Hello Nextclouders,
I would like to create an software that would index all my Nextcloud’s documents to an Elasticsearch mapping. For now i have a webdav based indexer that will use webhooks to be triggered and otherwise it will run with a cron like timing. But i heard that theres is an api from the fulltextsearch. So i wonders what would be the best way to do that.
The mappings i need to use :
"mapping": {
"properties": {
"display_name": {
"type": "text",
"fields": {
"keyword": { "type": "keyword" }
"basename": {
"type": "text",
"fields": {
"extension": { "type": "keyword" },
"display_name_sat": { "type": "search_as_you_type" },
"path": {
"type": "text",
"fields": {
"path_text": { "type": "text" },
"description": { "type": "text" },
"content": { "type": "text" },
"profile": { "type": "keyword" },
"app_id": { "type": "keyword" },
"tenant_id": { "type": "keyword" },
"mimetype": { "type": "keyword" },
"last_modified": { "type": "date" },
"last_opened_at": { "type": "date" },
"mount_type": { "type": "keyword" },
"file_id": { "type": "integer" },
"click_count": { "type": "long" },
"popularity": { "type": "float" },
"content_hash": { "type": "keyword"},
"tags": {
"properties": {
"ids": { "type": "keyword" },
"normalized": {
"type": "text",
"fields": {
"acl": {
"properties": {
"users": { "type": "keyword" },
"groups": { "type": "keyword" },
"roles": { "type": "keyword" },
"scopes": { "type": "keyword" }
The content and tags part are for other workers in my data pipeline to feed.
Thanks in advance
