I need help setting NC up using Traefik as reverse proxy. I used the guide at [Preformatted text](https://github.com/nextcloud/all-in-one/blob/main/reverse-proxy.md#3-limit-the-access-to-the-apache-container)
but I couldn’t get it working.
I’m using Traefik and installed it like this in combination with a Portainer instance:
services:
reverse-proxy:
# The official v2 Traefik docker image
image: traefik:v2.10
# Enables the web UI and tells Traefik to listen to docker
ports:
# The HTTP port
- "80:80"
# The Web UI (enabled by --api.insecure=true)
#- "8080:8080"
- "443:443"
volumes:
# So that Traefik can listen to the Docker events
- /var/run/docker.sock:/var/run/docker.sock
- ./traefik.yml:/traefik.yml:ro
- ./letsencrypt:/letsencrypt
- ./acme.json:/acme.json
I also use a traefik.yml file to load the configuration. I added this in the configuration as said in the guide
file:
directory: "/home/name/traefik/"
I’ve placed a file named “nextcloud.yml” into that folder and put in the code for that. I changed the rule to my subdomain e.g “nextcloud.myhost.com” and changed the URL from localhost:11000 to my VPS Ip address.
After that I ran the “startup command” with the only difference that I changed the port from 8080:8080 to 8081:8080.
The good thing is that I can reach the site and I can login either with “nextcloud.myhost.com” and my ip address:11000. Unfortunately tho is that I won’t accept the domain so I can’t procceed.
Always getting a Domain does not point to this server or the reverse proxy is not configured correctly. See the mastercontainer logs for more details. ('sudo docker logs -f nextcloud-aio-mastercontainer')
This is the output NOTICE: PHP message: Expected was: 31c27eff2f7d809015eada886a52bd49f034177d16cc167e NOTICE: PHP message: The error message was: NOTICE: PHP message: The response of the connection attempt to "https://nextcloud.myhost.com:443" was: 404 page not found NOTICE: PHP message: Expected was: 31c27eff2f7d809015eada886a52bd49f034177d16cc167e NOTICE: PHP message: The error message was:
Can anybody help me with this? I put both, the aio and the domaincheck in the Traefik network in Portainer but that didn’t help neither.
