Need help migrating the installation from SD card to USB stick while the main data drive remains the same
example
longer
example
here
Nextcloud version: 22.1.1
Operating system and version: Ubuntu 21.04
Apache or nginx version: Apache 2.4.45
PHP version : 8.0.10
I have a RaspberryPi using SD card for boot. It is small and I want to upgrade it to a larger usb stick. I use docker to run nextcloud. The /var/www/html/data volume is linked to an external HDD drive. I want the drive to remain, I am only swaping the SD card.
I cannot figure out how to create new nextcloud container on the USB such that I can access the data on the drive. If I try to use creadentials from the SD card I get an error that such user already exists. I presume there is some folder that should be copied from one container to another but I can’t figure out which one.
I am using MariaDB and I have tried making a backup using SD card and restoring using the USB stick but it didn’t work.
I still have the SD card working. If I use it to boot everything works.
  'apps_paths' =>
    0 =>
      'url' => '/apps',
      'writable' => false,
    1 =>
      'url' => '/custom_apps',
      'writable' => true,
  'instanceid' => '[XxX SENSIBLE CONTENT REMOVED BY MOD/JK XxX]',
  'passwordsalt' => '[XxX SENSIBLE CONTENT REMOVED BY MOD/JK XxX]',
  'secret' => '[XxX SENSIBLE CONTENT REMOVED BY MOD/JK XxX]',
    0 => 'nextcloud.mydomain.com',
  'version' => '22.1.1.2',
  'overwrite.cli.url' => 'https://nextcloud.mydomain.com',
  'dbname' => 'nextcloud',
  'dbhost' => 'mariadb:3306',
  'dbuser' => 'nextcloud',
  'dbpassword' => 'password',
pls take care to not provide any sensible data in the future… so pls regard your instance as compromised from now on unless you’re gonna fix the referring data
