example
longer
example
here
Nextcloud version (eg, 20.0.5): 25.0.2
Operating system and version (eg, Ubuntu 20.04): Unbuntu
Apache or nginx version (eg, Apache 2.4.25): Apache
PHP version (eg, 7.4): 8.0.26
Hi everyone,
After putting NC to maintenance mode off (true) and swichting back on (false), NC wants to run the web-based upgrader (or ./occ upgrade);
Running the web-based upgrade returns this error message.
Ist there a way to disable the upgrade? What is the issue? As far as I am aware, I have the current version.
Thanks.
Error Message:
Nextcloud or one of the apps require upgrade
Exception: Updates between multiple major versions and downgrades are unsupported.
Detaillierte Protokollmeldungen
Update vorbereiten
Log-Level auf "debug" gesetzt
Wartungsmodus eingeschaltet
Das Update war nicht erfolgreich. Für mehr Informationen lesen Sie unseren Forenbeitrag zu diesem Thema.
I am running NC on shared hoster (all-inkl), and only access to ssh!
Running occ maintenance:repair return the same message to upgrade.
- Call cloud.peralta.eu
- Start “Aktualisierung starten”
PASTE HERE
'instanceid' => 'ocwcefa9kssa',
'passwordsalt' => 'tiShb9bf/+bcTpfXAVGUXc+qICFGgy',
'secret' => 'O4J/0/OIqWLrrXvWrLO/3rt9Si6XkJtxPY4Tog/nNup/8Fls',
0 => 'cloud.peralta.eu',
'datadirectory' => '/www/htdocs/w00d52d0/two.peralta.eu/data',
'version' => '21.0.1.1',
'overwrite.cli.url' => 'http://cloud.peralta.eu',
'dbname' => 'xxx',
'dbhost' => 'localhost',
'dbuser' => 'xxx',
'dbpassword' => 'xxx',
'mail_smtpmode' => 'sendmail',
'mail_from_address' => 'ichausdercloud',
'mail_domain' => 'peralta.eu',
'updater.secret' => '$2y$10$llTH17Vv9AGZuEVD34VDHe0kigsSq7GFDCaPDu5kiU441JoEqPbay',
'app_install_overwrite' =>
0 => 'whiteboard',
'default_language' => 'de',
'default_phone_region' => 'de',
'theme' => '',
'loglevel' => 2,
'tempdirectory' => '/www/htdocs/w00d52d0/two.peralta.eu/data/tmp',
PASTE HERE > no access
PASTE HERE
PASTE HERE (sorry, can only copy from raw file)
{“reqId”:“Y6qm7PQ4WvWlEKrpLg7AjwAAAB0”,“level”:3,“time”:“2022-12-27T08:03:56+00:00”,“remoteAddr”:“88.130.147.168”,“user”:“–”,“app”:“no app in context”,“method”:“GET”,“url”:“/core/ajax/update.php?requesttoken=DVM%2BKuWjTqkCJaRCoCb96RvTKyiU21Jvh0nnLM2QKak%3D%3APRJtGInEPNhvfNEU8gmK3imlbUnYv2EJ0iKWeqjKHZA%3D”,“message”:“Updates between multiple major versions and downgrades are unsupported.”,“userAgent”:“Mozilla/5.0 (Macintosh; Intel Mac OS X 10_13_6) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/108.0.0.0 Safari/537.36”,“version”:“21.0.1.1”,“exception”:{“Exception”:“Exception”,“Message”:“Updates between multiple major versions and downgrades are unsupported.”,“Code”:0,“Trace”:[{“file”:“/www/htdocs/w00d52d0/two.peralta.eu/lib/private/Updater.php”,“line”:144,“function”:“doUpgrade”,“class”:“OC\Updater”,“type”:“->”,“args”:[“25.0.2.3”,“21.0.1.1”]},{“file”:“/www/htdocs/w00d52d0/two.peralta.eu/core/ajax/update.php”,“line”:185,“function”:“upgrade”,“class”:“OC\Updater”,“type”:“->”,“args”:}],“File”:“/www/htdocs/w00d52d0/two.peralta.eu/lib/private/Updater.php”,“Line”:245,“message”:“Updates between multiple major versions and downgrades are unsupported.”,“exception”:{},“CustomMessage”:“Updates between multiple major versions and downgrades are unsupported.”}}
{“reqId”:“Y6qm7PQ4WvWlEKrpLg7AjwAAAB0”,“level”:3,“time”:“2022-12-27T08:03:56+00:00”,“remoteAddr”:“88.130.147.168”,“user”:“–”,“app”:“updater”,“method”:“GET”,“url”:“/core/ajax/update.php?requesttoken=DVM%2BKuWjTqkCJaRCoCb96RvTKyiU21Jvh0nnLM2QKak%3D%3APRJtGInEPNhvfNEU8gmK3imlbUnYv2EJ0iKWeqjKHZA%3D”,“message”:“\OC\Updater::failure: Exception: Updates between multiple major versions and downgrades are unsupported.”,“userAgent”:“Mozilla/5.0 (Macintosh; Intel Mac OS X 10_13_6) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/108.0.0.0 Safari/537.36”,“version”:“21.0.1.1”,“data”:{“app”:“updater”}}
{“reqId”:“Y6qm7PQ4WvWlEKrpLg7AjwAAAB0”,“level”:3,“time”:“2022-12-27T08:03:56+00:00”,“remoteAddr”:“88.130.147.168”,“user”:“–”,“app”:“updater”,“method”:“GET”,“url”:“/core/ajax/update.php?requesttoken=DVM%2BKuWjTqkCJaRCoCb96RvTKyiU21Jvh0nnLM2QKak%3D%3APRJtGInEPNhvfNEU8gmK3imlbUnYv2EJ0iKWeqjKHZA%3D”,“message”:“\OC\Updater::updateEnd: Update failed”,“userAgent”:“Mozilla/5.0 (Macintosh; Intel Mac OS X 10_13_6) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/108.0.0.0 Safari/537.36”,“version”:“21.0.1.1”,“data”:{“app”:“updater”}}
{“reqId”:“Y6qm7PQ4WvWlEKrpLg7AjwAAAB0”,“level”:1,“time”:“2022-12-27T08:03:56+00:00”,“remoteAddr”:“88.130.147.168”,“user”:“–”,“app”:“updater”,“method”:“GET”,“url”:“/core/ajax/update.php?requesttoken=DVM%2BKuWjTqkCJaRCoCb96RvTKyiU21Jvh0nnLM2QKak%3D%3APRJtGInEPNhvfNEU8gmK3imlbUnYv2EJ0iKWeqjKHZA%3D”,“message”:“\OC\Updater::maintenanceActive: Maintenance mode is kept active”,“userAgent”:“Mozilla/5.0 (Macintosh; Intel Mac OS X 10_13_6) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/108.0.0.0 Safari/537.36”,“version”:“21.0.1.1”,“data”:{“app”:“updater”}}
{“reqId”:“Y6qm7PQ4WvWlEKrpLg7AjwAAAB0”,“level”:1,“time”:“2022-12-27T08:03:56+00:00”,“remoteAddr”:“88.130.147.168”,“user”:“–”,“app”:“updater”,“method”:“GET”,“url”:“/core/ajax/update.php?requesttoken=DVM%2BKuWjTqkCJaRCoCb96RvTKyiU21Jvh0nnLM2QKak%3D%3APRJtGInEPNhvfNEU8gmK3imlbUnYv2EJ0iKWeqjKHZA%3D”,“message”:“\OC\Updater::resetLogLevel: Reset log level to Warning(2)”,“userAgent”:“Mozilla/5.0 (Macintosh; Intel Mac OS X 10_13_6) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/108.0.0.0 Safari/537.36”,“version”:“21.0.1.1”,“data”:{“app”:“updater”}}
