just spun up nc23 the other day via docker containers. It’s running fine
I only have one issue. It has collabra core and collabra app included. Both are enabled and I’ve selected the core in the settings. NC seems to know the file types (e.g. .odt) as when you make a new file that is a choice.
But if you then open the file (in the browser ui, single click) instead of opening collabra libreoffice with that file it just wants to download it like it would any unknown file type.
Note: Markdown works. if you click on .md file it opens in the markdown editor.
Not sure what setting/setup I’m missing here but it’s not working “out of the box”.
