example
longer
example
here
Nextcloud version (eg, 20.0.5): 26.0.1.1
Operating system and version (eg, Ubuntu 20.04): debian 11
Apache or nginx version (eg, Apache 2.4.25): nginx 1.18.0.6
PHP version (eg, 7.4): 8.1
When I try to login after inputting the username and password, I get the following error:
" Internal Server Error
The server was unable to complete your request.
If this happens again, please send the technical details below to the server administrator.
Technical details
- Remote Address: 192.168.39.251
- Request ID: 1larJKnRh5WxyddCjEQs"
Is this the first time you’ve seen this error? (Y/N):Y
Repooted still the same issue
PASTE HERE
I am unable to log in as admin. The system is set to connect using AD. I can see the following errors in the nextcloud log:
\User_LDAP\{closure}“,“class”:“OCA\User_LDAP\Access”,“type”:”->“,“args”:[”*** sensitive parameters replaced “]},{“file”:”/usr/share/nginx/nextcloud/apps/user_ldap/lib/Access.php",“line”:253,“function”:“invokeLDAPMethod”,“class”:“OCA\User_LDAP\Access”,“type”:“->”,“args”:[" sensitive parameters replaced “]},{“file”:”/usr/share/nginx/nextcloud/apps/user_ldap/lib/Access.php",“line”:204,“function”:“executeRead”,“class”:“OCA\User_LDAP\Access”,“type”:“->”},{“file”:“/usr/share/nginx/nextcloud/apps/user_ldap/lib/User_LDAP.php”,“line”:324,“function”:“readAttribute”,“class”:“OCA\User_LDAP\Access”,“type”:“->”},{“function”:“userExistsOnLDAP”,“class”:“OCA\User_LDAP\User_LDAP”,“type”:“->”},{“file”:“/usr/share/nginx/nextcloud/apps/user_ldap/lib/User_Proxy.php”,“line”:110,“function”:“call_user_func_array”},{“file”:“/usr/share/nginx/nextcloud/apps/user_ldap/lib/Proxy.php”,“line”:140,“function”:“walkBackends”,“class”:“OCA\User_LDAP\User_Proxy”,“type”:“->”},{“file”:“/usr/share/nginx/nextcloud/apps/user_ldap/lib/User_Proxy.php”,“line”:246,“function”:“handleRequest”,“class”:“OCA\User_LDAP\Proxy”,“type”:“->”},{“file”:“/usr/share/nginx/nextcloud/apps/user_ldap/lib/User_Proxy.php”,“line”:223,“function”:“userExistsOnLDAP”,“class”:“OCA\User_LDAP\User_Proxy”,“type”:“->”},{“file”:“/usr/share/nginx/nextcloud/lib/private/User/Manager.php”,“line”:184,“function”:“userExists”,“class”:“OCA\User_LDAP\User_Proxy”,“type”:“->”},{“file”:“/usr/share/nginx/nextcloud/apps/files_antivirus/lib/BackgroundJob/BackgroundScanner.php”,“line”:95,“function”:“get”,“class”:“OC\User\Manager”,“type”:“->”},{“file”:“/usr/share/nginx/nextcloud/lib/public/BackgroundJob/Job.php”,“line”:78,“function”:“run”,“class”:“OCA\Files_Antivirus\BackgroundJob\BackgroundScanner”,“type”:“->”},{“file”:“/usr/share/nginx/nextcloud/lib/public/BackgroundJob/TimedJob.php”,“line”:103,“function”:“start”,“class”:“OCP\BackgroundJob\Job”,“type”:“->”},{“file”:“/usr/share/nginx/nextcloud/lib/public/BackgroundJob/TimedJob.php”,“line”:93,“function”:“start”,“class”:“OCP\BackgroundJob\TimedJob”,“type”:“->”},{“file”:“/usr/share/nginx/nextcloud/cron.php”,“line”:152,“function”:“execute”,“class”:“OCP\BackgroundJob\TimedJob”,“type”:“->”}],“File”:“/usr/share/nginx/nextcloud/apps/user_ldap/lib/LDAP.php”,“Line”:379,“message”:“LDAP Operations error”,“exception”:{},“CustomMessage”:“LDAP Operations error”}}
{“reqId”:“yF6xbXu3kirlWxYKLPdc”,“level”:3,“time”:“2023-05-28T12:35:18+00:00”,“remoteAddr”:“”,“user”:“–”,“app”:“files_antivirus”,“method”:“”,“url”:“–”,“message”:“LDAP Operations error”,“userAgent”:“–”,“version”:“26.0.1.1”,“exception”:{“Exception”:“Exception”,“Message”:“LDAP Operations error”,“Code”:1,“Trace”:[{“file”:“/usr/share/nginx/nextcloud/apps/user_ldap/lib/LDAP.php”,“line”:411,“function”:“processLDAPError”,“class”:“OCA\User_LDAP\LDAP”,“type”:“->”},{“file”:“/usr/share/nginx/nextcloud/apps/user_ldap/lib/LDAP.php”,“line”:308,“function”:“postFunctionCall”,“class”:“OCA\User_LDAP\LDAP”,“type”:“->”},{“file”:“/usr/share/nginx/nextcloud/apps/user_ldap/lib/LDAP.php”,“line”:186,“function”:“invokeLDAPMethod”,“class”:“OCA\User_LDAP\LDAP”,“type”:“->”,“args”:[" sensitive parameters replaced “]},{“function”:“read”,“class”:“OCA\User_LDAP\LDAP”,“type”:”->“},{“file”:”/usr/share/nginx/nextcloud/apps/user_ldap/lib/Access.php",“line”:1055,“function”:“call_user_func_array”},{“file”:“/usr/share/nginx/nextcloud/apps/user_ldap/lib/Access.php”,“line”:1058,“function”:“OCA\User_LDAP\{closure}”,“class”:“OCA\User_LDAP\Access”,“type”:“->”,“args”:[" sensitive parameters replaced “]},{“file”:”/usr/share/nginx/nextcloud/apps/user_ldap/lib/Access.php",“line”:253,“function”:“invokeLDAPMethod”,“class”:“OCA\User_LDAP\Access”,“type”:“->”,“args”:[" sensitive parameters replaced ***“]},{“file”:”/usr/share/nginx/nextcloud/apps/user_ldap/lib/Access.php",“line”:204,“function”:“executeRead”,“class”:“OCA\User_LDAP\Access”,“type”:“->”},{“file”:“/usr/share/nginx/nextcloud/apps/user_ldap/lib/User_LDAP.php”,“line”:324,“function”:“readAttribute”,“class”:“OCA\User_LDAP\Access”,“type”:“->”},{“function”:“userExistsOnLDAP”,“class”:“OCA\User_LDAP\User_LDAP”,“type”:“->”},{“file”:“/usr/share/nginx/nextcloud/apps/user_ldap/lib/User_Proxy.php”,“line”:110,“function”:“call_user_func_array”},{“file”:“/usr/share/nginx/nextcloud/apps/user_ldap/lib/Proxy.php”,“line”:140,“function”:“walkBackends”,“class”:“OCA\User_LDAP\User_Proxy”,“type”:“->”},{“file”:“/usr/share/nginx/nextcloud/apps/user_ldap/lib/User_Proxy.php”,“line”:246,“function”:“handleRequest”,“class”:“OCA\User_LDAP\Proxy”,“type”:“->”},{“file”:“/usr/share/nginx/nextcloud/apps/user_ldap/lib/User_Proxy.php”,“line”:223,“function”:“userExistsOnLDAP”,“class”:“OCA\User_LDAP\User_Proxy”,“type”:“->”},{“file”:“/usr/share/nginx/nextcloud/lib/private/User/Manager.php”,“line”:184,“function”:“userExists”,“class”:“OCA\User_LDAP\User_Proxy”,“type”:“->”},{“file”:“/usr/share/nginx/nextcloud/apps/files_antivirus/lib/BackgroundJob/BackgroundScanner.php”,“line”:95,“function”:“get”,“class”:“OC\User\Manager”,“type”:“->”},{“file”:“/usr/share/nginx/nextcloud/lib/public/BackgroundJob/Job.php”,“line”:78,“function”:“run”,“class”:“OCA\Files_Antivirus\BackgroundJob\BackgroundScanner”,“type”:“->”},{“file”:“/usr/share/nginx/nextcloud/lib/public/BackgroundJob/TimedJob.php”,“line”:103,“function”:“start”,“class”:“OCP\BackgroundJob\Job”,“type”:“->”},{“file”:“/usr/share/nginx/nextcloud/lib/public/BackgroundJob/TimedJob.php”,“line”:93,“function”:“start”,“class”:“OCP\BackgroundJob\TimedJob”,“type”:“->”},{“file”:“/usr/share/nginx/nextcloud/cron.php”,“line”:152,“function”:“execute”,“class”:“OCP\BackgroundJob\TimedJob”,“type”:“->”}],“File”:“/usr/share/nginx/nextcloud/apps/user_ldap/lib/LDAP.php”,“Line”:379,“message”:“LDAP Operations error”,“exception”:{},“CustomMessage”:“LDAP Operations error”}}
PASTE HERE
PASTE HERE
PASTE HERE
PASTE HERE
Any advice or guidance please
