I am planning to create a home server on an odroid-hc4 using Nextcloudpi.
So far I managed to install and run the basic setup.
In order to have some data safety, I would like to use RAID1 using two HDDs. Unfortunately, mdadm
cannot be installed. If I run sudo apt-get install mdadm
it reports follwing:
Package mdadm is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
E: Package 'mdadm' has no installation candidate
How do I properly set up RAID1 on a nextcloudpi instance? Or install mdadm
