Nextcloud 18.0.4
OpenSuse Leap 15.1
Apache 2.4.33
PHP 7.5.2
I was affected by this issue: Nextcloud 16 - Password change is disabled because the master key is disabled
Unfortunately the workaround didn’t work for me, “occ encryption:enable-master-key” “destroyed” my files, they’re all double-encrypted after that.
But back to my URGENT root issue:
As I (of course) have had a backup, so I performed all steps from the admin guide https://docs.nextcloud.com/server/18/admin_manual/maintenance/restore.html
I’ve made a full backup and recovery of the complete /* folder structure.
Restored the dump file for the mysql/mariadb user.
Performed an occ maintenance:data-fingerprint, plus as a try an occ maintenance:reapair.
NOTHING works, althouigh no error msgs for occ.
Current situation: I “can” login, but file are not shown, error msg translated from German: “This folder is not available, please check logfiles or contact your admin”. Browser (Firefox) than HANGS on all OS, tried WIn10, Linux, and Android.
No idea what the log errors means, example log line comes from Nextcloud Android app, tried to perform a daily upload of my Android; contacts.
{“reqId":“X95qOF5YBAtbnynC9eAF”,“level”:3,“time”:“2020-05-07T09:21:41+00:00”,“remoteAddr”:“91.13.153.238”,“user”:"michael@example.com”,“app”:“no app in context”,“method”:“PUT”,“url”:"/remote.php/webdav/.Contacts-Backup/2020-05-07_10-56-17.vcf",“message”:{“Exception”:“Symfony\Component\Routing\Exception\RouteNotFoundException”,“Message”:“Unable to generate a URL for the named route “tasks.page.index” as such route does not exist.”,“Code”:0,“Trace”:[{“file”:"/srv/www/htdocs/nextcloud/lib/private/Route/Router.php",“line”:339,“function”:“generate”,“class”:“Symfony\Component\Routing\Generator\UrlGenerator”,“type”:"->",“args”:[“tasks.page.index”,[],1]},{“file”:"/srv/www/htdocs/nextcloud/lib/private/URLGenerator.php",“line”:82,“function”:“generate”,“class”:“OC\Route\Router”,“type”:"->",“args”:[“tasks.page.index”,[]]},{“file”:"/srv/www/htdocs/nextcloud/lib/private/NavigationManager.php",“line”:293,“function”:“linkToRoute”,“class”:“OC\URLGenerator”,“type”:"->",“args”:[“tasks.page.index”]},{“file”:"/srv/www/htdocs/nextcloud/lib/private/NavigationManager.php",“line”:114,“function”:“init”,“class”:“OC\NavigationManager”,“type”:"->",“args”:[]},{“file”:"/srv/www/htdocs/nextcloud/apps/theming/lib/ThemingDefaults.php",“line”:182,“function”:“getAll”,“class”:“OC\NavigationManager”,“type”:"->",“args”:[“guest”]},{“file”:"/srv/www/htdocs/nextcloud/lib/private/legacy/defaults.php",“line”:263,“function”:“getShortFooter”,“class”:“OCA\Theming\ThemingDefaults”,“type”:"->",“args”:[]},{“file”:"/srv/www/htdocs/nextcloud/lib/public/Defaults.php",“line”:169,“function”:“getLongFooter”,“class”:“OC_Defaults”,“type”:"->",“args”:[]},{“file”:"/srv/www/htdocs/nextcloud/core/templates/layout.guest.php",“line”:55,“function”:“getLongFooter”,“class”:“OCP\Defaults”,“type”:"->",“args”:[]},{“file”:"/srv/www/htdocs/nextcloud/lib/private/Template/Base.php",“line”:179,“args”:["/srv/www/htdocs/nextcloud/core/templates/layout.guest.php"],“function”:“include”},{“file”:"/srv/www/htdocs/nextcloud/lib/private/Template/Base.php",“line”:151,“function”:“load”,“class”:“OC\Template\Base”,“type”:"->",“args”:["/srv/www/htdocs/nextcloud/core/templates/layout.guest.php",null]},{“file”:"/srv/www/htdocs/nextcloud/lib/private/legacy/template.php",“line”:181,“function”:“fetchPage”,“class”:“OC\Template\Base”,“type”:"->",“args”:[null]},{“file”:"/srv/www/htdocs/nextcloud/lib/private/legacy/template.php",“line”:212,“function”:“fetchPage”,“class”:“OC_Template”,“type”:"->",“args”:[null]},{“file”:"/srv/www/htdocs/nextcloud/lib/private/Template/Base.php",“line”:132,“function”:“fetchPage”,“class”:“OC_Template”,“type”:"->",“args”:[]},{“file”:"/srv/www/htdocs/nextcloud/lib/private/legacy/template.php",“line”:333,“function”:“printPage”,“class”:“OC\Template\Base”,“type”:"->",“args”:[]},{“file”:"/srv/www/htdocs/nextcloud/remote.php",“line”:85,“function”:“printExceptionErrorPage”,“class”:“OC_Template”,“type”:"::",“args”:[{“class”:“ArgumentCountError”},500]},{“file”:"/srv/www/htdocs/nextcloud/remote.php",“line”:170,“function”:“handleException”,“args”:[{“class”:“ArgumentCountError”}]}],“File”:"/srv/www/htdocs/nextcloud/3rdparty/symfony/routing/Generator/UrlGenerator.php",“Line”:144,“CustomMessage”:"–"},“userAgent”:“Mozilla/5.0 (Android) Nextcloud-android/3.11.1”,“version”:“18.0.4.2”}
Any hints would be great !!!
Rgds,
Michael
