Hi!
I have installed the collabora CODE arm64 from Nextcloud application.
Unfortunately the collabora app cannot connect to it.
I think this is due to a missing configuration of traefik in my docker-compose file but I didn’t found how to do it .
Here is my original docker-compose.yml:
version: '3'
services:
nextcloudpi:
image: ownyourbits/nextcloudpi-arm64
command: "192.168.1.17"
ports:
- "886:443"
- "4443:4443"
logging:
driver: "json-file"
options:
max-size: "100m"
max-file: "5"
labels: "production_status"
env: "os,customer"
labels:
- "traefik.enable=true"
- "traefik.protocol=http"
- "traefik.port=80"
- "traefik.http.routers.nextcloudpi.entrypoints=web"
- "traefik.http.routers.nextcloudpi.rule=Host(`ncp.exemple.org`)"
- "traefik.http.middlewares.https-redirect.redirectscheme.scheme=https"
- "traefik.http.routers.nextcloudpi.middlewares=https-redirect"
- "traefik.http.routers.nextcloudpi-secure.entrypoints=websecure"
- "traefik.http.routers.nextcloudpi-secure.rule=Host(`ncp.exemple.org`)"
- "traefik.http.middlewares.nc-rep.redirectregex.regex=https://(.*)/.well-known/(card|cal)dav"
- "traefik.http.middlewares.nc-rep.redirectregex.replacement=https://$$1/remote.php/dav/"
- "traefik.http.middlewares.nc-rep.redirectregex.permanent=true"
- "traefik.http.middlewares.nc-header.headers.customFrameOptionsValue=SAMEORIGIN"
- "traefik.http.middlewares.nextcloudpi.headers.stsSeconds=155520011"
- "traefik.http.middlewares.nextcloudpi.headers.stsIncludeSubdomains=true"
- "traefik.http.middlewares.nextcloudpi.headers.stsPreload=true"
- "traefik.http.routers.nextcloudpi-secure.middlewares=nc-rep,nc-header"
- "traefik.http.routers.nextcloudpi-secure.tls=true"
- "traefik.http.routers.nextcloudpi-secure.tls.certresolver=myresolver"
- "traefik.http.routers.nextcloudpi-secure.service=nextcloudpi"
- "traefik.http.services.nextcloudpi.loadbalancer.server.port=80"
- "traefik.docker.network=traefik"
environment:
- TRUSTED_PROXIES="traefik"
networks:
- traefik
- backend
volumes:
- ncdata:/data
- /etc/localtime:/etc/localtime:ro
- /media:/media
- /media/nfsnas:/mnt/nfsnas
container_name: nextcloudpi
restart: always
volumes:
ncdata:
networks:
traefik: # this is the network provided by traefik
external:
backend: # your database should be in this network
driver: bridge
Can someone help me to solve this?
