Need help setting up a Talk Bot in Nextcloud 32 (Webhook / n8n Integration on Synology RS1221+ with Reverse Proxy)
Hi everyone :waving_hand:
I’m trying to set up a Talk Bot in Nextcloud 32 that sends automated messages to Talk chats via n8n.
The bot was successfully created and activated using OCC commands, but every attempt to send messages via the API fails with either
401 (unauthorized) or 400 (value too great for base) errors.
Goal:
The bot should automatically post messages into a specific Talk room (e.g. for status updates or workflow notifications) from n8n.
:gear: Environment
Synology RS1221+
Reverse Proxy: configured via Synology DSM → Application Portal → Reverse Proxy (HTTPS → Nextcloud VM)
Nextcloud: running on a virtual machine (VM) under DSM Virtual Machine Manager
n8n: running in a Docker container on the same Synology
Both services communicate through the internal reverse proxy
(https://cloud.example.net and https://n8n.example.net)
:toolbox: Steps taken so far
Created the bot
occ talk:bot:install “n8nBot” “” “https://n8n.example.net/webhook” “TestBot”
Activated
occ talk:bot:state 1
Added it to the room
occ talk:bot:setup <ROOM_TOKEN>
Tested via curl:
POST /ocs/v2.php/apps/spreed/api/v1/bot/<ROOM_TOKEN>/message
with headers
OCS-APIRequest: true
X-Nextcloud-Talk-Bot-Random:
X-Nextcloud-Talk-Bot-Signature: <HMAC_SHA256(random+body,secret)>
Body:
{ “message”: “Hello from the Bot” }
The signature is generated in n8n using the Crypto node (HMAC-SHA256, hex-encoded).
The random string is a 64-character Base64 value without newlines or “=”.
Despite that, requests always return either 401 or 400,
so I suspect that the stricter API validation in NC 32 or the reverse proxy might alter headers.
:red_question_mark: Questions
  1. Has anyone successfully connected the Talk Bot with Nextcloud 32 / Talk v18?
  2. Are there new requirements for X-Nextcloud-Talk-Bot-Random or the signature format?
  3. Is the endpoint
still valid, or did it change in recent versions?
  1. Do I need to adjust anything in the Synology reverse proxy (e.g., header forwarding for OCS-APIRequest)?
  2. Does anyone have a working curl or n8n example for NC 32?
:receipt: System info
Nextcloud 32.0.x (Talk App v18.x)
n8n (latest Docker image on Synology)
Nextcloud VM under DSM Virtual Machine Manager
Reverse Proxy configured in DSM (HTTPS → VM)
Full shell and log access available
Thanks in advance for any hints, examples, or working configurations :folded_hands:
This works for me as a simple example. May not want to save the secret to file though:
#!/bin/bash
# Set these variables manually
NC_URL="https://cloud.example.com"
TOKEN="your_token"
SECRET="your_secret"
MESSAGE="your_message"
# Generate a random header and signature
RANDOM_HEADER=$(openssl rand -hex 32)
MESSAGE_TO_SIGN="${RANDOM_HEADER}${MESSAGE}"
SIGNATURE=$(echo -n "${MESSAGE_TO_SIGN}" | openssl dgst -sha256 -hmac "${SECRET}" | cut -d' ' -f2)
# Send the message
curl -X POST "${NC_URL}/ocs/v2.php/apps/spreed/api/v1/bot/${TOKEN}/message" \
 -H "Content-Type: application/json" \
 -H "Accept: application/json" \
 -H "OCS-APIRequest: true" \
 -H "X-Nextcloud-Talk-Bot-Random: ${RANDOM_HEADER}" \
 -H "X-Nextcloud-Talk-Bot-Signature: ${SIGNATURE}" \
 -d '{"message":"'"${MESSAGE}"'","silent":false}'
Hey, maybe you can add it as an example in spreed/docs/bots.md at main · nextcloud/spreed · GitHub?
ok.. i gave it a go here..
let me know if there are any issues
