New Photo Previews Blurry After Using Preview Generator – Need Help Fixing It
I recently learned that the Preview Generator app can create all previews at once to improve loading speed in the NextCloud photo app. After trying it, I noticed that only the new preview images became blurry, while the old ones were fine. However, after deleting all the old photo previews, everything is now blurry. Disabling Preview Generator doesn’t fix the issue either. I’m using NextCloud Memories, and weird enough that the preview seems fine. Does anyone know how to fix this?
  • Nextcloud version : 30.0.1.2 (docker)
  • Operating system and version: Debian 12
  • Apache or nginx version: 2.12.1 (docker)
  • PHP version: 8.2.25
My config.php file:
  'apps_paths' =>
    0 =>
      'url' => '/apps',
      'writable' => false,
    1 =>
      'url' => '/custom_apps',
      'writable' => true,
  'redis' =>
    'host' => 'redis',
    'password' => '',
    'port' => 6379,
  'instanceid' => 'ocxj7dyvbrq9',
  'passwordsalt' => *removed*,
  'secret' => *removed*,
    0 => *removed*,
  'dbtype' => 'sqlite3',
  'version' => '30.0.0.14',
  'overwrite.cli.url' => *removed*,
  'check_data_directory_permissions' => false,
  'memories.db.triggers.fcu' => true,
  'memories.exiftool' => '/var/www/html/custom_apps/memories/bin-ext/exiftool-a>
  'memories.vod.path' => '/var/www/html/custom_apps/memories/bin-ext/go-vod-aar>
Same here and i have no idea. Preview in NC folders are fine. Just in Photos try are blurry.
