Hi, I have a free Dynamic DNS account to access my Nextcloud from everywhere.
when I use the NextCloudPi Configuration tool to configure DDNS_spDYN it says:
[badauth] Not a valid username/password
when I try ‘the same’ with the spdnsUpdater.sh script, with the same hostname and updatetoken, everything works fine.
The Script is in
/usr/local/etc/spdnsupdater/
Is there a way to fix the NextcloudPi configuration tool to point to the correct script?
Thank you for your help.
