkDown',
'filesystem_check_changes' => 0,
'integrity.check.disabled' => false,
'knowledgebaseenabled' => false,
'logfile' => '/var/nc_data/nextcloud.log',
'loglevel' => 2,
'logtimezone' => 'America/New_York',
'log_rotate_size' => 104857600,
'preview_max_x' => 1024,
'preview_max_y' => 768,
'preview_max_scale_factor' => 1,
'redis' =>
'port' => 0,
'timeout' => 0.0,
'quota_include_external_storage' => false,
'share_folder' => '/Shares',
'skeletondirectory' => '',
'theme' => '',
'trashbin_retention_obligation' => 'auto, 7',
'mail_smtpmode' => 'smtp',
'mail_smtpsecure' => 'ssl',
'mail_smtpauth' => 1,
'mail_smtpport' => '465',
'mail_from_address' => '*********',
'mail_domain' => 'gmail.com',
'mail_smtphost' => 'smtp.gmail.com',
'mail_smtpname' => '***********@gmail.com',
'mail_smtppassword' => '*******',
2018/07/24 23:52:58 [error] 5432#5432: *10 access forbidden by rule, client: 192.168.10.119, server: putnam.*****.com, request: "GET /data/htaccesstest.txt HTTP/1.1", host: "putnam.*****.com"
2018/07/25 01:07:37 [warn] 1732#1732: *3 an upstream response is buffered to a temporary file /var/cache/nginx/fastcgi_temp/1/00/0000000001 while reading upstream, client: 192.168.10.119, server: putnam.*****.com, request: "GET /remote.php/webdav/Media/Movies/TestVid(1).mp4 HTTP/2.0", upstream: "fastcgi://unix:/run/php/php7.2-fpm.sock:", host: "putnam.*****.com"
2018/07/25 01:07:45 [warn] 1732#1732: *3 an upstream response is buffered to a temporary file /var/cache/nginx/fastcgi_temp/2/00/0000000002 while reading upstream, client: 192.168.10.119, server: putnam.*****.com, request: "GET /remote.php/webdav/Media/Movies/TestVid(1).mp4 HTTP/2.0", upstream: "fastcgi://unix:/run/php/php7.2-fpm.sock:", host: "putnam.*****.com"
2018/07/25 01:35:56 [warn] 1732#1732: *1676 an upstream response is buffered to a temporary file /var/cache/nginx/fastcgi_temp/3/00/0000000003 while reading upstream, client: 192.168.10.119, server: putnam.*****.com, request: "GET /remote.php/dav/files/Jeremiah/Nextcloud%20Manual.pdf HTTP/1.1", upstream: "fastcgi://unix:/run/php/php7.2-fpm.sock:", host: "putnam.*****.com"
^ Client 192.168.10.119 is my router. 192.168.10.100 is the server.
