Finally I got some time to check more thoroughly on my nc installation working via ncp.
I’m currently on a test version built after 1.50.1, when I tried to update to 1.50.2 I got an unhanded exception and didn’t have time to investigate so for now I’m not updating. I might try again later in the coming week, that will require more dedication on my part.
The diagnostics is currently reporting everything running and the installation basically works, meaning I can sync files, but the logs don’t look fine and MySQL isn’t writing to the /var/log/mysql directory at all, despite it being set as mysql owned (I tried both :adm and :mysql groups) with both writing and execution permissions allowed.
There’s some errors thrown out in the Nextcloud logs which I don’t understand.
NextCloudPi diagnostics
NextCloudPi version ed663f4
NextCloudPi image NextCloudPi_docker_09-28-22
OS Debian GNU/Linux 11. 4.14.222-odroidxu4 (armv7l)
automount no
USB devices sda
datadir /data/nextcloud/data
data in SD no
data filesystem ext2/ext3
data disk usage 1.4T/1.8T
rootfs usage 8.3G/30G
swapfile /dev/zram0
dbdir /data/database
Nextcloud check ok
Nextcloud version 24.0.3.2
HTTPD service up
PHP service up
MariaDB service up
Redis service up
HPB service up
Postfix service up
Internet check ok
public IP ***REMOVED SENSITIVE VALUE***
Port check 80 closed
Port check 443 open (ipv4)
gateway ***REMOVED SENSITIVE VALUE***
Interface eth0
certificates ***REMOVED SENSITIVE VALUE***
NAT loopback no
Uptime 8days
Nextcloud configuration
"trusted_domains": {
"0": "localhost",
"11": "***REMOVED SENSITIVE VALUE***",
"1": "172.17.0.4",
"5": "nextcloudpi.local",
"7": "nextcloudpi",
"8": "nextcloudpi.lan",
"6": "191.168.1.187",
"22": "191.168.1.187",
"21": "***REMOVED SENSITIVE VALUE***",
"12": "***REMOVED SENSITIVE VALUE***",
"3": "***REMOVED SENSITIVE VALUE***",
"": "***REMOVED SENSITIVE VALUE***",
"14": "9a3f44928cb9"
"dbtype": "mysql",
"version": "24.0.3.2",
"overwrite.cli.url": "https:\/\/***REMOVED SENSITIVE VALUE***\/",
"dbport": "",
"mysql.utf8mb4": true,
"redis": {
"port": 0,
"timeout": 0,
"tempdirectory": "\/data\/nextcloud\/data\/tmp",
"mail_smtpmode": "sendmail",
"mail_smtpauthtype": "LOGIN",
"preview_max_x": "2048",
"preview_max_y": "2048",
"jpeg_quality": "60",
"overwriteprotocol": "https",
"theme": "",
"loglevel": 2,
"htaccess.RewriteBase": "\/",
"twofactor_enforced": "true",
"admin"
"app_install_overwrite": [
"massassigntags"
"has_rebuilt_cache": true,
"logfile": "\/data\/nextcloud\/data\/nextcloud.log",
"data-fingerprint": "2af52e49f7d1888cf8769f16affdc840"
HTTPd logs
[Sun Oct 02 09:22:26.480539 2022] [authz_host:error] [pid 123:tid 2873668640] [client 192.168.1.80:56889] AH01753: access check of 'localhost' to /img/defaults.svg failed, reason: unable to get the remote host name
[Sun Oct 02 09:22:26.480541 2022] [authz_host:error] [pid 123:tid 2865275936] [client 192.168.1.80:56889] AH01753: access check of 'localhost' to /img/toggle.svg failed, reason: unable to get the remote host name
[Sun Oct 02 09:22:26.536128 2022] [authz_host:error] [pid 123:tid 2856883232] [client 192.168.1.80:56889] AH01753: access check of 'localhost' to /img/search.svg failed, reason: unable to get the remote host name, referer: https://192.168.1.187:4443/css/ncp.css
[Sun Oct 02 09:22:26.536944 2022] [authz_host:error] [pid 123:tid 2856883232] [client 192.168.1.80:56889] AH01753: access check of 'localhost' to /img/nc-button.svg failed, reason: unable to get the remote host name, referer: https://192.168.1.187:4443/css/ncp.css
[Sun Oct 02 09:22:26.537880 2022] [authz_host:error] [pid 123:tid 2856883232] [client 192.168.1.80:56889] AH01753: access check of 'localhost' to /img/dashboard.svg failed, reason: unable to get the remote host name, referer: https://192.168.1.187:4443/css/ncp.css
[Sun Oct 02 09:22:26.538622 2022] [authz_host:error] [pid 123:tid 2856883232] [client 192.168.1.80:56889] AH01753: access check of 'localhost' to /img/defaults-white.svg failed, reason: unable to get the remote host name, referer: https://192.168.1.187:4443/css/ncp.css
[Sun Oct 02 09:22:26.543325 2022] [authz_host:error] [pid 123:tid 2856883232] [client 192.168.1.80:56889] AH01753: access check of 'localhost' to /img/settings-white.svg failed, reason: unable to get the remote host name, referer: https://192.168.1.187:4443/css/ncp.css
[Sun Oct 02 09:22:26.544038 2022] [authz_host:error] [pid 123:tid 2856883232] [client 192.168.1.80:56889] AH01753: access check of 'localhost' to /img/logs.svg failed, reason: unable to get the remote host name, referer: https://192.168.1.187:4443/css/ncp.css
[Sun Oct 02 09:22:26.547505 2022] [authz_host:error] [pid 123:tid 2856883232] [client 192.168.1.80:56889] AH01753: access check of 'localhost' to /img/wizard.svg failed, reason: unable to get the remote host name, referer: https://192.168.1.187:4443/css/ncp.css
[Sun Oct 02 09:22:26.548663 2022] [authz_host:error] [pid 123:tid 2856883232] [client 192.168.1.80:56889] AH01753: access check of 'localhost' to /img/info-white.svg failed, reason: unable to get the remote host name, referer: https://192.168.1.187:4443/css/ncp.css
[Sun Oct 02 09:22:26.556979 2022] [authz_host:error] [pid 123:tid 2856883232] [client 192.168.1.80:56889] AH01753: access check of 'localhost' to /img/files.svg failed, reason: unable to get the remote host name, referer: https://192.168.1.187:4443/css/ncp.css
[Sun Oct 02 09:22:26.609117 2022] [authz_host:error] [pid 123:tid 2856883232] [client 192.168.1.80:56889] AH01753: access check of 'localhost' to /ncp-launcher.php failed, reason: unable to get the remote host name
[Sun Oct 02 09:22:26.610612 2022] [authz_host:error] [pid 123:tid 2873668640] [client 192.168.1.80:56889] AH01753: access check of 'localhost' to /img/poweroff.svg failed, reason: unable to get the remote host name
[Sun Oct 02 09:22:26.610844 2022] [authz_host:error] [pid 123:tid 2865275936] [client 192.168.1.80:56889] AH01753: access check of 'localhost' to /img/reboot.svg failed, reason: unable to get the remote host name
[Sun Oct 02 09:22:26.695848 2022] [authz_host:error] [pid 123:tid 2865275936] [client 192.168.1.80:56889] AH01753: access check of 'localhost' to /ncp-output.php failed, reason: unable to get the remote host name
[Sun Oct 02 09:22:26.718216 2022] [authz_host:error] [pid 123:tid 2873668640] [client 192.168.1.80:56889] AH01753: access check of 'localhost' to /img/favicon.png failed, reason: unable to get the remote host name
[Sun Oct 02 09:22:41.885811 2022] [authz_host:error] [pid 123:tid 2856883232] [client 192.168.1.80:56889] AH01753: access check of 'localhost' to /ncp-launcher.php failed, reason: unable to get the remote host name
[Sun Oct 02 09:22:41.914030 2022] [authz_host:error] [pid 123:tid 2856883232] [client 192.168.1.80:56889] AH01753: access check of 'localhost' to /ncp-launcher.php failed, reason: unable to get the remote host name
[Sun Oct 02 09:22:41.914031 2022] [authz_host:error] [pid 123:tid 2873668640] [client 192.168.1.80:56889] AH01753: access check of 'localhost' to /img/download.svg failed, reason: unable to get the remote host name
[Sun Oct 02 09:22:41.914115 2022] [authz_host:error] [pid 123:tid 2882061344] [client 192.168.1.80:56889] AH01753: access check of 'localhost' to /img/delete.svg failed, reason: unable to get the remote host name
Database logs
Nextcloud logs
{"reqId":"YzXp2gGSQySq80XK8EFU5wAATwE","level":3,"time":"2022-09-29T18:54:19+00:00","remoteAddr":"***REMOVED SENSITIVE VALUE***","user":"***USER_2***","app":"no app in context","method":"PUT","url":"/remote.php/dav/files/***USER_2***/Foto/2021/05/Foto%2021-05-14%2011-13-02%207351.jpg","message":"An exception occurred while executing a query: SQLSTATE[40001]: Serialization failure: 1213 Deadlock found when trying to get lock; try restarting transaction","userAgent":"Mozilla/5.0 (iOS) Nextcloud-iOS/4.4.4","version":"24.0.3.2","exception":{"Exception":"Doctrine\\DBAL\\Exception\\DeadlockException","Message":"An exception occurred while executing a query: SQLSTATE[40001]: Serialization failure: 1213 Deadlock found when trying to get lock; try restarting transaction","Code":1213,"Trace":[{"file":"/data/nextcloud/3rdparty/doctrine/dbal/src/Connection.php","line":1780,"function":"convert","class":"Doctrine\\DBAL\\Driver\\API\\MySQL\\ExceptionConverter","type":"->"},{"file":"/data/nextcloud/3rdparty/doctrine/dbal/src/Connection.php","line":1719,"function":"handleDriverException","class":"Doctrine\\DBAL\\Connection","type":"->"},{"file":"/data/nextcloud/3rdparty/doctrine/dbal/src/Connection.php","line":1173,"function":"convertExceptionDuringQuery","class":"Doctrine\\DBAL\\Connection","type":"->"},{"file":"/data/nextcloud/lib/private/DB/Connection.php","line":294,"function":"executeStatement","class":"Doctrine\\DBAL\\Connection","type":"->"},{"file":"/data/nextcloud/3rdparty/doctrine/dbal/src/Query/QueryBuilder.php","line":354,"function":"executeStatement","class":"OC\\DB\\Connection","type":"->"},{"file":"/data/nextcloud/lib/private/DB/QueryBuilder/QueryBuilder.php","line":281,"function":"execute","class":"Doctrine\\DBAL\\Query\\QueryBuilder","type":"->"},{"file":"/data/nextcloud/lib/private/Files/Cache/Cache.php","line":382,"function":"execute","class":"OC\\DB\\QueryBuilder\\QueryBuilder","type":"->"},{"file":"/data/nextcloud/lib/private/Files/Cache/Updater.php","line":256,"function":"update","class":"OC\\Files\\Cache\\Cache","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/data/nextcloud/lib/private/Files/Cache/Updater.php","line":138,"function":"correctParentStorageMtime","class":"OC\\Files\\Cache\\Updater","type":"->"},{"file":"/data/nextcloud/lib/private/Files/View.php","line":328,"function":"update","class":"OC\\Files\\Cache\\Updater","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/data/nextcloud/lib/private/Files/View.php","line":948,"function":"writeUpdate","class":"OC\\Files\\View","type":"->"},{"file":"/data/nextcloud/apps/files_versions/lib/Versions/LegacyVersionsBackend.php","line":93,"function":"copy","class":"OC\\Files\\View","type":"->"},{"file":"/data/nextcloud/apps/files_versions/lib/Versions/VersionManager.php","line":92,"function":"createVersion","class":"OCA\\Files_Versions\\Versions\\LegacyVersionsBackend","type":"->"},{"file":"/data/nextcloud/apps/files_versions/lib/Storage.php","line":217,"function":"createVersion","class":"OCA\\Files_Versions\\Versions\\VersionManager","type":"->"},{"file":"/data/nextcloud/apps/files_versions/lib/Hooks.php","line":56,"function":"store","class":"OCA\\Files_Versions\\Storage","type":"::"},{"file":"/data/nextcloud/lib/private/legacy/OC_Hook.php","line":106,"function":"write_hook","class":"OCA\\Files_Versions\\Hooks","type":"::"},{"file":"/data/nextcloud/apps/dav/lib/Connector/Sabre/File.php","line":449,"function":"emit","class":"OC_Hook","type":"::"},{"file":"/data/nextcloud/apps/dav/lib/Connector/Sabre/File.php","line":178,"function":"emitPreHooks","class":"OCA\\DAV\\Connector\\Sabre\\File","type":"->"},{"file":"/data/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":1137,"function":"put","class":"OCA\\DAV\\Connector\\Sabre\\File","type":"->"},{"file":"/data/nextcloud/3rdparty/sabre/dav/lib/DAV/CorePlugin.php","line":492,"function":"updateFile","class":"Sabre\\DAV\\Server","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/data/nextcloud/3rdparty/sabre/event/lib/WildcardEmitterTrait.php","line":89,"function":"httpPut","class":"Sabre\\DAV\\CorePlugin","type":"->"},{"file":"/data/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":472,"function":"emit","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/data/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":253,"function":"invokeMethod","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/data/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":321,"function":"start","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/data/nextcloud/apps/dav/lib/Server.php","line":352,"function":"exec","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/data/nextcloud/apps/dav/appinfo/v2/remote.php","line":35,"function":"exec","class":"OCA\\DAV\\Server","type":"->"},{"file":"/data/nextcloud/remote.php","line":166,"args":["/data/nextcloud/apps/dav/appinfo/v2/remote.php"],"function":"require_once"}],"File":"/data/nextcloud/3rdparty/doctrine/dbal/src/Driver/API/MySQL/ExceptionConverter.php","Line":37,"Previous":{"Exception":"Doctrine\\DBAL\\Driver\\PDO\\Exception","Message":"SQLSTATE[40001]: Serialization failure: 1213 Deadlock found when trying to get lock; try restarting transaction","Code":1213,"Trace":[{"file":"/data/nextcloud/3rdparty/doctrine/dbal/src/Driver/PDO/Statement.php","line":94,"function":"new","class":"Doctrine\\DBAL\\Driver\\PDO\\Exception","type":"::"},{"file":"/data/nextcloud/3rdparty/doctrine/dbal/src/Connection.php","line":1163,"function":"execute","class":"Doctrine\\DBAL\\Driver\\PDO\\Statement","type":"->"},{"file":"/data/nextcloud/lib/private/DB/Connection.php","line":294,"function":"executeStatement","class":"Doctrine\\DBAL\\Connection","type":"->"},{"file":"/data/nextcloud/3rdparty/doctrine/dbal/src/Query/QueryBuilder.php","line":354,"function":"executeStatement","class":"OC\\DB\\Connection","type":"->"},{"file":"/data/nextcloud/lib/private/DB/QueryBuilder/QueryBuilder.php","line":281,"function":"execute","class":"Doctrine\\DBAL\\Query\\QueryBuilder","type":"->"},{"file":"/data/nextcloud/lib/private/Files/Cache/Cache.php","line":382,"function":"execute","class":"OC\\DB\\QueryBuilder\\QueryBuilder","type":"->"},{"file":"/data/nextcloud/lib/private/Files/Cache/Updater.php","line":256,"function":"update","class":"OC\\Files\\Cache\\Cache","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/data/nextcloud/lib/private/Files/Cache/Updater.php","line":138,"function":"correctParentStorageMtime","class":"OC\\Files\\Cache\\Updater","type":"->"},{"file":"/data/nextcloud/lib/private/Files/View.php","line":328,"function":"update","class":"OC\\Files\\Cache\\Updater","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/data/nextcloud/lib/private/Files/View.php","line":948,"function":"writeUpdate","class":"OC\\Files\\View","type":"->"},{"file":"/data/nextcloud/apps/files_versions/lib/Versions/LegacyVersionsBackend.php","line":93,"function":"copy","class":"OC\\Files\\View","type":"->"},{"file":"/data/nextcloud/apps/files_versions/lib/Versions/VersionManager.php","line":92,"function":"createVersion","class":"OCA\\Files_Versions\\Versions\\LegacyVersionsBackend","type":"->"},{"file":"/data/nextcloud/apps/files_versions/lib/Storage.php","line":217,"function":"createVersion","class":"OCA\\Files_Versions\\Versions\\VersionManager","type":"->"},{"file":"/data/nextcloud/apps/files_versions/lib/Hooks.php","line":56,"function":"store","class":"OCA\\Files_Versions\\Storage","type":"::"},{"file":"/data/nextcloud/lib/private/legacy/OC_Hook.php","line":106,"function":"write_hook","class":"OCA\\Files_Versions\\Hooks","type":"::"},{"file":"/data/nextcloud/apps/dav/lib/Connector/Sabre/File.php","line":449,"function":"emit","class":"OC_Hook","type":"::"},{"file":"/data/nextcloud/apps/dav/lib/Connector/Sabre/File.php","line":178,"function":"emitPreHooks","class":"OCA\\DAV\\Connector\\Sabre\\File","type":"->"},{"file":"/data/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":1137,"function":"put","class":"OCA\\DAV\\Connector\\Sabre\\File","type":"->"},{"file":"/data/nextcloud/3rdparty/sabre/dav/lib/DAV/CorePlugin.php","line":492,"function":"updateFile","class":"Sabre\\DAV\\Server","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/data/nextcloud/3rdparty/sabre/event/lib/WildcardEmitterTrait.php","line":89,"function":"httpPut","class":"Sabre\\DAV\\CorePlugin","type":"->"},{"file":"/data/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":472,"function":"emit","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/data/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":253,"function":"invokeMethod","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/data/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":321,"function":"start","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/data/nextcloud/apps/dav/lib/Server.php","line":352,"function":"exec","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/data/nextcloud/apps/dav/appinfo/v2/remote.php","line":35,"function":"exec","class":"OCA\\DAV\\Server","type":"->"},{"file":"/data/nextcloud/remote.php","line":166,"args":["/data/nextcloud/apps/dav/appinfo/v2/remote.php"],"function":"require_once"}],"File":"/data/nextcloud/3rdparty/doctrine/dbal/src/Driver/PDO/Exception.php","Line":26,"Previous":{"Exception":"PDOException","Message":"SQLSTATE[40001]: Serialization failure: 1213 Deadlock found when trying to get lock; try restarting transaction","Code":"40001","Trace":[{"file":"/data/nextcloud/3rdparty/doctrine/dbal/src/Driver/PDO/Statement.php","line":92,"function":"execute","class":"PDOStatement","type":"->"},{"file":"/data/nextcloud/3rdparty/doctrine/dbal/src/Connection.php","line":1163,"function":"execute","class":"Doctrine\\DBAL\\Driver\\PDO\\Statement","type":"->"},{"file":"/data/nextcloud/lib/private/DB/Connection.php","line":294,"function":"executeStatement","class":"Doctrine\\DBAL\\Connection","type":"->"},{"file":"/data/nextcloud/3rdparty/doctrine/dbal/src/Query/QueryBuilder.php","line":354,"function":"executeStatement","class":"OC\\DB\\Connection","type":"->"},{"file":"/data/nextcloud/lib/private/DB/QueryBuilder/QueryBuilder.php","line":281,"function":"execute","class":"Doctrine\\DBAL\\Query\\QueryBuilder","type":"->"},{"file":"/data/nextcloud/lib/private/Files/Cache/Cache.php","line":382,"function":"execute","class":"OC\\DB\\QueryBuilder\\QueryBuilder","type":"->"},{"file":"/data/nextcloud/lib/private/Files/Cache/Updater.php","line":256,"function":"update","class":"OC\\Files\\Cache\\Cache","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/data/nextcloud/lib/private/Files/Cache/Updater.php","line":138,"function":"correctParentStorageMtime","class":"OC\\Files\\Cache\\Updater","type":"->"},{"file":"/data/nextcloud/lib/private/Files/View.php","line":328,"function":"update","class":"OC\\Files\\Cache\\Updater","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/data/nextcloud/lib/private/Files/View.php","line":948,"function":"writeUpdate","class":"OC\\Files\\View","type":"->"},{"file":"/data/nextcloud/apps/files_versions/lib/Versions/LegacyVersionsBackend.php","line":93,"function":"copy","class":"OC\\Files\\View","type":"->"},{"file":"/data/nextcloud/apps/files_versions/lib/Versions/VersionManager.php","line":92,"function":"createVersion","class":"OCA\\Files_Versions\\Versions\\LegacyVersionsBackend","type":"->"},{"file":"/data/nextcloud/apps/files_versions/lib/Storage.php","line":217,"function":"createVersion","class":"OCA\\Files_Versions\\Versions\\VersionManager","type":"->"},{"file":"/data/nextcloud/apps/files_versions/lib/Hooks.php","line":56,"function":"store","class":"OCA\\Files_Versions\\Storage","type":"::"},{"file":"/data/nextcloud/lib/private/legacy/OC_Hook.php","line":106,"function":"write_hook","class":"OCA\\Files_Versions\\Hooks","type":"::"},{"file":"/data/nextcloud/apps/dav/lib/Connector/Sabre/File.php","line":449,"function":"emit","class":"OC_Hook","type":"::"},{"file":"/data/nextcloud/apps/dav/lib/Connector/Sabre/File.php","line":178,"function":"emitPreHooks","class":"OCA\\DAV\\Connector\\Sabre\\File","type":"->"},{"file":"/data/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":1137,"function":"put","class":"OCA\\DAV\\Connector\\Sabre\\File","type":"->"},{"file":"/data/nextcloud/3rdparty/sabre/dav/lib/DAV/CorePlugin.php","line":492,"function":"updateFile","class":"Sabre\\DAV\\Server","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/data/nextcloud/3rdparty/sabre/event/lib/WildcardEmitterTrait.php","line":89,"function":"httpPut","class":"Sabre\\DAV\\CorePlugin","type":"->"},{"file":"/data/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":472,"function":"emit","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/data/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":253,"function":"invokeMethod","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/data/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":321,"function":"start","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/data/nextcloud/apps/dav/lib/Server.php","line":352,"function":"exec","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/data/nextcloud/apps/dav/appinfo/v2/remote.php","line":35,"function":"exec","class":"OCA\\DAV\\Server","type":"->"},{"file":"/data/nextcloud/remote.php","line":166,"args":["/data/nextcloud/apps/dav/appinfo/v2/remote.php"],"function":"require_once"}],"File":"/data/nextcloud/3rdparty/doctrine/dbal/src/Driver/PDO/Statement.php","Line":92}},"CustomMessage":"--"}}
{"reqId":"YzXp2gGSQySq80XK8EFU5QAATwA","level":3,"time":"2022-09-29T18:54:19+00:00","remoteAddr":"***REMOVED SENSITIVE VALUE***","user":"***USER_2***","app":"no app in context","method":"PUT","url":"/remote.php/dav/files/***USER_2***/Foto/2021/05/Foto%2021-05-12%2016-57-11%207349.jpg","message":"An exception occurred while executing a query: SQLSTATE[40001]: Serialization failure: 1213 Deadlock found when trying to get lock; try restarting transaction","userAgent":"Mozilla/5.0 (iOS) Nextcloud-iOS/4.4.4","version":"24.0.3.2","exception":{"Exception":"Doctrine\\DBAL\\Exception\\DeadlockException","Message":"An exception occurred while executing a query: SQLSTATE[40001]: Serialization failure: 1213 Deadlock found when trying to get lock; try restarting transaction","Code":1213,"Trace":[{"file":"/data/nextcloud/3rdparty/doctrine/dbal/src/Connection.php","line":1780,"function":"convert","class":"Doctrine\\DBAL\\Driver\\API\\MySQL\\ExceptionConverter","type":"->"},{"file":"/data/nextcloud/3rdparty/doctrine/dbal/src/Connection.php","line":1719,"function":"handleDriverException","class":"Doctrine\\DBAL\\Connection","type":"->"},{"file":"/data/nextcloud/3rdparty/doctrine/dbal/src/Connection.php","line":1173,"function":"convertExceptionDuringQuery","class":"Doctrine\\DBAL\\Connection","type":"->"},{"file":"/data/nextcloud/lib/private/DB/Connection.php","line":294,"function":"executeStatement","class":"Doctrine\\DBAL\\Connection","type":"->"},{"file":"/data/nextcloud/3rdparty/doctrine/dbal/src/Query/QueryBuilder.php","line":354,"function":"executeStatement","class":"OC\\DB\\Connection","type":"->"},{"file":"/data/nextcloud/lib/private/DB/QueryBuilder/QueryBuilder.php","line":281,"function":"execute","class":"Doctrine\\DBAL\\Query\\QueryBuilder","type":"->"},{"file":"/data/nextcloud/lib/private/Files/Cache/Cache.php","line":382,"function":"execute","class":"OC\\DB\\QueryBuilder\\QueryBuilder","type":"->"},{"file":"/data/nextcloud/lib/private/Files/Cache/Updater.php","line":256,"function":"update","class":"OC\\Files\\Cache\\Cache","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/data/nextcloud/lib/private/Files/Cache/Updater.php","line":138,"function":"correctParentStorageMtime","class":"OC\\Files\\Cache\\Updater","type":"->"},{"file":"/data/nextcloud/lib/private/Files/View.php","line":328,"function":"update","class":"OC\\Files\\Cache\\Updater","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/data/nextcloud/lib/private/Files/View.php","line":948,"function":"writeUpdate","class":"OC\\Files\\View","type":"->"},{"file":"/data/nextcloud/apps/files_versions/lib/Versions/LegacyVersionsBackend.php","line":93,"function":"copy","class":"OC\\Files\\View","type":"->"},{"file":"/data/nextcloud/apps/files_versions/lib/Versions/VersionManager.php","line":92,"function":"createVersion","class":"OCA\\Files_Versions\\Versions\\LegacyVersionsBackend","type":"->"},{"file":"/data/nextcloud/apps/files_versions/lib/Storage.php","line":217,"function":"createVersion","class":"OCA\\Files_Versions\\Versions\\VersionManager","type":"->"},{"file":"/data/nextcloud/apps/files_versions/lib/Hooks.php","line":56,"function":"store","class":"OCA\\Files_Versions\\Storage","type":"::"},{"file":"/data/nextcloud/lib/private/legacy/OC_Hook.php","line":106,"function":"write_hook","class":"OCA\\Files_Versions\\Hooks","type":"::"},{"file":"/data/nextcloud/apps/dav/lib/Connector/Sabre/File.php","line":449,"function":"emit","class":"OC_Hook","type":"::"},{"file":"/data/nextcloud/apps/dav/lib/Connector/Sabre/File.php","line":178,"function":"emitPreHooks","class":"OCA\\DAV\\Connector\\Sabre\\File","type":"->"},{"file":"/data/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":1137,"function":"put","class":"OCA\\DAV\\Connector\\Sabre\\File","type":"->"},{"file":"/data/nextcloud/3rdparty/sabre/dav/lib/DAV/CorePlugin.php","line":492,"function":"updateFile","class":"Sabre\\DAV\\Server","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/data/nextcloud/3rdparty/sabre/event/lib/WildcardEmitterTrait.php","line":89,"function":"httpPut","class":"Sabre\\DAV\\CorePlugin","type":"->"},{"file":"/data/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":472,"function":"emit","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/data/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":253,"function":"invokeMethod","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/data/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":321,"function":"start","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/data/nextcloud/apps/dav/lib/Server.php","line":352,"function":"exec","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/data/nextcloud/apps/dav/appinfo/v2/remote.php","line":35,"function":"exec","class":"OCA\\DAV\\Server","type":"->"},{"file":"/data/nextcloud/remote.php","line":166,"args":["/data/nextcloud/apps/dav/appinfo/v2/remote.php"],"function":"require_once"}],"File":"/data/nextcloud/3rdparty/doctrine/dbal/src/Driver/API/MySQL/ExceptionConverter.php","Line":37,"Previous":{"Exception":"Doctrine\\DBAL\\Driver\\PDO\\Exception","Message":"SQLSTATE[40001]: Serialization failure: 1213 Deadlock found when trying to get lock; try restarting transaction","Code":1213,"Trace":[{"file":"/data/nextcloud/3rdparty/doctrine/dbal/src/Driver/PDO/Statement.php","line":94,"function":"new","class":"Doctrine\\DBAL\\Driver\\PDO\\Exception","type":"::"},{"file":"/data/nextcloud/3rdparty/doctrine/dbal/src/Connection.php","line":1163,"function":"execute","class":"Doctrine\\DBAL\\Driver\\PDO\\Statement","type":"->"},{"file":"/data/nextcloud/lib/private/DB/Connection.php","line":294,"function":"executeStatement","class":"Doctrine\\DBAL\\Connection","type":"->"},{"file":"/data/nextcloud/3rdparty/doctrine/dbal/src/Query/QueryBuilder.php","line":354,"function":"executeStatement","class":"OC\\DB\\Connection","type":"->"},{"file":"/data/nextcloud/lib/private/DB/QueryBuilder/QueryBuilder.php","line":281,"function":"execute","class":"Doctrine\\DBAL\\Query\\QueryBuilder","type":"->"},{"file":"/data/nextcloud/lib/private/Files/Cache/Cache.php","line":382,"function":"execute","class":"OC\\DB\\QueryBuilder\\QueryBuilder","type":"->"},{"file":"/data/nextcloud/lib/private/Files/Cache/Updater.php","line":256,"function":"update","class":"OC\\Files\\Cache\\Cache","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/data/nextcloud/lib/private/Files/Cache/Updater.php","line":138,"function":"correctParentStorageMtime","class":"OC\\Files\\Cache\\Updater","type":"->"},{"file":"/data/nextcloud/lib/private/Files/View.php","line":328,"function":"update","class":"OC\\Files\\Cache\\Updater","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/data/nextcloud/lib/private/Files/View.php","line":948,"function":"writeUpdate","class":"OC\\Files\\View","type":"->"},{"file":"/data/nextcloud/apps/files_versions/lib/Versions/LegacyVersionsBackend.php","line":93,"function":"copy","class":"OC\\Files\\View","type":"->"},{"file":"/data/nextcloud/apps/files_versions/lib/Versions/VersionManager.php","line":92,"function":"createVersion","class":"OCA\\Files_Versions\\Versions\\LegacyVersionsBackend","type":"->"},{"file":"/data/nextcloud/apps/files_versions/lib/Storage.php","line":217,"function":"createVersion","class":"OCA\\Files_Versions\\Versions\\VersionManager","type":"->"},{"file":"/data/nextcloud/apps/files_versions/lib/Hooks.php","line":56,"function":"store","class":"OCA\\Files_Versions\\Storage","type":"::"},{"file":"/data/nextcloud/lib/private/legacy/OC_Hook.php","line":106,"function":"write_hook","class":"OCA\\Files_Versions\\Hooks","type":"::"},{"file":"/data/nextcloud/apps/dav/lib/Connector/Sabre/File.php","line":449,"function":"emit","class":"OC_Hook","type":"::"},{"file":"/data/nextcloud/apps/dav/lib/Connector/Sabre/File.php","line":178,"function":"emitPreHooks","class":"OCA\\DAV\\Connector\\Sabre\\File","type":"->"},{"file":"/data/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":1137,"function":"put","class":"OCA\\DAV\\Connector\\Sabre\\File","type":"->"},{"file":"/data/nextcloud/3rdparty/sabre/dav/lib/DAV/CorePlugin.php","line":492,"function":"updateFile","class":"Sabre\\DAV\\Server","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/data/nextcloud/3rdparty/sabre/event/lib/WildcardEmitterTrait.php","line":89,"function":"httpPut","class":"Sabre\\DAV\\CorePlugin","type":"->"},{"file":"/data/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":472,"function":"emit","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/data/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":253,"function":"invokeMethod","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/data/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":321,"function":"start","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/data/nextcloud/apps/dav/lib/Server.php","line":352,"function":"exec","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/data/nextcloud/apps/dav/appinfo/v2/remote.php","line":35,"function":"exec","class":"OCA\\DAV\\Server","type":"->"},{"file":"/data/nextcloud/remote.php","line":166,"args":["/data/nextcloud/apps/dav/appinfo/v2/remote.php"],"function":"require_once"}],"File":"/data/nextcloud/3rdparty/doctrine/dbal/src/Driver/PDO/Exception.php","Line":26,"Previous":{"Exception":"PDOException","Message":"SQLSTATE[40001]: Serialization failure: 1213 Deadlock found when trying to get lock; try restarting transaction","Code":"40001","Trace":[{"file":"/data/nextcloud/3rdparty/doctrine/dbal/src/Driver/PDO/Statement.php","line":92,"function":"execute","class":"PDOStatement","type":"->"},{"file":"/data/nextcloud/3rdparty/doctrine/dbal/src/Connection.php","line":1163,"function":"execute","class":"Doctrine\\DBAL\\Driver\\PDO\\Statement","type":"->"},{"file":"/data/nextcloud/lib/private/DB/Connection.php","line":294,"function":"executeStatement","class":"Doctrine\\DBAL\\Connection","type":"->"},{"file":"/data/nextcloud/3rdparty/doctrine/dbal/src/Query/QueryBuilder.php","line":354,"function":"executeStatement","class":"OC\\DB\\Connection","type":"->"},{"file":"/data/nextcloud/lib/private/DB/QueryBuilder/QueryBuilder.php","line":281,"function":"execute","class":"Doctrine\\DBAL\\Query\\QueryBuilder","type":"->"},{"file":"/data/nextcloud/lib/private/Files/Cache/Cache.php","line":382,"function":"execute","class":"OC\\DB\\QueryBuilder\\QueryBuilder","type":"->"},{"file":"/data/nextcloud/lib/private/Files/Cache/Updater.php","line":256,"function":"update","class":"OC\\Files\\Cache\\Cache","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/data/nextcloud/lib/private/Files/Cache/Updater.php","line":138,"function":"correctParentStorageMtime","class":"OC\\Files\\Cache\\Updater","type":"->"},{"file":"/data/nextcloud/lib/private/Files/View.php","line":328,"function":"update","class":"OC\\Files\\Cache\\Updater","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/data/nextcloud/lib/private/Files/View.php","line":948,"function":"writeUpdate","class":"OC\\Files\\View","type":"->"},{"file":"/data/nextcloud/apps/files_versions/lib/Versions/LegacyVersionsBackend.php","line":93,"function":"copy","class":"OC\\Files\\View","type":"->"},{"file":"/data/nextcloud/apps/files_versions/lib/Versions/VersionManager.php","line":92,"function":"createVersion","class":"OCA\\Files_Versions\\Versions\\LegacyVersionsBackend","type":"->"},{"file":"/data/nextcloud/apps/files_versions/lib/Storage.php","line":217,"function":"createVersion","class":"OCA\\Files_Versions\\Versions\\VersionManager","type":"->"},{"file":"/data/nextcloud/apps/files_versions/lib/Hooks.php","line":56,"function":"store","class":"OCA\\Files_Versions\\Storage","type":"::"},{"file":"/data/nextcloud/lib/private/legacy/OC_Hook.php","line":106,"function":"write_hook","class":"OCA\\Files_Versions\\Hooks","type":"::"},{"file":"/data/nextcloud/apps/dav/lib/Connector/Sabre/File.php","line":449,"function":"emit","class":"OC_Hook","type":"::"},{"file":"/data/nextcloud/apps/dav/lib/Connector/Sabre/File.php","line":178,"function":"emitPreHooks","class":"OCA\\DAV\\Connector\\Sabre\\File","type":"->"},{"file":"/data/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":1137,"function":"put","class":"OCA\\DAV\\Connector\\Sabre\\File","type":"->"},{"file":"/data/nextcloud/3rdparty/sabre/dav/lib/DAV/CorePlugin.php","line":492,"function":"updateFile","class":"Sabre\\DAV\\Server","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/data/nextcloud/3rdparty/sabre/event/lib/WildcardEmitterTrait.php","line":89,"function":"httpPut","class":"Sabre\\DAV\\CorePlugin","type":"->"},{"file":"/data/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":472,"function":"emit","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/data/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":253,"function":"invokeMethod","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/data/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":321,"function":"start","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/data/nextcloud/apps/dav/lib/Server.php","line":352,"function":"exec","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/data/nextcloud/apps/dav/appinfo/v2/remote.php","line":35,"function":"exec","class":"OCA\\DAV\\Server","type":"->"},{"file":"/data/nextcloud/remote.php","line":166,"args":["/data/nextcloud/apps/dav/appinfo/v2/remote.php"],"function":"require_once"}],"File":"/data/nextcloud/3rdparty/doctrine/dbal/src/Driver/PDO/Statement.php","Line":92}},"CustomMessage":"--"}}
The questions I have right now: is my nc installation in my /data external directory still usable? I would like to keep my existing settings intact, if possibile, without having to start over, re-importing files etc.
Oh, and this: why is “191.168.1.187” a trusted domain, when my LAN is set on 192.168..?
