Nextcloud logs
{"reqId":"YU0-lu8V1Rt@HBuE14@5GgAAVAM","level":0,"time":"2021-09-24T05:01:43+02:00","remoteAddr":"192.1 68.1.178","user":"--","app":"maps","method":"GET","url":"/index.php/csrftoken","message":"/appinfo/app. php is deprecated, use \\OCP\\AppFramework\\Bootstrap\\IBootstrap on the application class instead.","u serAgent":"Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/93.0 .4577.82 Safari/537.36","version":"21.0.4.1"}
{"reqId":"YU0-lu8V1Rt@HBuE14@5GgAAVAM","level":1,"time":"2021-09-24T05:01:43+02:00","remoteAddr":"192.1 68.1.178","user":"--","app":"no app in context","method":"GET","url":"/index.php/csrftoken","message":{ "Exception":"Symfony\\Component\\Routing\\Exception\\RouteNotFoundException","Message":"Unable to gener ate a URL for the named route \"ocs.password_policy.API.generate\" as such route does not exist.","Code ":0,"Trace":[{"file":"/data/nextcloud/lib/private/Route/Router.php","line":365,"function":"generate","c lass":"Symfony\\Component\\Routing\\Generator\\UrlGenerator","type":"->","args":["ocs.password_policy.A PI.generate",[],1]},{"file":"/data/nextcloud/lib/private/Route/CachingRouter.php","line":60,"function": "generate","class":"OC\\Route\\Router","type":"->","args":["ocs.password_policy.API.generate",[],false] },{"file":"/data/nextcloud/lib/private/URLGenerator.php","line":101,"function":"generate","class":"OC\\ Route\\CachingRouter","type":"->","args":["ocs.password_policy.API.generate",[],false]},{"file":"/data/ nextcloud/apps/password_policy/lib/Capabilities.php","line":57,"function":"linkToOCSRouteAbsolute","cla ss":"OC\\URLGenerator","type":"->","args":["password_policy.API.generate"]},{"file":"/data/nextcloud/li b/private/CapabilitiesManager.php","line":72,"function":"getCapabilities","class":"OCA\\Password_Policy \\Capabilities","type":"->","args":[]},{"file":"/data/nextcloud/lib/private/Template/JSConfigHelper.php ","line":183,"function":"getCapabilities","class":"OC\\CapabilitiesManager","type":"->","args":[]},{"fi le":"/data/nextcloud/lib/private/TemplateLayout.php","line":211,"function":"getConfig","class":"OC\\Tem plate\\JSConfigHelper","type":"->","args":[]},{"file":"/data/nextcloud/lib/private/legacy/OC_Template.p hp","line":183,"function":"__construct","class":"OC\\TemplateLayout","type":"->","args":["guest","core" ]},{"file":"/data/nextcloud/lib/private/Template/Base.php","line":132,"function":"fetchPage","class":"O C_Template","type":"->","args":[]},{"file":"/data/nextcloud/lib/base.php","line":780,"function":"printP age","class":"OC\\Template\\Base","type":"->","args":[]},{"file":"/data/nextcloud/lib/base.php","line": 1076,"function":"init","class":"OC","type":"::","args":[]},{"file":"/data/nextcloud/index.php","line":3 5,"args":["/data/nextcloud/lib/base.php"],"function":"require_once"}],"File":"/data/nextcloud/3rdparty/ symfony/routing/Generator/UrlGenerator.php","Line":143,"CustomMessage":"--"},"userAgent":"Mozilla/5.0 ( Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/93.0.4577.82 Safari/537.36", "version":"21.0.4.1"}
{"reqId":"YU0-lu8V1Rt@HBuE14@5GgAAVAM","level":1,"time":"2021-09-24T05:01:43+02:00","remoteAddr":"192.1 68.1.178","user":"--","app":"no app in context","method":"GET","url":"/index.php/csrftoken","message":{ "Exception":"Symfony\\Component\\Routing\\Exception\\RouteNotFoundException","Message":"Unable to gener ate a URL for the named route \"ocs.password_policy.API.validate\" as such route does not exist.","Code ":0,"Trace":[{"file":"/data/nextcloud/lib/private/Route/Router.php","line":365,"function":"generate","c lass":"Symfony\\Component\\Routing\\Generator\\UrlGenerator","type":"->","args":["ocs.password_policy.A PI.validate",[],1]},{"file":"/data/nextcloud/lib/private/Route/CachingRouter.php","line":60,"function":
...(too long --> removed)
