Need nelp to Migrate PostgreSQL to AIO
    • 11.9.0
    • TrueNAS 25.04
    • no idea
    • Zoraxy 3.2.5
    • no idea
    • replace me
    • Since beginning
    • AIO
    • Cloudflare X CrowdSec
I have backed up PostgreSQL of TrueNAS’s official app with the help of pgAdmin. Now I wish to migrate to AIO. I’m just stuck at the final part is to recover the database to fresh deployed AIO.
If I restore without cleaning is ok-ish. Meaning that all users can log-in, but loosing a lot of content such as theming, branding, contacts, conversations,… those are missing. Activities list is also good. I feel that I’m so close to the final goal.
  1. Deploy custom yaml for pgAdmin by putting into 2 docker network of the 2 Nextcloud instances. ix-dextcloud_default and nextcloud-aio
  2. Get the password of the 2 databases by going into their configuration file
  3. Configure pgAdmin to connect to those database containers.
    Names/hostnames of the containers are
    • ix-nextcloud-postgres-1
    • nextcloud-aio-database
  4. Back up the database of the actual Nextcloud instance to a .sql file
  5. Restore the database to AIO by checking Pre-data, Data, Post-data, Clean before messes up and got error 500, so If it’s not checked, that’s ok
The logs shows after the fresh install. Haven’t started the restoration of the database yet
Not posting it. Due to tons of sensitive data such as IP and FQDN
PASTE
PASTE HERE
PASTE HERE
Personal notes
Sorry If I have missed out to post something might be important.
Hi, see https://github.com/nextcloud/all-in-one/blob/main/migration.md#migrate-the-files-and-the-database
Hoi! Danke viel mal!
I was using Truecharts’s apps back then. One day the forced us to migrate to new instance due to incompatibility after an upgrade. That was easy
Is there a possibility to use pgAdmin to restore? As I could successfully restore users. They can all log in seemlessly. As being wrote, only activities list are shown. Not the rest.
Was following the guide by skipping a lot of steps
I go imediately to the step to check ownership and found differences
Follow up:
I could easilly restore the dabase. Found out that pgAdmin was using the wrong username that I set to connect to database. I used nextcloud instead of oc_nextcloud after restoration of the db with nextcloud user all tables ownership is automatically assigned to nextcloud.
When using oc_nextcloud to connect to the database, is fine. Could restore and is reacheable.
Is way simpler and faster than the doc you sent me.
