Nextcloud version (eg, 20.0.5): 24.0.7
Operating system and version (eg, Ubuntu 20.04): Manjaro Linux
Apache or nginx version (eg, Apache 2.4.25): nginx version: nginx/1.22.1
PHP version (eg, 7.4): PHP 8.1.13
sudo -u http php --define apc.enable_cli=1 /var/www/nextcloud/updater/updater.ph
ar
Cannot load the ionCube PHP Loader - it was already loaded
Nextcloud Updater - version: v24.0.0beta3-1-g67bf13b dirtyCurrent version is 24.0.7.
Update to Nextcloud 24.0.8 available. (channel: “stable”)
Following file will be downloaded automatically: https://download.nextcloud.com/server/releases/nextcloud-
24.0.8.zip
Open changelogSteps that will be executed:
Check for expected files
Check for write permissions
Create backup
Downloading
Verify integrity
Extracting
Enable maintenance mode
Replace entry points
Delete old files
Move new files in place
DoneStart update? [y/N] y
Info: Pressing Ctrl-C will finish the currently running step and then stops the updater.
] Check for expected files
[] Check for write permissions
[] Create backup
[] Downloading
[] Verify integrity
Extracting …PHP Warning: require(/var/www/nextcloud/updater/…/version.php): Failed to open stream:
No such file or directory in phar:///var/www/nextcloud/updater/updater.phar/lib/Updater.php on line 676
PHP Fatal error: Uncaught Error: Failed opening required ‘/var/www/nextcloud/updater/…/version.php’ (inc
lude_path=‘.:’) in phar:///var/www/nextcloud/updater/updater.phar/lib/Updater.php:676
Stack trace:
#0 phar:///var/www/nextcloud/updater/updater.phar/lib/Updater.php(713): NC\Updater\Updater->getVersionByVe
rsionFile()
#1 phar:///var/www/nextcloud/updater/updater.phar/lib/UpdateCommand.php(372): NC\Updater\Updater->extractD
ownload()
#2 phar:///var/www/nextcloud/updater/updater.phar/lib/UpdateCommand.php(233): NC\Updater\UpdateCommand->ex
ecuteStep()
#3 phar:///var/www/nextcloud/updater/updater.phar/vendor/symfony/console/Command/Command.php(256): NC\Upda
ter\UpdateCommand->execute()
#4 phar:///var/www/nextcloud/updater/updater.phar/vendor/symfony/console/Application.php(820): Symfony\Com
ponent\Console\Command\Command->run()
#5 phar:///var/www/nextcloud/updater/updater.phar/vendor/symfony/console/Application.php(187): Symfony\Com
ponent\Console\Application->doRunCommand()
#6 phar:///var/www/nextcloud/updater/updater.phar/vendor/symfony/console/Application.php(118): Symfony\Com
ponent\Console\Application->doRun()
#7 phar:///var/www/nextcloud/updater/updater.phar/updater.php(10): Symfony\Component\Console\Application->
run()
#8 /var/www/nextcloud/updater/updater.phar(14): require(‘…’)
#9 {main}
thrown in phar:///var/www/nextcloud/updater/updater.phar/lib/Updater.php on line 676
