From what i have seen so far with NextCloud i am very impressed.
However, I need to move the data storage directory to another mounted drive (larger), is there a way to do this? i have tried just changing the path in the config.php but when i refresh the web page it says “missing ocdata” but i cannot find this to make sure it’s gone across. Any ideas would be received gratefully.
When you change the config.php you should copy or move all your data to the new location you set in the config.php this includes HIDDEN files starting with .
