example
longer
example
here
NCP Version: before 1.31.1 after 1.30.1
Nextcloud version (eg, 18.0.2): 19.0.4.2
Operating system and version (eg, Ubuntu 20.04): Raspbian 5.4.72-v7l+
Apache or nginx version (eg, Apache 2.4.25): 2.4.38 (Raspbian)
PHP version (eg, 7.1): 7.3.19-1~deb10u1
- running ncp-config / updates / nc-update results in downgrading from NCP 1.31.1 to NCP 1.30.1
- second run gives same result
The output of your log in:
[ nc-update ] (Thu Nov 26 16:53:34 CET 2020)
Downloading updates
Downloading updates
Performing updates
NextCloudPi updated to version v1.30.1
