NCP-Web login from outside --> 403 forbidden
Hey,
if i want to connect my cloud from outside over https://cloud.my.de:4443 my server said this:
403 Forbidden
You don’t have permission to access / on this server.
[Thu Mar 08 14:45:47.281806 2018] [authz_host:error] [pid 4071:tid 1943708720] [client 192.168.1.17:64123] AH01753: access check of ā€˜localhost’ to /favicon.ico failed, reason: unable to get the remote host name
[Thu Mar 08 15:10:09.033418 2018] [authz_core:error] [pid 4071:tid 1926931504] [client 80.187.112.129:9675] AH01630: client denied by server configuration: /var/www/ncp-web/
i have installed Nextcloud 13 and the NCP version 0.47.0. From inside (LAN) i can access to NCP-Web login without problems.
hello,
For security reasons, you can only access ncp-web from the local network
