NC26: Background job execution problem, News not updating
example
longer
example
here
Nextcloud version (eg, 20.0.5): Turnkey Linux container (17.2), Nextcloud Hub 4 (26.0.2)
Operating system and version (eg, Ubuntu 20.04): Debian 11/Bullseye
Apache or nginx version (eg, Apache 2.4.25): Apache 2.4.56-1
PHP version (eg, 7.4): 8.1.17
Mysql: 10.5.18
Platform: Proxmox PVE 7.4
I am new to NC and recently installed NC26. After installation I see the following:
Last background job execution ran 7 days ago. Something seems wrong.
I have set background jobs to use CRON and tried adding apc.enable_cli=1 to php.ini.
Neither change fixed the problem and I removed the line from php.ini. Any suggestions on how to solve this problem would be greatly appreciated.
Is this the first time you’ve seen this error? (Y/N): Y (new install)
Steps to replicate it: New install, no actions required
Level	App	Message
Time
Error	drawio	OCP\Files\NotFoundException: /appdata_dedaf85457c51/drawio/previews		2023-06-05T20:28:45-0400
Error	drawio	OCP\Files\NotFoundException: /appdata_dedaf85457c51/drawio/previews		2023-06-05T20:28:30-0400
Error	drawio	OCP\Files\NotFoundException: /appdata_dedaf85457c51/drawio/previews		2023-06-05T20:28:29-0400
Warning	no app in context	Login failed: ken (Remote IP: 192.168.10.100)		2023-06-05T20:22:18-0400
Error	index	OCP\Files\NotPermittedException: Could not create folder		2023-06-05T11:28:09-0400
Error	webdav	Doctrine\DBAL\Exception\DeadlockException: An exception occurred while executing a query: SQLSTATE[40001]: Serialization failure: 1213 Deadlock found when trying to get lock; try restarting transaction		2023-06-05T11:27:00-0400
Warning	news	https://www.fantasypros.com/ read error : malformed xml string. parsing error : DOMDocument::loadXML(): xmlParseEntityRef: no name in Entity, line: 20 (2)		2023-06-03T13:41:50-0400
Warning	news	No valid feed found at URL, attempting auto discovery		2023-06-03T13:41:50-0400
Warning	news	https://cnn.com/ read error : malformed xml string. parsing error : DOMDocument::loadXML(): EntityRef: expecting ';' in Entity, line: 4 (2)		2023-06-02T12:54:55-0400
Warning	news	No valid feed found at URL, attempting auto discovery		2023-06-02T12:54:54-0400
Warning	news	https://cnn.com/ read error : malformed xml string. parsing error : DOMDocument::loadXML(): EntityRef: expecting ';' in Entity, line: 4 (2)		2023-06-02T12:54:54-0400
Warning	core	Renewing session token failed		2023-06-01T19:37:41-0400
Warning	no app in context	Login failed: admin (Remote IP: 192.168.10.104)		2023-06-01T14:05:20-0400
Info	updater	\OC\Updater::resetLogLevel: Reset log level to Warning(2)		2023-06-01T12:52:10-0400
Info	updater	\OC\Updater::maintenanceDisabled: Turned off maintenance mode		2023-06-01T12:52:10-0400
Info	updater	\OC\Updater::updateEnd: Update successful		2023-06-01T12:52:10-0400
Info	updater	\OC\Updater::finishedCheckCodeIntegrity: Finished code integrity check		2023-06-01T12:52:10-0400
Info	updater	\OC\Updater::startCheckCodeIntegrity: Starting code integrity check...		2023-06-01T12:52:09-0400
Info	updater	OC\Repair\Events\RepairStepEvent: Repair step: Add possibly missing system config		2023-06-01T12:52:09-0400
Info	updater	OC\Repair\Events\RepairStepEvent: Repair step: Clean up abandoned apps		2023-06-01T12:52:09-0400
Info	updater	OC\Repair\Events\RepairStepEvent: Repair step: Add token cleanup job		2023-06-01T12:52:09-0400
Info	updater	OC\Repair\Events\RepairStepEvent: Repair step: Add background job to set the lookup server share state for users		2023-06-01T12:52:09-0400
Info	updater	OC\Repair\Events\RepairStepEvent: Repair step: Repair DAV shares		2023-06-01T12:52:09-0400
Info	updater	OC\Repair\Events\RepairStepEvent: Repair step: Queue a one-time job to check for user uploaded certificates		2023-06-01T12:52:09-0400
Info	updater	OC\Repair\Events\RepairStepEvent: Repair step: Add job to cleanup the bruteforce entries		2023-06-01T12:52:09-0400
Info	updater	OC\Repair\Events\RepairStepEvent: Repair step: Remove old dashboard app config data		2023-06-01T12:52:09-0400
Info	updater	OC\Repair\Events\RepairStepEvent: Repair step: Check encryption key format		2023-06-01T12:52:09-0400
Info	updater	OC\Repair\Events\RepairStepEvent: Repair step: Keep legacy encryption enabled		2023-06-01T12:52:09-0400
Info	updater	OC\Repair\Events\RepairStepEvent: Repair step: Reset generated avatar flag		2023-06-01T12:52:09-0400
Info	updater	OC\Repair\Events\RepairStepEvent: Repair step: Clear access cache of projects		2023-06-01T12:52:09-0400
Info	updater	OC\Repair\Events\RepairInfoEvent: Repair info: No need to remove link shares.		2023-06-01T12:52:09-0400
Info	updater	OC\Repair\Events\RepairStepEvent: Repair step: Remove potentially over exposing share links		2023-06-01T12:52:09-0400
Info	updater	OC\Repair\Events\RepairStepEvent: Repair step: Add background job to cleanup login flow v2 tokens		2023-06-01T12:52:09-0400
Info	updater	OC\Repair\Events\RepairStepEvent: Repair step: Cleanup invalid photocache files for carddav		2023-06-01T12:52:09-0400
Info	updater	OC\Repair\Events\RepairStepEvent: Repair step: Queue a one-time job to cleanup old backups of the updater		2023-06-01T12:52:09-0400
Info	updater	OC\Repair\Events\RepairStepEvent: Repair step: Add preview background cleanup job		2023-06-01T12:52:09-0400
Info	updater	OC\Repair\Events\RepairInfoEvent: Repair info: Avatar cache clearing job added		2023-06-01T12:52:09-0400
Info	updater	OC\Repair\Events\RepairStepEvent: Repair step: Clear every generated avatar		2023-06-01T12:52:09-0400
Info	updater	OC\Repair\Events\RepairInfoEvent: Repair info: JS cache cleared		2023-06-01T12:52:09-0400
Info	updater	OC\Repair\Events\RepairInfoEvent: Repair info: Image cache cleared		2023-06-01T12:52:09-0400
Info	updater	OC\Repair\Events\RepairStepEvent: Repair step: Clear frontend caches		2023-06-01T12:52:09-0400
Info	updater	OC\Repair\Events\RepairStepEvent: Repair step: Add log rotate job		2023-06-01T12:52:09-0400
Info	updater	OC\Repair\Events\RepairStepEvent: Repair step: Repair language codes		2023-06-01T12:52:09-0400
Info	updater	OC\Repair\Events\RepairInfoEvent: Repair info: No mounts updated		2023-06-01T12:52:09-0400
Info	updater	OC\Repair\Events\RepairStepEvent: Repair step: Fix potential broken mount points		2023-06-01T12:52:09-0400
Info	updater	OC\Repair\Events\RepairInfoEvent: Repair info: Update the oauth2_clients table schema.		2023-06-01T12:52:09-0400
Info	updater	OC\Repair\Events\RepairInfoEvent: Repair info: Update the oauth2_access_tokens table schema.		2023-06-01T12:52:09-0400
Info	updater	OC\Repair\Events\RepairStepEvent: Repair step: Migrate oauth2_clients table to nextcloud schema		2023-06-01T12:52:08-0400
Info	updater	OC\Repair\Events\RepairStepEvent: Repair step: Add preview cleanup background jobs		2023-06-01T12:52:08-0400
Info	updater	OC\Repair\Events\RepairInfoEvent: Repair info: Add background job		2023-06-01T12:52:08-0400
Info	updater	OC\Repair\Events\RepairStepEvent: Repair step: Add move avatar background job		2023-06-01T12:52:08-0400
Info	updater	OC\Repair\Events\RepairInfoEvent: Repair info: .step file moved to .step-previous-update		2023-06-01T12:52:08-0400
Info	updater	OC\Repair\Events\RepairInfoEvent: Repair info: .step file exists		2023-06-01T12:52:08-0400
Info	updater	OC\Repair\Events\RepairStepEvent: Repair step: Move .step file of updater to backup location		2023-06-01T12:52:08-0400
Info	updater	OC\Repair\Events\RepairStepEvent: Repair step: Repair invalid shares		2023-06-01T12:52:08-0400
Info	updater	OC\Repair\Events\RepairInfoEvent: Repair info: 0 tags with no entries have been removed.		2023-06-01T12:52:08-0400
Info	updater	OC\Repair\Events\RepairInfoEvent: Repair info: 0 tag entries for deleted tags have been removed.		2023-06-01T12:52:08-0400
Info	updater	OC\Repair\Events\RepairInfoEvent: Repair info: 0 tags for delete files have been removed.		2023-06-01T12:52:08-0400
Info	updater	OC\Repair\Events\RepairInfoEvent: Repair info: 0 tags of deleted users have been removed.		2023-06-01T12:52:08-0400
Info	updater	OC\Repair\Events\RepairStepEvent: Repair step: Clean tags and favorites		2023-06-01T12:52:08-0400
Info	updater	OC\Repair\Events\RepairStepEvent: Repair step: Repair mime types		2023-06-01T12:52:08-0400
Info	updater	OC\Repair\Events\RepairInfoEvent: Repair info: All tables already have the correct collation -> nothing to do		2023-06-01T12:52:08-0400
Info	updater	OC\Repair\Events\RepairStepEvent: Repair step: Repair MySQL collation		2023-06-01T12:52:08-0400
Debug	updater	\OC\Updater::checkAppStoreApp: Checked for update of app "workflowengine" in appstore		2023-06-01T12:52:08-0400
Debug	updater	\OC\Updater::checkAppStoreAppBefore: Checking for update of app "workflowengine" in appstore		2023-06-01T12:52:08-0400
Debug	updater	\OC\Updater::checkAppStoreApp: Checked for update of app "weather_status" in appstore		2023-06-01T12:52:08-0400
Debug	updater	\OC\Updater::checkAppStoreAppBefore: Checking for update of app "weather_status" in appstore		2023-06-01T12:52:08-0400
Debug	updater	\OC\Updater::checkAppStoreApp: Checked for update of app "viewer" in appstore		2023-06-01T12:52:08-0400
Debug	updater	\OC\Updater::checkAppStoreAppBefore: Checking for update of app "viewer" in appstore		2023-06-01T12:52:08-0400
Debug	updater	\OC\Updater::checkAppStoreApp: Checked for update of app "user_status" in appstore		2023-06-01T12:52:08-0400
Debug	updater	\OC\Updater::checkAppStoreAppBefore: Checking for update of app "user_status" in appstore		2023-06-01T12:52:08-0400
Debug	updater	\OC\Updater::checkAppStoreApp: Checked for update of app "updatenotification" in appstore		2023-06-01T12:52:08-0400
Debug	updater	\OC\Updater::checkAppStoreAppBefore: Checking for update of app "updatenotification" in appstore		2023-06-01T12:52:08-0400
Debug	updater	\OC\Updater::checkAppStoreApp: Checked for update of app "twofactor_backupcodes" in appstore		2023-06-01T12:52:08-0400
Debug	updater	\OC\Updater::checkAppStoreAppBefore: Checking for update of app "twofactor_backupcodes" in appstore		2023-06-01T12:52:08-0400
Debug	updater	\OC\Updater::checkAppStoreApp: Checked for update of app "theming" in appstore		2023-06-01T12:52:08-0400
Debug	updater	\OC\Updater::checkAppStoreAppBefore: Checking for update of app "theming" in appstore		2023-06-01T12:52:08-0400
Debug	updater	\OC\Updater::checkAppStoreApp: Checked for update of app "text" in appstore		2023-06-01T12:52:08-0400
Debug	updater	\OC\Updater::checkAppStoreAppBefore: Checking for update of app "text" in appstore		2023-06-01T12:52:08-0400
Debug	updater	\OC\Updater::checkAppStoreApp: Checked for update of app "systemtags" in appstore		2023-06-01T12:52:08-0400
Debug	updater	\OC\Updater::checkAppStoreAppBefore: Checking for update of app "systemtags" in appstore		2023-06-01T12:52:08-0400
Debug	updater	\OC\Updater::checkAppStoreApp: Checked for update of app "survey_client" in appstore		2023-06-01T12:52:08-0400
Debug	updater	\OC\Updater::checkAppStoreAppBefore: Checking for update of app "survey_client" in appstore		2023-06-01T12:52:08-0400
Debug	updater	\OC\Updater::checkAppStoreApp: Checked for update of app "support" in appstore		2023-06-01T12:52:08-0400
Debug	updater	\OC\Updater::checkAppStoreAppBefore: Checking for update of app "support" in appstore		2023-06-01T12:52:08-0400
Debug	updater	\OC\Updater::checkAppStoreApp: Checked for update of app "sharebymail" in appstore		2023-06-01T12:52:08-0400
Debug	updater	\OC\Updater::checkAppStoreAppBefore: Checking for update of app "sharebymail" in appstore		2023-06-01T12:52:08-0400
Debug	updater	\OC\Updater::checkAppStoreApp: Checked for update of app "settings" in appstore		2023-06-01T12:52:08-0400
Debug	updater	\OC\Updater::checkAppStoreAppBefore: Checking for update of app "settings" in appstore		2023-06-01T12:52:08-0400
Debug	updater	\OC\Updater::checkAppStoreApp: Checked for update of app "serverinfo" in appstore		2023-06-01T12:52:08-0400
Debug	updater	\OC\Updater::checkAppStoreAppBefore: Checking for update of app "serverinfo" in appstore		2023-06-01T12:52:08-0400
Debug	updater	\OC\Updater::checkAppStoreApp: Checked for update of app "related_resources" in appstore		2023-06-01T12:52:08-0400
Debug	updater	\OC\Updater::checkAppStoreAppBefore: Checking for update of app "related_resources" in appstore		2023-06-01T12:52:08-0400
Debug	updater	\OC\Updater::checkAppStoreApp: Checked for update of app "recommendations" in appstore		2023-06-01T12:52:08-0400
Debug	updater	\OC\Updater::checkAppStoreAppBefore: Checking for update of app "recommendations" in appstore		2023-06-01T12:52:08-0400
Debug	updater	\OC\Updater::checkAppStoreApp: Checked for update of app "provisioning_api" in appstore		2023-06-01T12:52:08-0400
Debug	updater	\OC\Updater::checkAppStoreAppBefore: Checking for update of app "provisioning_api" in appstore		2023-06-01T12:52:08-0400
Debug	updater	\OC\Updater::checkAppStoreApp: Checked for update of app "privacy" in appstore		2023-06-01T12:52:08-0400
Debug	updater	\OC\Updater::checkAppStoreAppBefore: Checking for update of app "privacy" in appstore		2023-06-01T12:52:08-0400
Debug	updater	\OC\Updater::checkAppStoreApp: Checked for update of app "photos" in appstore		2023-06-01T12:52:08-0400
Debug	updater	\OC\Updater::checkAppStoreAppBefore: Checking for update of app "photos" in appstore		2023-06-01T12:52:08-0400
Debug	updater	\OC\Updater::checkAppStoreApp: Checked for update of app "password_policy" in appstore		2023-06-01T12:52:08-0400
Debug	updater	\OC\Updater::checkAppStoreAppBefore: Checking for update of app "password_policy" in appstore		2023-06-01T12:52:08-0400
Debug	updater	\OC\Updater::checkAppStoreApp: Checked for update of app "oauth2" in appstore		2023-06-01T12:52:08-0400
Debug	updater	\OC\Updater::checkAppStoreAppBefore: Checking for update of app "oauth2" in appstore		2023-06-01T12:52:08-0400
Debug	updater	\OC\Updater::checkAppStoreApp: Checked for update of app "notifications" in appstore		2023-06-01T12:52:08-0400
Debug	updater	\OC\Updater::checkAppStoreAppBefore: Checking for update of app "notifications" in appstore		2023-06-01T12:52:08-0400
Debug	updater	\OC\Updater::checkAppStoreApp: Checked for update of app "nextcloud_announcements" in appstore		2023-06-01T12:52:08-0400
Debug	updater	\OC\Updater::checkAppStoreAppBefore: Checking for update of app "nextcloud_announcements" in appstore		2023-06-01T12:52:08-0400
Debug	updater	\OC\Updater::checkAppStoreApp: Checked for update of app "lookup_server_connector" in appstore		2023-06-01T12:52:08-0400
Debug	updater	\OC\Updater::checkAppStoreAppBefore: Checking for update of app "lookup_server_connector" in appstore		2023-06-01T12:52:08-0400
Debug	updater	\OC\Updater::checkAppStoreApp: Checked for update of app "logreader" in appstore		2023-06-01T12:52:08-0400
Debug	updater	\OC\Updater::checkAppStoreAppBefore: Checking for update of app "logreader" in appstore		2023-06-01T12:52:08-0400
Debug	updater	\OC\Updater::checkAppStoreApp: Checked for update of app "firstrunwizard" in appstore		2023-06-01T12:52:08-0400
Debug	updater	\OC\Updater::checkAppStoreAppBefore: Checking for update of app "firstrunwizard" in appstore		2023-06-01T12:52:08-0400
Debug	updater	\OC\Updater::checkAppStoreApp: Checked for update of app "files_versions" in appstore		2023-06-01T12:52:08-0400
Debug	updater	\OC\Updater::checkAppStoreAppBefore: Checking for update of app "files_versions" in appstore		2023-06-01T12:52:08-0400
Debug	updater	\OC\Updater::checkAppStoreApp: Checked for update of app "files_trashbin" in appstore		2023-06-01T12:52:08-0400
Debug	updater	\OC\Updater::checkAppStoreAppBefore: Checking for update of app "files_trashbin" in appstore		2023-06-01T12:52:08-0400
Debug	updater	\OC\Updater::checkAppStoreApp: Checked for update of app "files_sharing" in appstore		2023-06-01T12:52:08-0400
Debug	updater	\OC\Updater::checkAppStoreAppBefore: Checking for update of app "files_sharing" in appstore		2023-06-01T12:52:08-0400
Debug	updater	\OC\Updater::checkAppStoreApp: Checked for update of app "files_rightclick" in appstore		2023-06-01T12:52:08-0400
Debug	updater	\OC\Updater::checkAppStoreAppBefore: Checking for update of app "files_rightclick" in appstore		2023-06-01T12:52:08-0400
Debug	updater	\OC\Updater::checkAppStoreApp: Checked for update of app "files_pdfviewer" in appstore		2023-06-01T12:52:08-0400
Debug	updater	\OC\Updater::checkAppStoreAppBefore: Checking for update of app "files_pdfviewer" in appstore		2023-06-01T12:52:08-0400
Debug	updater	\OC\Updater::checkAppStoreApp: Checked for update of app "files" in appstore		2023-06-01T12:52:08-0400
Debug	updater	\OC\Updater::checkAppStoreAppBefore: Checking for update of app "files" in appstore		2023-06-01T12:52:08-0400
Debug	updater	\OC\Updater::checkAppStoreApp: Checked for update of app "federation" in appstore		2023-06-01T12:52:08-0400
Debug	updater	\OC\Updater::checkAppStoreAppBefore: Checking for update of app "federation" in appstore		2023-06-01T12:52:08-0400
Debug	updater	\OC\Updater::checkAppStoreApp: Checked for update of app "federatedfilesharing" in appstore		2023-06-01T12:52:08-0400
Debug	updater	\OC\Updater::checkAppStoreAppBefore: Checking for update of app "federatedfilesharing" in appstore		2023-06-01T12:52:08-0400
Debug	updater	\OC\Updater::checkAppStoreApp: Checked for update of app "dav" in appstore		2023-06-01T12:52:08-0400
Debug	updater	\OC\Updater::checkAppStoreAppBefore: Checking for update of app "dav" in appstore		2023-06-01T12:52:08-0400
Debug	updater	\OC\Updater::checkAppStoreApp: Checked for update of app "dashboard" in appstore		2023-06-01T12:52:08-0400
Debug	updater	\OC\Updater::checkAppStoreAppBefore: Checking for update of app "dashboard" in appstore		2023-06-01T12:52:08-0400
Debug	updater	\OC\Updater::checkAppStoreApp: Checked for update of app "contactsinteraction" in appstore		2023-06-01T12:52:08-0400
Debug	updater	\OC\Updater::checkAppStoreAppBefore: Checking for update of app "contactsinteraction" in appstore		2023-06-01T12:52:08-0400
Debug	updater	\OC\Updater::checkAppStoreApp: Checked for update of app "comments" in appstore		2023-06-01T12:52:08-0400
Debug	updater	\OC\Updater::checkAppStoreAppBefore: Checking for update of app "comments" in appstore		2023-06-01T12:52:08-0400
Debug	updater	\OC\Updater::checkAppStoreApp: Checked for update of app "cloud_federation_api" in appstore		2023-06-01T12:52:08-0400
Debug	updater	\OC\Updater::checkAppStoreAppBefore: Checking for update of app "cloud_federation_api" in appstore		2023-06-01T12:52:08-0400
Debug	updater	\OC\Updater::checkAppStoreApp: Checked for update of app "circles" in appstore		2023-06-01T12:52:08-0400
Debug	updater	\OC\Updater::checkAppStoreAppBefore: Checking for update of app "circles" in appstore		2023-06-01T12:52:08-0400
Debug	updater	\OC\Updater::checkAppStoreApp: Checked for update of app "activity" in appstore		2023-06-01T12:52:08-0400
Debug	updater	\OC\Updater::checkAppStoreAppBefore: Checking for update of app "activity" in appstore		2023-06-01T12:52:00-0400
Info	updater	\OC\Updater::dbUpgrade: Updated database		2023-06-01T12:52:00-0400
Info	updater	\OC\Updater::dbUpgradeBefore: Updating database schema		2023-06-01T12:52:00-0400
Info	updater	OC\Repair\Events\RepairStepEvent: Repair step: Drop account terms table when migrating from ownCloud		2023-06-01T12:52:00-0400
Info	updater	OC\Repair\Events\RepairStepEvent: Repair step: Copy data from accounts table when migrating from ownCloud		2023-06-01T12:52:00-0400
Info	updater	OC\Repair\Events\RepairStepEvent: Repair step: Repair SQLite autoincrement		2023-06-01T12:52:00-0400
Info	updater	OC\Repair\Events\RepairInfoEvent: Repair info: All tables already have the correct collation -> nothing to do		2023-06-01T12:52:00-0400
Info	updater	OC\Repair\Events\RepairStepEvent: Repair step: Repair MySQL collation		2023-06-01T12:52:00-0400
Debug	core	starting upgrade from 26.0.0.11 to 26.0.2.1		2023-06-01T12:52:00-0400
Info	updater	\OC\Updater::maintenanceEnabled: Turned on maintenance mode		2023-06-01T12:52:00-0400
Error	PHP	Undefined array key "mail_smtpauthtype" at /var/www/nextcloud/apps/settings/templates/settings/admin/additional-mail.php#132		2023-06-01T12:20:51-0400
Warning	ocs_api	OC\HintException: Password needs to be at least 10 characters long. Password is present in compromised password list. Please choose a different password.
    0 => 'localhost',
    1 => '*.home.arpa',
  'datadirectory' => '/var/www/nextcloud-data',
  'version' => '26.0.2.1',
  'overwrite.cli.url' => 'http://localhost',
  'dbname' => 'nextcloud',
  'dbhost' => 'localhost',
  'dbuser' => 'nextcloud',
  'dbpassword' => 'xyz',
  'instanceid' => 'xyz',
  'redis' =>
    'host' => '/var/run/redis/redis.sock',
    'port' => 0,
    'timeout' => 0.0,
  'updater.secret' => 'abc',
  'theme' => '',
  'loglevel' => 2,
Jun  1 11:36:00 nextcloud systemd-sysusers[57]: Creating group systemd-timesync with gid 999.
Jun  1 11:36:00 nextcloud systemd-sysusers[57]: Creating user systemd-timesync (systemd Time Synchronization) with uid 999 and gid 999.
Jun  1 11:36:00 nextcloud mount[42]: mount: /sys/kernel/debug: permission denied.
Jun  1 11:36:00 nextcloud systemd-sysusers[57]: Creating group systemd-coredump with gid 998.
Jun  1 11:36:00 nextcloud systemd-sysusers[57]: Creating user systemd-coredump (systemd Core Dumper) with uid 998 and gid 998.
Jun  1 11:36:00 nextcloud systemd[1]: Starting Flush Journal to Persistent Storage...
Jun  1 11:36:00 nextcloud systemd[1]: Finished Apply Kernel Variables.
Jun  1 11:36:00 nextcloud mount[54]: mount: /sys/kernel/config: permission denied.
Jun  1 11:36:00 nextcloud systemd[1]: Finished Create System Users.
Jun  1 11:36:00 nextcloud systemd[1]: Starting Create Static Device Nodes in /dev...
Jun  1 11:36:00 nextcloud systemd[1]: Finished Flush Journal to Persistent Storage.
Jun  1 11:36:00 nextcloud systemd[1]: e2scrub_reap.service: Succeeded.
Jun  1 11:36:00 nextcloud systemd[1]: Finished Remove Stale Online ext4 Metadata Check Snapshots.
Jun  1 11:36:00 nextcloud inithooks: running /usr/lib/inithooks/firstboot.d/01ipconfig
Jun  1 11:36:00 nextcloud inithooks: successfully completed /usr/lib/inithooks/firstboot.d/01ipconfig
Jun  1 11:36:00 nextcloud inithooks: running /usr/lib/inithooks/firstboot.d/05autogrow-fs
Jun  1 11:36:00 nextcloud inithooks: successfully completed /usr/lib/inithooks/firstboot.d/05autogrow-fs
Jun  1 11:36:00 nextcloud inithooks: running /usr/lib/inithooks/firstboot.d/09hostname
Jun  1 11:36:00 nextcloud inithooks: successfully completed /usr/lib/inithooks/firstboot.d/09hostname
Jun  1 11:36:00 nextcloud inithooks: running /usr/lib/inithooks/firstboot.d/10randomize-cronapt
Jun  1 11:36:00 nextcloud inithooks: successfully completed /usr/lib/inithooks/firstboot.d/10randomize-cronapt
Jun  1 11:36:00 nextcloud inithooks: running /usr/lib/inithooks/firstboot.d/10randomize-crontab
Jun  1 11:36:00 nextcloud inithooks: successfully completed /usr/lib/inithooks/firstboot.d/10randomize-crontab
Jun  1 11:36:00 nextcloud inithooks: running /usr/lib/inithooks/firstboot.d/10regen-sshkeys
Jun  1 11:36:00 nextcloud inithooks[162]: Stopping SSH service to regenerate new keys
Jun  1 11:36:00 nextcloud ifup[106]: udhcpc: sending discover
Jun  1 11:36:00 nextcloud inithooks[162]: Generating new SSH2 RSA key; this may take a while...
Jun  1 11:36:00 nextcloud inithooks[162]: Generating new SSH2 ECDSA key; this may take a while...
Jun  1 11:36:00 nextcloud inithooks[162]: Generating new SSH2 ED25519 key; this may take a while...
Jun  1 11:36:00 nextcloud inithooks[162]: Moving keys into place
Jun  1 11:36:00 nextcloud inithooks[162]: Restarting SSH service
Jun  1 11:36:00 nextcloud ifup[106]: udhcpc: sending select for 192.168.10.7
Jun  1 11:36:00 nextcloud ifup[106]: udhcpc: lease of 192.168.10.7 obtained, lease time 7200
Jun  1 11:36:00 nextcloud ifup[172]: /etc/udhcpc/default.script: Resetting default routes
Jun  1 11:36:00 nextcloud ifup[174]: SIOCDELRT: No such process
Jun  1 11:36:00 nextcloud ifup[172]: /etc/udhcpc/default.script: Adding DNS 192.168.10.1
Jun  1 11:36:00 nextcloud ifup[184]: /etc/resolvconf/update.d/libc: Warning: /etc/resolv.conf is not a symbolic link to /run/resolvconf/resolv.conf
Jun  1 11:36:00 nextcloud systemd[1]: Finished Wait for Network to be Configured.
Jun  1 11:36:00 nextcloud systemd[1]: Finished Raise network interfaces.
Jun  1 11:36:00 nextcloud systemd[1]: Reached target Network.
Jun  1 11:36:00 nextcloud systemd[1]: Starting The Apache HTTP Server...
Jun  1 11:36:00 nextcloud systemd[1]: Started Fail2Ban Service.
Jun  1 11:36:00 nextcloud systemd[1]: Starting MariaDB 10.5.18 database server...
Jun  1 11:36:00 nextcloud systemd[1]: Starting Advanced key-value store...
Jun  1 11:36:00 nextcloud systemd[1]: Condition check resulted in fast remote file copy program daemon being skipped.
Jun  1 11:36:00 nextcloud systemd[1]: Starting OpenBSD Secure Shell server...
Jun  1 11:36:00 nextcloud systemd[1]: Starting Universal SSL tunnel for network daemons (shellinabox)...
Jun  1 11:36:00 nextcloud systemd[1]: Starting Universal SSL tunnel for network daemons (webmin)...
Jun  1 11:36:00 nextcloud systemd[1]: Starting Permit User Sessions...
Jun  1 11:36:00 nextcloud systemd[1]: Finished Permit User Sessions.
Jun  1 11:36:00 nextcloud systemd[1]: Started Console Getty.
Jun  1 11:36:00 nextcloud systemd[1]: Started Container Getty on /dev/tty2.
Jun  1 11:36:00 nextcloud systemd[1]: Condition check resulted in Getty on tty1 being skipped.
Jun  1 11:36:00 nextcloud systemd[1]: Condition check resulted in inithooks: firstboot and everyboot initialization scripts being skipped.
Jun  1 11:36:00 nextcloud stunnel: LOG5[ui]: stunnel 5.56 on x86_64-pc-linux-gnu platform
Jun  1 11:36:00 nextcloud stunnel: LOG5[ui]: Compiled with OpenSSL 1.1.1k  25 Mar 2021
Jun  1 11:36:00 nextcloud stunnel: LOG5[ui]: Running  with OpenSSL 1.1.1n  15 Mar 2022
Jun  1 11:36:00 nextcloud stunnel: LOG5[ui]: Threading:PTHREAD Sockets:POLL,IPv6,SYSTEMD TLS:ENGINE,FIPS,OCSP,PSK,SNI Auth:LIBWRAP
Jun  1 11:36:00 nextcloud stunnel: LOG5[ui]: Reading configuration from file /etc/stunnel/webmin.conf
Jun  1 11:36:00 nextcloud stunnel: LOG5[ui]: UTF-8 byte order mark not detected
Jun  1 11:36:00 nextcloud stunnel: LOG5[ui]: FIPS mode disabled
Jun  1 11:36:00 nextcloud stunnel: LOG5[ui]: Configuration successful
Jun  1 11:36:00 nextcloud stunnel: LOG5[ui]: Switched to chroot directory: /var/lib/stunnel4/
Jun  1 11:36:00 nextcloud systemd[1]: stunnel4@webmin.service: Can't open PID file /var/lib/stunnel4/webmin.pid (yet?) after start: Operation not permitted
Jun  1 11:36:00 nextcloud stunnel: LOG5[ui]: Reading configuration from file /etc/stunnel/shellinabox.conf
Jun  1 11:36:00 nextcloud systemd[1]: Started Universal SSL tunnel for network daemons (webmin).
Jun  1 11:36:00 nextcloud systemd[1]: Started Advanced key-value store.
Jun  1 11:36:00 nextcloud systemd[1]: Started Universal SSL tunnel for network daemons (shellinabox).
Jun  1 11:36:00 nextcloud systemd[1]: Started OpenBSD Secure Shell server.
Jun  1 11:36:00 nextcloud inithooks: successfully completed /usr/lib/inithooks/firstboot.d/10regen-sshkeys
Jun  1 11:36:00 nextcloud inithooks: running /usr/lib/inithooks/firstboot.d/15regen-sslcert
Jun  1 11:36:00 nextcloud inithooks[287]: INFO: [15regen-sslcert] Generating SSL/TLS cert & key.
Jun  1 11:36:00 nextcloud systemd[1]: Started The Apache HTTP Server.
Jun  1 11:36:00 nextcloud systemd[1]: Starting Disk Cache Cleaning Daemon for Apache HTTP Server...
Jun  1 11:36:00 nextcloud systemd[1]: Started Disk Cache Cleaning Daemon for Apache HTTP Server.
Jun  1 11:36:00 nextcloud inithooks[290]: INFO [turnkey-make-ssl-cert]: Generating certificate and key files.
Jun  1 11:36:00 nextcloud fail2ban-server[247]: 2023-06-01 11:36:00,357 fail2ban                [247]: ERROR   Failed during configuration: Have not found any log file for nextcloud jail
Jun  1 11:36:00 nextcloud fail2ban-server[247]: 2023-06-01 11:36:00,359 fail2ban                [247]: ERROR   Async configuration of server failed
Jun  1 11:36:00 nextcloud systemd[1]: fail2ban.service: Main process exited, code=exited, status=255/EXCEPTION
Jun  1 11:36:00 nextcloud systemd[1]: fail2ban.service: Failed with result 'exit-code'.
Jun  1 11:36:00 nextcloud inithooks[290]: INFO [turnkey-make-ssl-cert]: Generating Diffie-Hellman parameters file - using predifined parameters as per RFC7919.
Jun  1 11:36:00 nextcloud inithooks[333]: Updating certificates in /etc/ssl/certs...
Jun  1 11:36:00 nextcloud mariadbd[478]: 2023-06-01 11:36:00 0 [Note] /usr/sbin/mariadbd (mysqld 10.5.18-MariaDB-0+deb11u1) starting as process 478 ...
Jun  1 11:36:00 nextcloud mariadbd[478]: 2023-06-01 11:36:00 0 [Warning] The parameter innodb_file_format is deprecated and has no effect. It may be removed in future releases. See https://mariadb.com/kb/en/library/xtradbinnodb-file-format/
Jun  1 11:36:00 nextcloud mariadbd[478]: 2023-06-01 11:36:00 0 [Note] InnoDB: Uses event mutexes
Jun  1 11:36:00 nextcloud mariadbd[478]: 2023-06-01 11:36:00 0 [Note] InnoDB: Compressed tables use zlib 1.2.11
Jun  1 11:36:00 nextcloud mariadbd[478]: 2023-06-01 11:36:00 0 [Note] InnoDB: Number of pools: 1
Jun  1 11:36:00 nextcloud mariadbd[478]: 2023-06-01 11:36:00 0 [Note] InnoDB: Using crc32 + pclmulqdq instructions
Jun  1 11:36:00 nextcloud mariadbd[478]: 2023-06-01 11:36:00 0 [Note] InnoDB: Using Linux native AIO
Jun  1 11:36:00 nextcloud mariadbd[478]: 2023-06-01 11:36:00 0 [Note] InnoDB: Initializing buffer pool, total size = 134217728, chunk size = 134217728
Jun  1 11:36:00 nextcloud mariadbd[478]: 2023-06-01 11:36:00 0 [Note] InnoDB: Completed initialization of buffer pool
Jun  1 11:36:00 nextcloud mariadbd[478]: 2023-06-01 11:36:00 0 [Note] InnoDB: 128 rollback segments are active.
Jun  1 11:36:00 nextcloud mariadbd[478]: 2023-06-01 11:36:00 0 [Note] InnoDB: Creating shared tablespace for temporary tables
Jun  1 11:36:00 nextcloud mariadbd[478]: 2023-06-01 11:36:00 0 [Note] InnoDB: Setting file './ibtmp1' size to 12 MB. Physically writing the file full; Please wait ...
Jun  1 11:36:00 nextcloud mariadbd[478]: 2023-06-01 11:36:00 0 [Note] InnoDB: File './ibtmp1' size is now 12 MB.
Jun  1 11:36:00 nextcloud mariadbd[478]: 2023-06-01 11:36:00 0 [Note] InnoDB: 10.5.18 started; log sequence number 982050; transaction id 2119
Jun  1 11:36:00 nextcloud mariadbd[478]: 2023-06-01 11:36:00 0 [Note] Plugin 'FEEDBACK' is disabled.
Jun  1 11:36:00 nextcloud mariadbd[478]: 2023-06-01 11:36:00 0 [Note] InnoDB: Loading buffer pool(s) from /var/lib/mysql/ib_buffer_pool
Jun  1 11:36:00 nextcloud mariadbd[478]: 2023-06-01 11:36:00 0 [Note] Server socket created on IP: '127.0.0.1'.
Jun  1 11:36:00 nextcloud mariadbd[478]: 2023-06-01 11:36:00 0 [Note] Reading of all Master_info entries succeeded
Jun  1 11:36:00 nextcloud mariadbd[478]: 2023-06-01 11:36:00 0 [Note] Added new Master_info '' to hash table
Jun  1 11:36:00 nextcloud mariadbd[478]: 2023-06-01 11:36:00 0 [Note] /usr/sbin/mariadbd: ready for connections.
Jun  1 11:36:00 nextcloud mariadbd[478]: Version: '10.5.18-MariaDB-0+deb11u1'  socket: '/run/mysqld/mysqld.sock'  port: 3306  Debian 11
Jun  1 11:36:00 nextcloud systemd[1]: Started MariaDB 10.5.18 database server.
Jun  1 11:36:00 nextcloud /etc/mysql/debian-start[858]: Upgrading MySQL tables if necessary.
Jun  1 11:36:00 nextcloud /etc/mysql/debian-start[865]: Looking for 'mariadb' as: /usr/bin/mariadb
Jun  1 11:36:00 nextcloud /etc/mysql/debian-start[865]: Looking for 'mariadb-check' as: /usr/bin/mariadb-check
Jun  1 11:36:00 nextcloud /etc/mysql/debian-start[865]: This installation of MariaDB is already upgraded to 10.5.18-MariaDB.
Jun  1 11:36:00 nextcloud /etc/mysql/debian-start[865]: There is no need to run mysql_upgrade again for 10.5.18-MariaDB.
Jun  1 11:36:00 nextcloud /etc/mysql/debian-start[865]: You can use --force if you still want to run mysql_upgrade
Jun  1 11:36:00 nextcloud /etc/mysql/debian-start[914]: Checking for insecure root accounts.
Jun  1 11:36:00 nextcloud mariadbd[478]: 2023-06-01 11:36:00 0 [Note] InnoDB: Buffer pool(s) load completed at 230601 11:36:00
Jun  1 11:36:00 nextcloud /etc/mysql/debian-start[962]: Triggering myisam-recover for all MyISAM tables and aria-recover for all Aria tables
Jun  1 11:36:00 nextcloud inithooks[333]: 1 added, 0 removed; done.
Jun  1 11:36:00 nextcloud inithooks[333]: Running hooks in /etc/ca-certificates/update.d...
Jun  1 11:36:00 nextcloud inithooks[333]: done.
Jun  1 11:36:00 nextcloud inithooks[287]: INFO: [15regen-sslcert] Restarting relevant services.
Jun  1 11:36:00 nextcloud inithooks[1415]: Failed to print table: Broken pipe
Jun  1 11:36:00 nextcloud inithooks[287]: INFO: [15regen-sslcert] apache2.service found; (re)starting...
Jun  1 11:36:00 nextcloud systemd[1]: Stopping The Apache HTTP Server...
Jun  1 11:36:00 nextcloud systemd[1]: apache2.service: Succeeded.
Jun  1 11:36:00 nextcloud systemd[1]: Stopped The Apache HTTP Server.
Jun  1 11:36:00 nextcloud inithooks[1433]: Failed to print table: Broken pipe
Jun  1 11:36:00 nextcloud inithooks[287]: INFO: [15regen-sslcert] stunnel4@webmin.service found; (re)starting...
Jun  1 11:36:00 nextcloud stunnel: LOG5[main]: Terminated
Jun  1 11:36:00 nextcloud systemd[1]: Stopping Universal SSL tunnel for network daemons (webmin)...
Jun  1 11:36:00 nextcloud stunnel: LOG5[main]: Terminating 1 service thread(s)
Jun  1 11:36:00 nextcloud stunnel: LOG5[main]: Service threads terminated
Jun  1 11:36:00 nextcloud systemd[1]: stunnel4@webmin.service: Succeeded.
Jun  1 11:36:00 nextcloud systemd[1]: Stopped Universal SSL tunnel for network daemons (webmin).
Jun  1 11:36:00 nextcloud inithooks[287]: INFO: [15regen-sslcert] stunnel4@shellinabox.service found; (re)starting...
Jun  1 11:36:00 nextcloud systemd[1]: Stopping Universal SSL tunnel for network daemons (shellinabox)...
Jun  1 11:36:00 nextcloud systemd[1]: stunnel4@shellinabox.service: Succeeded.
Jun  1 11:36:00 nextcloud systemd[1]: Stopped Universal SSL tunnel for network daemons (shellinabox).
Jun  1 11:36:00 nextcloud systemd[1]: stunnel4@shellinabox.service: Can't open PID file /var/lib/stunnel4/shellinabox.pid (yet?) after start: Operation not permitted
Jun  1 11:36:00 nextcloud inithooks[1458]: Updating certificates in /etc/ssl/certs...
Jun  1 11:36:00 nextcloud systemd[1]: Finished Wait for network to be configured by ifupdown.
Jun  1 11:36:00 nextcloud systemd[1]: Reached target Network is Online.
Jun  1 11:36:00 nextcloud systemd[1]: Starting LSB: HubDNS startup and shutdown init script...
Jun  1 11:36:00 nextcloud systemd[1]: Starting Postfix Mail Transport Agent (instance -)...
Jun  1 11:36:00 nextcloud systemd[1]: Starting Shell In A Box Daemon (aka WebShell)...
Jun  1 11:36:00 nextcloud systemd[1]: Starting Webmin server daemon...
Jun  1 11:36:01 nextcloud systemd[1]: Started LSB: HubDNS startup and shutdown init script.
Jun  1 11:36:01 nextcloud systemd[1]: Started Shell In A Box Daemon (aka WebShell).
Jun  1 11:36:01 nextcloud inithooks[1458]: 0 added, 0 removed; done.
Jun  1 11:36:01 nextcloud inithooks[1458]: Running hooks in /etc/ca-certificates/update.d...
Jun  1 11:36:01 nextcloud inithooks[1458]: done.
Jun  1 11:36:01 nextcloud inithooks: successfully completed /usr/lib/inithooks/firstboot.d/15regen-sslcert
Jun  1 11:36:01 nextcloud inithooks: running /usr/lib/inithooks/firstboot.d/20regen-nextcloud-secrets
Jun  1 11:36:01 nextcloud inithooks: successfully completed /usr/lib/inithooks/firstboot.d/20regen-nextcloud-secrets
Jun  1 11:36:01 nextcloud inithooks: running /usr/lib/inithooks/firstboot.d/29preseed
Jun  1 11:36:01 nextcloud inithooks: successfully completed /usr/lib/inithooks/firstboot.d/29preseed
Jun  1 11:36:01 nextcloud inithooks: running /usr/lib/inithooks/firstboot.d/29sudoadmin
Jun  1 11:36:01 nextcloud inithooks[2204]: INFO [turnkey-sudoadmin]: inithooks_sudoadmin false
Jun  1 11:36:01 nextcloud inithooks[2204]: INFO [turnkey-sudoadmin]: setup_initfence root
Jun  1 11:36:01 nextcloud inithooks[2204]: INFO [turnkey-sudoadmin]: update_confconsole_services root admin
Jun  1 11:36:01 nextcloud inithooks[2204]: INFO [turnkey-sudoadmin]: ssh_authorizedkeys_inithook root
Jun  1 11:36:01 nextcloud inithooks[2204]: INFO [turnkey-sudoadmin]: ssh_authorizedkeys_merge root admin
Jun  1 11:36:01 nextcloud inithooks[2204]: INFO [turnkey-sudoadmin]: permitrootlogin_ssh yes
Jun  1 11:36:01 nextcloud inithooks[2204]: INFO [turnkey-sudoadmin]: user_state root unlock
Jun  1 11:36:01 nextcloud inithooks[2222]: passwd: password expiry information changed.
Jun  1 11:36:01 nextcloud inithooks[2204]: INFO [turnkey-sudoadmin]: user_state admin lock
Jun  1 11:36:01 nextcloud inithooks[2204]: INFO [turnkey-sudoadmin]: set_sshrootbanner
Jun  1 11:36:01 nextcloud inithooks[2204]: INFO [turnkey-sudoadmin]: restart_sshd
Jun  1 11:36:01 nextcloud systemd[1]: Stopping OpenBSD Secure Shell server...
Jun  1 11:36:01 nextcloud systemd[1]: ssh.service: Succeeded.
Jun  1 11:36:01 nextcloud systemd[1]: Stopped OpenBSD Secure Shell server.
Jun  1 11:36:01 nextcloud systemd[1]: Starting OpenBSD Secure Shell server...
Jun  1 11:36:01 nextcloud systemd[1]: Started OpenBSD Secure Shell server.
Jun  1 11:36:01 nextcloud inithooks[2235]: Restarting ssh (via systemctl): ssh.service.
Jun  1 11:36:01 nextcloud inithooks: successfully completed /usr/lib/inithooks/firstboot.d/29sudoadmin
Jun  1 11:36:01 nextcloud inithooks: running /usr/lib/inithooks/firstboot.d/29tagid
Jun  1 11:36:01 nextcloud inithooks: successfully completed /usr/lib/inithooks/firstboot.d/29tagid
Jun  1 11:36:01 nextcloud inithooks: running /usr/lib/inithooks/firstboot.d/30turnkey-init-fence
Jun  1 11:36:01 nextcloud inithooks[2282]: turnkey-init-fence.service is not a native service, redirecting to systemd-sysv-install.
Jun  1 11:36:01 nextcloud inithooks[2282]: Executing: /lib/systemd/systemd-sysv-install enable turnkey-init-fence
Jun  1 11:36:01 nextcloud systemd[1]: Reloading.
Jun  1 11:36:01 nextcloud systemd-networkd[68]: eth0: Gained IPv6LL
Jun  1 11:36:02 nextcloud systemd[1]: /lib/systemd/system/inithooks.service:12: Standard output type syslog+console is obsolete, automatically updating to journal+console. Please update your unit file, and consider removing the setting altogether.
Jun  1 11:36:02 nextcloud systemd[1]: /lib/systemd/system/inithooks.service:13: Standard output type syslog+console is obsolete, automatically updating to journal+console. Please update your unit file, and consider removing the setting altogether.
Jun  1 11:36:02 nextcloud systemd[1]: Reloading.
Jun  1 11:36:02 nextcloud systemd[1]: Starting LSB: Fences off appliance ports until after initialization...
Jun  1 11:36:02 nextcloud systemd[1]: Started LSB: Fences off appliance ports until after initialization.
Jun  1 11:36:02 nextcloud inithooks[2276]: turnkey-init-fence is up
Jun  1 11:36:02 nextcloud inithooks: successfully completed /usr/lib/inithooks/firstboot.d/30turnkey-init-fence
Jun  1 11:36:02 nextcloud inithooks: running /usr/lib/inithooks/firstboot.d/35adminer-mysqlpass
Jun  1 11:36:02 nextcloud inithooks: successfully completed /usr/lib/inithooks/firstboot.d/35adminer-mysqlpass
Jun  1 11:36:02 nextcloud inithooks: running /usr/lib/inithooks/firstboot.d/35postfix-unprivileged
Jun  1 11:36:02 nextcloud inithooks[2577]: chattr: Operation not permitted while setting flags on /var/spool/postfix/dev/urandom
Jun  1 11:36:02 nextcloud inithooks[2577]: chattr: Operation not permitted while setting flags on /var/spool/postfix/dev/random
Jun  1 11:36:02 nextcloud systemd[1]: webmin.service: Can't open PID file /var/webmin/miniserv.pid (yet?) after start: Operation not permitted
Jun  1 11:36:02 nextcloud systemd[1]: Started Webmin server daemon.
Jun  1 11:36:03 nextcloud postfix/postfix-script[2959]: starting the Postfix mail system
Jun  1 11:36:03 nextcloud postfix/master[2961]: daemon started -- version 3.5.17, configuration /etc/postfix
Jun  1 11:36:03 nextcloud systemd[1]: Started Postfix Mail Transport Agent (instance -).
Jun  1 11:36:03 nextcloud systemd[1]: Starting Postfix Mail Transport Agent...
Jun  1 11:36:03 nextcloud systemd[1]: Finished Postfix Mail Transport Agent.
Jun  1 11:36:03 nextcloud inithooks: successfully completed /usr/lib/inithooks/firstboot.d/35postfix-unprivileged
Jun  1 11:36:03 nextcloud inithooks: running /usr/lib/inithooks/firstboot.d/40nextcloud
Jun  1 11:36:03 nextcloud inithooks: successfully completed /usr/lib/inithooks/firstboot.d/40nextcloud
Jun  1 11:36:03 nextcloud inithooks: running /usr/lib/inithooks/firstboot.d/80hub-services
Jun  1 11:36:03 nextcloud inithooks: successfully completed /usr/lib/inithooks/firstboot.d/80hub-services
Jun  1 11:36:03 nextcloud inithooks: running /usr/lib/inithooks/firstboot.d/85secalerts
Jun  1 11:36:03 nextcloud inithooks: successfully completed /usr/lib/inithooks/firstboot.d/85secalerts
Jun  1 11:36:03 nextcloud inithooks: running /usr/lib/inithooks/firstboot.d/92etckeeper
Jun  1 11:36:03 nextcloud inithooks[3205]: Auto packing the repository in background for optimum performance.
Jun  1 11:36:03 nextcloud inithooks[3205]: See "git help gc" for manual housekeeping.
Jun  1 11:36:03 nextcloud inithooks: successfully completed /usr/lib/inithooks/firstboot.d/92etckeeper
Jun  1 11:36:03 nextcloud inithooks: running /usr/lib/inithooks/firstboot.d/95secupdates
Jun  1 11:36:03 nextcloud inithooks: successfully completed /usr/lib/inithooks/firstboot.d/95secupdates
Jun  1 11:36:03 nextcloud inithooks: running /usr/lib/inithooks/firstboot.d/97turnkey-init-fence-disable
Jun  1 11:36:03 nextcloud inithooks: successfully completed /usr/lib/inithooks/firstboot.d/97turnkey-init-fence-disable
Jun  1 11:36:03 nextcloud inithooks: running /usr/lib/inithooks/firstboot.d/98finalize
Jun  1 11:36:03 nextcloud inithooks: successfully completed /usr/lib/inithooks/firstboot.d/98finalize
Jun  1 11:36:03 nextcloud inithooks: Inithook run completed, exiting.
Jun  1 11:36:03 nextcloud systemd[1]: inithooks-lxc.service: Succeeded.
Jun  1 11:36:03 nextcloud systemd[1]: Finished inithooks-lxc: firstboot and everyboot initialization scripts (lxc).
Jun  1 11:36:03 nextcloud systemd[1]: inithooks-lxc.service: Consumed 1.285s CPU time.
Jun  1 11:36:03 nextcloud systemd[1]: Started Container Getty on /dev/tty1.
Jun  1 11:36:03 nextcloud systemd[1]: Reached target Login Prompts.
Jun  1 11:36:03 nextcloud systemd[1]: Reached target Multi-User System.
Jun  1 11:36:03 nextcloud systemd[1]: Reached target Graphical Interface.
Jun  1 11:36:03 nextcloud systemd[1]: Starting Update UTMP about System Runlevel Changes...
Jun  1 11:36:03 nextcloud systemd[1]: systemd-update-utmp-runlevel.service: Succeeded.
Jun  1 11:36:03 nextcloud systemd[1]: Finished Update UTMP about System Runlevel Changes.
Jun  1 11:36:03 nextcloud systemd[1]: Startup finished in 3.790s.
Jun  1 11:37:01 nextcloud cron[93]: (*system*) RELOAD (/etc/crontab)
Jun  1 11:37:01 nextcloud cron[93]: (*system*cron-apt) RELOAD (/etc/cron.d/cron-apt)
Jun  1 11:37:01 nextcloud CRON[3327]: (root) CMD (   cd / && run-parts --report /etc/cron.hourly)
Jun  1 11:39:01 nextcloud CRON[3356]: (root) CMD (  [ -x /usr/lib/php/sessionclean ] && if [ ! -d /run/systemd/system ]; then /usr/lib/php/sessionclean; fi)
Jun  1 11:39:01 nextcloud systemd[1]: Starting Clean php session files...
Jun  1 11:39:01 nextcloud systemd[1]: phpsessionclean.service: Succeeded.
Jun  1 11:39:01 nextcloud systemd[1]: Finished Clean php session files.
Jun  1 11:39:31 nextcloud postfix/pickup[2962]: 40BF410005B: uid=0 from=<root>
Jun  1 11:39:31 nextcloud postfix/cleanup[3439]: 40BF410005B: message-id=<20230601113931.40BF410005B@nextcloud>
Jun  1 11:39:31 nextcloud postfix/qmgr[2963]: 40BF410005B: from=<root@nextcloud>, size=610, nrcpt=1 (queue active)
Jun  1 11:39:31 nextcloud postfix/cleanup[3439]: 428F910005C: message-id=<20230601113931.40BF410005B@nextcloud>
Jun  1 11:39:31 nextcloud postfix/qmgr[2963]: 428F910005C: from=<root@nextcloud>, size=730, nrcpt=1 (queue active)
Jun  1 11:39:31 nextcloud postfix/local[3449]: 40BF410005B: to=<root@nextcloud>, orig_to=<root>, relay=local, delay=0.01, delays=0.01/0/0/0, dsn=2.0.0, status=sent (forwarded as 428F910005C)
Jun  1 11:39:31 nextcloud postfix/qmgr[2963]: 40BF410005B: removed
Jun  1 11:39:41 nextcloud systemd[1]: Reloading.
Jun  1 11:39:41 nextcloud systemd[1]: /lib/systemd/system/inithooks.service:12: Standard output type syslog+console is obsolete, automatically updating to journal+console. Please update your unit file, and consider removing the setting altogether.
Jun  1 11:39:41 nextcloud systemd[1]: /lib/systemd/system/inithooks.service:13: Standard output type syslog+console is obsolete, automatically updating to journal+console. Please update your unit file, and consider removing the setting altogether.
Jun  1 11:39:42 nextcloud systemd[1]: Reloading.
Jun  1 11:39:42 nextcloud systemd[1]: /lib/systemd/system/inithooks.service:12: Standard output type syslog+console is obsolete, automatically updating to journal+console. Please update your unit file, and consider removing the setting altogether.
Jun  1 11:39:42 nextcloud systemd[1]: /lib/systemd/system/inithooks.service:13: Standard output type syslog+console is obsolete, automatically updating to journal+console. Please update your unit file, and consider removing the setting altogether.
Jun  1 11:39:42 nextcloud systemd[1]: Stopping LSB: Fences off appliance ports until after initialization...
Jun  1 11:39:42 nextcloud systemd[1]: turnkey-init-fence.service: Succeeded.
Jun  1 11:39:42 nextcloud systemd[1]: Stopped LSB: Fences off appliance ports until after initialization.
Jun  1 11:40:01 nextcloud postfix/smtp[3450]: connect to gmail-smtp-in.l.google.com[172.253.122.27]:25: Connection timed out
Jun  1 11:40:31 nextcloud postfix/smtp[3450]: connect to gmail-smtp-in.l.google.com[2607:f8b0:4004:c09::1b]:25: Connection timed out
Jun  1 11:41:01 nextcloud postfix/smtp[3450]: connect to alt1.gmail-smtp-in.l.google.com[209.85.202.26]:25: Connection timed out
Jun  1 11:41:31 nextcloud postfix/smtp[3450]: connect to alt1.gmail-smtp-in.l.google.com[2a00:1450:400b:c00::1a]:25: Connection timed out
Jun  1 11:42:01 nextcloud postfix/smtp[3450]: connect to alt2.gmail-smtp-in.l.google.com[64.233.184.26]:25: Connection timed out
Jun  1 11:42:01 nextcloud postfix/smtp[3450]: 428F910005C: to=<khw1502@gmail.com>, orig_to=<root>, relay=none, delay=150, delays=0/0.01/150/0, dsn=4.4.1, status=deferred (connect to alt2.gmail-smtp-in.l.google.com[64.233.184.26]:25: Connection timed out)
Jun  1 11:45:01 nextcloud CRON[5296]: (www-data) CMD (^I/usr/bin/php -f /var/www/nextcloud/occ /dev/null 2>&1)
Jun  1 11:45:01 nextcloud postfix/pickup[2962]: 3A6E41000A0: uid=33 from=<www-data>
Jun  1 11:45:01 nextcloud postfix/cleanup[5311]: 3A6E41000A0: message-id=<20230601114501.3A6E41000A0@nextcloud>
Jun  1 11:45:01 nextcloud postfix/qmgr[2963]: 3A6E41000A0: from=<www-data@nextcloud>, size=703, nrcpt=1 (queue active)
Jun  1 11:45:01 nextcloud postfix/local[5313]: 3A6E41000A0: to=<www-data@nextcloud>, orig_to=<www-data>, relay=local, delay=0.01, delays=0.01/0/0/0, dsn=2.0.0, status=sent (delivered to mailbox)
Jun  1 11:45:01 nextcloud postfix/qmgr[2963]: 3A6E41000A0: removed
Jun  1 11:49:28 nextcloud postfix/smtpd[5349]: connect from localhost[127.0.0.1]
Jun  1 11:49:28 nextcloud postfix/smtpd[5349]: lost connection after STARTTLS from localhost[127.0.0.1]
Jun  1 11:49:28 nextcloud postfix/smtpd[5349]: disconnect from localhost[127.0.0.1] ehlo=1 starttls=1 commands=2
Jun  1 11:51:02 nextcloud systemd[1]: Starting Autocommit of changes in /etc directory...
Jun  1 11:51:02 nextcloud systemd[1]: Starting Cleanup of Temporary Directories...
Jun  1 11:51:02 nextcloud systemd[1]: systemd-tmpfiles-clean.service: Succeeded.
Jun  1 11:51:02 nextcloud systemd[1]: Finished Cleanup of Temporary Directories.
Jun  1 11:51:03 nextcloud systemd[1]: etckeeper.service: Succeeded.
Jun  1 11:51:03 nextcloud systemd[1]: Finished Autocommit of changes in /etc directory.
Jun  1 11:51:03 nextcloud postfix/qmgr[2963]: 428F910005C: from=<root@nextcloud>, size=730, nrcpt=1 (queue active)
Jun  1 11:51:33 nextcloud postfix/smtp[5469]: connect to gmail-smtp-in.l.google.com[2607:f8b0:4004:c06::1b]:25: Connection timed out
Jun  1 11:52:03 nextcloud postfix/smtp[5469]: connect to gmail-smtp-in.l.google.com[172.253.115.26]:25: Connection timed out
Jun  1 11:52:33 nextcloud postfix/smtp[5469]: connect to alt1.gmail-smtp-in.l.google.com[209.85.202.26]:25: Connection timed out
Jun  1 11:53:03 nextcloud postfix/smtp[5469]: connect to alt1.gmail-smtp-in.l.google.com[2a00:1450:400b:c00::1b]:25: Connection timed out
Jun  1 11:53:33 nextcloud postfix/smtp[5469]: connect to alt2.gmail-smtp-in.l.google.com[2a00:1450:400c:c0b::1a]:25: Connection timed out
Jun  1 11:53:33 nextcloud postfix/smtp[5469]: 428F910005C: to=<khw1502@gmail.com>, orig_to=<root>, relay=none, delay=842, delays=692/0.01/150/0, dsn=4.4.1, status=deferred (connect to alt2.gmail-smtp-in.l.google.com[2a00:1450:400c:c0b::1a]:25: Connection timed out)
Jun  1 11:57:14 nextcloud systemd[1]: container-getty@1.service: Succeeded.
Jun  1 11:57:14 nextcloud systemd[1]: container-getty@1.service: Consumed 5.741s CPU time.
Jun  1 11:57:14 nextcloud systemd[1]: container-getty@1.service: Scheduled restart job, restart counter is at 1.
Jun  1 11:57:14 nextcloud systemd[1]: Stopped Container Getty on /dev/tty1.
Jun  1 11:57:14 nextcloud systemd[1]: Started Container Getty on /dev/tty1.
Jun  1 12:00:01 nextcloud CRON[5480]: (www-data) CMD (^I/usr/bin/php -f /var/www/nextcloud/occ /dev/null 2>&1)
Jun  1 12:00:01 nextcloud postfix/pickup[2962]: 6309E10016F: uid=33 from=<www-data>
Jun  1 12:00:01 nextcloud postfix/cleanup[5490]: 6309E10016F: message-id=<20230601120001.6309E10016F@nextcloud>
Jun  1 12:00:01 nextcloud postfix/qmgr[2963]: 6309E10016F: from=<www-data@nextcloud>, size=703, nrcpt=1 (queue active)
Jun  1 12:00:01 nextcloud postfix/local[5492]: 6309E10016F: to=<www-data@nextcloud>, orig_to=<www-data>, relay=local, delay=0.02, delays=0.01/0/0/0, dsn=2.0.0, status=sent (delivered to mailbox)
Jun  1 12:00:01 nextcloud postfix/qmgr[2963]: 6309E10016F: removed
Jun  1 12:09:01 nextcloud CRON[5496]: (root) CMD (  [ -x /usr/lib/php/sessionclean ] && if [ ! -d /run/systemd/system ]; then /usr/lib/php/sessionclean; fi)
Jun  1 12:09:01 nextcloud systemd[1]: Starting Clean php session files...
Jun  1 12:09:01 nextcloud systemd[1]: phpsessionclean.service: Succeeded.
Jun  1 12:09:01 nextcloud systemd[1]: Finished Clean php session files.
Jun  1 12:11:03 nextcloud postfix/qmgr[2963]: 428F910005C: from=<root@nextcloud>, size=730, nrcpt=1 (queue active)
Jun  1 12:11:34 nextcloud postfix/smtp[5551]: connect to gmail-smtp-in.l.google.com[2607:f8b0:4004:c09::1a]:25: Connection timed out
Jun  1 12:12:04 nextcloud postfix/smtp[5551]: connect to gmail-smtp-in.l.google.com[172.253.122.27]:25: Connection timed out
Jun  1 12:12:34 nextcloud postfix/smtp[5551]: connect to alt1.gmail-smtp-in.l.google.com[209.85.202.27]:25: Connection timed out
Jun  1 12:13:04 nextcloud postfix/smtp[5551]: connect to alt1.gmail-smtp-in.l.google.com[2a00:1450:400b:c00::1a]:25: Connection timed out
Jun  1 12:13:34 nextcloud postfix/smtp[5551]: connect to alt2.gmail-smtp-in.l.google.com[2a00:1450:400c:c0b::1b]:25: Connection timed out
Jun  1 12:13:34 nextcloud postfix/smtp[5551]: 428F910005C: to=<khw1502@gmail.com>, orig_to=<root>, relay=none, delay=2043, delays=1892/0.01/150/0, dsn=4.4.1, status=deferred (connect to alt2.gmail-smtp-in.l.google.com[2a00:1450:400c:c0b::1b]:25: Connection timed out)
Jun  1 12:15:01 nextcloud CRON[5555]: (www-data) CMD (^I/usr/bin/php -f /var/www/nextcloud/occ /dev/null 2>&1)
Jun  1 12:15:01 nextcloud postfix/pickup[2962]: 8BC1610016F: uid=33 from=<www-data>
Jun  1 12:15:01 nextcloud postfix/cleanup[5566]: 8BC1610016F: message-id=<20230601121501.8BC1610016F@nextcloud>
Jun  1 12:15:01 nextcloud postfix/qmgr[2963]: 8BC1610016F: from=<www-data@nextcloud>, size=703, nrcpt=1 (queue active)
Jun  1 12:15:01 nextcloud postfix/local[5568]: 8BC1610016F: to=<www-data@nextcloud>, orig_to=<www-data>, relay=local, delay=0.01, delays=0.01/0/0/0, dsn=2.0.0, status=sent (delivered to mailbox)
Jun  1 12:15:01 nextcloud postfix/qmgr[2963]: 8BC1610016F: removed
Jun  1 12:30:01 nextcloud CRON[5572]: (www-data) CMD (^I/usr/bin/php -f /var/www/nextcloud/occ /dev/null 2>&1)
Jun  1 12:30:01 nextcloud postfix/pickup[2962]: B44B110016F: uid=33 from=<www-data>
Jun  1 12:30:01 nextcloud postfix/cleanup[5583]: B44B110016F: message-id=<20230601123001.B44B110016F@nextcloud>
Jun  1 12:30:01 nextcloud postfix/qmgr[2963]: B44B110016F: from=<www-data@nextcloud>, size=703, nrcpt=1 (queue active)
Jun  1 12:30:01 nextcloud postfix/local[5585]: B44B110016F: to=<www-data@nextcloud>, orig_to=<www-data>, relay=local, delay=0.02, delays=0.01/0/0/0, dsn=2.0.0, status=sent (delivered to mailbox)
Jun  1 12:30:01 nextcloud postfix/qmgr[2963]: B44B110016F: removed
Jun  1 12:37:01 nextcloud CRON[5602]: (root) CMD (   cd / && run-parts --report /etc/cron.hourly)
Jun  1 12:39:01 nextcloud CRON[5605]: (root) CMD (  [ -x /usr/lib/php/sessionclean ] && if [ ! -d /run/systemd/system ]; then /usr/lib/php/sessionclean; fi)
Jun  1 12:39:01 nextcloud systemd[1]: Starting Clean php session files...
Jun  1 12:39:01 nextcloud systemd[1]: phpsessionclean.service: Succeeded.
Jun  1 12:39:01 nextcloud systemd[1]: Finished Clean php session files.
Jun  1 12:45:01 nextcloud CRON[5661]: (www-data) CMD (^I/usr/bin/php -f /var/www/nextcloud/occ /dev/null 2>&1)
Jun  1 12:45:01 nextcloud postfix/pickup[2962]: DE8261000C7: uid=33 from=<www-data>
Jun  1 12:45:01 nextcloud postfix/cleanup[5672]: DE8261000C7: message-id=<20230601124501.DE8261000C7@nextcloud>
Jun  1 12:45:01 nextcloud postfix/qmgr[2963]: DE8261000C7: from=<www-data@nextcloud>, size=703, nrcpt=1 (queue active)
Jun  1 12:45:01 nextcloud postfix/local[5674]: DE8261000C7: to=<www-data@nextcloud>, orig_to=<www-data>, relay=local, delay=0.01, delays=0.01/0/0/0, dsn=2.0.0, status=sent (delivered to mailbox)
Jun  1 12:45:01 nextcloud postfix/qmgr[2963]: DE8261000C7: removed
Jun  1 12:51:03 nextcloud postfix/qmgr[2963]: 428F910005C: from=<root@nextcloud>, size=730, nrcpt=1 (queue active)
Jun  1 12:51:33 nextcloud postfix/smtp[5678]: connect to gmail-smtp-in.l.google.com[172.253.122.26]:25: Connection timed out
Jun  1 12:52:03 nextcloud postfix/smtp[5678]: connect to gmail-smtp-in.l.google.com[2607:f8b0:4004:c1b::1a]:25: Connection timed out
Jun  1 12:52:33 nextcloud postfix/smtp[5678]: connect to alt1.gmail-smtp-in.l.google.com[209.85.202.27]:25: Connection timed out
Jun  1 12:53:03 nextcloud postfix/smtp[5678]: connect to alt1.gmail-smtp-in.l.google.com[2a00:1450:400b:c00::1a]:25: Connection timed out
Jun  1 12:53:33 nextcloud postfix/smtp[5678]: connect to alt2.gmail-smtp-in.l.google.com[64.233.184.26]:25: Connection timed out
Jun  1 12:53:33 nextcloud postfix/smtp[5678]: 428F910005C: to=<khw1502@gmail.com>, orig_to=<root>, relay=none, delay=4443, delays=4292/0.01/151/0, dsn=4.4.1, status=deferred (connect to alt2.gmail-smtp-in.l.google.com[64.233.184.26]:25: Connection timed out)
Jun  1 13:00:01 nextcloud CRON[5682]: (www-data) CMD (^I/usr/bin/php -f /var/www/nextcloud/occ /dev/null 2>&1)
Jun  1 13:00:02 nextcloud postfix/pickup[2962]: 12A9510016D: uid=33 from=<www-data>
Jun  1 13:00:02 nextcloud postfix/cleanup[5693]: 12A9510016D: message-id=<20230601130002.12A9510016D@nextcloud>
Jun  1 13:00:02 nextcloud postfix/qmgr[2963]: 12A9510016D: from=<www-data@nextcloud>, size=703, nrcpt=1 (queue active)
Jun  1 13:00:02 nextcloud postfix/local[5695]: 12A9510016D: to=<www-data@nextcloud>, orig_to=<www-data>, relay=local, delay=0.02, delays=0.01/0/0/0, dsn=2.0.0, status=sent (delivered to mailbox)
Jun  1 13:00:02 nextcloud postfix/qmgr[2963]: 12A9510016D: removed
Jun  1 13:09:01 nextcloud CRON[5699]: (root) CMD (  [ -x /usr/lib/php/sessionclean ] && if [ ! -d /run/systemd/system ]; then /usr/lib/php/sessionclean; fi)
Jun  1 13:09:01 nextcloud systemd[1]: Starting Clean php session files...
Jun  1 13:09:01 nextcloud systemd[1]: phpsessionclean.service: Succeeded.
Jun  1 13:09:01 nextcloud systemd[1]: Finished Clean php session files.
J
PASTE HERE
You appear to have a period Nextcloud cron job configured:
But I’d expect to be something more like:
/usr/bin/php /var/www/nextcloud/cron.php
That command you have looks incorrect.
It’s safe to try running it manually to make sure it works (as thewww-data user).
https://docs.nextcloud.com/server/latest/admin_manual/configuration_server/background_jobs_configuration.html?highlight=cron
Thank you for you help. I ran the command suggested and the error went away and news app was updating. I also ran ‘crontab -u www-data -l’ which returned no crontab file for user found. I then added ‘*/5 * * * * php -f /var/www/nextcloud/cron.php’ as www-data. I will monitor and if everything seems ok after a few days will make the problem solved.
If anyone sees a problem with what I have done please let me know as this is the first time I have used nextcloud.
