help.nextcloud.com is for home/non-enterprise users. If you’re running a business, paid support can be accessed via portal.nextcloud.com, where we can ensure your business keeps running smoothly.
example
longer
example
here
Some or all of the below information will be requested if it isn’t supplied; for fastest response, please provide as much as you can
Nextcloud version (eg, 20.0.5): Nextcloud Hub 5 (27.0.2)
Operating system and version (eg, Ubuntu 20.04): Linux 4.19.0-17-amd64 x86_64
Apache or nginx version (eg, Apache 2.4.25): replace me
PHP version (eg, 7.4): Version: 8.1.21
I work for a public library, our system admin set up a test server for Nextcloud, this is our first time ever using / testing it.
We want to be able to have library patrons & staff log into Nextcloud using their library email accounts, which are hosted on our servers, instead of having to manually create an account for everyone.
So, our system admin would like to be able to set Nextcloud to authenticate using IMAP.
I do not know how most of this works et cetera, we looked at the documentation:
User Authentication With IMAP, SMB, FTP And Others which references the readme for the External User Backends (user_external) app.
We looked at both of those, installed the External User Authentication App, made sure that it was enabled, and added a modified version of this code from the readme to an .ini file in /etc/php/8.1/apache2/conf.d:
‘user_backends’ => array(
array(
‘class’ => ‘\OCA\UserExternal\IMAP’,
‘arguments’ => array(
‘127.0.0.1’, 143 as the port, ‘null as the encryption type’, ‘our email domain’, true, false
Then we possibly used the command service apache2 reload.
Anyway, we need some help on this one, any help on figuring out how to get this working would be appreciated, and I can pass the information on to our system admin.
Thank you.
PASTE HERE
PASTE HERE
PASTE HERE
PASTE HERE
PASTE HERE
