Last week I upgraded to buster with ncp-dist-upgrade
. I have edited a few of the cron scripts to also ping my healthchecks.io instance. The health-checks related to /etc/cron.hourly/btrfs-snp
started failing after the upgrade. It seems that /usr/local/bin/btrfs-snp
did not update to the latest version that is buster compatible (according to btrfs-snp. After I manually updated the script, it started working again.
Is this because I edited the cron scripts; Have you noticed anything similar after you upgraded to buster?
Best regards,
Panos
System information
NextCloudPi diagnostics
NextCloudPi version v1.20.7
NextCloudPi image NextCloudPi_01-17-19
distribution Debian GNU/Linux 10 \n \l
automount yes
USB devices sda sdb
datadir /media/nextcloud/ncdata
data in SD no
data filesystem btrfs
data disk usage 376G/800G
rootfs usage 6.7G/29G
swapfile /var/swap
dbdir /media/nextcloud/ncdatabase
Nextcloud check ok
Nextcloud version 17.0.2.1
HTTPD service up
PHP service up
MariaDB service up
Redis service up
Postfix service up
internet check ok
port check 80 open
port check 443 open
IP ***REMOVED SENSITIVE VALUE***
gateway ***REMOVED SENSITIVE VALUE***
interface eth0
certificates ***REMOVED SENSITIVE VALUE***
NAT loopback no
uptime 4:21
Nextcloud configuration
"trusted_domains": {
"0": "localhost",
"5": "nextcloudpi.local",
"7": "nextcloudpi",
"8": "nextcloudpi.lan",
"1": "192.168.1.167",
"4": "leontiou.hopto.org",
"11": "77.49.255.42",
"20": "leontiou.hopto.org",
"21": "nextcloudpi.local",
"22": "192.168.1.167"
"dbtype": "mysql",
"version": "17.0.2.1",
"overwrite.cli.url": "https:\/\/192.168.1.167\/",
"dbport": "",
"mysql.utf8mb4": true,
"redis": {
"port": 0,
"timeout": 0,
"tempdirectory": "\/media\/nextcloud\/ncdata\/tmp",
"mail_smtpmode": "smtp",
"mail_smtpauthtype": "PLAIN",
"overwriteprotocol": "https",
"logfile": "\/media\/nextcloud\/ncdata\/nextcloud.log",
"loglevel": "2",
"log_type": "file",
"jpeg_quality": "60",
"app_install_overwrite": [
"mail"
"mail_sendmailmode": "smtp",
"mail_smtpsecure": "tls",
"mail_smtpport": "25",
"mail_smtpauth": 1,
"preview_max_x": "2048",
"preview_max_y": "2048",
"theme": ""
HTTPd logs
[Mon Feb 24 00:00:03.121335 2020] [ssl:warn] [pid 2650:tid 548492449136] AH01909: localhost:4443:0 server certificate does NOT include an ID which matches the server name
[Mon Feb 24 00:00:03.139515 2020] [mpm_event:notice] [pid 2650:tid 548492449136] AH00489: Apache/2.4.38 (Debian) OpenSSL/1.1.1d configured -- resuming normal operations
[Mon Feb 24 00:00:03.139594 2020] [core:notice] [pid 2650:tid 548492449136] AH00094: Command line: '/usr/sbin/apache2'
[Mon Feb 24 12:56:53.854859 2020] [mpm_event:notice] [pid 2650:tid 548492449136] AH00491: caught SIGTERM, shutting down
[Mon Feb 24 12:57:55.054228 2020] [ssl:warn] [pid 2595:tid 547577288048] AH01909: localhost:4443:0 server certificate does NOT include an ID which matches the server name
[Mon Feb 24 12:57:55.098225 2020] [ssl:warn] [pid 2650:tid 547577288048] AH01909: localhost:4443:0 server certificate does NOT include an ID which matches the server name
[Mon Feb 24 12:57:55.104134 2020] [mpm_event:notice] [pid 2650:tid 547577288048] AH00489: Apache/2.4.38 (Debian) OpenSSL/1.1.1d configured -- resuming normal operations
[Mon Feb 24 12:57:55.104280 2020] [core:notice] [pid 2650:tid 547577288048] AH00094: Command line: '/usr/sbin/apache2'
Database logs
2020-02-24 12:57:47 0 [Note] InnoDB: Compressed tables use zlib 1.2.11
2020-02-24 12:57:47 0 [Note] InnoDB: Number of pools: 1
2020-02-24 12:57:47 0 [Note] InnoDB: Using generic crc32 instructions
2020-02-24 12:57:47 0 [Note] InnoDB: Initializing buffer pool, total size = 896M, instances = 1, chunk size = 128M
2020-02-24 12:57:47 0 [Note] InnoDB: Completed initialization of buffer pool
2020-02-24 12:57:47 0 [Note] InnoDB: If the mysqld execution user is authorized, page cleaner thread priority can be changed. See the man page of setpriority().
2020-02-24 12:57:47 0 [Note] InnoDB: 128 out of 128 rollback segments are active.
2020-02-24 12:57:47 0 [Note] InnoDB: Creating shared tablespace for temporary tables
2020-02-24 12:57:47 0 [Note] InnoDB: Setting file './ibtmp1' size to 12 MB. Physically writing the file full; Please wait ...
2020-02-24 12:57:48 0 [Note] InnoDB: File './ibtmp1' size is now 12 MB.
2020-02-24 12:57:48 0 [Note] InnoDB: Waiting for purge to start
2020-02-24 12:57:48 0 [Note] InnoDB: 10.3.22 started; log sequence number 7427788229; transaction id 168199512
2020-02-24 12:57:48 0 [Note] InnoDB: Loading buffer pool(s) from /media/nextcloud/ncdatabase/ib_buffer_pool
2020-02-24 12:57:48 0 [Note] Plugin 'FEEDBACK' is disabled.
2020-02-24 12:57:48 0 [Note] Server socket created on IP: '127.0.0.1'.
2020-02-24 12:57:48 0 [Note] Reading of all Master_info entries succeeded
2020-02-24 12:57:48 0 [Note] Added new Master_info '' to hash table
2020-02-24 12:57:48 0 [Note] /usr/sbin/mysqld: ready for connections.
Version: '10.3.22-MariaDB-0+deb10u1' socket: '/var/run/mysqld/mysqld.sock' port: 3306 Debian 10
2020-02-24 12:57:49 0 [Note] InnoDB: Buffer pool(s) load completed at 200224 12:57:49
Nextcloud logs
